Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF] Generated MDForms Field(Form fields use KeyListener)
[EEF] Generated MDForms Field [message #1037912] Wed, 10 April 2013 02:54
John Mark is currently offline John Mark
I am using EEF to generate Master detail forms.
The generated code looks like this -
		name.addKeyListener(new KeyAdapter() {
			 * @see org.eclipse.swt.events.KeyAdapter#keyPressed(org.eclipse.swt.events.KeyEvent)
			@SuppressWarnings("synthetic-access")
			public void keyPressed(KeyEvent e) {
				if (e.character == SWT.CR) {
					if (propertiesEditionComponent != null)
						propertiesEditionComponent.firePropertiesChanged(new PropertiesEditionEvent(ProjectPropertiesEditionPartForm.this, Fusion_portalViewsRepository.Project.Properties.portalName, PropertiesEditionEvent.COMMIT, PropertiesEditionEvent.SET, null, portalName.getText()));
Here the user is forced to press the Return key for the input to be accepted. Any reason the modifyListener is not used instead?
Is there any way to change the code generation to change this?
[Updated on: Wed, 10 April 2013 02:55]
Report message to a moderator
Previous Topic:EPackageImpl.ePackageExtendedMetaData.nameToClassifierMap not updated when classifier removed
Next Topic:Using EMFStore Navigator with model that has been modified programmatically
Current Time: Tue May 28 12:27:38 EDT 2013
Powered by FUDForum. Page generated in 0.01470 seconds
