Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EmfStore] Null Context in MEEditorInput
[EmfStore] Null Context in MEEditorInput [message #1049796] Fri, 26 April 2013 05:29 Go to next message
Dmitriy Shishkin is currently offline Dmitriy Shishkin
I use Ecp and EmfStore from git-sources and I have java.lang.NullPointerException when try to open my model element.
From source I found:
1. Created MEEditorInput with non null context
2. Invoked WorkbenchSourceProvider.checkActivePart and
Object newEditorInput = currentState.get(ISources.ACTIVE_EDITOR_INPUT_NAME)
returned MEEditorInput with null context
3. When WorkbenchSourceProvider compare inputs it is throws java.lang.NullPointerException
Can any body halp me?
Stack trace:
!ENTRY org.eclipse.ui.workbench 4 2 2013-04-26 13:21:06.379
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
at org.eclipse.emf.ecp.editor.e3.MEEditorInput.equals(MEEditorInput.java:98)
at org.eclipse.ui.internal.util.Util.equals(Util.java:370)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.checkActivePart(WorkbenchSourceProvider.java:363)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.checkActivePart(WorkbenchSourceProvider.java:297)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$2.windowDeactivated(WorkbenchSourceProvider.java:270)
at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:987)
at org.eclipse.ui.internal.Workbench.fireWindowDeactivated(Workbench.java:985)
at org.eclipse.ui.internal.WorkbenchWindow$14.shellDeactivated(WorkbenchWindow.java:1789)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:111)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1676)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2145)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4525)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3129)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3753)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
[Updated on: Fri, 26 April 2013 05:31]
Report message to a moderator
Re: [EmfStore] Null Context in MEEditorInput [message #1051760 is a reply to message #1049796] Mon, 29 April 2013 03:42 Go to previous messageGo to next message
Eugen Neufeld is currently offline Eugen Neufeld
Hi Dimitriy,
thank you very much. I'm happy to help you with this problem.
Could you please look in your stacktrace and post the first two
exceptions that occur. Maybe you have to increase the size of your
stacktrace in order to find the root exception.
Eugen
Am 26.04.2013 11:29, schrieb Dmitriy Shishkin:
> 1. Create MEEditorInput with non null context
> 2. Invoke WorkbenchSourceProvider.checkActivePart and
> currentState.get(ISources.ACTIVE_EDITOR_INPUT_NAME) return MEEditorInput
> with null context
> Stack trace:
> !STACK 0
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
Re: [EmfStore] Null Context in MEEditorInput [message #1052527 is a reply to message #1051760] Tue, 30 April 2013 03:47 Go to previous messageGo to next message
Thanks a lot for your pointing.
I found that it was throwed because it wasn't some properties in property file
When I fix it it helps for me)
Stack trace of first 2 exceptions:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-04-30 11:43:23.261
!MESSAGE
!STACK 0
java.util.MissingResourceException: The string resource '_UI_HasSingleID_type' could not be located
	at org.eclipse.emf.common.util.DelegatingResourceLocator.delegatedGetString(DelegatingResourceLocator.java:480)
	at org.eclipse.emf.common.util.DelegatingResourceLocator.getString(DelegatingResourceLocator.java:385)
	at org.eclipse.emf.edit.provider.ItemProviderAdapter.getString(ItemProviderAdapter.java:2001)
	at org.eclipse.emf.edit.provider.ItemProviderAdapter.getString(ItemProviderAdapter.java:1991)
	at com.tes.als.project.provider.AlsProjectItemProvider.addIdPropertyDescriptor(AlsProjectItemProvider.java:135)
	at com.tes.als.project.provider.AlsProjectItemProvider.getPropertyDescriptors(AlsProjectItemProvider.java:71)
	at org.eclipse.emf.edit.provider.AdapterFactoryItemDelegator.getPropertyDescriptors(AdapterFactoryItemDelegator.java:393)
	at org.eclipse.emf.ecp.internal.editor.FormEditorComposite.sortAndOrderAttributes(FormEditorComposite.java:177)
	at org.eclipse.emf.ecp.internal.editor.FormEditorComposite.createUI(FormEditorComposite.java:113)
	at org.eclipse.emf.ecp.editor.internal.e3.MEEditorPage.createFormContent(MEEditorPage.java:113)
	at org.eclipse.ui.forms.editor.FormPage$1.run(FormPage.java:152)
	at org.eclipse.ui.forms.editor.FormPage.createPartControl(FormPage.java:150)
	at org.eclipse.ui.forms.editor.FormEditor.pageChange(FormEditor.java:471)
	at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiPageEditorPart.java:1081)
	at org.eclipse.ui.forms.editor.FormEditor.setActivePage(FormEditor.java:603)
	at org.eclipse.ui.forms.editor.SharedHeaderFormEditor.createPages(SharedHeaderFormEditor.java:103)
	at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:358)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:129)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:95)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:300)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:859)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:839)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:319)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:896)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:630)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:732)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:703)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:697)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:682)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:91)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:418)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:385)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:579)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:315)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:985)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3079)
	at org.eclipse.ui.internal.WorkbenchPage.access$22(WorkbenchPage.java:3003)
	at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2985)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2981)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2940)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2931)
	at org.eclipse.emf.ecp.explorereditorbridge.internal.EditorModelElementOpener.openModelElement(EditorModelElementOpener.java:59)
	at org.eclipse.emf.ecp.internal.ui.util.ECPHandlerHelper.openModelElement(ECPHandlerHelper.java:391)
	at org.eclipse.emf.ecp.ui.views.ModelExplorerView$DoubleClickListener.doubleClick(ModelExplorerView.java:74)
	at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:845)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:843)
	at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1477)
	at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1246)
	at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:249)
	at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:246)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:307)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-04-30 11:43:23.263
!MESSAGE
!STACK 0
	at org.eclipse.emf.ecp.editor.e3.MEEditorInput.getName(MEEditorInput.java:152)
	at org.eclipse.ui.internal.ErrorEditorPart.init(ErrorEditorPart.java:83)
	at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:324)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:150)
Re: [EmfStore] Null Context in MEEditorInput [message #1052534 is a reply to message #1052527] Tue, 30 April 2013 03:58 Go to previous messageGo to next message
great that it worked for you.
Am 30.04.2013 09:47, schrieb Dmitriy Shishkin:
> property file
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [EmfStore] Null Context in MEEditorInput [message #1052549 is a reply to message #1052534] Tue, 30 April 2013 04:19 Go to previous messageGo to next message
After fixing a new problem has grown..
Before moving on ECP I had my own navigator with some decorators and it was some problems with it related with that EObjects are not thread safe and decorator (I think it was decorator) sometimes corrupt my adapters im model elements
(http://www.eclipse.org/forums/index.php/m/1008115/#msg_1008115)
I fixed it with synhronized method in all decorators:
public void decorate(Object element, IDecoration decoration) {
	ItemProviderAdapter provider = null;
	synchronized (element){
		AdapterFactory adapterFactory = AlsDomainPlugin.getInjector().getInstance(AdapterFactory.class);
		provider = (ItemProviderAdapter) adapterFactory.adapt(element, IItemLabelProvider.class);
	if (provider != null) {
		String text = Dictionary.get(element, provider);
		if (text != null && text.length() > 0){
			decoration.addSuffix(" " + "[" + text + "]");
And now I have similar problem I think:
index.php/fa/14567/0/
Maybe it is bug in my own decorators. If you can help I would be very grateful
Stack for this error:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-04-30 12:05:26.699
!MESSAGE Unable to create class 'org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor' from bundle '840'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.util.NoSuchElementException
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
Caused by: java.util.NoSuchElementException
	at org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(AbstractEList.java:711)
	at org.eclipse.emf.common.util.AbstractEList$EIterator.next(AbstractEList.java:690)
	at org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.adapt(AdapterFactoryImpl.java:80)
	at com.tes.als.chapter.provider.ChapterItemProviderAdapterFactory.adapt(ChapterItemProviderAdapterFactory.java:172)
	at org.eclipse.emf.edit.provider.ComposedAdapterFactory.adapt(ComposedAdapterFactory.java:294)
	at org.eclipse.emf.edit.provider.ComposedAdapterFactory.adapt(ComposedAdapterFactory.java:271)
	at org.eclipse.emf.edit.provider.ComposedAdapterFactory.adapt(ComposedAdapterFactory.java:258)
	at org.eclipse.emf.edit.ui.provider.AdapterFactoryLabelProvider.getText(AdapterFactoryLabelProvider.java:370)
	at org.eclipse.emf.ecp.editor.internal.e3.ShortLabelProvider.getText(ShortLabelProvider.java:42)
	at org.eclipse.emf.ecp.editor.internal.e3.MEEditor.init(MEEditor.java:202)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:288)
	... 87 more
!ENTRY org.eclipse.emf.ecp.ui 4 0 2013-04-30 12:05:26.726
!MESSAGE java.lang.NullPointerException
!STACK 0
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3095)
  • Attachment: emfStore.PNG
    (Size: 9.07KB, Downloaded 47 times)
Re: [EmfStore] Null Context in MEEditorInput [message #1052724 is a reply to message #1052549] Tue, 30 April 2013 08:56 Go to previous message
Maximilian Koegel is currently offline Maximilian Koegel
Hi Dmitriy,
as Ed already mentioned thread-safety must be provided on an application
level. The problem with the decorator as it seems is that it will add
adapters during decoration effectively changing the model and thereby
contending with other threads. It will be difficult to enforce
synchronization by only adding a synchronized block to your code.
One way to handle multi-threading are Transactional Editing domains. But
for your case it seems overkill, maybe a simple way to solve your
problem is to add the suffix you create directly in the
ItemProvider.getText() of the respective EClasses instead of later
adding them to the label by decoration. (Remember to add a @generated
NOT annotation). This way threading issues should vanish in my opinion.
Maximilian
Am 30.04.2013 10:19, schrieb Dmitriy Shishkin:
> @Override
> !STACK 0
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> ... 87 more
> !STACK 0
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Previous Topic:Create EMF project using mdl file
Next Topic:ITableItemLabelProvider code generation annotation in eCore model
Current Time: Tue May 28 12:17:53 EDT 2013
Powered by FUDForum. Page generated in 0.02157 seconds
