| help on running eclipse designer bpel process on ode [message #1043430] |
Wed, 17 April 2013 13:47 |
Bradi Rares Messages: 1 Registered: April 2013 |
Junior Member |
Good day,
I've installed the bpel plugin for eclipse along with apache ode on tomcat. I tried to model a credit loan process like in many examples there on the web. it is composed of 3 services: a creditRating (designed in eclipse bpel designer deployed before and tested to work), an external currency conversion service in .NET and the main process creditBuletin. While it deploys without problems when I run it it gives:
Error sending message to Axis2 for ODE mex {PartnerRoleMex#hqejbhcnphr87m7k1sx6f9 [PID {CreditBuletinNamespace}CreditBuletin-135] calling WSAEndpoint@385efc.getRating(...) Status REQUEST}
along with
Binding operation not found: service
I have tried google-ing for some answers but have failed to find a solution. I'm sure I've made some beginner mistakes but can't find them. Maybe to an expert they pop-up more clearly. I have attached the project files used because I believe they would explain more better what I'm trying to do than I can and probably faster. Any help or reference to a possible solution helps.
Thank-you
FUDForum. Page generated in 0.03821 seconds
