Home » Modeling » GMF (Graphical Modeling Framework) » Filemenu popup within GMF
Filemenu popup within GMF [message #1007178] Mon, 04 February 2013 14:00 Go to next message
Phil H is currently offline Phil H
Member
I've created a GMF Editor which works fine so far.
What I want to do now is implementing a popup which opens when an user clicks on a node. This popup should realise some kind of a file manager, like the attached immage. The user should be able to choose a file somewhere from the drive and then the file path should be stored as an String attribute in the gmf model.
Hope you understand what I mean. Is there any chance to realise something like that? Maybe eclipse provide some support.
[Updated on: Tue, 05 February 2013 05:45]
Report message to a moderator
Re: Filemneu popup within GMF [message #1007231 is a reply to message #1007178] Tue, 05 February 2013 02:14 Go to previous messageGo to next message
Daniel König is currently offline Daniel König
Hello Phil
You may try it with an OpenEditPolicy (http://publib.boulder.ibm.com/infocenter/rsahelp/v7r0m0/index.jsp?topic=/org.eclipse.gmf.doc/reference/api/runtime/org/eclipse/gmf/runtime/diagram/ui/editpolicies/OpenEditPolicy.html) and then open a FileDialog (http://www.vogella.com/articles/EclipseDialogs/article.html#tutorialswt).
I think this could work, but no guarantee Wink
Re: Filemenu popup within GMF [message #1007301 is a reply to message #1007178] Tue, 05 February 2013 07:53 Go to previous messageGo to next message
Member
Thx so far! I searched a lot, but I couldn't find a good tutorial which explains the use of OpenEditPolicy from scratch. I've no idea where to implement my own OpenEditPolicy in this whole mess of generated classes. Can someone give me a hint? Is it possible to realise this outside the generated code, since I using Eugenia for generating the code?
Re: Filemenu popup within GMF [message #1007397 is a reply to message #1007301] Tue, 05 February 2013 12:51 Go to previous messageGo to next message
Member
I'm now able to open a filedailog and read out the filepath. Furthermore I can acces my Element. But when I try to assign the filepath to an attribute, i get the following error:
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
I already read about using an ICommandProxy to overcome this, bute I've no Idea how to use this in my case. Any suggestions?
public class MyOpenEditPolicy extends OpenEditPolicy {
	protected Command getOpenCommand(final Request request) {
		return new Command() {
			public void execute() {
				EditPart targetEditPart = getTargetEditPart(request);
				if (targetEditPart instanceof IGraphicalEditPart) {
					IGraphicalEditPart graphicalEditPart = (IGraphicalEditPart) targetEditPart;
					if (graphicalEditPart.getModel() instanceof View) {
						View view = (View) graphicalEditPart.getModel();
						if (view.getElement() instanceof Feature) {
							Feature feature = (Feature) view.getElement();
							Shell shell = Display.getCurrent().getActiveShell();
							FileDialog fileDialog = new FileDialog(shell);
							fileDialog.setText("Select an EFVM File");
							fileDialog
									.setFilterExtensions(new String[] { "*.efvm" });
							fileDialog
									.setFilterNames(new String[] { "*.efvm" });
							if (fileDialog.open() != null) {
								String selected = fileDialog.open();
								System.out.println("file: "
										+ feature.getFilepath());
								// feature.setFilepath(selected);
Re: Filemenu popup within GMF [message #1007541 is a reply to message #1007397] Wed, 06 February 2013 06:10 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph Gerbig
all you need to do is get the EditDomain from the editpart then get its command stack and execute a EMF SetCommand on that stack. You can use SetCommand.Create(...) to create a new SetCommand.
Ralph
[Updated on: Wed, 06 February 2013 06:12]
Re: Filemenu popup within GMF [message #1007559 is a reply to message #1007541] Wed, 06 February 2013 08:29 Go to previous messageGo to next message
Here is an example:
// SetRequest and Command
int x = 4711;
EObject element = // your element with the attribute to set
TransactionalEditingDomain editingDomain = this.getEditingDomain();
SetRequest setRequestX = new SetRequest(editingDomain, element, XYZPackage.eINSTANCE.getYOURATTRIBUTE(), x);
SetValueCommand setX = new SetValueCommand(setRequestX);
try {
	setX.execute(null, null);
} catch (ExecutionException e) {
	e.printStackTrace();
I hope it also works for you Wink
Re: Filemenu popup within GMF [message #1007586 is a reply to message #1007178] Wed, 06 February 2013 10:19 Go to previous messageGo to next message
Member
Big thx Daniel and Ralph, it's working now like ecpected Smile
Re: Filemenu popup within GMF [message #1036758 is a reply to message #1007586] Mon, 08 April 2013 15:22 Go to previous messageGo to next message
Simon Zutterman is currently offline Simon Zutterman
Hey Phil,
I'd also really like to implement something like this in my editor, but even with the previous posts, I don't have a clue how.
As I would like it, I would have a node with a normal feature name label, but in the metamodel with a second attribute (filepath), if you double click on the node in the editor, you get the file manager popup, select a file on your drive and the filepath would be stored in the attribute, displayed in the properties view.
It would be a massive help and I would be eternally grateful if you could give me a more detailed explanation on how to do this! Or if you were willing, post me your project files so i can sort it out myself?
regards,
Simon
Re: Filemenu popup within GMF [message #1052645 is a reply to message #1007178] Tue, 30 April 2013 06:47 Go to previous message
Member
Hi Simon,
sry I just noticed your post now.
In your diagram edit.part package you should have a generated class for your node (called NameOfYourNodeEditPart). In your method createDefaultEditPolicies() you have to install your own created EditPolicy. In my case I just added:
installEditPolicy(EditPolicyRoles.OPEN_ROLE,new FilePathOpenEditPolicy());
The mentioned policy class looks like this:
public class FilePathOpenEditPolicy extends OpenEditPolicy {
					TransactionalEditingDomain editingDomain = graphicalEditPart.getEditingDomain();
							fileDialog.setFilterExtensions(new String[] { "*.efvm" });
							fileDialog.setFilterNames(new String[] { "*.efvm" });
							try {
								String path = fileDialog.open();
								if (!path.isEmpty()) {
									SetRequest setRequestX = new SetRequest(editingDomain, feature,PldPackage.eINSTANCE.getFeature_FilePath(),path);
							} catch (Exception e) {
								MessageDialog.openWarning(shell, "Warning",
										"No efvm file has been selected!");
								// e.printStackTrace();
Hope this helps.
Phil
Previous Topic:What is the best code practice to modify the domain model on diagram loading?
Next Topic:Customize Scalable Polygon Figure
Current Time: Tue May 28 13:42:10 EDT 2013
Powered by FUDForum. Page generated in 0.09384 seconds
