Home » Modeling » BPEL Designer » [SOLVED]Apache ODE Server setup issue
[SOLVED]Apache ODE Server setup issue [message #1046717] Mon, 22 April 2013 05:13
sams good is currently offline sams good
After installing BPEL Designer successfully by following this tutorial http://www-inf.int-evry.fr/cours/WebServices/TP_BPEL/installation.html
I'm stucking at step 3 of the "Setting up the ODE server on Eclipse" part, I dont see any ode Server v1.x in the Apache server list.
the ODE webapp is deployed succesfully and I can access it at localhost:8081/ode
(I'm using the same Apache Tomcat server v7 as the one used by eclipse and I use the port 8081 cause the 8080 is used by Glassfish)
any suggestions ?
SOLUTION:
install the ODE server adapter in Eclipse help=>install new software
thank you
[Updated on: Mon, 22 April 2013 05:23]
Report message to a moderator
Previous Topic:help on running eclipse designer bpel process on ode
Next Topic:Web Service Orchestration
Current Time: Tue May 28 09:51:42 EDT 2013
Powered by FUDForum. Page generated in 0.04855 seconds
