Home » Language IDEs » AJDT » Better singleton aspect
Better singleton aspect [message #1034484] Fri, 05 April 2013 09:39 Go to next message
Kirsten M. Z. is currently offline Kirsten M. Z.
The following is a neat Java singleton pattern:
public class XXX {
    private static XXX instance = new Singleton();
    private XXX () {}
    public static XXX getInstance() {
        return instance;
I hoped that I could implement an 'aspect' which can be applied to singleton classes in order to avoid this overhead. However, I am unable to find or implement a good solution. Google can only find the following one: http://www.christianschenk.org/blog/singletons-with-aspectj/
But honestly, "new XXX()" for getting the singleton instance? This solution can also be found in the AspectJ cookbook. IMHO this is a no go! There is also a quote:
The presented implementation should be well documented, because nothing would be more irritating than a novice developer in your team who doesn't know about this magic behind the scenes and relies on different instances of the singleton class ("I thought new would be doing...").
I cannot believe that the trivial singleton code above cannot be weaved into some classes (e.g. with MySingletonAnnotation). Is there no solution which allows the writing of "XXX.getInstance()"?
Re: Better singleton aspect [message #1041806 is a reply to message #1034484] Mon, 15 April 2013 11:51 Go to previous messageGo to next message
Andrew Eisenberg is currently offline Andrew Eisenberg
Because of the singleton pattern's reliance on static methods, there would be no clean solution in an aspect. I agree with you that the solution posted in the blog is not what I would suggest. I'll play around a bit and see if I can come up with a better solution myself. However, my guess is that no matter what, there will always be a cast involved around the getInstance() method.
Re: Better singleton aspect [message #1042579 is a reply to message #1041806] Tue, 16 April 2013 11:53 Go to previous messageGo to next message
Probably, there is no better solution. Otherwise, somebody might have found it already. However, using the word "find" for such a trivial case speaks volumes *sigh* 10 years ago I really expected that aspect-oriented programming could revolutionize programming (or clean the mess, at least). I tried using AOP in about 5 or 6 new Projects now. Each time I run into some trouble in the beginning :/ Either there are bugs in some products, other techical issues (modern platforms etc.) or I cannot solve trivial problems which should be in the scope of AOP like the posted issue. Colleagues of mine gave up a long time ago :/
Re: Better singleton aspect [message #1042648 is a reply to message #1042579] Tue, 16 April 2013 13:53 Go to previous message
The best thing to do is to post to the AJ users mailing list, see here: http://eclipse.org/aspectj/userlists.php. And you are correct that not all problems are solvable using AspectJ. However, there is a certain class of problems that it excels at (modularizing crosscutting concerns like security, transactions, logging, etc).
Previous Topic:Plugin class calls logging
Next Topic:classes & methods nale
Current Time: Tue May 28 04:49:02 EDT 2013
Powered by FUDForum. Page generated in 0.04643 seconds
