Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Annotation to cause package import
Annotation to cause package import [message #1041697] Mon, 15 April 2013 08:31 Go to next message
J. Michael Dean, M.D. is currently offline J. Michael Dean, M.D.
In my model I have an operation with a body that uses a
GregorianCalendar (image attached). The generated code is fine except
that there is no import at the beginning of the file, so this method has
an error that I have to manually fix by importing GregorianCalendar.
How can I annotate the model for such a simple thing as making sure that
the generator generates the following in its list of imports?
import java.util.GregorianCalendar;
Thanks for any assistance.
- Mike
  • Attachment: model.tiff
    (Size: 26.20KB, Downloaded 10 times)
Re: Annotation to cause package import [message #1041734 is a reply to message #1041697] Mon, 15 April 2013 09:38 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Mike,
You'd have an easier time if you use Xcore... In general in the bodies
you need to use fully qualified names. You can surround such a name
with <%%> to indicate you want it imported, e.g., <%a.b.C%> will result
in an import of a.b.C and the use of C in the body, assuming there isn't
some other conflicting import of C, in which case the fully qualified
name is used in the body.
> has an error that I have to manually fix by importing GregorianCalendar.
> that the generator generates the following in its list of imports?
> - Mike
Re: Annotation to cause package import [message #1041903 is a reply to message #1041734] Mon, 15 April 2013 14:41 Go to previous message
On 4/15/13 7:38 AM, Ed Merks wrote:
> Mike,
>> - Mike
That worked perfectly (and cleaned up the bodies where I had remembered
to use the fully qualified names). Thank you.
Have not heard of Xcore - barely climbing the initial EMF learning
curve. Will take a look. Thanks for the suggestion.
- Mike
Previous Topic:Annotation to cause package import
Next Topic:Validating emf model using OAW framework and Check language
Current Time: Tue May 28 12:23:24 EDT 2013
Powered by FUDForum. Page generated in 0.06009 seconds
