| "Searching for local file" problem in Juno [message #1049159] |
Thu, 25 April 2013 09:01 |
Hugh Messenger Messages: 17 Registered: January 2010 |
Junior Member |
I recently upgraded to Juno, and all seems to be well, except with debugging one of my PHP projects. When debugging with xdebug, every line I step through, I get:
An internal error occurred during: "Searching for local file...".
Illegal or not full path:
But it happily debugs anyway, everything works as expected. It just pukes up what appears to be a spurious error on every step.
If it makes any difference, I'm starting the session using &XDEBUG_SESSION_START=ide_name on the URL from an external browser, and running through a dbgpproxy. But the other half dozen PHP projects all work just fine, and I've checked and re-checked settings and debug configs till I'm cross-eyed, can't see anything odd about that one project.
TIA for any suggestions. Or failing that, good lightbulb jokes.
-- hugh
FUDForum. Page generated in 0.01539 seconds
