| Diagram disappears after saving when one tries to edit [message #1042436] |
Tue, 16 April 2013 08:36  |
Rui Domingues Messages: 162 Registered: October 2010 |
Hi.
I developed a custom editor, for which I contributed a customized EditorInput and where I reimplemented init in order to be possible to load directly the model file and generate diagram from it if necessary.
Everything runs ok. After opening I can edit and create new objects, however after Saving, the editor becomes unusable, graphic elements disappear, and I can't create anything.
Do you know what can be happening. Is this a symptom of issues with recordsets transactionaleditingdomains?
Thanks in advance
rui
FUDForum. Page generated in 0.01735 seconds
