Home » Eclipse Projects » Dali » JPQL Refactoring?(Is there any support for refactoring of JPQL queries?)
icon5.gif  JPQL Refactoring? [message #1046960] Mon, 22 April 2013 11:47 Go to next message
Peer  Törngren is currently offline Peer Törngren
Looking into Dali primarily in search for refactoring tools that support JPQL queries.
Is there some way to write a JPQL query to ensure it is updated when types or attributes are renamed (without "updating textual references")?
Writing a regular string that is passed into the query will obviously (?) not work:
return em.createQuery("select c from Company c where c.type = :type", Company.class)
.setParameter("type", type.toString())
.getResultList();
PS: I did have a look at patterns for typesafe JPA queries using the CriteriaQuery API (http://www.ibm.com/developerworks/java/library/j-typesafejpa), but most of us feel that this requires too much extra code to be an attractive option.
Re: JPQL Refactoring? [message #1047008 is a reply to message #1046960] Mon, 22 April 2013 13:07 Go to previous message
Neil Hauge is currently offline Neil Hauge
Using the Criteria API will give you a partial (type level) support, but I wouldn't recommend using it based on this alone.
Dali will currently provide validation to indicate where refactoring has caused errors in NamedQueries defined in JPA metadata (annotations or orm.xml). This will allow you to refactor with less fear of breaking your queries at run-time, as the problems will be identified at design-time. We have an enhancement that is planned for our next release to add refactoring support to NamedQueries. This is on our short list for added refactoring support, so it has higher priority than many other features.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=365950
You could add yourself as a CC to this bug to be alerted of updates.
Neil
Previous Topic:Hibernate to JPA 2.0 migration issues
Current Time: Mon May 27 22:41:01 EDT 2013
Powered by FUDForum. Page generated in 0.01536 seconds
