Home » Modeling » MoDisco » A simpler ecore java model?
A simpler ecore java model? [message #1044606] Fri, 19 April 2013 01:47 Go to next message
Jeremie Bresson is currently offline Jeremie Bresson
I am looking for an emf model to represent java classes.
I have started to read about MoDisco java.ecore model: Java Metamodel
It seems too complete for what I want to do. I look for something similar to what you can get with java reflexion (java.lang.Class, java.lang.Package and java.lang.reflect.*). It is about classes, methods, java signature...
Do you thing, I can use a subset from the eClass defined in your java.ecore? Do you think that it is possible and that it makes sense?
Thanks a lot in advance.
Please tell me if you think I should use something else...
MoDisco forum references:
http://www.eclipse.org/forums/index.php/t/281293/
http://www.eclipse.org/forums/index.php/t/462039/
Re: A simpler ecore java model? [message #1044675 is a reply to message #1044606] Fri, 19 April 2013 03:36 Go to previous message
Hugo Bruneliere is currently offline Hugo Bruneliere
The MoDisco Java metamodel is very complete and cover all the details of Java. However, this does not mean that corresponding models are always using 100% of this metamodel.
Notably, the MoDisco Model Discoverer has several launching options including one named "Deep Analysis".
When it is set to "false", the discovered Java models are only covering the superstructure of the reverse engineered Java code: packages, classes, attributes and method signatures (no method body content).
From what you are telling in your post, this seems to be what you are searching for.
I hope this helps.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Previous Topic:Modisco and Eclipse Juno
Next Topic:Changing KDM programatically
Current Time: Tue May 28 18:46:12 EDT 2013
Powered by FUDForum. Page generated in 0.13532 seconds
