Home » Modeling » Papyrus » OCL constraints on stereotypes
OCL constraints on stereotypes [message #1046896] Mon, 22 April 2013 10:08 Go to next message
Vincent Verdier is currently offline Vincent Verdier
Hi everyone,
I'm using Papyrus on Eclipse Juno and I have definied an OCL constraint on a stereoptype. Unfortunately, Papyrus doesn't seem to check this kind of constraints. I also tried on Eclipse Kelpler.
What can I do in order to check the OCL constraints that I have defined in a profile ?
Any help would be much appreciate.
Thanks.
Re: OCL constraints on stereotypes [message #1046925 is a reply to message #1046896] Mon, 22 April 2013 10:53 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille Letavernier
Hi Vincent,
It's currently work in progress in Kepler. Most of the features should work on the latest nightly builds (Define constraints in the profile, validate models on which the profile is applied). You need the latest Papyrus and OCL builds.
Camille
Re: OCL constraints on stereotypes [message #1046949 is a reply to message #1046925] Mon, 22 April 2013 11:33 Go to previous messageGo to next message
Thanks for your answer.
So I downloaded the latest nightybuild of Papyrus from :
http://download.eclipse.org/modeling/mdt/papyrus/updates/nightly/kepler
Then I have tried to validate a very simple test. I got this exception :
Error	An exception occurred while delegating evaluation of the 'Constraint1' invariant on 'Test 0 -> <<test>> <Class> Class1': null	Test 0 -> <<test>> <Class> Class1	null	EMF Problem
Did I do something wrong or is this due to the nightybuild ?
Re: OCL constraints on stereotypes [message #1046982 is a reply to message #1046949] Mon, 22 April 2013 12:30 Go to previous messageGo to next message
Do you have a more precise message? e.g. the message from the root exception? (An OCL exception, probably)
What did you write on your OCL constraint?
Camille
Re: OCL constraints on stereotypes [message #1047027 is a reply to message #1046949] Mon, 22 April 2013 13:37 Go to previous messageGo to next message
Camille wrote to use the latest OCL and Papyrus. Your message suggests
that you used only Papyrus nightly.
You should also use the latest Xtext ... all of which are available from
http://download.eclipse.org/releases/staging.
Ed Willink
Re: OCL constraints on stereotypes [message #1047437 is a reply to message #1046896] Tue, 23 April 2013 03:48 Go to previous messageGo to next message
The problem is resolved. You were right, I forgot to update OCL to the latest nightlybuild...
Thank you both of you.
Re: OCL constraints on stereotypes [message #1047725 is a reply to message #1046982] Tue, 23 April 2013 11:09 Go to previous messageGo to next message
Walid Ban is currently offline Walid Ban
I installed Papyrus latest nightly build (0.10.0.v201304222226) and OCL last nightly build (4.1.0.v20130423-0101) and Xtext SDK (2.4.1.v201304180855).
I added the following constraint attached to the stereotype "Provider" that extend "Actor" (it means that the context is Provider):
self.base_Actor.getAssociations()-> forAll (a | a.memberEnd->exists (r|r.type.oclIsKindOf (ServiceInteraction)) and
a.memberEnd ->exists (r|r.type.oclIsKindOf (ServicePublication)) and
a.memberEnd->exists (r|r.type.oclIsKindOf (ServiceSearch)))
Note that "ServiceInteraction","ServicePublication" and "ServiceSearch" are stereotypes that extend "Use Case"
It doesn't contain errors. I tried to verify the constraint, i made an assocaition between an Actor stereotyped "Provider" and a Use Case stereotyped "ServiceComposition".But when i validate the model that apply my profile (open *.uml-->right click on the model-->validate), the validation is successful!
I'm confused between 2 things:
- The constraint is badly described and so it doesn't work or
- Something wrong with the validation Task in Papyrus.
Could you help me please..Thank you
Re: OCL constraints on stereotypes [message #1047741 is a reply to message #1047725] Tue, 23 April 2013 11:34 Go to previous messageGo to next message
A lead:
- a.memberEnds is a UML feature. This means that it returns instances of UML Elements (Which might be stereotyped with ServiceInteraction). It *won't* return instances of ServiceInteraction (Or any other stereotype). a is an Association, memberEnd contains Properties, r is a Property, and r.type is a UML Type. So you should type something like: not r.type.getAppliedStereotype(yourProfile::ServiceInteraction).oclIsUndefined()
However, this constraint should fail during validation.
You should use Papyrus to validate profiled models defined in Papyrus. Or, at least, use the latest UML integration build.
Camille
Re: OCL constraints on stereotypes [message #1047823 is a reply to message #1047741] Tue, 23 April 2013 13:51 Go to previous message
Thank you a lot Camille...really!
It worked!
Best regards
Previous Topic:Which version of UML is supported for Papyrus?
Next Topic:Question about all the functionalities
Current Time: Tue May 28 16:54:41 EDT 2013
Powered by FUDForum. Page generated in 0.01833 seconds
