Home » Modeling » UML2 » How to get default value of Enumeration Literal in UML?
icon5.gif  How to get default value of Enumeration Literal in UML? [message #1053536] Mon, 06 May 2013 08:38 Go to next message
Félix SILINOU KAMDEM is currently offline Félix SILINOU KAMDEM
Hello there,
I am currently doing some model transformations.
In my model transformation I generated Enumaration Class and their attributes: here it's an EnumerationLitteral.
The question now is that I want to get the default value of EnumerationLitteral type.
Re: How to get default value of Enumeration Literal in UML? [message #1053591 is a reply to message #1053536] Mon, 06 May 2013 12:03 Go to previous message
Rafael Chaves is currently offline Rafael Chaves
There is no such thing. You can set the default value locally for any attribute or parameter or variable that is typed by the enumeration. If you want a global default value, use convention, for instance, the first value is the default value.
Rafael
http://abstratt.com/blog
Previous Topic:How to identify Exclusive and combined Enumeration in UML2.
Next Topic:Migration from UML2 3.2.0 to 4.0 with Profiles and Stereotypes
Current Time: Tue May 28 17:30:11 EDT 2013
Powered by FUDForum. Page generated in 0.01617 seconds
