Home » Modeling » GMF (Graphical Modeling Framework) » Customize Scalable Polygon Figure
Customize Scalable Polygon Figure [message #1052833] Tue, 30 April 2013 12:03
Luca Gherardi is currently offline Luca Gherardi
Member
Hi all,
In my Diagram I've created a Figure associated to a Node.
This figure is a Scalable Polygon:
      <actualFigure
          xsi:type="gmfgraph:ScalablePolygon">
        <backgroundColor
            xsi:type="gmfgraph:ConstantColor"
            value="lightGray"/>
        <maximumSize
            dx="80"
            dy="35"/>
        <minimumSize
            dx="80"
            dy="35"/>
        <preferredSize
            dx="80"
            dy="35"/>
        <insets
            top="15"
            left="5"
            right="5"/>
        <children
            xsi:type="gmfgraph:Label"
            name="ContainmentAssociationTriangleLabel"
            text=""/>
        <template
            x="40"/>
        <template
            y="35"/>
        <template
            x="80"
            y="35"/>
      </actualFigure>
Basically it is a triangle with a label.
The associated node is a child of another node which is represent with a rectangle.
In the diagram the triangle is attached to the south border ot the rectangle.
I achieved it by setting the property "Affixed Parent Size" of the Node to "SOUTH".
Now I would like to customize three aspects:
  1. I would like to make the border of the triangle of a different color based on the content of the label. I'm already able to change the color of the triangle background programmatically but I don't know hot to do the same for setting the color of the border.
  2. I would like to disable the possibility of moving the triangle (or at least disable the possibility of moving it in a position different from the bottom border of the rectangle) and I would like to center its top vertex on the center of the rectangle bottom border. Currently it is automatically created on the bottom side but not in the center.
  3. I would like to disable the possibility of resizing the triangle. It is not necessary and when the user try to do it an exception is generated (see below)
Thanks in advance,
Luca
!ENTRY org.eclipse.ui 4 0 2013-04-30 18:02:42.324
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.ClassCastException: org.eclipse.gmf.runtime.diagram.ui.figures.BorderItemLocator cannot be cast to org.eclipse.draw2d.geometry.Rectangle
	at org.eclipse.gef.editpolicies.XYLayoutEditPolicy.getCurrentConstraintFor(XYLayoutEditPolicy.java:102)
	at org.eclipse.gef.editpolicies.XYLayoutEditPolicy.getConstraintFor(XYLayoutEditPolicy.java:55)
	at org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy.getConstraintFor(ConstrainedLayoutEditPolicy.java:244)
	at org.eclipse.gmf.runtime.diagram.ui.editpolicies.XYLayoutEditPolicy.getConstraintFor(XYLayoutEditPolicy.java:227)
	at org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy.getAddCommand(ConstrainedLayoutEditPolicy.java:184)
	at org.eclipse.gef.editpolicies.LayoutEditPolicy.getCommand(LayoutEditPolicy.java:216)
	at org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy.getCommand(ConstrainedLayoutEditPolicy.java:214)
	at org.eclipse.gmf.runtime.diagram.ui.editpolicies.XYLayoutEditPolicy.getCommand(XYLayoutEditPolicy.java:329)
	at org.eclipse.gef.editparts.AbstractEditPart.getCommand(AbstractEditPart.java:500)
	at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.access$1(GraphicalEditPart.java:1)
	at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart$1.run(GraphicalEditPart.java:482)
	at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
	at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.getCommand(GraphicalEditPart.java:477)
	at org.eclipse.gmf.runtime.diagram.ui.editpolicies.DragDropEditPolicy.getDropCommand(DragDropEditPolicy.java:112)
	at org.eclipse.gmf.runtime.diagram.ui.editpolicies.DiagramDragDropEditPolicy.getDropCommand(DiagramDragDropEditPolicy.java:151)
	at org.eclipse.gmf.runtime.diagram.ui.editpolicies.DragDropEditPolicy.getCommand(DragDropEditPolicy.java:75)
	at org.eclipse.gef.editparts.AbstractEditPart.getCommand(AbstractEditPart.java:502)
	at org.eclipse.gmf.runtime.diagram.ui.tools.DragEditPartsTrackerEx.getCommand(DragEditPartsTrackerEx.java:63)
	at org.eclipse.gef.tools.DragEditPartsTracker.handleDragInProgress(DragEditPartsTracker.java:370)
	at org.eclipse.gmf.runtime.diagram.ui.tools.DragEditPartsTrackerEx.handleDragInProgress(DragEditPartsTrackerEx.java:177)
	at org.eclipse.gef.tools.AbstractTool.mouseDrag(AbstractTool.java:1114)
	at org.eclipse.gef.tools.SelectionTool.mouseDrag(SelectionTool.java:538)
	at org.eclipse.gef.EditDomain.mouseDrag(EditDomain.java:259)
	at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouseMoved(DomainEventDispatcher.java:363)
	at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseMove(LightweightSystem.java:543)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:212)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4136)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1458)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1481)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1271)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3982)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3621)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:601)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Previous Topic:Filemenu popup within GMF
Next Topic:Problem with diagram initialization
Current Time: Tue May 28 13:41:46 EDT 2013
Powered by FUDForum. Page generated in 0.01801 seconds
