| ATL Plug-in dont run [message #1049709] |
Fri, 26 April 2013 03:17  |
serhat gezgin Messages: 136 Registered: January 2013 Location: Izmir |
Hi all,
I create atl plug-in project for invoke transformation programmaticaly. First i
create command and i invoke this command from file right click and generate button.
But i cant run transformation i always get error.When i debug i see asm variable
always null and error occurs because of this. My code and error is blow
Not i use xtext as a input
Anyone can help me to fix this ?
Code;
public class deneme {
public static void aaa(String filepath, String outPutFilePath) throws ATLCoreException, IOException {
// Replace DSL by your Language name
FilesystemStandaloneSetup dsl = new FilesystemStandaloneSetup();
Injector injector = dsl.createInjectorAndDoEMFRegistration();
XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
Resource resource = resourceSet.getResource(URI.createURI(filepath), true);
// Create factory and injector
EMFModelFactory factory = new EMFModelFactory();
EMFInjector emfinjector = new EMFInjector();
// Load the DSL metamodel
EMFReferenceModel dslMetamodel = (EMFReferenceModel) factory.newReferenceModel();
emfinjector.inject(dslMetamodel, "File://C:\\Users\\unituser\\XtextAndGmfSynchronization\\org.eclipse.m2m.atl.filesystem\\model\\Filesystem.ecore");
// Load the XtextResource as an EMFModel
EMFModel model = (EMFModel) factory.newModel(dslMetamodel);
emfinjector.inject(model, resource);
EMFReferenceModel outMetamodel = (EMFReferenceModel) factory.newReferenceModel();
emfinjector.inject(outMetamodel, "File://C:\\Users\\unituser\\XtextAndGmfSynchronization\\org.eclipse.m2m.atl.filesystem\\model\\filesystem2.ecore");
EMFModel outModel = (EMFModel) factory.newModel(outMetamodel);
EMFVMLauncher launcher = new EMFVMLauncher();
launcher.initialize(Collections.<String, Object> emptyMap());
launcher.addInModel(model, "IN", "Filesystem");
launcher.addOutModel(outModel, "OUT", "filesystem2");
InputStream asm = deneme.class.getResourceAsStream("org.eclipse.m2m.atl.filesystem/files/transformation.asm");
launcher.launch(
ILauncher.RUN_MODE,
new NullProgressMonitor(),
Collections.<String, Object> emptyMap(),
new Object[] {asm} );
outModel.getResource().setURI(URI.createURI(outPutFilePath));
outModel.getResource().save(Collections.EMPTY_MAP);
Error;
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch(EMFVMLauncher.java:139)
at org.eclipse.m2m.atl.filesystem.files.deneme.aaa(deneme.java:53)
at org.xtext.example.filesystem.generator.plugin.handler.Translate.createOutput(Translate.java:58)
at org.xtext.example.filesystem.generator.plugin.handler.Translate.execute(Translate.java:29)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:231)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:212)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:831)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:724)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:708)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:647)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
[Updated on: Fri, 26 April 2013 09:55] Report message to a moderator
| Re: ATL Plug-in dont run [message #1049980 is a reply to message #1049709] |
Fri, 26 April 2013 10:40   |
Hugo Bruneliere Messages: 469 Registered: July 2009 |
Before generating the ATL plugin, have you already tried to run your transformation manually in your development workbench using an ATL launch configuration?
If this works, have you actually generated your ATL plugin from this launch configuration?
This could help to identify whether the problem comes from the generated Java launcher or from the transformation itself.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
| Re: ATL Plug-in dont run [message #1049988 is a reply to message #1049980] |
Fri, 26 April 2013 10:53   |
yes i tried to run my transformation manually and it have been worked perfect (i use
non xtext resource just use emf resource for manually). But i must use xtext as input
file so i think i cant use raw atl plug-in i tihnk i must change its run method (like
my above method). Because i tried this too and it have not been worked. It gives me
error like your input file not emf resource
[Updated on: Fri, 26 April 2013 10:54] Report message to a moderator
| Re: ATL Plug-in dont run [message #1050004 is a reply to message #1049988] |
Fri, 26 April 2013 11:07  |
Maybe your problem is not related to ATL itself, but more to how you can load an Xtext Resource as a standard EMF Resource.
You should ask a specific question about this onto the Xtext (and/or EMF) forum.
Hugo
Nantes - France
FUDForum. Page generated in 0.01622 seconds
