Home » Modeling » UML2 » How to register a UML Profile
How to register a UML Profile [message #1047527] Tue, 23 April 2013 06:38 Go to next message
André Ribeiro is currently offline André Ribeiro
Member
Hello everyone,
I would like to register a custom UML profile in Eclipse, so that when I launch Eclipse my profile is automatically loaded.
I've found this link* but I'm not quite sure how to do such a thing.
If someone could provide me some steps I would appreciate.
Many thanks.
* - http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.uml2.doc%2Freferences%2Fextension-points%2Forg_eclipse_uml2_uml_generated_package.html
André Ribeiro
IST Lisbon
Portugal
Re: How to register a UML Profile [message #1047577 is a reply to message #1047527] Tue, 23 April 2013 07:56 Go to previous messageGo to next message
Copying is often a good idea in Eclipse.
Try copying the MARTE profile.
Ed Willink
On 23/04/2013 11:38, André Ribeiro wrote:
> Hello everyone,
> Many thanks.
Re: How to register a UML Profile [message #1047624 is a reply to message #1047577] Tue, 23 April 2013 09:00 Go to previous messageGo to next message
Member
Thanks for the answer Ed.
I don't have the MARTE profile, but I can use for instance the SysML one. Now, I don't know where to look to perform the copying you refer.
I've found the following link that suggests the use of a plugin.xml file:
http://wiki.eclipse.org/MDT-UML2Tools_How_To_Use_UML_Profiles#Register_Profile
Probably you have experience doing something like this. Can you please give some more clues?
Thank you.
André Ribeiro
IST Lisbon
Portugal
Re: How to register a UML Profile [message #1047637 is a reply to message #1047624] Tue, 23 April 2013 09:11 Go to previous messageGo to next message
plugin.xml is where registrations are usually found.
Ed Willink
> file:
> Thank you.
Re: How to register a UML Profile [message #1047948 is a reply to message #1047637] Tue, 23 April 2013 17:54 Go to previous message
Member
For those who also want to register their own UML Profile I recommend the following links. I was able to achieve it following the steps described.
http://www.papyrusuml.org/home/liblocal/docs/Documentation/ExtensionPoints/EnclosingProfileInPlugin.swf
http://www.papyrusuml.org/scripts/home/publigen/content/templates/show.asp?P=148&L=EN&ITEMID=25
André Ribeiro
IST Lisbon
Portugal
Previous Topic:Magicdraw EMF UML2 export
Next Topic:Implementation of UML::Integer too restricting
Current Time: Tue May 28 17:33:29 EDT 2013
Powered by FUDForum. Page generated in 0.01651 seconds
