| [ETL] using generated EMF code instead of dynamicEObjects [message #1039463] |
Fri, 12 April 2013 03:39  |
Balázs Grill Messages: 4 Registered: July 2009 |
Junior Member |
Hi!
Is it possible to tell the transformation (called from an ant script) to create the output model using the generated EMF classes instead of DynamicEObjectImpl?
I'm using a custom, domain-specific persistence, which requires to be called with the proper java interfaces, but it is called with dynamic eobjects, despite I'm using metamodels registered by the platform.
Balázs;
FUDForum. Page generated in 0.01557 seconds
