Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EPackageImpl.ePackageExtendedMetaData.nameToClassifierMap not updated when classifier removed
EPackageImpl.ePackageExtendedMetaData.nameToClassifierMap not updated when classifier removed [message #1030950] Sun, 31 March 2013 21:45 Go to next message
David Rees is currently offline David Rees
Member
When EPackageImpl.getEClassifiers().remove(EClassifier) is called, the underlying EPackageImpl.ePackageExtendedMetaData.nameToClassifierMap does not have its corresponding entry deleted.
So when I later try to load a model using the modified EPackage I get a BasicIndexOutOfBoundsException in BasicExtendedMetaData$EPackageExtendedMetaDataImpl.getType(String) line: 2173. In particular the problem is the following lines which assume the nameToClassifierMap's size is less than or equal to the eClassifier's size. Unfortunately because the entries were not deleted the nameToClassifierMap is actually larger than the eClassifiers.
if (nameToClassifierMap.size() != size)
for (int i = 0; i < originalMapSize; ++i)
EClassifier eClassifier = eClassifiers.get(i);
Am I using things somehow incorrectly? I know we can't change a metamodel once it's model is loaded, but I had assumed that we should be able to modify a loaded metamodel before we load the model.
If we are using it correctly then it I guess the EPackageExtendedMetaDataImpl should be updated to register for notifications on eClassifiers so it can delete entries when needed.
dave
Eclipse Modeling Framework Runtime and Tools
Version: 2.9.0.v20130204-1146
Build id: S201302041146
Re: EPackageImpl.ePackageExtendedMetaData.nameToClassifierMap not updated when classifier removed [message #1031034 is a reply to message #1030950] Mon, 01 April 2013 00:41 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
David,
Comments below.
It's not updated when you rename something either, nor are things like
org.eclipse.emf.ecore.impl.EPackageImpl.eNameToEClassifierMap
Perhaps. These types of things aren't expected to be used on a model
that mutates and a model that's been used to create instances isn't
expected to mutate once it's used in that way.
> we load the model.
Before it's used to create instances (with loading just being one of those).
What are you using extended meta data for? How are you using it in
combination with deleting classifiers from a package (or renaming them,
or deleting/renaming features in a class, all of which will have similar
issues). The list of all the things that are cached and affected by
arbitrary changes you make to the model is very long...
If you use this constructor you can flush the map (or create a new
instances) whenever you make these types of changes.
org.eclipse.emf.ecore.util.BasicExtendedMetaData.BasicExtendedMetaData(String,
Registry, Map<EModelElement, EAnnotation>)
> dave
Re: EPackageImpl.ePackageExtendedMetaData.nameToClassifierMap not updated when classifier removed [message #1031364 is a reply to message #1031034] Mon, 01 April 2013 12:19 Go to previous messageGo to next message
Member
Ed Merks wrote on Mon, 01 April 2013 00:41
> we load the model.
To be clear, we haven't used the metamodel yet to create model instances when we do the remove. It's something like this...
// load the metamodel
XMLResource resource = new XMIResourceImpl(metamodelURI);
resource.load(null);
// then get its package
EPackage epackage = resource.getContents().get(0);
// then delete a class from it, here I am just removing the first class, but we actually remove a few based on their name
epackage.getEClassifiers().remove(0);
// then try to load a model using that epackage
        XMLResource resource = new XMLResourceImpl();
        ExtendedMetaData extendedMetaData = BasicExtendedMetaData.INSTANCE;
        extendedMetaData.putPackage(null, defaultEPackage);
        resource.getDefaultLoadOptions().put(XMLResource.OPTION_EXTENDED_META_DATA, extendedMetaData);
        resource.getDefaultLoadOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE, Boolean.TRUE);
        resource.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LEXICAL_HANDLER, Boolean.TRUE);
        ResourceSet resourceSet = new ResourceSetImpl();
        resourceSet.getResources().add(resource);
Unfortunately simply replacing the BasicExtendedMetaData won't make a difference, because by default BasicExtendedMetaData.extendedMetaDataHolderCache is null so the EPackageExtendedMetaDataImpl is actually stored inside EPackageImpl.ePackageExtendedMetaData. So even a new BasicExtendedMetaData will still get the same EPackageExtendedMetaDataImpl for that package.
That said, if instead of using BasicExtendedMetaData.INSTANCE I use an instance of this simple subclass things seems to be work. Though I am not 100% sure why yet...
public class CacheUsingBasicExtendedMetaData extends BasicExtendedMetaData {
    public CacheUsingBasicExtendedMetaData() {
        super();
        extendedMetaDataHolderCache = new HashMap<EModelElement, Object>();
I had thought in addition to introducing the CacheUsingBasicExtendedMetaData I would have to add a cache reset after the class deletes, but it works without doing that for some reason (and I don't like fixes that magically work Smile.
Thanks for your help on this,
dave
Re: EPackageImpl.ePackageExtendedMetaData.nameToClassifierMap not updated when classifier removed [message #1031731 is a reply to message #1031364] Tue, 02 April 2013 02:05 Go to previous messageGo to next message
David,
Comments below.
>> the > underlying
>> EPackageImpl.ePackageExtendedMetaData.nameToClassifierMap > does not
>> like org.eclipse.emf.ecore.impl.EPackageImpl.eNameToEClassifierMap
>> > Am I using things somehow incorrectly? Perhaps. These types of
>> things aren't expected to be used on a model that mutates and a model
>> that's been used to create instances isn't expected to mutate once
>> before > we load the model.
>> those).
>> > If we are using it correctly then it I guess the >
>> EPackageExtendedMetaDataImpl should be updated to register for >
>> them, or deleting/renaming features in a class, all of which will
>> have similar issues). The list of all the things that are cached and
>> affected by arbitrary changes you make to the model is very long...
That's all very normal although this would only work well if the model
doesn't have relative references to other models.
Are you using extended meta data in some way during this removal
process? I don't see how there would otherwise be stale cached
information in the model at this point unless there's more going on than
what you've shown here.
> extendedMetaData);
> Boolean.TRUE);
> Boolean.TRUE);
That's why I specifically mentioned that particular constructor.
> super();
> Object>();
> reason (and I don't like fixes that magically work :).
Well, what you show avoids using the internally cached data, but from
you show, it's not clear what's causing the internally cached data to be
cached in the first place...
> dave
Re: EPackageImpl.ePackageExtendedMetaData.nameToClassifierMap not updated when classifier removed [message #1034759 is a reply to message #1031731] Fri, 05 April 2013 17:33 Go to previous messageGo to next message
Member
Ed Merks wrote on Tue, 02 April 2013 02:05
David,
It looks like the EMF BasicValidator class accesses the extended metadata to get the DocumentRoot as part of loading the metamodel. In fact, it accesses ExtendedMetaData.INSTANCE (so there is no way to override it). Here is the stack:
Thread [main] (Suspended)
	BasicExtendedMetaData$EPackageExtendedMetaDataImpl.getType(String) line: 2146
	BasicExtendedMetaData.getType(EPackage, String) line: 108
	BasicExtendedMetaData.getDocumentRoot(EPackage) line: 130
	FeatureMapUtil$BasicValidator.<init>(EClass, EStructuralFeature) line: 1555
	FeatureMapUtil.getValidator(EClass, EStructuralFeature) line: 1706
	BasicFeatureMap.<init>(InternalEObject, int) line: 48
	AnyTypeImpl.getMixed() line: 90
	SAXXMIHandler(XMLHandler).<init>(XMLResource, XMLHelper, Map<?,?>) line: 438
	SAXXMIHandler(XMIHandler).<init>(XMLResource, XMLHelper, Map<?,?>) line: 49
	SAXXMIHandler.<init>(XMLResource, XMLHelper, Map<?,?>) line: 33
	XMILoadImpl.makeDefaultHandler() line: 33
	XMILoadImpl(XMLLoadImpl).load(XMLResource, InputStream, Map<?,?>) line: 139
	XMIResourceImpl(XMLResourceImpl).doLoad(InputStream, Map<?,?>) line: 253
	XMIResourceImpl(ResourceImpl).load(InputStream, Map<?,?>) line: 1529
	XMIResourceImpl(ResourceImpl).load(Map<?,?>) line: 1308
It's also accessed by the SAXMLHandler in createDocumentRoot. In that case it uses the BasicExtendedMetaData that was passed to it in the load options. So by overriding it in the load the user is actually causing two different ExtendedMetaDatas to be used depending on the call path. That doesn't seem correct, does it? Even though I think that is what is causing my code to magically work when I switch to my own ExtendedMetaData instance (the caching that causes the problem is done in the ExtendedMetaData.INSTANCE rather than mine).
Thread [main] (Suspended (breakpoint at line 2146 in BasicExtendedMetaData$EPackageExtendedMetaDataImpl))
	SAXXMIHandler(XMLHandler).createDocumentRoot(String, String, String, EFactory, boolean) line: 1379
	SAXXMIHandler(XMIHandler).createDocumentRoot(String, String, String, EFactory, boolean) line: 108
	SAXXMIHandler(XMLHandler).createObjectByType(String, String, boolean) line: 1326
	SAXXMIHandler(XMLHandler).createTopObject(String, String) line: 1475
	SAXXMIHandler(XMLHandler).processElement(String, String, String) line: 1026
	SAXXMIHandler(XMIHandler).processElement(String, String, String) line: 77
	SAXXMIHandler(XMLHandler).startElement(String, String, String) line: 1008
	SAXXMIHandler(XMLHandler).startElement(String, String, String, Attributes) line: 719
	SAXXMIHandler(XMIHandler).startElement(String, String, String, Attributes) line: 163
	SAXParserImpl$JAXPSAXParser(AbstractSAXParser).startElement(QName, XMLAttributes, Augmentations) line: 501
	XMLDTDValidator.startElement(QName, XMLAttributes, Augmentations) line: 767
	XMLDocumentScannerImpl(XMLDocumentFragmentScannerImpl).scanStartElement() line: 1363
	XMLDocumentScannerImpl$ContentDriver.scanRootElementHook() line: 1315
	XMLDocumentScannerImpl$ContentDriver(XMLDocumentFragmentScannerImpl$FragmentContentDriver).next() line: 3104
	XMLDocumentScannerImpl$PrologDriver.next() line: 921
	XMLDocumentScannerImpl.next() line: 647
	XMLDocumentScannerImpl(XMLDocumentFragmentScannerImpl).scanDocument(boolean) line: 511
	XIncludeAwareParserConfiguration(XML11Configuration).parse(boolean) line: 808
	XIncludeAwareParserConfiguration(XML11Configuration).parse(XMLInputSource) line: 737
	SAXParserImpl$JAXPSAXParser(XMLParser).parse(XMLInputSource) line: 119
	SAXParserImpl$JAXPSAXParser(AbstractSAXParser).parse(InputSource) line: 1205
	SAXParserImpl$JAXPSAXParser.parse(InputSource) line: 522
	SAXParserImpl(SAXParser).parse(InputSource, DefaultHandler) line: 395
	XMILoadImpl(XMLLoadImpl).load(XMLResource, InputStream, Map<?,?>) line: 175
dave
Re: EPackageImpl.ePackageExtendedMetaData.nameToClassifierMap not updated when classifier removed [message #1034960 is a reply to message #1034759] Sat, 06 April 2013 01:14 Go to previous message
David,
Comments below.
>> David,
>> model doesn't have relative references to other models.
>> than what you've shown here.
>> be cached in the first place...
> line: 2146
> line: 1555
Sure for the model of the XMLTypePackage.
> line: 438
> line: 49
> line: 139
> line: 253
Yes for the model of the instance being loaded.
We'd not allow more than one instance ever to be created if it wasn't
okay to do so.
> than mine).
> line: 2146
> boolean) line: 1326
> line: 1026
> line: 77
> line: 1008
> line: 767
> line: 1363
> line: 3104
> line: 511
> 808
> line: 737
> 119
> line: 1205
> line: 175
> line: 253
When I set a breakpoint is EPackageImpl.setExtendedMetaData and I load a
*.ecore resource in the Sample Ecore Editor, I don't see that loading
the model causes this to be called on the model being loaded. I.e., in
your logic
I don't think it's called before your "// then delete a class" logic but
rather I suspect something you're doing in that logic is causing it to
be called.
> dave
Previous Topic:[Texo] Persist already deleted objects
Next Topic:[EEF] Generated MDForms Field
Current Time: Tue May 28 12:28:00 EDT 2013
Powered by FUDForum. Page generated in 0.01796 seconds
