Home » Language IDEs » AJDT » IllegalMonitorStateException using locks
IllegalMonitorStateException using locks [message #1052978] Wed, 01 May 2013 13:05 Go to next message
Pedro Miguel Pereira Serrano Martins is currently offline Pedro Miguel Pereira Serrano Martins
Hellow, I have a code that uses multiple threads, and so I need read and write locks for it. Simply put, this is what I have so far:
public interface IReadWriteLock{
    public void lockWrite();
    public void unlockWrite();
    public void lockRead();
    public void unlockRead();
This interface would then be implemented by a class:
public class RWPriorityMonitorLock implements IReadWriteLock{
	private boolean dbWritting, writterWantsIn;
	private int numReaders;
	public RWPriorityMonitorLock() {
		dbWritting = false;
		numReaders = 0;
		writterWantsIn = false;
	public void lockRead() {
		while(dbWritting || writterWantsIn)
			try{
				wait();
			}catch(InterruptedException e){ e.printStackTrace(); }
		numReaders++;
	public void unlockRead() {
		numReaders--;
		if(numReaders == 0)
			notify();
	public void lockWrite() {
		writterWantsIn = true;
		while(numReaders > 0 || dbWritting)
			try{
				wait();
		dbWritting = true;
	public void unlockWrite() {
		dbWritting = false;
		notifyAll();
Now, in order to force synchronization , I use the aspect:
public aspect IReadWriteLockAspect {
	private static Map<IReadWriteLock, Lock> allLocks = new HashMap<>();
	pointcut lockReflectInit(): call(public Object
			java.lang.reflect.Constructor.newInstance(..));
	pointcut hardWaitMutex():
		call(public void IReadWriteLock+.*());
	void around(): hardWaitMutex(){
		IReadWriteLock currentLock = (IReadWriteLock) thisJoinPoint.getTarget();
		Lock mutex = allLocks.get(currentLock);
		mutex.lock();
		try{
			proceed();
		}finally{
			mutex.unlock();
	Object around(): lockReflectInit() {
		IReadWriteLock lockType = (IReadWriteLock)proceed();
		allLocks.put(lockType, new ReentrantLock(true));
		return lockType;
The point is, every time I try to execute something, I get an IllegalMonitorStateException. In this link:
questions/1537116/illegalmonitorstateexception-on-wait-call @ stackovweflow
They say that the thread must own the monitor, but I don't see where that is not happening. Can some one help?
Re: IllegalMonitorStateException using locks [message #1052988 is a reply to message #1052978] Wed, 01 May 2013 13:59 Go to previous messageGo to next message
Andrew Eisenberg is currently offline Andrew Eisenberg
I don't know how your RWPriorityMonitorLock gets instantiated, so I can't tell why it's not working. Regardless, I'd recommend moving to a different aspect isntantiation model here.
http://www.eclipse.org/aspectj/doc/released/progguide/semantics-aspects.html
I'd go either with perThis(IReadWriteLock) in order to avoid the allLocks field in the aspect. But, this would not address your threading problem. Or, I would go with perCFlow(SomeObject.someMethod(..)) to ensure that you always use the same lock on each call to someMethod (this will be implementation specific).
Re: IllegalMonitorStateException using locks [message #1053226 is a reply to message #1052978] Fri, 03 May 2013 04:57 Go to previous messageGo to next message
Hey, thanks, but the first answer is indicated for the Singleton pattern (from what I read) and I wouldn't understand the need for the second. What troubles me is that if I simply remove the advices and copy-paste it's code into the methods everything works fine and I have no idea why =(
Re: IllegalMonitorStateException using locks [message #1053283 is a reply to message #1053226] Fri, 03 May 2013 10:43 Go to previous message
Well, based on the exception you are getting, there is a lock being used outside of the thread that it was created in. Or perhaps, it is getting locked on one thread and unlocked on another.
I'd make sure that each RWPriorityMonitorLock instance only operates in a single thread.
Previous Topic:A simple parametrized class question
Next Topic:AspectJ AOP config with JSP
Current Time: Tue May 28 04:45:44 EDT 2013
Powered by FUDForum. Page generated in 0.02899 seconds
