| Can you auto build eugenia and xtext [message #1046753] |
Mon, 22 April 2013 06:18  |
Hello
I wanted to ask if it is possible to generate a maven build for a eugenia and xtext project? I noticed you had a tutorial about making a ANT build but it looked like it used a predefined emf file and since I use one from the generated code I wanted to check if it can be done?
Seems like the one who I do my project for want to only have one eclipse window up and not have to build in eclipse first to get a second window
Side note, but is it possible to make it compile to a runnable jar? I was asked if my project could be completely removed from eclipse so they have a program they can bring along instead of needing to install eclipse on computers when they want to use it.
Thanks for all help
Write you later / Mårten
| Re: Can you auto build eugenia and xtext [message #1048444 is a reply to message #1047942] |
Wed, 24 April 2013 09:29  |
Hi Dimitris
Ok, I think I will try and make a plugin thingie
It seems you can export them as an Eclipse Product that way so thanks for the tips!
I guess they will just have to live with working in eclipse... although I don't see anything bad with it
Now just to read and figure out how it is done
FUDForum. Page generated in 0.01689 seconds
