Home » Language IDEs » C / C++ IDE (CDT) » Using not supported Compiler (Using C/C++ Compiler without Plugins)
Using not supported Compiler [message #1047572] Tue, 23 April 2013 11:52 Go to next message
Arash Java is currently offline Arash JavaFriend
is there a possibility to get a not (no Plugin)supported Compiler/Linker to work with ecplise? should i write my own Plugin for this? or can i create a new Toolchain in Ecplise menu?
thanks
Re: Using not supported Compiler [message #1047895 is a reply to message #1047572] Tue, 23 April 2013 20:13 Go to previous message
Nobody Mising name is currently offline Nobody Mising nameFriend
Member
Arash Java wrote on Tue, 23 April 2013 07:52
It is possible to use custom commands for building, in particular to use makefile inside which you can use any compiler you want.
Previous Topic:multiple main functions within one C project
Next Topic:Eclipse plugin for plotting serial data over windows
Current Time: Sat Jul 22 09:22:12 GMT 2017
Powered by FUDForum. Page generated in 0.02280 seconds
