| PDT [message #715190] |
Fri, 12 August 2011 12:29  |
Bugzy Magro Messages: 10 Registered: August 2011 |
Junior Member |
Please someone help me.
I get this error on starting eclipse:
Error creation extension for extension-point
org.eclipse.php.internal.debug.daemon.communication
Plug-in org.eclipse.php.debug.core was unable to load class
org.eclipse.php.internal.debug.core.zend.communication.DebuggerCommunicationDaemon.
An error occurred while automatically activating bundle
org.eclipse.php.debug.core (16994).
after the IDE would have loaded and be ready for use:
Then when I do:
Window-->preferences-php-->debug
I get:
"The curently displayed page contains invalid values" error
I have tried all updates and error still persists, please someone help me, am I missing a package and what package could it be?
| Re: PDT [message #718628 is a reply to message #716769] |
Wed, 24 August 2011 17:42   |
Anttix Messages: 1 Registered: August 2011 |
Junior Member |
Thank You for the tip Toshihiro.
I had a similar problem when m2eclipse plugin started throwing errors in POM editor after I installed wtp. I removed the following conflicting files from my ~/.eclipse/*/plugins :
javax.xml_1.3.4.v201005080400.jar
org.apache.xerces_2.9.0.v201005080400.jar
org.apache.xml.resolver_1.2.0.v201005080400.jar
org.apache.xml.serializer_2.7.1.v201005080400.jar
And it works now!
Running on Fedora 15 with eclipse-platform-3.6.2-5.fc15.x86_64 and eclipse-dtp-1.8.2-1.fc15.noarch
[Updated on: Wed, 24 August 2011 17:49] Report message to a moderator
| Re: PDT [message #894203 is a reply to message #716627] |
Sat, 07 July 2012 11:16   |
prbhas raju Messages: 8 Registered: July 2012 |
Junior Member |
@Bugzy Magro
Hi, I was tried through "Install new Software" to install a Plugin Tool for UML(eUML2 provided by soyatec.com). But it shows Unable to connect the site connection refused. Even i tried to instll from downloads.eclipse.com but getting same error. How do install new plugins to Eclipse Helios in Fedora15.
Thanks in Advance.
[Updated on: Sat, 07 July 2012 11:16] Report message to a moderator
| Re: PDT [message #1041576 is a reply to message #715190] |
Mon, 15 April 2013 05:10  |
Paul van Erk Messages: 1 Registered: April 2013 |
Junior Member |
The problem suddenly occured for me.
This fixed it for me.
Run > Skip all breakpoint. Close Eclipse, start eclipse and I could start the project again.
FUDForum. Page generated in 0.03053 seconds
