Home » Modeling » Epsilon » [EGL] Arrays in Epsilon?
[EGL] Arrays in Epsilon? [message #1047873] Tue, 23 April 2013 15:34 Go to next message
Patricia Fernández is currently offline Patricia Fernández
I've created a Java Tool which looks like this:
package pluginChooseModel;
public class ChooseModel extends JFrame{
	public String WindowChooseModel (String[] models){
I also added the operation in the EOL file:
operation chooseModel (models: List): String {
	var sampleTool = new Native("pluginChooseModel.ChooseModel");
	return sampleTool.WindowChooseModel(models);
But when I try to use it in an EGL file:
var models:List;
for (mod in Model.allInstances()){
	models.add(mod.name);
var e= chooseModel(models);
It gives me the following error Type 'pluginChooseModel.ChooseModel' not found. I added the jar to the source path and re-started Epsilon but it keeps giving me that error.
Could it be because I'm using a List as parameter instead of an array? If so, how can I declare an array in Epsilon? I tried many ways (like var a:[],var a: String[]...) but it doesn't work.
Thanks in advance.
[Updated on: Tue, 23 April 2013 15:34]
Report message to a moderator
Re: [EGL] Arrays in Epsilon? [message #1047921 is a reply to message #1047873] Tue, 23 April 2013 17:05 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris Kolovos
Hi Particia,
The error message you're receiving would indicate that the tool has not been registered successfully with Epsilon. Are your running your EGL template from a launch configuration or directly from Java?
Dimitris
Re: [EGL] Arrays in Epsilon? [message #1047935 is a reply to message #1047921] Tue, 23 April 2013 17:31 Go to previous messageGo to next message
Hi Dimistris,
I'm using a launch configuration.
Also, the project where pluginChooseModel is implemented contains other packages with tools and the other ones work ok.
But now I'm receiving this error:
Method 'WindowChooseModel' not found for: pluginChooseModel.ChooseModel[frame1,0,0,0x0,invalid,hidden,
layout=java.awt.BorderLayout,title=,resizable,normal,defaultCloseOperation=HIDE_ON_CLOSE,
rootPane=javax.swing.JRootPane[,0,0,0x0,invalid,layout=javax.swing.JRootPane$RootLayout,alignmentX=0.0,alignmentY=0.0,
border=,flags=16777673,maximumSize=,minimumSize=,preferredSize=],rootPaneCheckingEnabled=true]
Here is the full implementation of the tool, if needed:
import javax.swing.JFrame;
import javax.swing.JOptionPane;
	    JFrame frame = new JFrame();
	    String name = (String) JOptionPane.showInputDialog(frame,
	        "Select the name of the model you want to generate.",
	        "Choose the model",
	        JOptionPane.QUESTION_MESSAGE,
	        null,
	        models,
	        models[0]);
	    return name;
[Updated on: Tue, 23 April 2013 17:33]
Re: [EGL] Arrays in Epsilon? [message #1048537 is a reply to message #1047935] Wed, 24 April 2013 12:02 Go to previous messageGo to next message
Hi Patricia,
This is a different error message which, as you suspected, is a result of the incompatibility between String[] and List. Changing "String[] models" to "List models" in your operation signature would probably do the trick.
Dimitris
Re: [EGL] Arrays in Epsilon? [message #1048681 is a reply to message #1048537] Wed, 24 April 2013 16:31 Go to previous messageGo to next message
Hi Dimitris,
I tried that, but it keeps failing when I run the EGL file.
public String windowChooseModel (List m){
	    String models[] = m.getItems();
	    String name= (String) JOptionPane.showInputDialog(frame,
	        "Choose the model",
	        null,
	        models,
	        models[0]);
	    return name;
[Updated on: Wed, 24 April 2013 16:35]
Re: [EGL] Arrays in Epsilon? [message #1049018 is a reply to message #1048681] Thu, 25 April 2013 04:33 Go to previous messageGo to next message
Hi Patricia,
Could you please put together a minimal example [1] I can use to reproduce/investigate this?
Dimitris
[1] http://eclipse.org/epsilon/doc/articles/minimal-examples/
Re: [EGL] Arrays in Epsilon? [message #1049150 is a reply to message #1049018] Thu, 25 April 2013 08:47 Go to previous messageGo to next message
Hi Dimitris,
Of course! I attach the following files:
- MinimalEGL.zip: Contains the .egl and .eol files and an uml model.
- PluginMinimal.zip: Contains the java tool.
- pluginMinimal.jar: The exported file from PluginMinimal.
Thanks for your time.
Cheers.
Re: [EGL] Arrays in Epsilon? [message #1049775 is a reply to message #1049150] Fri, 26 April 2013 04:59 Go to previous messageGo to next message
Hi Patricia,
In your ChooseModel class you should use java.util.List instead of java.awt.List.
Dimitris
Re: [EGL] Arrays in Epsilon? [message #1049898 is a reply to message #1049775] Fri, 26 April 2013 08:27 Go to previous message
Hi Dimitris,
I tried it and it works now, thank you so much for the help.
[Updated on: Fri, 26 April 2013 08:27]
Previous Topic:[EVL] Custom validation messages
Next Topic:Modellink - reproducing screencast problem
Current Time: Tue May 28 12:46:24 EDT 2013
Powered by FUDForum. Page generated in 0.03685 seconds
