Home » Modeling » UML2 » Magicdraw EMF UML2 export(Magicdraw EMF UML2 export)
Magicdraw EMF UML2 export [message #1037970] Wed, 10 April 2013 04:33 Go to next message
Benoit Lelandais is currently offline Benoit Lelandais
We use Magicdraw 17.0.1 and export our model in "EMF UML v3.x". Then, we load the "*.uml" files in Eclipse to transform the model and generate code.
It works fine with Eclipse 3.7 and MDT UML2 3.0.0.
With Eclipse 3.8 and MDT UML2 4.0.0 all the comments (instance from uml::Comment) are lost because Magicdraw writes them as XML attributes (body="my comment body") and Eclipse 3.8 needs them as XML elements (<body>my comment body</body>) whereas Eclipse 3.7 can read both.
What can we do ?
Thanks for help.
Re: Magicdraw EMF UML2 export [message #1038171 is a reply to message #1037970] Wed, 10 April 2013 09:50 Go to previous messageGo to next message
Kenn Hussey is currently offline Kenn Hussey
This sounds like a regression. Could you open a bug report and attach a
representative sample?
Kenn
On 13-04-10 4:33 AM, Benoit Mising name wrote:
> What can we do ?
> Thanks for help.
Re: Magicdraw EMF UML2 export [message #1038219 is a reply to message #1038171] Wed, 10 April 2013 11:12 Go to previous messageGo to next message
Done.
Bug 405374.
Thanks for your answer.
Re: Magicdraw EMF UML2 export [message #1038407 is a reply to message #1037970] Wed, 10 April 2013 16:46 Go to previous messageGo to next message
If you're using legacy formats you should use 4.0.2 rather than 4.0.0.
Probably won't help with the comment problem but it may avoid other
known issues.
Ed Willink
On 10/04/2013 09:33, Benoit Mising name wrote:
> generate code.
> What can we do ?
> Thanks for help.
Re: Magicdraw EMF UML2 export [message #1038851 is a reply to message #1038407] Thu, 11 April 2013 08:28 Go to previous message
We are now in 4.0.2 and we have integrated the bug correction provided by Kenn.
It works fine. Perfect.
Thanks a lot.
Previous Topic:Re: Specifying derived values in a UML model
Next Topic:How to register a UML Profile
Current Time: Tue May 28 17:34:04 EDT 2013
Powered by FUDForum. Page generated in 0.07954 seconds
