| creating association in uml profiles [message #1050182] |
Fri, 26 April 2013 16:45  |
Jeni Martin Messages: 15 Registered: November 2012 |
Junior Member |
Hi All,
I want to create association in my UML profile by the use of EMF. In papyrus, it allows me to have association between two metaclasses. But in EMF, I have to create properties as associations are properties. But don't know what should I set in the properties?
for example, I have two metaclasses A and B, and I want to create a composition from A to B. So I created an attribute (property) for metaclass A and called it b. now in the Properties window I have to set Aggregation to composition. How about others like Association, type, ...
| Re: creating association in uml profiles [message #1050189 is a reply to message #1050182] |
Fri, 26 April 2013 16:57   |
Christian W. Damus Messages: 551 Registered: July 2009 |
Hi, Jeni,
I'd suggest having a look at what the
TypeOperations::createAssociation(...) method does.
Also, you might create an association in Papyrus and open the model's
*.uml resource in the UML Editor to see what the structure of the
association and its end properties looks like.
HTH,
Christian
On 2013-04-26 20:45:29 +0000, Jeni Martin said:
> Hi All,
> Thanks
| Re: creating association in uml profiles [message #1051215 is a reply to message #1050189] |
Sun, 28 April 2013 07:55  |
Ed Willink Messages: 3191 Registered: July 2009 |
HI
You could also looks at the "Introduction to UML2 Profiles" sectionm in
the UML2 documentation.
Ed Willink
On 26/04/2013 21:57, Christian W. Damus wrote:
> Hi, Jeni,
> HTH,
> Christian
>> Hi All,
>> type, ...
>> Thanks
FUDForum. Page generated in 0.01914 seconds
