Home » Modeling » M2T (model-to-text transformation) » EcoreXMI to OMG standard xmi conversion(EcoreXMI to OMG standard xmi conversion)
EcoreXMI to OMG standard xmi conversion [message #1034165] Fri, 05 April 2013 00:53 Go to next message
sheeshma m is currently offline sheeshma m
Hi we are trying to convert ecore xmi file to omg standard xmi, please let us know if there is any api or tool which can do this conversion.
Or is der any uml tool which can read ecore xmi file?
Can any one please help me .
Re: EcoreXMI to OMG standard xmi conversion [message #1034686 is a reply to message #1034165] Fri, 05 April 2013 15:22 Go to previous messageGo to next message
The differences are tiny and unintentional so I suspect you have
misunderstood your problem.
Ed Willink
Re: EcoreXMI to OMG standard xmi conversion [message #1035051 is a reply to message #1034686] Sat, 06 April 2013 04:27 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Yes, this question was posted on eclipse.newcomer as well. There I
replied suggesting it's better to ask on eclipse.tools.emf and asking:
Are you trying to serialize a *.ecore resource as EMOF? You you
can do that using Save As in the Sample Ecore Editor and choosing a
local with .emof as the file extension.
Of course it's not clear if the question is really about serializing
Ecore or some other model...
On 05/04/2013 9:22 PM, Ed Willink wrote:
> Hi
> Regards
> Ed Willink
>> conversion. Or is der any uml tool which can read ecore xmi file?
Re: EcoreXMI to OMG standard xmi conversion [message #1043038 is a reply to message #1035051] Wed, 17 April 2013 03:32 Go to previous messageGo to next message
Hi Ed.. Thanks for your reply...
To be more clear we have generated ecore xmi file, now we need to view this diagramatically as in ecorediag..
But we i convert .ecore to .ecorediag through right click on .ecore file, it gives me a scattered diagram.. Sad..
So just wanted to know is there any other tool which can open this .ecore file view diagramatically..Or after converting this to EMOF can i get diagramatic view on anyother tool...
Re: EcoreXMI to OMG standard xmi conversion [message #1043828 is a reply to message #1043038] Thu, 18 April 2013 03:04 Go to previous message
It seems that Ecore Tooling has successfully displayed a diagramatic
view of your model. You are just unhappy with the auto-layout.
IMHO layout is an important editorial issue that you should not expect a
tool to do for you. So looking around for another tool may just give you
a differently unsatisfactory default layout.
If you want X/Y positioning to be an important aspect of your model then
you need to specify it. Expect to at least reposition elements in the
Ecore Diagram and, if the model is large, to partition into multiple
diagrams.
Ed Willink
> file, it gives me a scattered diagram.. :(..
> Regards
Previous Topic:[Acceleo] Generate Eclipse Project
Next Topic:[Xpand/Xtend] Extension problem
Current Time: Tue May 28 14:58:09 EDT 2013
Powered by FUDForum. Page generated in 0.01558 seconds
