Home » Modeling » ATL » Escape from a for loop
Escape from a for loop [message #1049932] Fri, 26 April 2013 09:18 Go to next message
Mohamed Mussa is currently offline Mohamed Mussa
Member
Is there a way to escape an imperative loop?
like break in Java
Thanks in advance.
Mohamed
Re: Escape from a for loop [message #1049993 is a reply to message #1049932] Fri, 26 April 2013 10:57 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
As indicated from the ATL user guide, such loops are made to navigate over collections and to terminate at the end of this navigation.
Note that using imperative constructs in ATL is not recommended in the general case and should be reserved only for a few particular situations.
The recommended style for ATL is declarative, which is applicable in a very large majority of the transformation scenarios.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: Escape from a for loop [message #1050022 is a reply to message #1049993] Fri, 26 April 2013 11:32 Go to previous messageGo to next message
Member
Thanks Hugo,
I am using the imperative code for pre-evaluation of my models to select & merge only the targeted fragments.
More precisely, I am comparing the behavior of two UML lifelines, one from each model, and merge them if applicable. So, I have to arrange the events according to their model specification.
I believe I have to make a NOP statement for the rest of the loop.
Mohamed
Re: Escape from a for loop [message #1050028 is a reply to message #1050022] Fri, 26 April 2013 11:40 Go to previous messageGo to next message
You could implement this filtering/merging operation in OCL using its different iteration expressions, and put this as a condition in the source pattern of the concerned matched rule(s) (cf. the ATL language reference documentation containing all the relevant information about these). This is exactly the role of such conditions in declarative rules.
Hugo
Nantes - France
Re: Escape from a for loop [message #1050042 is a reply to message #1050028] Fri, 26 April 2013 12:04 Go to previous message
Member
Previous Topic:ATL Plug-in dont run
Next Topic:[ATL] EMFTVM: PackageNotFoundException: Package with uri not found
Current Time: Tue May 28 09:36:13 EDT 2013
Powered by FUDForum. Page generated in 0.01590 seconds
