Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Validating emf model using OAW framework and Check language(provideing external ecore path in workflow file)
Validating emf model using OAW framework and Check language [message #1042397] Tue, 16 April 2013 07:30
Abhijeet Shankargouda is currently offline Abhijeet Shankargouda
Member
Here is the sample workflow file.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<workflow>
<component class="org.eclipse.xtend.check.CheckComponent">
<metaModel class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel" id="mm"/>
<emfAllChildrenSlot value="model"/>
<checkFile value="CheckFile"/>
</component>
</workflow>
It is taking ecore file at runtime from my project, but i want to specify specific ecore, which OAW should refer to validate.
How can i give or provide ecore path externally in workflow file, so that OAW refer while validating my model object.
Abhijith
Previous Topic:Annotation to cause package import
Next Topic:[Edapt] Migrate programmatically - Incorrect strategy?
Current Time: Tue May 28 12:23:02 EDT 2013
Powered by FUDForum. Page generated in 0.01783 seconds
