| foreach [message #1038837] |
Thu, 11 April 2013 08:03  |
samar sousou Messages: 57 Registered: March 2013 |
Member |
hi,
why the distinct and the foreach don't work!! there is a plug in not installed!!
my rule is :
rule EnumColumn {
from
i : XML!Element (
if i.name = 'TableInfoTable'
then
i.getFirstElementByName('Type').getTextValue().startsWith('enum')
else
false
endif
using {
items : Sequence(String) =
i.getFirstElementByName('Type').getTextValue().getItemList();
to
o : MySQL!EnumColumn (
name <- i.getFirstElementByName('Field').getTextValue(),
type <- 'enum',
isPrimaryKey <-
i.getFirstElementByName('Key').getTextValue() = 'PRI',
null <- i.getFirstElementByName('Null').getTextValue() = 'YES',
defaultValue <- i.getFirstElementByName('Default').getTextValue(),
comment <- i.getFirstElementByName('Comment').getTextValue(),
table <- i.parent,
enumSet <- e1
e1 : MySQL!EnumSet (
enumItems <- e2
e2 : distinct MySQL!EnumItem foreach(i in items) (
name <- i,
enumSet <- e1
the error was:
distinct-foreach target pattern elements are deprecated, use lazy rules instead
but how can I do the lazy rule!!
I tried but there is a problem all the time :'(
I need your help.
thank you.
| Re: foreach [message #1048266 is a reply to message #1038837] |
Wed, 24 April 2013 04:33  |
Ronan B Messages: 195 Registered: July 2009 |
Collect the values from MySQL!EnumItem and call a lazy rule for each element in the list.
Ronan
FUDForum. Page generated in 0.01550 seconds
