Home » Modeling » M2T (model-to-text transformation) » [Acceleo] How to get a default value of EnumerationLiteral attribute and how to get a target name of
icon5.gif  [Acceleo] How to get a default value of EnumerationLiteral attribute and how to get a target name of [message #1053706] Tue, 07 May 2013 06:39
Félix SILINOU KAMDEM is currently offline Félix SILINOU KAMDEM
Hello there,
I am generating a code using as an input Metamodel (an UML one).
--> I would like to know how to get a default value of an EnumerationLiteral attribute. The problem is that I cannot use Acceleo method named defaultValue. I also tried getValue() but the parameters is not allow me to use it in this case. (See at the code bellow).
[template private processEnumerationlitteral(e : Enumeration) post (trim())]
      [for ( el: EnumerationLiteral | e.eAllContents(EnumerationLiteral))]
            [if (e.getValue(enumaration, e.name))]
<symbol name="[el.name/]" value="[el.getValue(enumaration, e.name)/]"/>
            [else]
<symbol name="[el.name/]"/>
            [/if]
      [/for]
[/template]
--> My second problem concerns the association. I would like to get a target name of an association but everything I have tried won't work. (See at the code bellow).
      [if (c.clientDependency->notEmpty())]
Class [c.name/]
            [for (d : Dependency | c.clientDependency)]
      target --> [d.target/]
      target name --> [d.target.name/]
            [/for]
      [/if]
Thank you for your advice.
[Updated on: Tue, 07 May 2013 06:40]
Report message to a moderator
Previous Topic:MWE and Check language
Next Topic:M2T with Xtext2 and Xtend2
Current Time: Tue May 28 14:52:49 EDT 2013
Powered by FUDForum. Page generated in 0.01643 seconds
