Home » Modeling » Compare » [EMF Compare] Retrieve original value of AttributeChange
[EMF Compare] Retrieve original value of AttributeChange [message #1049734] Fri, 26 April 2013 03:53 Go to next message
Aleksandar Toshovski is currently offline Aleksandar Toshovski
How can I retrieve the old value of AttributeChange? With
 diff.getValue()
I can retrieve the new value of the Attribute, but I don't find a way to retrieve the old one.
Re: [EMF Compare] Retrieve original value of AttributeChange [message #1049931 is a reply to message #1049734] Fri, 26 April 2013 09:17 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent Goubet
Aleksandar,
You need to look the "old" value up yourself. Note that the following is only true for differences of type "CHANGE" (single-valued attribute). For diffs of type "ADD" or "DELETE" (multi-valued attribute), there is no old value.
In two-way :
Object oldAttributeValue = null;
Match match = diff.getMatch();
if (match.getRight() != null) {
  value = match.getRight().eGet(diff.getAttribute());
} else {
  // this item didn't exist previously
In three-way:
if (match.getOrigin() != null) {
  value = match.getOrigin().eGet(diff.getAttribute());
} else {
as you can see, there is no real sense to "old" value : it could have been null, or the object where we detected a change didn't previously exist.
Laurent Goubet
Obeo
Re: [EMF Compare] Retrieve original value of AttributeChange [message #1052961 is a reply to message #1049931] Wed, 01 May 2013 11:22 Go to previous message
Thanks again for your help Laurent.
Previous Topic:MOVE DifferenceKind semantics
Next Topic:[EMFCompare] Diff: Deleted attribute from a class
Current Time: Tue May 28 10:17:38 EDT 2013
Powered by FUDForum. Page generated in 0.01731 seconds
