Home » Modeling » Graphiti » Graphiti opens multiple tabs for the same file
Graphiti opens multiple tabs for the same file [message #1043346] Wed, 17 April 2013 11:31 Go to next message
Rui Domingues is currently offline Rui Domingues
HI.
I implemented an editor. but when I open the same file multiple times, it opens an editor tab for each open.
I tried to implement a FileEditorInput for my editor and implemented equals method, but the method is never invoked.
How can I solve this
Thanks in advance.
rui
Re: Graphiti opens multiple tabs for the same file [message #1046870 is a reply to message #1043346] Mon, 22 April 2013 09:31 Go to previous message
Michael Wenz is currently offline Michael Wenz
Rui,
Graphiti uses a matchingStrategy to check for an altready opened editor for
a file (it is set in plugin.xml at the editor definition). The default is
org.eclipse.graphiti.ui.editor.DiagramEditorMatchingStrategy, maybe you need
to change it.
Michael
Previous Topic:Diagram disappears after saving when one tries to edit
Next Topic:hiding context menu entries
Current Time: Tue May 28 14:29:19 EDT 2013
Powered by FUDForum. Page generated in 0.01730 seconds
