| User Enum Promt EOL [message #1051779] |
Mon, 29 April 2013 04:06  |
serhat gezgin Messages: 136 Registered: January 2013 Location: Izmir |
Hi all,
I want to create a prompt which want Enum Literal from User.
I have Enum on my metamodel(ecore) like;
ENUM EXT
EMPTY 0
PNG 1
TXT 2
i write this for choose but it throws error
var targetEXT := UserInput.choose('Select target', EXT);
is anyone can help me to solve this problem ?
Eror;
Undefined variable, type or model: 'EXT' (bundleentry://943.fwk144050306/wizards/filesystem.ewl@112:20)
at org.eclipse.epsilon.eol.execute.NameExecutor.execute(NameExecutor.java:84)
at org.eclipse.epsilon.eol.execute.NameExecutor.execute(NameExecutor.java:97)
at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(ExecutorFactory.java:226)
at org.eclipse.epsilon.eol.execute.ParametersExecutor.execute(ParametersExecutor.java:29)
at org.eclipse.epsilon.eol.execute.PointExecutor.executeOperation(PointExecutor.java:131)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointExecutor.java:75)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointExecutor.java:44)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointExecutor.java:90)
at org.eclipse.epsilon.eol.execute.AssignExecutor.execute(AssignExecutor.java:48)
at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(ExecutorFactory.java:196)
at org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execute(StatementBlockExecutor.java:26)
at org.eclipse.epsilon.eol.execute.IfStatementExecutor.execute(IfStatementExecutor.java:43)
at org.eclipse.epsilon.ewl.EwlWizard.process(EwlWizard.java:78)
at org.eclipse.epsilon.ewl.EwlWizardInstance.process(EwlWizardInstance.java:66)
at org.eclipse.epsilon.ewl.emf.ExecuteWizardInstanceCommand.execute(ExecuteWizardInstanceCommand.java:42)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doExecute(WorkspaceCommandStackImpl.java:208)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction.execute(AbstractContributeWizardsAction.java:135)
at org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction$1.widgetSelected(AbstractContributeWizardsAction.java:260)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.jface.action.ActionContributionItem$9.handleEvent(ActionContributionItem.java:1284)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
[Updated on: Mon, 29 April 2013 04:13] Report message to a moderator
FUDForum. Page generated in 0.01578 seconds
