Home » Modeling » Epsilon » Modellink - reproducing screencast problem(Can't create models vs registered metamodels)
Modellink - reproducing screencast problem [message #1016708] Thu, 07 March 2013 07:45 Go to next message
Julian Johnson is currently offline Julian Johnson
Hi, I've been trying to reproduce the model creation and linking in the Establishing links between EMF models screencast. Although I can create the metamodels (although the metamodel creation appears to put the following as firsst few lines:
@namespace(uri=etc, prefix="p") )...I CAN create the ecore files, and attempt to register the metamodels. However, I get two problems:
1. Despite the fact I get a confirmation that each metamodel is registered successfully in console, in the Epackage registry (after refresh), only one of these metamodels 'sticks' in the list of registered packages
2. When I try to create a model versus the metamodel that appears to be registered, I see no drop down of registered models in the dialogue. If I browse to select the metamodel I don't see the metamodel listed.
Help!
Re: Modellink - reproducing screencast problem [message #1016801 is a reply to message #1016708] Thu, 07 March 2013 12:54 Go to previous messageGo to next message
Antonio Garcia-Dominguez is currently offline Antonio Garcia-Dominguez
Hi Julian,
Can you post the .ecore metamodels over here, so we can have a look at them?
Re: Modellink - reproducing screencast problem [message #1016869 is a reply to message #1016801] Thu, 07 March 2013 19:26 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris Kolovos
Hi Julian,
I've uploaded the code for this example under [1] but unfortunately drag-n-drop seems to be broken on Windows (works fine on my Mac). I'll investigate and try to fix this within the next few days.
Dimitris
[1] https://dev.eclipse.org/svnroot/modeling/org.eclipse.epsilon/trunk/examples/org.eclipse.epsilon.examples.modelink.personshouses
Re: Modellink - reproducing screencast problem [message #1016960 is a reply to message #1016801] Fri, 08 March 2013 06:05 Go to previous messageGo to next message
Hi, the two metamodels I created are attached. (I get an error "You can only use links to eclipse.org sites while you have fewer than 5 messages" if I put the text of either file inline in this response).
Is there a problem with the namespace clause? This was autogenerated.
  • Attachment: Houses.emf
    (Size: 0.17KB, Downloaded 16 times)
  • Attachment: Persons.emf
    (Size: 0.17KB, Downloaded 14 times)
Re: Modellink - reproducing screencast problem [message #1017025 is a reply to message #1016960] Fri, 08 March 2013 11:49 Go to previous messageGo to next message
Hi, an update:
I did modify the @namespace clause of the two metamodels, to change the rather obscure uri to simple ones like "houses" and "persons", and that appeared to solve the problem firsst reported. I was able to generate ecore, register the metamodels, then create a corresponding model.
My new stumbling block with the same Modellink example is at the point where I attempt to populate the linking model. So I've created a linking metamodel, registered it, and used the modellink wizard to attempt to create linking instances. Although I can create an instance in the linking model (create child), if I drag either a Person or a House instance on to the centre pane, the editor does not accept it (get the 'no entry' symbol). Any idea of the problem?
Screen dump, and relevant emf files attached. I attempted to include PersonHouses.modelink and PersonHouses.model, but get the "You can only use links to eclipse.org sites while you have fewer than 5 messages." error message. Can send if required.
Re: Modellink - reproducing screencast problem [message #1017242 is a reply to message #1017025] Mon, 11 March 2013 05:40 Go to previous messageGo to next message
Hi Julian,
Unfortunately, this appears to be a bug on Windows. Please see http://www.eclipse.org/forums/index.php/mv/msg/458023/1016869/#msg_1016869. I'll try to fix this within the next few days.
Dimitris
Re: Modellink - reproducing screencast problem [message #1047724 is a reply to message #1017242] Tue, 23 April 2013 11:06 Go to previous messageGo to next message
Dimitris
hi, did you have any luck fixing this problem?
Thanks, Julian.
Re: Modellink - reproducing screencast problem [message #1047936 is a reply to message #1047724] Tue, 23 April 2013 17:33 Go to previous messageGo to next message
Hi Julian,
Unfortunately, I haven't had a chance to work on this yet but it's in my to-do list.
Dimitris
Re: Modellink - reproducing screencast problem [message #1048261 is a reply to message #1047936] Wed, 24 April 2013 04:29 Go to previous messageGo to next message
thanks!
Julian.
Re: Modellink - reproducing screencast problem [message #1050590 is a reply to message #1048261] Sat, 27 April 2013 08:17 Go to previous messageGo to next message
This has been fixed in the SVN and the fix will appear in the next interim version.
Dimitris
Re: Modellink - reproducing screencast problem [message #1051763 is a reply to message #1050590] Mon, 29 April 2013 03:47 Go to previous messageGo to next message
Thanks. When is the 'next interim version' due to be rolled-out?
Julian.
Re: Modellink - reproducing screencast problem [message #1051820 is a reply to message #1051763] Mon, 29 April 2013 04:58 Go to previous messageGo to next message
It should be out by the end of the week.
Dimitris
Re: Modellink - reproducing screencast problem [message #1051838 is a reply to message #1051820] Mon, 29 April 2013 05:16 Go to previous message
thanks, great.
Julian.
Previous Topic:[EGL] Arrays in Epsilon?
Next Topic:Collapseble nodes?
Current Time: Tue May 28 12:45:51 EDT 2013
Powered by FUDForum. Page generated in 0.01820 seconds
