Home » Modeling » Ecore Tools » Diff 2 EObjects of the same ecore model(Diff 2 EObjects of the same ecore model)
Diff 2 EObjects of the same ecore model [message #1053769] Tue, 07 May 2013 10:23
Andrew Whelan is currently offline Andrew Whelan
Member
I am looking to compare 2 EObjects. These 2 EObjects are from the same data model. All I am looking for is something (relatively simple) that will return some kind of structure, like the following.
DiffStructure diffObject = EMFDiff.(eObject1, eObject2);
I would then be able to recurse the diffObject to find what has changed from the 1st object (object1) to the second (object2).
Does something close to this exist? EMFCompare seems to compare differences in models? I am looking to compare two EObjects from the same model.
Any information on this will be appreciated.
-Andy
Previous Topic:[TEXO] move from normal EMF to TEXO
Next Topic:[TEXO] texo skips to generate EOperations from ecore
Current Time: Tue May 28 10:53:41 EDT 2013
Powered by FUDForum. Page generated in 0.01554 seconds
