| MWE framework and Check language [message #1048204] |
Wed, 24 April 2013 02:57 |
Dhanya M Messages: 9 Registered: April 2013 |
Junior Member |
I have 2 ecores in my project having the same contexts in it with same namespace. I want to validate based on one of the ecores. I use a check language and write workflow files to validate.
My workflow file:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<workflow>
<component class="org.eclipse.xtend.check.CheckComponent">
<metaModel class="org.eclipse.xtend.typesystem.emf.EmfMetaModel">
<modelFile value="actual path of the ecore"/>
</metaModel>
<emfAllChildrenSlot value="model"/>
<checkFile value="CheckFile"/>
</component>
</workflow>
When i gave a relative path to my ecore, it was not able to find it. When i gave the actual path of the ecore workflow file executed. However it was not reporting any issues as it used to when there was only one ecore.
How can i be sure that it picks the correct ecore and validate?
I suppose it has something to do with same context names and same namespace. How can i resolve this?
FUDForum. Page generated in 0.01680 seconds
