| Problem with emf2java ant script [message #1053721] |
Tue, 07 May 2013 07:39  |
Victor Roy Messages: 1 Registered: May 2013 |
Junior Member |
I am having trouble understanding the parameters that go into the emf2java ant task, so I am appealing here for help.
My (simple) ant script is the following:
<project name="myexample" basedir="/Users/vroy/Documents/workspace/myexample">
<property name="model.dir" value="model"/>
<target name="generateSources">
<emf.Ecore2Java model="${model.dir}/example.ecore"
genModel="${model.dir}/example.genmodel"
generateModelProject = "true"
generateEditProject = "true"
generateEditorProject = "true"
modelProject="${basedir}"
modelProjectFragmentPath ="src">
<arg line="-package http://example.eclipse.org/1.0 com.demo.emf.example.model example" />
<arg line="-modelProject //Users//vroy//Documents//workspace//com.demo.emf.example.model src"/>
<arg line="-editProject //Users//vroy//Documents//com.demo.emf.example.model.edit src"/>
<arg line="-editorProject //Users//vroy//Documents//com.demo.emf.example.model.editor src"/>
</emf.Ecore2Java>
</target>
</project>
The questions I have are the following:
a. I want to define the location of the edit and editor projects, relative to the model project but this is impossible. If I don't define an absolute path in the
then the projects are created inside the eclipse installation folders (on my mac, this means that are created inside /Applications/eclipse/Eclipse.app/Contents/MacOS ) no matter what. So, how can I define a relative location?
b. With the above script, if I try to place the newly created projects in my workspace, even with an absolute path I can't. They end up in the eclipse's installation folder. Why is this happening? Is there any way to fix it?
c. The above script sometimes fails, and I get the following error:
[emf.Ecore2Java] org.eclipse.core.internal.resources.ResourceException: Errors occurred while refreshing resources with the local file system.
[emf.Ecore2Java] at java.lang.Thread.run(Thread.java:722)
[emf.Ecore2Java] Contains: The project description file (.project) for 'com.demo.emf.example.model.edit' is missing. This file contains important information about the project. The project will not function properly until this file is restored.
BUILD SUCCESSFUL
Any idea why?
I will appreciate any answers
Thanks in advance
V Roy
| Re: Problem with emf2java ant script [message #1053754 is a reply to message #1053721] |
Tue, 07 May 2013 09:53  |
Ed Merks Messages: 24570 Registered: July 2009 |
Victor,
Comments below.
On 07/05/2013 3:06 PM, Victor Roy wrote:
> Hello,
> </emf.Ecore2Java>
> </target>
> </project>
Unfortunately I really don't know much about how Ant works... But my
sense is that if you have an existing already populated *.genmodel then
it will have have all the project folders already specified and they'll
just work...
I found one script that looks like this, so maybe with some kind of
macro thingy you can specify some things only once...
<project default="codegen" basedir="..">
<dirname property="antfile.dir" file="${ant.file}"/>
<!-- Global properties -->
<property name="main.directory" location="${antfile.dir}/.."/>
<property name="output.directory" location="${main.directory}"/>
<property name="source.directory" value="src"/>
<property name="genJDKLevel" value="5.0"/>
<target name="codegen">
<!-- A macrodef makes it easier to generate code for multiple
models in one script. -->
<macrodef name="ecore2Java">
<attribute name="modelName"/>
<element name="settings"/>
<sequential>
<emf.Ecore2Java
model="${main.directory}/model/@{modelName}.ecore"
genModel="${output.directory}/emf/@{modelName}.genmodel"
modelProject="${output.directory}"
modelProjectFragmentPath="${source.directory}"
modelPluginID="@{modelName}.model"
copyright="This is my code."
jdkLevel="${genJDKLevel}">
<settings/>
</emf.Ecore2Java>
</sequential>
</macrodef>
<!-- Generating the code for the library model -->
<ecore2Java modelName="library">
<settings>
<arg line="-package http:///library.ecore org.examples
Library"/>
</settings>
</ecore2Java>
</target>
</project>
> <arg line=... then the projects are created inside the eclipse
I think you'd need to use some kind of macro substitution in Ant itself.
> way to fix it?
I don't know about that.
> [emf.Ecore2Java]
> BUILD SUCCESSFUL
> Any idea why?
The generator does not produce .project files. IProjects are only
created when you generate in the IDE the normal way.
> Thanks in advance
> V Roy
FUDForum. Page generated in 0.01572 seconds
