Home » Modeling » Compare » [EMF Compare] Ignore order in EMFCompare
[EMF Compare] Ignore order in EMFCompare [message #1046737] Mon, 22 April 2013 05:49 Go to next message
Aleksandar Toshovski is currently offline Aleksandar Toshovski
I'm comparing ecore models and the following example returns an EMF Compare move. In the following example I move the name Attribute. The same happens when I change the order of the classes in the ecore model.
original code:
<eClassifiers xsi:type="ecore:EClass" name="Author">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="test" eType="#//Book" eOpposite="#//Book/test"/>
  </eClassifiers>
moved "name" element
  </eClassifiers>
They are not breaking the generated code. Is it possible in EMF Compare to set these changes to be ignored?
Re: [EMF Compare] Ignore order in EMFCompare [message #1047411 is a reply to message #1046737] Tue, 23 April 2013 03:07 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent Goubet
Aleksandar,
EMF Compare does not detect "changes that break the generated code". It compares the two given models and detects differences between them, without any assumption that these models are used to generated code (and without assuming that this will be the "default" generated code). Ordering differences will be detected on all "ordered" features, as well as on "containment" features.
That being said, these differences can be ignored. Please see the FAQ on that point.
Laurent Goubet
Obeo
Re: [EMF Compare] Ignore order in EMFCompare [message #1047471 is a reply to message #1046737] Tue, 23 April 2013 04:52 Go to previous message
Thanks! That was exactly what I wanted.
Previous Topic:Logical model compare (Compare 1.3.1, with SVN)
Next Topic:[EMF Compare] Compute degree of similarity
Current Time: Tue May 28 10:19:06 EDT 2013
Powered by FUDForum. Page generated in 0.01548 seconds
