Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Equality, hashcodes, EMF and Hibernate
Equality, hashcodes, EMF and Hibernate [message #1040657] Sat, 13 April 2013 20:09 Go to next message
J. Michael Dean, M.D. is currently offline J. Michael Dean, M.D.
I KNOW that this has been addressed before somewhere, but remain at an
impasse. EMF framework depends on user not overriding the
equal/hashCode methods of objects, and Hibernate encourages overriding
these methods. The main purpose from Hibernate standpoint is assuring
that Java equality not override SQL record equality.
In EMF model, I have an object (Patient) that contains clinical
decisions made about the patient (Decisions). I do not want duplicate
decisions in my database, and these are defined as decisions with the
same attribute A and attribute B.
In my eCore model I have added attributes A and B to the EKeys property
of the relation between Patient and Decisions. But I can add objects
all day long and there is no error or prevention.
I really appreciate your help. I am a newbie to this, but have tried
hard to find the answer.
- Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040780 is a reply to message #1040657] Sun, 14 April 2013 01:07 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Mike,
You can use Diagnostician.INSTANCE to validate your instances. Of
course even if you could override equals, there would be nothing to
prevent logic that added a Decision and then changed the A and B
attribute values to cause a duplicate. I.e., this isn't a constraint
you can generally expect to be always fail fast enforceable so better to
assume you need to do a validity check at some point, i.e., before saving.
> property of the relation between Patient and Decisions. But I can add
> objects all day long and there is no error or prevention.
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040784 is a reply to message #1040657] Sun, 14 April 2013 01:07 Go to previous messageGo to next message
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040788 is a reply to message #1040657] Sun, 14 April 2013 01:07 Go to previous messageGo to next message
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040792 is a reply to message #1040657] Sun, 14 April 2013 01:07 Go to previous messageGo to next message
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040796 is a reply to message #1040657] Sun, 14 April 2013 01:07 Go to previous messageGo to next message
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040800 is a reply to message #1040657] Sun, 14 April 2013 01:07 Go to previous messageGo to next message
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040804 is a reply to message #1040657] Sun, 14 April 2013 01:07 Go to previous messageGo to next message
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040809 is a reply to message #1040657] Sun, 14 April 2013 01:07 Go to previous messageGo to next message
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1041211 is a reply to message #1040657] Sun, 14 April 2013 16:21 Go to previous message
Martin Taal is currently offline Martin Taal
Hi Michael,
EKeys are not transferred to the hibernate mapping. You can define/use the jpa unique constraint annotation for this, so
the unique constraints are enforced by the model then.
I would only override the equals/hashcode methods if you have a direct need for that.
gr. Martin
On 04/14/2013 02:09 AM, J. Michael Dean wrote:
> I KNOW that this has been addressed before somewhere, but remain at an impasse. EMF framework depends on user not
> overriding the equal/hashCode methods of objects, and Hibernate encourages overriding these methods. The main purpose
> from Hibernate standpoint is assuring that Java equality not override SQL record equality.
> In EMF model, I have an object (Patient) that contains clinical decisions made about the patient (Decisions). I do not
> want duplicate decisions in my database, and these are defined as decisions with the same attribute A and attribute B.
> In my eCore model I have added attributes A and B to the EKeys property of the relation between Patient and Decisions.
> But I can add objects all day long and there is no error or prevention.
> I really appreciate your help. I am a newbie to this, but have tried hard to find the answer.
> - Mike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Previous Topic:[Resolve][Teneo] - Howto copy EMF model from one database to another one
Next Topic:Annotation to cause package import
Current Time: Tue May 28 12:25:15 EDT 2013
Powered by FUDForum. Page generated in 0.01884 seconds
