| Error creating a web service using JBossWS and JBoss [message #998085] |
Wed, 09 January 2013 05:48  |
Marwa Ahmad Messages: 2 Registered: January 2013 |
Junior Member |
I have Eclipse Helios SP2, Build id: 20110218-0911.
My issue is, when I create a web service from a java class annotated as a webservice and contains a public method, using JBoss AS 6.0 as web server and JbossWS as WS runtime, i got the error msg: "The system cannot find the path specified"!.
Although, I have added a JBossWS Runtime from the preferences->Web services->JBossWS preferences and refer to the installed JBoss server directory.
FYI: Option Generate WSDL file and update web.xml schema were checked while creating a WS from the java class.
Do you have any idea why did this error appear, did i miss any configuration in eclipse?
Thanks in advance,
Marwa Ahmad
FUDForum. Page generated in 0.02003 seconds
