Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » [AGR] Hang problem in AGR 4.4
| [AGR] Hang problem in AGR 4.4 [message #103448] |
Sat, 07 July 2007 14:36  |
Barbara Rosi-Schwartz Messages: 448 Registered: July 2009 |
Hello everybody.
I have been trying to run AGR under Europa and TPTP 4.4, but I am having
exactly the same hang problem as that reported by Chalmers Wang in
thread "AGR 4.4 hangs in standard mode". My simple test runs in quick
mode, but hangs at 36% when played back in standard mode.
I see that Chalmers' solution was that of installing the WTP Eclipse
package, but I really do not want to do that as I do not need WTP and I
prefer to stay with the standard Europa distribution.
I have run the Launch Doctor and attempted to run java from the command
line, using the parameters listed in the Launch Doctor's log file, as
Joe recommended.
However my command line java execution returns after a couple of seconds
without doing anything. No errors are generated, no Eclipse workbench is
instantiated and no data directory is created (in my java command line I
have the -data option specified).
What next?
One interesting thing that I noticed is that, in the Launch Doctor's log
file, the same block of information, from "Launch started!" to
"DataProcessors initialised", is repeated twice. Does this mean anything
or is it normal?
TIA,
B.
| Re: [AGR] Hang problem in AGR 4.4 [message #103508 is a reply to message #103448] |
Sun, 08 July 2007 10:58   |
--------------000604000409030903010400
Hi again.
I thought it might be useful if I attached the Eclipse .log file
generated in my workspace's .metadata directory, as there are a few
exceptions from TPTP classes and a ClassCastException from the Launch
Doctor itself.
I have also attached the log from the Launch Doctor, just in case.
Hope this helps in figuring out what is going wrong.
Finally, for completeness, I am using JRE 1.6.0 and the Agent
Controller, running on the same machine, is configured to automatically
start and stop as needed.
B.
name="eclipseLog"
Content-Disposition: inline;
filename="eclipseLog"
!SESSION 2007-07-08 13:14:26.838 -----------------------------------------------
eclipse.buildId=I20070625-1500
java.version=1.6.0
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86 -data c:/projects/agr_test
!ENTRY org.eclipse.jface 2 0 2007-07-08 13:15:39.369
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2007-07-08 13:15:39.369
!MESSAGE A conflict occurred for ALT+SHIFT+R:
Binding(ALT+SHIFT+R,
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.ja va.rename.element,Rename - Refactoring ,
Rename the selected element,
Category(org.eclipse.jdt.ui.category.refactoring,Refactor - Java,Java Refactoring Actions,true),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(com.etish.useme.client.editor.r efactor.rename,Rename,
Rename an artifact,
Category(com.etish.useme.client.editor.category.refactor,Ref actor,Refactoring Commands,true),
,,true),null),
!MESSAGE A conflict occurred for ALT+SHIFT+V:
Binding(ALT+SHIFT+V,
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.ja va.move.element,Move - Refactoring ,
Move the selected element to a new location,
,,true),null),
ParameterizedCommand(Command(com.etish.useme.client.editor.r efactor.move,Move,
Move an artifact to a different location,
,,true),null),
!ENTRY org.eclipse.ui 4 4 2007-07-08 14:03:37.759
!MESSAGE Exception in org.eclipse.ui.internal.PageLayout.addView: org.eclipse.ui.PartInitException: Could not create view: org.eclipse.tptp.monitoring.managedagent.ui.explorer.interna l.ui.MRExplorerView
!STACK 1
at org.eclipse.ui.internal.ViewFactory.createView(ViewFactory.j ava:156)
at org.eclipse.ui.internal.LayoutHelper.createView(LayoutHelper .java:162)
at org.eclipse.ui.internal.PageLayout.createView(PageLayout.jav a:506)
at org.eclipse.ui.internal.PageLayout.addView(PageLayout.java:3 86)
at org.eclipse.ui.internal.PageLayout.addView(PageLayout.java:3 72)
at org.eclipse.ui.internal.registry.PerspectiveExtensionReader. processView(PerspectiveExtensionReader.java:272)
at org.eclipse.ui.internal.registry.PerspectiveExtensionReader. processExtension(PerspectiveExtensionReader.java:118)
at org.eclipse.ui.internal.registry.PerspectiveExtensionReader. readElement(PerspectiveExtensionReader.java:329)
at org.eclipse.ui.internal.registry.RegistryReader.readElements (RegistryReader.java:138)
at org.eclipse.ui.internal.registry.RegistryReader.readExtensio n(RegistryReader.java:149)
at org.eclipse.ui.internal.registry.RegistryReader.readRegistry (RegistryReader.java:170)
at org.eclipse.ui.internal.registry.PerspectiveExtensionReader. extendLayout(PerspectiveExtensionReader.java:82)
at org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:770)
at org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:258)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:146)
at org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:1537)
at org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPage.java:981)
at org.eclipse.ui.internal.WorkbenchPage.access$17(WorkbenchPag e.java:972)
at org.eclipse.ui.internal.WorkbenchPage$18.run(WorkbenchPage.j ava:3560)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:3558)
at org.eclipse.ui.internal.Workbench.showPerspective(Workbench. java:2555)
at org.eclipse.tptp.test.auto.gui.internal.actions.AutoGUIRecor dAction.run(AutoGUIRecordAction.java:132)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:443)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
!SUBENTRY 1 org.eclipse.ui 4 0 2007-07-08 14:03:37.759
!MESSAGE Could not create view: org.eclipse.tptp.monitoring.managedagent.ui.explorer.interna l.ui.MRExplorerView
!ENTRY org.eclipse.osgi 2 1 2007-07-08 14:04:20.744
!MESSAGE NLS unused message: AdjustTestCasePropertiesChange_ADJUST_METHOD_NAME_CHANGE in: org.eclipse.hyades.test.tools.core.internal.common.messages
!ENTRY org.eclipse.ui 4 4 2007-07-08 14:05:37.650
!MESSAGE Plug-in 'org.eclipse.tptp.monitoring.instrumentation.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.source.menu' is invalid): org.eclipse.tptp.monitoring.instrumentation.ui.CbeExceptionA ddAction1
!MESSAGE Plug-in 'org.eclipse.tptp.monitoring.instrumentation.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.source.menu' is invalid): org.eclipse.tptp.monitoring.instrumentation.ui.CbeEntryExitD eleteAction
!ENTRY org.eclipse.ui 4 4 2007-07-08 14:05:37.666
!MESSAGE Plug-in 'org.eclipse.tptp.monitoring.instrumentation.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.source.menu' is invalid): org.eclipse.tptp.monitoring.instrumentation.ui.CbeExceptionA ddAction2
!MESSAGE Plug-in 'org.eclipse.tptp.monitoring.instrumentation.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.source.menu' is invalid): org.eclipse.tptp.monitoring.instrumentation.ui.CbeEntryExitA ddAction
!MESSAGE Plug-in 'org.eclipse.tptp.trace.arm.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt..ui.source.menu' is invalid): org.eclipse.tptp.trace.arm.ui.ArmRemovection
!MESSAGE Plug-in 'org.eclipse.tptp.trace.arm.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.source.menu' is invalid): org.eclipse.tptp.trace.arm.ui.ArmAddAction
!ENTRY org.eclipse.ui 4 4 2007-07-08 14:06:26.916
!MESSAGE Plug-in 'org.eclipse.tptp.trace.arm.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.source.menu' is invalid): org.eclipse.tptp.trace.arm.ui.ArmRemovection
!ENTRY org.eclipse.equinox.preferences 4 4 2007-07-08 14:07:21.884
!MESSAGE Extension does not extend class AbstractPreferenceInitializer.
!STACK 0
java.lang.ClassCastException: org.eclipse.tptp.test.launchdoctor.preferences.LaunchDoctorP references cannot be cast to org.eclipse.core.runtime.preferences.AbstractPreferenceIniti alizer
at org.eclipse.core.internal.preferences.PreferenceServiceRegis tryHelper.runInitializer(PreferenceServiceRegistryHelper.jav a:275)
at org.eclipse.core.internal.preferences.PreferenceServiceRegis tryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelp er.java:130)
at org.eclipse.core.internal.preferences.PreferencesService.app lyRuntimeDefaults(PreferencesService.java:337)
at org.eclipse.core.internal.preferences.DefaultPreferences.app lyRuntimeDefaults(DefaultPreferences.java:163)
at org.eclipse.core.internal.preferences.DefaultPreferences.loa dDefaults(DefaultPreferences.java:236)
at org.eclipse.core.internal.preferences.DefaultPreferences.loa d(DefaultPreferences.java:232)
at org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:307)
at org.eclipse.core.internal.preferences.EclipsePreferences.int ernalNode(EclipsePreferences.java:543)
at org.eclipse.core.internal.preferences.EclipsePreferences.nod e(EclipsePreferences.java:662)
at org.eclipse.core.internal.preferences.AbstractScope.getNode( AbstractScope.java:38)
at org.eclipse.core.runtime.preferences.DefaultScope.getNode(De faultScope.java:67)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultP references(ScopedPreferenceStore.java:247)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferen ceNodes(ScopedPreferenceStore.java:281)
at org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet (ScopedPreferenceStore.java:471)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean( ScopedPreferenceStore.java:383)
at org.eclipse.tptp.test.launchdoctor.LaunchDoctor.logMessage(L aunchDoctor.java:46)
at org.eclipse.tptp.test.launchdoctor.LaunchDoctor.logMessage(L aunchDoctor.java:77)
at org.eclipse.tptp.test.launchdoctor.LaunchDoctor.launchStarte d(LaunchDoctor.java:166)
at org.eclipse.hyades.execution.harness.provisional.TestExecuti onHarnessListenerNotifier.notifyLaunchStarted(TestExecutionH arnessListenerNotifier.java:37)
at org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:1918)
at org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$2(TestExecutionHarness.java:1830)
at org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:750)
!ENTRY org.eclipse.update.configurator 2007-07-08 14:07:23.525
!MESSAGE Can't find bundle for base name feature, locale en_GB
!ENTRY org.eclipse.update.configurator 2007-07-08 14:07:25.181
!ENTRY org.eclipse.update.configurator 2007-07-08 14:07:25.994
!ENTRY org.eclipse.update.configurator 2007-07-08 14:07:26.041
!ENTRY org.eclipse.update.configurator 2007-07-08 14:07:26.478
!ENTRY org.eclipse.update.configurator 2007-07-08 14:07:26.603
!ENTRY org.eclipse.update.configurator 2007-07-08 14:07:26.619
!ENTRY org.eclipse.update.configurator 2007-07-08 14:07:26.697
!ENTRY org.eclipse.update.configurator 2007-07-08 14:07:26.978
!ENTRY org.eclipse.update.configurator 2007-07-08 14:07:27.150
!ENTRY org.eclipse.hyades.test.core 1 0 2007-07-08 14:11:32.666
!MESSAGE org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
!STACK 0
at org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:422)
at org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2098)
!MESSAGE java.lang.RuntimeException: org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
!STACK 0
at org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.handleException(TestExecutionHarnessExecutorStub.j ava:347)
at org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:434)
Caused by: org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
... 4 more
!ENTRY org.eclipse.hyades.test.core 4 0 2007-07-08 14:11:32.697
!MESSAGE IWAT4039E The Test Execution Harness reported the following problems:org.eclipse.hyades.internal.execution.local.control .InactiveProcessException
!ENTRY org.eclipse.hyades.test.core 1 0 2007-07-08 15:37:10.400
!STACK 0
!ENTRY org.eclipse.hyades.test.core 1 0 2007-07-08 15:37:10.416
!STACK 0
... 4 more
!ENTRY org.eclipse.hyades.test.core 4 0 2007-07-08 15:37:10.416
name="launch_doctor.log"
filename="launch_doctor.log"
Launch started!
session Created.
test artifacts deployed.
executionEnvironment Adapted. CLASSPATH =3D=20
C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tpt p.platform.j=
vmti.runtime_4.4.0.v200706070100\agent_files\win_ia32;C:\usr \local\opt\ec=
lipse\3.3\eclipse\plugins\org.eclipse.tptp.platform.collecti on.framework_=
4.2.100.v200704140100\hcframe.jar;C:\usr\local\opt\eclipse\3 .3\eclipse\pl=
ugins\org.eclipse.hyades.execution_4.4.0.v200706080100\hexr. jar;C:\usr\lo=
cal\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades.execu tion_4.4.0.v2=
00706080100\hexl.jar;C:\usr\local\opt\eclipse\3.3\eclipse\pl ugins\org.ecl=
ipse.hyades.execution_4.4.0.v200706080100\hexcore.jar;C:\usr \local\opt\di=
taOT\DITA-OT1.3.1\lib;C:\usr\local\opt\ditaOT\DITA-OT1.3.1\l ib\dost.jar;C=
:\usr\local\opt\ditaOT\DITA-OT1.3.1\lib\resolver.jar;C:\usr\ local\opt\dit=
aOT\DITA-OT1.3.1\lib\fop.jar;C:\usr\local\opt\ditaOT\DITA-OT 1.3.1\lib\ava=
lon-framework-cvs-20020806.jar;C:\usr\local\opt\ditaOT\DITA- OT1.3.1\lib\b=
atik.jar;C:\usr\local\opt\ditaOT\DITA-OT1.3.1\lib\xalan.jar; C:\usr\local\=
opt\ditaOT\DITA-OT1.3.1\lib\xercesImpl.jar;C:\usr\local\opt\ ditaOT\DITA-O=
T1.3.1\lib\xml-apis.jar;C:\usr\local\opt\ditaOT\DITA-OT1.3.1 \lib\icu4j.ja=
r;.;C:\Program Files\Java\jre1.6.0\lib\ext\QTJava.zip;C:\usr\local\opt\ec=
lipse\3.3\eclipse\plugins\org.eclipse.core.runtime_3.3.100.v 20070530.jar;=
C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.equ inox.common_3=
=2E3.0.v20070426.jar;C:\usr\local\opt\eclipse\3.3\eclipse\pl ugins\org.ecl=
ipse.osgi_3.3.0.v20070530.jar;C:\usr\local\opt\eclipse\3.3\e clipse\plugin=
s\org.eclipse.core.runtime_3.3.100.v20070530.jar;C:\usr\loca l\opt\eclipse=
\3.3\eclipse\plugins\org.eclipse.equinox.common_3.3.0.v20070 426.jar;C:\us=
r\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.osgi_3.3 .0.v20070530.=
jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\com.ibm.icu _3.6.1.v20070=
417.jar;;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.ec lipse.equinox=
=2Ecommon_3.3.0.v20070426.jar;C:\usr\local\opt\eclipse\3.3\e clipse\plugin=
s\org.eclipse.equinox.common_3.3.0.v20070426.jar;;C:\usr\loc al\opt\eclips=
e\3.3\eclipse\plugins\org.eclipse.core.commands_3.3.0.I20070 605-0010.jar;=
C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.cor e.commands_3.=
3.0.I20070605-0010.jar;;C:\usr\local\opt\eclipse\3.3\eclipse \plugins\org.=
eclipse.jface_3.3.0.I20070606-0010.jar;C:\usr\local\opt\ecli pse\3.3\eclip=
se\plugins\org.eclipse.jface_3.3.0.I20070606-0010.jar;;C:\us r\local\opt\e=
clipse\3.3\eclipse\plugins\org.eclipse.swt.win32.win32.x86_3 .3.0.v3346.ja=
r;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.s wt_3.3.0.v334=
6.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclip se.swt.win32.=
win32.x86_3.3.0.v3346.jar;C:\usr\local\opt\eclipse\3.3\eclip se\plugins\or=
g.eclipse.swt_3.3.0.v3346.jar;;C:\usr\local\opt\eclipse\3.3\ eclipse\plugi=
ns\org.eclipse.emf.common_2.3.0.v200706262000.jar;C:\usr\loc al\opt\eclips=
e\3.3\eclipse\plugins\org.eclipse.emf.common_2.3.0.v20070626 2000.jar;;C:\=
usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.emf.ec ore_2.3.0.v20=
0706262000.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\ org.eclipse.e=
mf.ecore_2.3.0.v200706262000.jar;;C:\usr\local\opt\eclipse\3 .3\eclipse\pl=
ugins\org.eclipse.emf.ecore.xmi_2.3.0.v200706262000.jar;C:\u sr\local\opt\=
eclipse\3.3\eclipse\plugins\org.eclipse.emf.ecore.xmi_2.3.0. v200706262000=
=2Ejar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.ecli pse.hyades.ex=
ecution_4.4.0.v200706080100\hexcore.jar;C:\usr\local\opt\ecl ipse\3.3\ecli=
pse\plugins\org.eclipse.hyades.execution_4.4.0.v200706080100 \hexl.jar;C:\=
usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades .execution_4.=
4.0.v200706080100\hexr.jar;C:\usr\local\opt\eclipse\3.3\ecli pse\plugins\o=
rg.eclipse.hyades.logging.core_4.3.100.v200704140100\hl14.ja r;C:\usr\loca=
l\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades.logging .core_4.3.100=
=2Ev200704140100\hlcommons.jar;C:\usr\local\opt\eclipse\3.3\ eclipse\plugi=
ns\org.eclipse.hyades.logging.core_4.3.100.v200704140100\hlc ore.jar;C:\us=
r\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades.l ogging.core_4=
=2E3.100.v200704140100\hllog4j.jar;C:\usr\local\opt\eclipse\ 3.3\eclipse\p=
lugins\org.eclipse.hyades.logging.core_4.3.100.v200704140100 \config.jar;C=
:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyad es.logging.co=
re_4.3.100.v200704140100\hl14.jar;C:\usr\local\opt\eclipse\3 .3\eclipse\pl=
ugins\org.eclipse.hyades.logging.core_4.3.100.v200704140100\ hlcommons.jar=
;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hy ades.logging.=
core_4.3.100.v200704140100\hlcore.jar;C:\usr\local\opt\eclip se\3.3\eclips=
e\plugins\org.eclipse.hyades.logging.core_4.3.100.v200704140 100\hllog4j.j=
ar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse. tptp.platform=
=2Elogging.events_4.3.100.v200704140100\tlcore.jar;C:\usr\lo cal\opt\eclip=
se\3.3\eclipse\plugins\org.eclipse.tptp.platform.logging.eve nts_4.3.100.v=
200704140100\hlcbe101.jar;C:\usr\local\opt\eclipse\3.3\eclip se\plugins\or=
g.eclipse.tptp.platform.logging.events_4.3.100.v200704140100 \tlcbe101.jar=
;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tp tp.platform.l=
ogging.events_4.3.100.v200704140100\config.jar;C:\usr\local\ opt\eclipse\3=
=2E3\eclipse\plugins\org.eclipse.tptp.platform.logging.event s_4.3.100.v20=
0704140100\hlcbe101.jar;C:\usr\local\opt\eclipse\3.3\eclipse \plugins\org.=
eclipse.tptp.platform.logging.events_4.3.100.v200704140100\t lcbe101.jar;C=
:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tptp .platform.log=
ging.events_4.3.100.v200704140100\tlcore.jar;C:\usr\local\op t\eclipse\3.3=
\eclipse\plugins\org.eclipse.hyades.test.core_4.2.200.v20070 6050100\hexre=
cr.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.ecli pse.hyades.te=
st.tools.core_4.4.0.v200706050100\common.runner.jar;C:\usr\l ocal\opt\ecli=
pse\3.3\eclipse\plugins\org.eclipse.hyades.test.tools.core_4 .4.0.v2007060=
50100\http.hexrecr.jar;C:\usr\local\opt\eclipse\3.3\eclipse\ plugins\org.e=
clipse.hyades.test.tools.core_4.4.0.v200706050100\http.runne r.jar;C:\usr\=
local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades.tes t.tools.core_=
4.4.0.v200706050100\java.runner.jar;C:\usr\local\opt\eclipse \3.3\eclipse\=
plugins\org.eclipse.hyades.test.tools.core_4.4.0.v2007060501 00\manual.run=
ner.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.ecl ipse.hyades.t=
est.tools.core_4.4.0.v200706050100\common.runner.jar;C:\usr\ local\opt\ecl=
ipse\3.3\eclipse\plugins\org.eclipse.hyades.test.tools.core_ 4.4.0.v200706=
050100\config.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugi ns\org.eclips=
e.hyades.test.tools.core_4.4.0.v200706050100\http.hexrecr.ja r;C:\usr\loca=
l\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades.test.to ols.core_4.4.=
0.v200706050100\http.hextgen.jar;C:\usr\local\opt\eclipse\3. 3\eclipse\plu=
gins\org.eclipse.hyades.test.tools.core_4.4.0.v200706050100\ http.runner.j=
ar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse. hyades.test.t=
ools.core_4.4.0.v200706050100\java.runner.jar;C:\usr\local\o pt\eclipse\3.=
3\eclipse\plugins\org.eclipse.hyades.test.tools.core_4.4.0.v 200706050100\=
manual.runner.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugi ns\org.eclips=
e.hyades.test.tools.core_4.4.0.v200706050100\tools-core.jar; ;C:\usr\local=
\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tptp.platform.m odels_4.3.0.v=
200706132116\fastxpath.jar;C:\usr\local\opt\eclipse\3.3\ecli pse\plugins\o=
rg.eclipse.tptp.platform.models_4.3.0.v200706132116\tptp-mod els.jar;C:\us=
r\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tptp.pla tform.models_=
4.3.0.v200706132116\fastxpath.jar;C:\usr\local\opt\eclipse\3 .3\eclipse\pl=
ugins\org.eclipse.tptp.platform.models_4.3.0.v200706132116\t ptp-models.ja=
r;;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.junit_3. 8.2.v20070611=
1738\junit.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\ org.junit_3.8=
=2E2.v200706111738\junit.jar
c:/tmp/brs/AgrTest/bin
C:/projects/agr_test/AgrTest/bin
C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.equ inox.launche=
r_1.0.0.v20070606.jar
executable Object Adapted
jvmArgs: -Dhyades.runner.agentName=3Dorg.eclipse.hyades.execution.har nes=
s.XMLExecutionDataProcessor -Dtptp.automated.gui=3Dtrue -Dtptp.automated.=
gui.resource.id=3DC4F89239299FB57C66DCE3C02D5311DC -Dtptp.automated.gui.e=
xecutor=3Dorg.eclipse.hyades.execution.harness.XMLExecutionD ataProcessor =
org.eclipse.core.launcher.Main -data "C:\projects\agr_test/../auto-gui-wo=
rkspace"
DataProcessors initialized.
--------------000604000409030903010400--
| Re: [AGR] Hang problem in AGR 4.4 [message #103609 is a reply to message #103508] |
Mon, 09 July 2007 07:10   |
Paul Slauenwhite Messages: 970 Registered: July 2009 |
Hi Barbara,
Unfortunately, TPTP has not declared support for Java 6. That said, we
would still like to confirm if this is a JRE-specific issue so we can
capture the symptom in a defect. Can you try the same scenario with Java 5?
Paul
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:f6qu30$m97$1@build.eclipse.org...
> Hi again.
> Doctor itself.
> B.
> !SESSION 2007-07-08
> java.version=1.6.0
> - Refactoring ,
> ,,true),null),
> Rename an artifact,
> Commands,true),
> ,,true),null),
> - Refactoring ,
> ,,true),null),
> Commands,true),
> ,,true),null),
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> cannot be cast to
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> Caused by:
> at
> ... 4 more
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> Caused by:
> at
> ... 4 more
Launch started!
session Created.
C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tpt p.platform.jvmti.runtime_4.4.0.v200706070100\agent_files\win _ia32;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclip se.tptp.platform.collection.framework_4.2.100.v200704140100\ hcframe.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org .eclipse.hyades.execution_4.4.0.v200706080100\hexr.jar;C:\us r\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades.e xecution_4.4.0.v200706080100\hexl.jar;C:\usr\local\opt\eclip se\3.3\eclipse\plugins\org.eclipse.hyades.execution_4.4.0.v2 00706080100\hexcore.jar;C:\usr\local\opt\ditaOT\DITA-OT1.3.1 \lib;C:\usr\local\opt\ditaOT\DITA-OT1.3.1\lib\dost.jar;C:\us r\local\opt\ditaOT\DITA-OT1.3.1\lib\resolver.jar;C:\usr\loca l\opt\ditaOT\DITA-OT1.3.1\lib\fop.jar;C:\usr\local\opt\ditaO T\DITA-OT1.3.1\lib\avalon-framework-cvs-20020806.jar;C:\usr\ local\opt\ditaOT\DITA-OT1.3.1\lib\batik.jar;C:\usr\local\opt \ditaOT\DITA-OT1.3.1\lib\xalan.jar;C:\usr\local\opt\ditaOT\D ITA-OT1.3.1\lib\xercesImpl.jar;C:\usr\local\opt\ditaOT\DITA- OT1.3.1\lib\xml-apis.jar;C:\usr\local\opt\ditaOT\DITA-OT1.3. 1\lib\icu4j.jar;.;C:\Program
Files\Java\jre1.6.0\lib\ext\QTJava.zip;C:\usr\local\opt\ecli pse\3.3\eclipse\plugins\org.eclipse.core.runtime_3.3.100.v20 070530.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org. eclipse.equinox.common_3.3.0.v20070426.jar;C:\usr\local\opt\ eclipse\3.3\eclipse\plugins\org.eclipse.osgi_3.3.0.v20070530 .jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclips e.core.runtime_3.3.100.v20070530.jar;C:\usr\local\opt\eclips e\3.3\eclipse\plugins\org.eclipse.equinox.common_3.3.0.v2007 0426.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.ec lipse.osgi_3.3.0.v20070530.jar;C:\usr\local\opt\eclipse\3.3\ eclipse\plugins\com.ibm.icu_3.6.1.v20070417.jar;;C:\usr\loca l\opt\eclipse\3.3\eclipse\plugins\org.eclipse.equinox.common _3.3.0.v20070426.jar;C:\usr\local\opt\eclipse\3.3\eclipse\pl ugins\org.eclipse.equinox.common_3.3.0.v20070426.jar;;C:\usr \local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.core.comm ands_3.3.0.I20070605-0010.jar;C:\usr\local\opt\eclipse\3.3\e clipse\plugins\org.eclipse.core.commands_3.3.0.I20070605-001 0.jar;;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.ecli pse.jface_3.3.0.I20070606-0010.jar;C:\usr\local\opt\eclipse\ 3.3\eclipse\plugins\org.eclipse.jface_3.3.0.I20070606-0010.j ar;;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse .swt.win32.win32.x86_3.3.0.v3346.jar;C:\usr\local\opt\eclips e\3.3\eclipse\plugins\org.eclipse.swt_3.3.0.v3346.jar;C:\usr \local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.swt.win32 .win32.x86_3.3.0.v3346.jar;C:\usr\local\opt\eclipse\3.3\ecli pse\plugins\org.eclipse.swt_3.3.0.v3346.jar;;C:\usr\local\op t\eclipse\3.3\eclipse\plugins\org.eclipse.emf.common_2.3.0.v 200706262000.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugin s\org.eclipse.emf.common_2.3.0.v200706262000.jar;;C:\usr\loc al\opt\eclipse\3.3\eclipse\plugins\org.eclipse.emf.ecore_2.3 .0.v200706262000.jar;C:\usr\local\opt\eclipse\3.3\eclipse\pl ugins\org.eclipse.emf.ecore_2.3.0.v200706262000.jar;;C:\usr\ local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.emf.ecore. xmi_2.3.0.v200706262000.jar;C:\usr\local\opt\eclipse\3.3\ecl ipse\plugins\org.eclipse.emf.ecore.xmi_2.3.0.v200706262000.j ar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse. hyades.execution_4.4.0.v200706080100\hexcore.jar;C:\usr\loca l\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades.executi on_4.4.0.v200706080100\hexl.jar;C:\usr\local\opt\eclipse\3.3 \eclipse\plugins\org.eclipse.hyades.execution_4.4.0.v2007060 80100\hexr.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\ org.eclipse.hyades.logging.core_4.3.100.v200704140100\hl14.j ar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse. hyades.logging.core_4.3.100.v200704140100\hlcommons.jar;C:\u sr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades. logging.core_4.3.100.v200704140100\hlcore.jar;C:\usr\local\o pt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades.logging.co re_4.3.100.v200704140100\hllog4j.jar;C:\usr\local\opt\eclips e\3.3\eclipse\plugins\org.eclipse.hyades.logging.core_4.3.10 0.v200704140100\config.jar;C:\usr\local\opt\eclipse\3.3\ecli pse\plugins\org.eclipse.hyades.logging.core_4.3.100.v2007041 40100\hl14.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\ org.eclipse.hyades.logging.core_4.3.100.v200704140100\hlcomm ons.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.ecl ipse.hyades.logging.core_4.3.100.v200704140100\hlcore.jar;C: \usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyade s.logging.core_4.3.100.v200704140100\hllog4j.jar;C:\usr\loca l\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tptp.platform. logging.events_4.3.100.v200704140100\tlcore.jar;C:\usr\local \opt\eclipse\3.3\eclipse\plugins\org.eclipse.tptp.platform.l ogging.events_4.3.100.v200704140100\hlcbe101.jar;C:\usr\loca l\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tptp.platform. logging.events_4.3.100.v200704140100\tlcbe101.jar;C:\usr\loc al\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tptp.platform .logging.events_4.3.100.v200704140100\config.jar;C:\usr\loca l\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tptp.platform. logging.events_4.3.100.v200704140100\hlcbe101.jar;C:\usr\loc al\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tptp.platform .logging.events_4.3.100.v200704140100\tlcbe101.jar;C:\usr\lo cal\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tptp.platfor m.logging.events_4.3.100.v200704140100\tlcore.jar;C:\usr\loc al\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades.test.c ore_4.2.200.v200706050100\hexrecr.jar;C:\usr\local\opt\eclip se\3.3\eclipse\plugins\org.eclipse.hyades.test.tools.core_4. 4.0.v200706050100\common.runner.jar;C:\usr\local\opt\eclipse \3.3\eclipse\plugins\org.eclipse.hyades.test.tools.core_4.4. 0.v200706050100\http.hexrecr.jar;C:\usr\local\opt\eclipse\3. 3\eclipse\plugins\org.eclipse.hyades.test.tools.core_4.4.0.v 200706050100\http.runner.jar;C:\usr\local\opt\eclipse\3.3\ec lipse\plugins\org.eclipse.hyades.test.tools.core_4.4.0.v2007 06050100\java.runner.jar;C:\usr\local\opt\eclipse\3.3\eclips e\plugins\org.eclipse.hyades.test.tools.core_4.4.0.v20070605 0100\manual.runner.jar;C:\usr\local\opt\eclipse\3.3\eclipse\ plugins\org.eclipse.hyades.test.tools.core_4.4.0.v2007060501 00\common.runner.jar;C:\usr\local\opt\eclipse\3.3\eclipse\pl ugins\org.eclipse.hyades.test.tools.core_4.4.0.v200706050100 \config.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org .eclipse.hyades.test.tools.core_4.4.0.v200706050100\http.hex recr.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.ec lipse.hyades.test.tools.core_4.4.0.v200706050100\http.hextge n.jar;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclip se.hyades.test.tools.core_4.4.0.v200706050100\http.runner.ja r;C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.h yades.test.tools.core_4.4.0.v200706050100\java.runner.jar;C: \usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyade s.test.tools.core_4.4.0.v200706050100\manual.runner.jar;C:\u sr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.hyades. test.tools.core_4.4.0.v200706050100\tools-core.jar;;C:\usr\l ocal\opt\eclipse\3.3\eclipse\plugins\org.eclipse.tptp.platfo rm.models_4.3.0.v200706132116\fastxpath.jar;C:\usr\local\opt \eclipse\3.3\eclipse\plugins\org.eclipse.tptp.platform.model s_4.3.0.v200706132116\tptp-models.jar;C:\usr\local\opt\eclip se\3.3\eclipse\plugins\org.eclipse.tptp.platform.models_4.3. 0.v200706132116\fastxpath.jar;C:\usr\local\opt\eclipse\3.3\e clipse\plugins\org.eclipse.tptp.platform.models_4.3.0.v20070 6132116\tptp-models.jar;;C:\usr\local\opt\eclipse\3.3\eclips e\plugins\org.junit_3.8.2.v200706111738\junit.jar;C:\usr\loc al\opt\eclipse\3.3\eclipse\plugins\org.junit_3.8.2.v20070611 1738\junit.jar
C:\usr\local\opt\eclipse\3.3\eclipse\plugins\org.eclipse.equ inox.launcher_1.0.0.v20070606.jar
jvmArgs: -Dhyades.runner.agentName=org.eclipse.hyades.execution.harne ss.XMLExecutionDataProcessor
-Dtptp.automated.gui=true -Dtptp.automated.gui.resource.id=C4F89239299FB57C66DCE3C02D5 311DC
-Dtptp.automated.gui.executor=org.eclipse.hyades.execution.h arness.XMLExecutionDataProcessororg.eclipse.core.launcher.Ma in -data"C:\projects\agr_test/../auto-gui-workspace"DataProcessors initialized.
| Re: [AGR] Hang problem in AGR 4.4 [message #104105 is a reply to message #103987] |
Tue, 10 July 2007 13:11   |
--------------060601040504090601020800
Hi Liz.
Thanks for your message, very happy to hear of your determination... :-)
I have tried executing both a JUnit test and a JUnit plugin test with
TPTP, as you recommended. Both execute successfully.
The JRE I am currently using is 1.5.0_11.
Here are the steps, as best as I can recall, for building the eclipse we
are using:
1) I installed eclipse-jee-europa-win32.zip
2) I ran the update manager and selected the Europa Discovery Site
3) I then selected an almost complete Europa install. The only things
that I did not take were a few or the more esoteric (from our point of
view :-) options. I have included a screenshot of exactly what was NOT
taken.
4) I added AGR of course: org.eclipse.tptp.test.auto-TPTP-4.4.0.zip
5) I added Derby database support: derby_core_plugin_10.2.2.485682.zip
and derby_ui_plugin_1.1.0.zip
6) I added the latest Subclipse from the Tigris update site.
7) We use Glassfish in our development, so I have added support by
downloading an additional server adapter for it via the "New Server
Runtime" wizard.
I have also attached a copy of the installation's configuration details
as displayed in Help --> About --> Configuration Details.
I hope this clarifies things, but let me know if you need any further
information.
Thanks and kind regards,
B.
Liz Dancy wrote:
> Hi Barbara,
> I am very committed to getting to the bottom of this issue for you. I am not
> able to reproduce it on my machines however other users are also reporting
> it. Could you try executing a JUnit test and if that is successful, a Junit
> plugin test with TPTP?
> Furthermore, could you walk me through the setup process you used? Did you
> choose the All-in-one package or the runtimes and/or the update manager? Do
> you have previous versions of the AC installed on your machine? What
> specific JRE are you using?
> Thanks for your help and I will continue working with you until this is
> resolved.
> Sincerely,
> Liz Dancy
> news:f6tsou$hrn$1@build.eclipse.org...
>> Hi Paul.
>> Thanks for your reply. Tried with Java 5 and no joy. Exactly the same
>> symptoms and results as described in my previous message. Any other idea?
>> Thanks and regards,
>> B.
>> Paul Slauenwhite wrote:
>>> Hi Barbara,
>>> we would still like to confirm if this is a JRE-specific issue so we can
>>> 5?
>>> Paul
Content-Type: image/png;
name="updates.PNG"
filename="updates.PNG"
iVBORw0KGgoAAAANSUhEUgAAA8AAAALJCAIAAAD0zN2wAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
/45JREFUeF7s/XuQXNWV54/WfUTcuBH3TvT9p383fjHt6Zkf4O5mHt09+tn3 XtoRE/GbHtOA
3bib6hn3jMfNuBu3sY3BFga3kSgP2OiBsTGIhw20MUVTCJCQkBBQeoKE0BOp 9CypVFUqvUpS
QVGSSiVVVqnuOmfvs/faj3NyZ1Zm1snMb8UO6eTJtfde+7v3yfycleuc83+a mppqYX9f//r9
/CW2oQAUgAJQAApAASgwUwo8/fSPZqpr9AsFshQggBZ/t902l8q8h55d9Pgr HS+tQ4ECUAAK
QAEoAAWgwEwpQDRCTCLgRLEKNqBAThRoUfRMK3X37t6J+C8nzsENKAAFoAAU gAJQoDkVEEBC
ZEJ8AoZuzjWQ51FHAE3rklbngYMDtFLPjZwfOvvx0YGz9BIFCkABKAAFoAAU gAK1V4A4hGiE
mITIhHoHQ+cZJZvTtwigH3roV4Kejx8b3LWrf+vWQ6tXf4gCBaAAFIACUAAK QIGZUoBohJiE
yEQwNLFKc4IaRp1PBVoo/EzpTSdPftTV1U8HybLXN85UthP6hQJQAApAASgA BaCAUoCYhMiE
+IQohXYikSOfKNmcXkUAvX7D7q6uvpUrtrS/sBYFCkABKAAFoAAUqHcFVnVu fPm1t0stVIsP
/MGHf/PNu39WaqFaViP/9P/9j6UW3gjxCVEKsQoAujlRNZ+jlgC9efPeV1/Z iAIFoAAUgAJQ
AArUuwKCno8ePT05ORkIH2RJ9lSL6orhC3revu1IoRB6awGyJHuqRXVFI48+ tZjQeeoff3pl
Xft4z6rxs6vGT795OS6eDXq3ZxVZkj3VorpqIohSANCBUwmz2igQAfT7Hxx4 a9WHS5dsRoEC
UAAKQAEoAAXqXQFBz+fPXSy1CIYWwycO7tp97NzIWKmFalFd0Qhx8IUFc0Z/ /mMq5956LqQI
Y6pFddVEEKUQqyACXRs0RC8hCkiAXvbGByhQAApAASgABaBAAyhAEHzh/Ngn wxdKLVSL6goF
CII/Onv+9OBIqYVqUV3RCEHwSNvdnzx43+jDD449+8i5V54YWf6rj1b8amjl M+4GvUs2ZEn2
VIvq8rkAQIdQHWxqpoAE6BVvbrbKylUfvLdq+/6Vu/cu+fCDjg+f/J9rHvjh O/d//82f3P/m
Y4+988or77pVsAcKQAEoAAWgABSYcQUIgk+cGDp9erjUQrWorvCfIHjf3mP9 fWdKLVSL6opG
CILP/OB7p++7d/hH/3Bu/o/+06f+Vypnn1p45lcPf/TkAr4h3iIbsiR7qkV1 uZIA6JqhIToK
USAVoLet3Hns/d5j2wc2rjzwy8e3tP1D5z/MfvN7d7x++9dfufVv2mfPfvnZ 51bP+GcEHIAC
UAAKQAEoAAUsBQRAnzr1UanFBuh9x3oOn6Jy5PCpq6/+THYRllT27TMA+tT3 vnPq7u+e+f73
ztz7fcElBMqn597LC+0Rb5ENWZI91QJAh2AcbGZKgQigN285QMfem2998OZb W958ewv9u27Z
B71v7x3sOn700NC61Ud+8487fxDT8ze/vvh//E37f/nPz/75Fxf9/d//40sv bxBVVol/o7oL
/9Nv/dY/u34h7RHl/ut/65/91hfvT16q/Wkbv/rbf/fPfuvffe0ZWb2oPQyg QNkKRKsXBQrk
W4GylzcqNrMCBNB03zei4VIL1YquI4y/simKvH//8YMHTxw8eJIY5Y5v/yyj EFuTWWx8gmpR
3aiRt7cQBB+/49vHZ3/n1F3foX8V6xAx00tRFD3Tu8qSalFdwST0L1EKsQpy oGcKFtGvq0AE
0Fu2HiR6fnv1tneisr1zzbZdL287vHTXnvU9mzceXbXi4NOLNn9X0PNX27/8 n58hev7T//TI
n3zuJ3Puf/nt1dupvNNJ/0bV3179088TQN/46Ob1O8VbbX9GAH3z/Hc/XBu/ LFqeuY0A+g+/
2b5r/Rq/cdTgv7njmYCmivYFgyZXgFY7ChTIvQLikxkFCpSggADogYHTpRYB 0GK9EQQTDe/Z
c5RKCEALSypUi+oKoiAI7v/G3x/99reO3/Xt48TQd95hMPSddxj0fOcdZECW ZE+1qG50eMaA
QZRCrAKABsjmR4EIoLduP7h2/Ydr1n+4dv1OKus27Nr38rbdv9q04sUPl766 97lfbb3/h6so
cyOm52f//M+Jnn9K9PzHs+7/y9afUcW4lvx3zfqf/ZkA6A2ytQduFAC9a0Pc eNHy/N//oQDo
9/zGcfv/9q6Od3etD2itaHcwaGYF1qzfiQIFcq5AMx+hGHvZChAEHz9+9tix wVIL1aK6ol8R
gd6zp58KUQvFmDPYhd4VllREBFqAQQTQt/3d0dtvP/atb6nCGVptcwOyp1pU NyYTUXYSqwCg
84OP8CQC6O07D727sWvDxt0bon+jjQOLd7zzwUkqb20+uXLTiTfeO750/cCr a492dPa9+Fbv
b1b2Pre855evH3rk+R1xRVnejVp49AYB0O/RdlR+fJMA6N3v/dNd/5re0uUP //6fpM2Gjcv+
/t8ab32zffdGWVfsF8am2U2PRl2wZv/17cviTrnZzT+O3UCBAj4F9OpVyxgb UCBXCtBnLAoU
KFUBguCBgTNHj54qtVAtqiu6Iwjes2fgw11HqAiAFttusd6lWlRXcAVB8OG/ /duj3/i7/m99
gxcLv6x3yZ5qUV06GGO0iPiEWAUADWzNjwIRQH/44aFNH+zlZf/iHe8/sqbt +5T3vIwyN279
6gv/5a+ivOc//dNHrvvcT/5o1v2/96/v+RdX3XX1H3xv0+a4Iv0blX2bNj92 owDojXs3bt5H
5aEvCIDu2tTxPQLof/ONZZvf3U1lfhSZ/sPbO8hmxTf+HW1/af570f6Ob4gI dNf770fVN21U
xl+aH+2J248i0NH+zf/0XWrzX39z+fu0/dDNhNo3zt/7T9/6o3/2W390+4tx xW+QZRc5JpxB
gQKGAh/s3YgCBXKuwGb6LEWBAqUpQBDc33+6t/dUqYVqUV2x5AiCd+3u37at h4pAZLHtFutd
qkV1iQqoEQHQfX/3t/23/z0vPHODtq13yV4A9MYP9olPafoeJ1YBQOcHH+FJ BNC7ug5v23Fw
647ubTvp34Nbdx7c89K2wAj01p3dVHfbju6k+qIvCIB+fz/tpPLwnwuA3rv1 tbv/bQzQH3wQ
2W977e5/E71cvuXVeP/tBNZ7qZFXvvPHAqC3bOve9shf8oj1N9vJ4ImofQLo jfsS4z+icHXc
ZvzWjY9+sFDU+tJCaoEc+yCyFM6gQAFDAVq9KFAg5wpEH7AoUKA0BQiCj/Se 6uk9UWqhWlRX
LDmC4G3bez/Y2k1FILLY1mWL3NbvxnuoVlQ3JgqC4ANf/SrRcP/X/46yMnq/ /nUqnJ4Fh9Ee
8RbZkCXZUy2qS0ASY0ZUiFUA0MDW/CgQAXTX3iMfdvXsisqR+N+eD1/bse2Z TU/9wxv/g2LP
8T03/vRPfypjz9fe87tX3fn//p1v/tZv/90P5rwo7GWtaOOpLwqA3nxQ7PzZ lwRA79ux/PsC
oLdsPRS9pV4+HPHuTQ/tFvtfv4sAmph4z/af3UL7/+13VrCw9J7tHz715wKg Nx3YKRvnuR+y
69e/Q0HoeP8ffv915iH3FttQ4MMuWvkoUCDXCuA4hQJlKEAQfOjw8UOHj5Ve jlNd0SNB8Adb
Dr+3cT8Vgchi2y3Wu1SL6hJXUBEA3X3r/+j5u78ThdMzveT50MqG7AVAayzp 6iFWAUDnBx/h
SQTQ+/Yf2Xewf//Bo/RvtHGgv2vzwR0vbVv1s7V33/aim7nxv/zO7f+v377t z7740Jr1u+Mq
VPHovgPUApVffUkA9JbD1A6Vx/5CAPT+3W/e++9igN6640j0lnr5SATKtH/7 rsh+5ex/HwP0
3qXfFRu7yT5uJNr54Z64fQLo97v3SGMKV8fpHKrEXe/ZsTfOBvmtf/PNVWQp nEGBAoYC0YpF
gQK5VkB+wIqPWRQoEKYAQfCBgwP7DxylQqDz+OPPuEW8axWqRXXFSiMIfm9T 9+o1u6kIRBbb
brHepVrRBYgH+vcdOEoQvO8rf0Pl4N/cSljM6ZleisIZml6SpahCdekjWgBG 9O9+ADSoNUcK
RAB94GBvT+9JVqIffbrW7d/y0vbXH11/z+3/9H/8Hwv+aNZckff8v0Sx59tu /NL8V5e8H/02
dERUFL8TRRtPtkbJzd98ldo80bP6h39IvPvFRze/e3BfvP1vv7Fs266Bnt4N d/8xmd3y8Lu7
t+165i+jaPHND0f7T7xzzyzBysvupg2KTO/t6hbGbJsAevPhg6r9Gx/r6o77 +uMfvhO58dxf
tj6neic0j3ss+ZcsVIECUAAKQAEoUI8KEATv3d+/d18vFSKOt1Z9YBXiafGu Xfb3U10xZILg
dRv2v/X2TioCkcW2W6x3qRbVFUhAELzjy/9991//971fufUvr/5dhT/7v/o1 XtR+siFLsqda
VJfTBbEKItA54semdyUC6O7uvmMnzhw7fubYibNRoQ26/c3xM90f9m15fVfn rz94+bF1N/7H
Bdf+63uu+vRdn7/hoQceWrJle3diH1cke9FCvP1ElPcsyx/fu3o7xYZ3Dhzb MPePjbtw/JfH
PqCw8aFDUafPRIkZuhBA79vX9/73/0jubP3hfSJ6vav77LHn/ou0nDV3HdX9 ZWtS8X//were
7R/09vKO/v09r767e/veU3JoYoAoUEAvdbVusQEFcqkAfbSiQIESFSAI7trT t3t3D5U0gBbv
WoVqUV2x5AiCV6/du3z5VioCkbOLsKRCtahuDBJnBUBT2fVf/2bvf/uqgC7a cIt6iyxFFaob
k4bkE2IVAHTTU2uOBIgAuudw/5mzn0Rl6JPTZ4fPRCV+KTfUnnj/kNiflCHL WNbq3aVzKnYc
OBtVfL/t38cRaJZucbhXdkS1Tu7haRjv7u8+TjvPdm+R7ew5cHTHu7tlU0cO y0a2HD1OLaiX
stYnZ45HxoaN7kgMDQUKxIsZBQrkXAH+eYttKBCmQJTHvKtn585DVNKIQ7xr FapFdcVXPEHw
m2/vfm3J+1RCsEVY0q/TVIvqiu9ZAdDbbvnyjr/6rzu//NVdf12kkA1ZRvYx QHMOIVYBQIdM
BGxqo0AE0L1Hjo6MXKDyCZVzF0ao0Mtzo5+cGxU7xbsjI+LlaGQWb0R7YmNh SdtRdWlDZmbZ
9sCsGKB3Hhq237Is8RIKQAEoAAWkAuLzFgUKlKAAQfD2nYe3bjtYaqFaVFes N4Lg5St3vdTx
bqmFalHdCBLOXSAIfvcv/isVwcQhhSxFFaorPIkx4wKxCgC6NmiIXkIUiAC6 v//oxbHLY2OX
6d+4XKLtsbFLtBHvj19eFNuRQfyu2KN3mnUTG2VMG7t+/L/HAP3hkXOyBf4u tqFAzRVIFq1a
+diAArlTAJ+WUKAMBaJb0W0/9N6mvaUWqkV1RY8EwT+e//ozz60ttVAtqhuz xCWC4MV/0ko0
/P4tf/1+638LKrf8NdlTLaorCSTmEGIVAHQI2MGmNgpEAD1wdKAwMVEoTBQm JicKkwUqE1To
bzL6pyD+Vf8Is+jd2FL9RWa0J6oVNecrI6d2vbt7V99oqkFaReyHAlVQoApN YmlDgYorID6Q
UaBACQq8v2UPcfCatV2lFqpFdcV6e6b9bcHQpRaqRXUFV9CGYOhSC9USjQgO IX+IVQDQtUFD
9BKiQATQ9PtIiClsoAAUgAJQAApAgfwrMPzxx4KhVVkcb9O/YiOtUC2qKwZ4 /NgxwdCqfOv7
P6dt+ldspBWqRXVFI0NnzgiGVuWl/1+0Tf+KjbRCtagul5pYBQCd/7XXPB5G AE2/jNBaR4EC
UAAKQAEoAAWgQD4VIFYBQDcPnuZ/pBKgV6/ZgQIFoAAUgAJQAApAgXwqAIDO P1M2lYcSoJ96
6qV77vkFChSAAlAACkABKAAF8qYAUQoAuqnwNP+DjQCacvM7Xu7ELyP5ny14 CAWgABSAAlCg
4RW4cmVqvDB5YWzyo5HC4MfjxCdEKcQqAJWGn/o6GiAAuo4mC65CASgABaAA FGhYBSYnpy6N
T4xcmBDcrAoAumGnvJ4HBoCu59mD71AACkABKAAF6lwBijcTN1O82UVnwdAA 6Dqf4cZ0HwDd
mPOKUUEBKAAFoAAUyLkCE5NXBDqrbA0eeEYEOufT1+TuAaCbfAFg+FAACkAB KAAFaqoAhZwJ
nS9eKgh0psDzmeFxKl56RgS6pnODzoIVAEAHSwVDKAAFoAAUgAINp8Dly5d6 DvXs2Xt4psqH
XbsA0A23rBp/QADoxp9jjBAKQAEoAAWgQJoCBNDvbd3169fWh5T2Ze/x0rFi Ey/WuyENChsA
NNZn3SkAgK67KYPDUAAKQAEoAAUqpsAnn4ysfm97UdhVcGxB8+I3N4uSBtNF WwZAV2wu0VAN
FQBA11BsdAUFoAAUgAJQIGcKEEAv79wiMPezf3p7zcqXv/ETxdaIQOdsUcCd 4goAoItrBAso
AAWgABSAAo2qAAfo//SXdx85Mdx7cqT/1CdUjg6O8EJ76C0yOHR8+ODA8P6j H1PpOjJE5cPD
Z7d3n9ly4DSVTXtPbeg6SWXNzuNU3t5+7M0tA1SWv99PZenGvlc2HLnrsXUH Dh9TAH38zCgu
ImzUBdao48oTQO9tu7aF/loXz6DYi1sjF2bWhxkcPrqGAlAACkCBJlPAAmgi 5tMfjw59ctEt
tF+Ukx9dOH7mPBWB1xZV7+n7iHiaCudpImmB0V6A3t97BgDdZOuu7odbFKAl UcZYWWWyDAFo
aZO4U3GXNEDLnq5t21v3k4wBQAEoAAWgQNMrMH7pk+Ez+1wZLIAmLD43eonu MWeVC2OXqdBb
VIbPj1EhwlYwTRgt4tMUmaYiwtIiJi0C0ioUDYBu+pXYIAJkArTFkPHLKgJl KQAtwtQSdyvo
EwC6QRY2hgEFoAAUgAKGAjtX3bml/f+zf/29li4uQBMo0/NNeBEw7QVoxdAc oCkInQHQxNBW
Cgci0FisdadAFkB7YrB721plRNaITCdZF1a4WoGtxtJ4y6BfGUwm2wSgW0Ua hRfWkwi0aMJ8
pYnajpabfkVuGaka7EWy2SbSSfRf3KHbTt1NOByGAlAACkCBplTggyV/c3rf fS5DWwBN6RkK
oMcLkwqjOUOrCLQVhKYItEiPBkA35RJrrkEHALQHZgVIGhArAdPDzCxSfK2g UrK1co0Xt2qA
jttNS6AwkdlsJcUrsTtxjBoIAejFrgfedpprtWC0UAAKQAEoUK8KEEB/dOSh K6Mvvf/yjTwO
nQbQgp7pX7EBgK7XiYff1VEgOwfazTiO4NNKtUjJvOC8aada+PHYaMjEVTV4 xyN1yWGaV6qG
cXFisQi0C9D+dqozK2gVCkABKAAFoEBlFVAAbTG0C9DEygqdFUALhhaZ0IhA V3Zq0Fo9KlD0
IsJ4UDx1oXWxlahhXF5ovycCv/a9Lfz3uvAAtHM7DBaBTrqSYJzulf1OVKF0 gLYTOHCrjnpc
7/AZCkABKNCsCgiAHj/+y6mxVVcuva/i0F6AFtysikjkAEA369rBuD0KZAH0 4lZf0PbatsUp
t5sz48qeCLQdLbYu/isRoDXRxu0WvwSRx5DLAehEPsSicShBASgABaBAnShw 5sQHohAxE0AX
+h+lMlXYXRjdIxg6IwdaxKEVPavrCBGBrpPJh5tVVCAboPmFfAw53QyMOIfZ gFLDxok421f/
8Rxo4xJD+6bQVkUehU7xSiY9s0g6S0OJEZ636bmeUN6W2t9OFacGTUMBKAAF oAAUKEcBumPd
3vcXbXrpljd/8W/oqkECZVEo/CwAujD4T1OTR8bHu2kn3Z1DPYmQHqQiLiIU WRxpN+IAQJcz
K6jTWApkp3BYyQ88YmwnI8fvMftrxQWD/hQORrPJfS7YXTj4HeqKALTuUnTk 8crapcag90tX
43QRX2RaXPho3ZejgrfOa6wVhdFAASgABaDATCpA6EzcvPfNL5/teYKyNaKE jdGXRKFtydCD
/3RpaMWVyRNUiKHf+M2t4qGAHKDdW0FnR6DFbexwF46ZnHv0XUMFwnKga+gQ uoICUAAKQAEo
AAXKUIACzxR1JiCO4PjS+1QEPRM0jx/5CQWeBT1H/8YAPf7x+1eunKNaiqEV QIuLBd3iPkiF
7gMtnkoY/iAVdR/o9mXvCXDHfaDLmG5UmVkFANAzqz96hwJQAApAAShQGQXo MkEqlN9MheiZ
QPnywfsu77lrbPvfUqENemkBNGVCUxCaSJqC1o8/uZgAWjyJUDwzhQO0QOfs JxEeORHdBHr/
0Y/pKSr0KO+iTyLMBuiTQ5eOnblM5bbb5na83FmYmKSNyiiFVqDAtBUAQE9b QjQABaAAFIAC
UGCmFaDMjXee+Y+U2RwVStU48hNFz6MbW6kIhrYAOopDH/8l5XtQXQXQIsVZ FE7MfL94hAp/
lDflb2QD9JtbBqjwR3lzgB78eFwQ89HBS32nLvWe1AUAPdOLC/17FABAY1lA ASgABaAAFKhv
BSgNg0LIp0+9RfQcMXFMz0TMxM0X1/yZKLRNO3kONCVyEE8rehY50EcHRzgo W9vEzaq4AC0S
oFUEesuB01Q27T21oevkmp3HiZ6Xv9/vBWgKVxM0W9ysGBoAXd+rs0G9B0A3 6MRiWFAACkAB
KNA0CvTtWrzp5S9HFwVeej+KMR/5iaLn3uWfpxtxUOl67c+iZOgkDZpsLnTd Qzsp9vyr9lef
fGGFAmhOybRNDG3tEeisws+U9UHYTeFnAmiiZyoExFQEQAt6fnv7sQyA3nXw DAC6aVZrgwwU
AN0gE4lhQAEoAAWgQNMqQKnPx3tepvCzCCqLvGdCZwpL013qBva+Ku4DTffl EHgt4tPiDnf9
fT3Pd7yl7sJB1wIqPk7boFvdURHXDgp6ploKoPf0faQAWoWfFUC/suEIlbse W3fg8DGVwgGA
btqlW78DB0DX79zBcygABaAAFIACkQKL/+e/iC4HjC8cFOFnomcKLV8YPqYE ohC1AGiB14Ke
Kffj5IlTr63arACaUpkFH2cUjs6CntUN7Cj8LADaewUhpXAAoLFkG0MBAHRj zCNGAQWgABSA
As2rAAE05W9Q9jNFoAVAU+yZ4JgrIgCaYs+UDK3omQzOnP1I0LNI4aBAsuJj 7wYRsyiCm8W1
g5S8Yd0B2gJokb8BgG7eNdpwIwdAN9yUYkBQAApAASjQZAoQQE9NnY3yNwb/ iRCZws9da35k
aUAAfXpfRM/E1iL2LAwsgCYOVojs3fBys7h2UISf6R52RM9UKH/DewUhUjia bHk25nAB0I05
rxgVFIACUAAKNI8CBND0XG4VgaZLA+mudi5A035Gz1empqJCAE0pHIvfjMq9 P/41oTBFlEVo
2S30ligq5MzRWdCzAGh+/w3rCsIXVx+a88z7lAOtIt/IgW6etdowIwVAN8xU YiBQAApAASjQ
pAoQFo98srMoQDN6LkxNXRLl408G39u6SxS6F4fiYyLjtCKCzSLerKBZXDgo Ys/WDewA0E26
Lht62ADohp5eDA4KQAEoAAWaQAFK2KBCAB0xdP+jJzZ+LXokofk3fGYf3e2O Mjfo8d1UKOWD
CmVOX7x0+OCR3VQ2b3t35ZrO42fPUBF31VAArYhZQbPFzS46i+QNfg87cQdo Cj8jAt0ES7Lx
h1gdgN7bdu21bXuno97i1pb4r3XxdFqph7pCK69iFRdh+vNStqLV6zqj5ep1 WrYOqAgFoAAU
qIICdLcNii7TnexEEJpu8GxeREipGlHIWXAzQbN4YOHAyV1UjhzdtOfguu4j H9Ct7mh7aOQI
xaRPD50kjO45cVY8FcUqItjshpxF2oZKfRb0bD1CBQBdhflHkzOgQFkATVwi 8Lalxc/J4eDi
tyRyLAXAw7sLVzikzRAb0WNRyPMYlChCxtBU4+EOhwsVaFm9rjNGl3Fykj0p gYOCGRSAAlAg
NwpQdJmgmehZBKHFE1LiKwWJniU6EzRTqvSe7l0dKzb99B/XUJn3yxVU7nt0 OZXZD71OKRwU
h74wtvfc+YNE0oKh1X2dRXqGKiJPw4Vmxc2UuSGSN/gjVAigf/1WN3Kgc7Nw 4EiZCpQB0Bzs
Frd6Q8ThtOS1jAC9lNBzeHfhKlW2zTIAulQRANCuyNmTWNkpDl9asIQCUAAK VEcBYmi6mnD/
+nvF41TEJYObXrqFsjso6izQmZ5dQuXdTeso6kyP/ibapuTp8+eP0aWEW7sG XlyygzCaYJoM
CKOJoU+dOXb4+Bl1Yw0Xmnm82UJnl55FCgcAujrzj1ZrqkB5AO3QrY5Jx5Fj HhS0Q9VJXkKU
nmFVEyPXBlEY2jFxwt/MorVVp46w6GNblA8S+5zRmhHyNu30K3Pgdhc65ySt vjEgEWX3R0mZ
CHGc3zeEZETX0rBF17Jbx8tkDmJ94qZYeox3EpK4uTF7ReciHot2lU1la5t6 y8nMsWplzxGn
XkM63zBMbTMmpabHHDqDAlAAClRNAUp0ptvVCW7e++aXqQiMpojy8s4tdJ+N 7V1bKE+DCtEz
B+joed0nL53pnTi2Z6L9hX3f+fHiBU+9cnpoJzF0/6nj3Uf1beksYlbQLJ7X raBZ3fiZUp9F
9rOiZwB01eYfDddOgTIAOsEijWlEe8kLA1mc/THAGnjnjQLqnW4LTBr1Jud1 xcHKE51I7fMz
cceOpRs+SCPbe7cLEZ1ndrJZ7zCFO36Atk9CEtEisBbbspPov3jM0TvJhpX/ wvVRasgfEtIV
tkcRMBcxorKlwOaav2Ulpxi1is1RKkD78mS4toGTUrtDDz1BASgABaqlAKVE UzSa7mRHsWcK
SNPGqo37qFAEmnKdvQA99MlFQc9HNk9SWfvWRQpFP/DzFxVDUxBaXRfIoTmE m9W1gyL8DICu
1sSj3RoqUA5AS/dEkFQgYJISLSObjCzZO3GENI3t+JhN4DNaMKLISQp2NkBz pLb8lOcCvnSR
tDY5/7vsK2spaZJRWdin3FCXD2Yo4yKjaFUQoetnSU25c6cnwhyF15LvtC6F tNxIG4UYSPgc
lQ3Q7ly7QtXwwENXUAAKQIEqK1AQlwxS7JnQecP2np37DxBA0902BEPzCPS5 8x+p8DPR8/53
rohCDE13hiaGPnayZ2d3FGDmKCwuB1RM/NCL27yF0p3d8vUFnbgPdJUXAJqv rgLTAOjIsThe
mEZsIbjshRgvvGpqTGgrmx1T6dYV1OFdTnU23jHaLtIFa9Y4JTD9dxtRIxWG 1QboIpdrJqPw
zqa61rOo2uEA7ffH54bVadA69E1KdQ8xtA4FoAAUqL0C0YWDRM+U90zoTIXy m6kIhk4DaBF+
VvQsQtHE0JTLQe1QnjRxNqVKV7DgQSq1XxnosVIKlA7QhCmKIVnA1ZeYofMN WCTWSeFwrxfU
JOS0wCApin4qxNQpztIR+a4BVZ7WWuXd9hz4iuqLppysCaV9GjXubbObVa25 /pcE0K4z2WcR
+qxDJUwntxdMmzs2OnMUAXNhqKgVjJoMBGg2QOmIJeZinQRkT7HZoe40UTh1 UoR7JV23Wqnj
D+1AASgABaqiQBR+pgsH+/sieqbgsQBol6HpIkIKUX/yyQjlb1j0TDxNZd+u T/77939N94em
G94Rf69+b/uSt7fSkwup0IZbxFuUb02F7vVBReRei4sXyZ7+JW6m/bQTAF2V yUejNVGgdIA2
MjZYMNVNS5BcYt7xLiIV4yI2ERK0L+Hz/qavcn3FHfTYJYOqEdW8fNcCY9Z7 3KW+Vs+Ne2rH
dK3UiwjlTa8ZlYpBqmZVa6pLw8O06KmFnoakJhO7JM0WkOzdvcjSO0eyoiOO rZ6Wr6ja4iJC
UyV2VsXVLzZHGVNsryXj5MQz1+YUl3Ljl5ocnOgECkABKFCWAjL8TE9IoWRl ulvz/t4zxNB0
Aw3F0CIITfeNpkIbPYeP8/AzkTS9JKSmMnJqim7N8bUfRokclP5BTysUQCyK wGVVCI6/2/bL
5zveon+/PvvndFO8H81/gTYoD4S26d8vf+MntEcYUAFAlzW/qJQLBcoA6Fz4 DSegABSAAlAA
CkABnwJXVPiZiJlu5Ez30CCGJpJWoWi6F8f695a+1fkiXV9IN37e+Nb+N3+z d92Lxyl/Q9Ez
ofPF4anLF6c+Gil8+Xu/XPve2xSE/rArAmgRWvYWwuUvfeXuL/z1nWKDCm38 l7/9kdgmhlbb
dIUiABoLuH4VAEDX79zBcygABaAAFIACrgLx5YOTRyh5g7j56OAIPZdbYTQx NO1/5fXVRM8K
oFct30sATYVIWkSdBTpPFK5MTEwUJsbpkSuUCS0AmrI4RD5G0aL4uOjGroNn +k5dotJ70lNu
u21ux8udhYlJ2sB8Q4GcKACAzslEwA0oAAWgABSAAhVRILp8kPI36OYbJz+6 QGXwzLnjZ84T
Rh85MUzRaAohE0ALhn5x2RtPvLjh189/IOh52/tdlM4xXpgkaL58+dLFsfNU 6NpBytz40ree
oCwOikOLZAyRg+EthNriysXwcnBgGABdkblHIzVTAABdM6nRERSAAlAACkCB aisgE6BPnd1P
/Bo9HuWTi6Kc/niUYJpuHkchZGJoih8TOvOnee/8YA8FmCmj4/TQyY8/GaRC G6Ls7e6+4bbH
KFuariak1AtKZf78f78vrRBeD348LsqJocsnhy7Rv6ocO3NZlKODl1QR9IwI dLUXB9qvoAIA
6AqKiaagABSAAlAACsysAhKg6YI/AugLY5dFOTd6iQrxNKEwhZNFGgYBNCVJ E1vTzTHo8d0U
WqYAMxW61R3d+NkqBNDiXQowU1ozMXRaAUDP7ApA77VRAABdG53RCxSAAlAA CkCBGiggAZog
mACaMpitv55DPRRmphJlbry2fmLyyqXxCQJrAuh5v5QATe+eHOyjwhn6T2/9 OdHzu5vW/ar9
VXGTjbRC99lABLoGM40uZlYBAPTM6o/eoQAUgAJQAApUUAEN0JQDHV0FWIgQ ma4IpHJhbPLg
gaOU6LzxvX0if4MuMaR3CbVFBJr4mArBtwBoXgRAU4IH3YSOsjgycqDFnezE hYN0q7vjZ0at
IjI3+k+OugUXEVZwKaCpqioAgK6qvGgcCkABKAAFoEAtFdApHATQ589NUfn4 46icHowKPRiF
7rlBhS4cFAnQRNJEz1Qov1kANAWeT505JopgaHogiwJouvqQsjgozJxWKDJN hE02VKh9yhKh
6xepDBz/qPfkCP1L1zJ6C/E0ALqWawV9TUcBAPR01ENdKAAFoAAUgAJ5UyC6 CwddREgBYAHN
VPr7orJ/b1TaX9hH5fFHd4sgtEjeICwW9Ey3iFbXDiqMppxpAmi6iJAMRAQ6 HKDJ/vCRwYzS
e3SICiE1ADpvKwn+ZCgAgMbygAJQAApAASjQSArI+0ATQH+45xOOzlven6Ly cscQ0TMVAc2U
8Uz/ivxmytDoP3VcAbTYIIwmwqbEjD0H1z2/+DW6RvAv/+b+L/z1nBv+8w9F oW1RaD8VuriQ
R6ApM4T4e9/ePqtQMgndEoTAWtEz7sLRSKuw4ccCgG74KcYAoQAUgAJQoKkU kE8iJGx9cfUh
EXUW6Exl5fKJV1++QgxNKRwiZ0Pcuk4ANCVviHvYnTn7EcdoehIhoTOZiSsI CZHpgYJUBDGL
bX5TDgugKQhN98hTpWvHQYJpAmhBz5TXQbFn3MauqdZoAwwWAN0Ak4ghQAEo AAWgABRQCsg0
aHpwIGVoKHRe+9ZFQc9UaJsuHKRsDSp0Xw66t524dR0FmwU3c4Z+bdVmuocd hZ8JsomMKcVZ
cLMqAqA5Q1OCB1kqjKZkaIp208WLVAQ9U+xZBZ7pgkLcBxrLt+4UAEDX3ZTB YSgABaAAFIAC
2QpEWRxXJk90rNj0j6/sIYa26HnTprMUACZiJlAWTxwkdKaXdL2gCjwLhqaM Dgo/U+C5+8gH
IgH68ScXp5XnnlvmFqpChQCaItBEzzzwjAepYB3XrwIA6PqdO3gOBaAAFIAC UMCrgH4eIaUv
U8KGij3TBtEz3RmDAs+EywqgiZsFQKsgtIhDU3UCaHqI99CZnqN9xwh/D+45 RGXP3sNphSjZ
LWRMgWd6TrgIPPPHECICjUVcjwoAoOtx1uAzFIACUAAKQIGgIDTlZtB9Noih KXOD6JlC0QTQ
xLJ0ZzrC5XPnP6IINBViZXXXZ8XQ9ITCL33rCYo9nz9/TASk6SZ0IUXcWMMt 4lYbRMx4lDeW
b70rAICu9xmE/1AACkABKAAFDAWuXJmiMjUlEznoYkFi6Gd/MyDomcLPFEgm gCZQtgCaB6Hp
Jnd06zqqS6kgY5c/EU8C/2ikIMqZ4XFdPh478/EYPX3w9EdjopwcuiTKiaHL 9K96kApxsyo8
CI0caKzgulMAAF13UwaHoQAUgAJQAAqkKiDomQo9prswMS6SoeliwdkPvU7X FKr8DXHDDQHQ
ZEYbKg2arin8zo8XU+yZagl6vjB2eeTChCiKof0wPTyunuNNGwKg6V9VANBY u42hAAC6MeYR
o4ACUAAKQAEoECmg6JkAemJiQjE03ZSDEpqJjCm0/N7W6J4bCqDJjACaXi7v 3EI2dM8NuoHG
ufMHXXoGQGORQQGhAAAaKwEKQAEoAAWgQIMoIOh5cjIKP8vCGHpq8gjdy5kQ +Ws//DWRNOV1
EEwvfnMz7aFtCjkTOtMt5yjwTPSs8p4Hz5yjvOejgyO0YRWVs0EbPPCsthGB bpCFhWE4CgCg
sSigABSAAlAACjSCApT2rOh5vDB58VKBspY/+WSELv47eeJUVAb76GYaw2f2 UTSaSPrFZW/w
QntGPtlJ7545deDkQDfdpoPutqHup0Hb4uknVOhmGvQMlL7+01TUNYVE2FSO nzkfl1GeA40U
jkZYXhiDqQAAGisCCkABKAAFoEAjKKDCz0TPlLVM9CzQmXhX3HuOCmFxdP+N gW4qBMq8iJ30
rkJnunOzePqJuIVzdBdnE6OpZY7R/ac+4Qwtrh1EDnQjrC2MARForAEoAAWg ABSAAo2ngAo/
y/yNiYlL4xMCo0UQmkLFBLt0L2dRCJTdItCZB57FgwNF7JlwWRQBzUXDz+ou HIhAN956w4gQ
gcYagAJQAApAAShQ9wqo8LORAJ1kQlNMmniaCuV1EFVTodvSiTvTiTL0ycXT H4+6Wc5qz8mP
LsiM549HVeoz3b1OlviudpT6LP5FDnTdrycMoJgCAOhiCuF9KAAFoAAUgAL5 VkDduo7oOQ2g
iaFVETDNC4F1zNaU+6GLunUd38Bt7PK9FuBdjRQAQNdIaHQDBaAAFIACUKBK CgCgqyQsmoUC
aQoYAP3ss8+jQAEoAAWgABSAAlAgPwrcdtvcjpc7CxOTtAGegwI5UQAR6JxM BNyAAlAACkAB
KAAFPAoAoLEscqiAAdD90WW5KFAACkABKAAFoAAUyIsCAOgc4iNcAkDn5QMC py5QAApAASgA
BaCAqwAAGrSaQwUA0ABoKAAFoAAUgAJQIL8KAKBziI9wCQCd348MxCGgABSA AlAACkABADRo
NYcKAKAB0FAACkABKAAFoEB+FQBA5xAf4RIAOr8fGYg6QAEoAAWgABSAAgBo 0GoOFQBAA6Ch
ABSAAlAACkCB/CoAgM4hPsIlAHR+PzIQdYACUAAKQAEoAAUA0KDVHCoAgAZA QwEoAAWgABSA
AvlVAACdQ3yESwDo/H5kIOoABaAAFIACUAAKAKBBqzlUAAANgIYCUAAKQAEo AAXyqwAAOof4
CJcA0Pn9yEDUAQpAASgABaAAFABAg1ZzqEBFAfqd71599Xc7+6aNpGW0s+im lvjvxkXT7n36
/le1BSFOGRJV1Ss0DgWgABSAAlCgOgoAoHOIj3CpFIAmaBOU2tJy9Z1rPOfE 4VTntVQ7w9uR
x+qTN7Zcc+c7wehccvsBLYe0GWIjRpRhCYCuzgc0YjxQAApAASiQTwUA0KDV HCpQAkAzSH3y
xhuezBFAR2R/06JwrgoH2ZlqEwAdrjwsoQAUgAJQoKEVAEDnEB/hUkkA7UCq jknHAWAeQpah
ahUYpiCx/Ltx0Zo7k1A2i2SznTfcRFkKd96g7JOgrN2mCAzrlltEboNp1nnn NUnPwhm7I5lz
wiK7cdfxYDNaM5JVzBHpWqZidhc650Q7GTVrtGb7b0Wgo75Kib439IdsPmMn 8AoKQAEoAAWm
owAAGrSaQwVKAOhFgmh17JnINQFEg+qc/TERGtnJRVM4VDYzJTdHTOm2ydIq dGuZZtSUcN6b
K6KGoBOpfQNMhrzoBh8cJ0AvBhuxLw/Vu12I0bEIumzWq4/wHwCNcwAoAAWg ABRoJgUA0DnE
R7hUAkDL00dxuZ4guSS0G/9/0yIGiOydZD8/2osCtIrvprXpbc11yYgiU+52 fI1jNkDzrq0B
ymi3L10krU2eW+KmL8taIojOmuX68EGpywerkYXSTB/H04mFoC4UgAJQAArU UgEANGg1hwqU
DtAyyJqOxS7bhewJ51qX87zwqq7GUxkOrpnFqdbdLVIh1eHdDOeDAJrnoiSp I4r1Lf9dCgf4
QgEoAAWgABRoXAUA0DnER7hUAkBfrbIRWNzUl5gR8aV5OzlfCod72Z/KZHC5 Ng79pt6izkjh
SM0ViRIqNJWqFGcZ95XvGtDsdPrOd2+Utx+hEZmZxzoNQ9dKTeFw4ut2sz4p DA/5yQByoBv3
a6OWMR70BQWgABTIpwIAaNBqDhUoAaDVlX8tPCaqkhx4+NbKOjDzKAQHi4xq 63Z4cmd8EaFx
bZ83E0NhU0bCQ9JR1BdrVvWuLtGT71pRZ3sg+oJF90Z+ekS6VupFhOboPM2q 1mTqufLfikBH
feEiwoD7DAKyoQAUgAJQoD4VAEDnEB/hUgkAnc8TU3gFBaAAFIACUAAKNLAC AGjQag4VAEDX
NHgp4vUN/DGHoUEBKAAFoAAUqKwCAOgc4iNcAkDXFKAr+5mC1qAAFIACUAAK NLwCAGjQag4V
AEADoKEAFIACUAAKQIH8KgCAziE+wiUAdH4/Mho+qIABQgEoAAWgABQoqgAA GrSaQwUA0ABo
KAAFoAAUgAJQIL8KAKBziI9wCQCd34+MoiflMIACUAAKQAEo0PAKAKBBqzlU oASAvv/Zt1Gg
ABSAAlAACkCBbAUsou090t+9/+CBvXv275mZ0rVzWy2LGiYN+eC+fTR2UmA6 lA+AziE+wqXS
ABp6QQEoAAWgABSAAhkKEFtbsEgE2Xf4wL2Pv3z1Xz3Y8iezm6f89hfm3vaT 5/t7u3sO9wCg
cdQ0mAJ1D9D/7H+088Knh+64vHzFOvxbKQUabOljOFAACkCBaijgAjRFYYme W+f8Zv2HR6rR
Y27b3Nc3SKP+weOLEYHO7RzBsbIVaASAXri+IAqRNBeC6BmlUgoQhZe9yFAR CkABKNA8CngB
mmLP63b2NI8IaqTrdh6msR89ehwR6Cac/cYecl0C9Nu/2ktFTAxBcxpAi8gr SqUUaOwjAaOD
AlAAClREARegKRWY0jao8cnm+6NR09hPnBgEQFdkdaGR/CgwMwD9O3/xo5Di lYnQ+dzikdd+
8qFgaALoBWsvR2XdZUSgK8XKbjuIQOfnoIUnUAAK5FkBbwS6yQH65MnTAOg8 L1r4VoYCFQPo
xxf9xi1pDhE99/QcEKW3t7u///DAQO+JEwODgyeGhk4PDw+NjAyTjVt9xaId RM9Tq6d2P91P
DL180Y7n1nU/tHosKp1j/8+/+Q2vggh0ZXm6jOWFKlAACkCBZlMAAM3j7CIC fQoA3WyHQROM
tzIATejs1SptvwLoNHo+f37EBehXfr5J0PPUSC9tCIZ+5Webdh4r/PjtC1T+ H//tOe5GhI9P
/M2niKP13+9++YlqJnWY3V13b9wX7fzU3zw+s8kkzLFP/fU/apeCfUMEugk+ DTBEKAAFKqBA
BkBfmpisXem6//f/4P4PK9ijaLDEZgHQFVhSaCKXClQMoN3MrrFL49kAnUHP o6MXLIB+/idv
K3omJWk7YugnI4amt3YMXP6fb4783//zL+0IdDAgViZYy7uLmVUy9MzS84r7 r2tRZw73X/cn
9+vBlqJPLhcwnIICUAAK5EuBDIC+ODZZvOy8//dZ1OcvXgyo4m2W2vn9+3cE 9ui33PNDckW9
JRoMbzbuGgCdr9UJbyqnQMUA+vL4OBWCZlHOnb946uxwBkBn0/PY2EULoJ+c +xqxsirzbl2s
Cr21/eil+5d//H/7iyc8EWgr+msxLr0b7/nyn9An1n+4xwhaJy8/9R+uS+LY Aogf/+vfTT7f
zJC2xaPiZbJT15IuEdfKv6hZHSRWbsQbUSFLy7e4X8Pzf/zypxSvc2Jm1RXH S5eiKuJPhqXl
K0+cHhHoyh10aAkKQIFGViADoC+MThYv2yNO3SYsabul5UsvBNRyW+btZPeb Zhntv+VLv/8H
/7A9cYYcC2827hQA3chrvbnHVjGAvjh22ciVaGnpP3k2A6C9ec+UuUGxZ6Ln y5cvuSkcP737
eRegaee2vrH7lp6h8n/9wqOeCDR3i+GsTq4wQsUR1GpKpmBt9G4ClPf+BwnZ ikRpT1ZANwZf
hdECglesu+dPaIPzrmBcs9/ILAFi2UuC0SotxApyK2csr+Kmoj/lqgJ9TfxO 407UvLmPFIwe
CkABKBCkQAZAfzIyUbxsmft7vzf3A2WpXtKG/Dr7g3u3RO188IM/kDuEvWWQ XvGTkY6bk2/G
m5/vujdp9/d+0MXdo/Zpz69vbpH7RYOWe8VGBIAOWjQwqkMFKgbQhL0UdR4+ d2F45PzQ8PmT
Zz4+MnA6A6DdqwY5PRcK496LCB/49pOCoUX4mV7+6s2uH7x6iso/vHrq//Jn Pys7Ai1zlO0c
jAR/dSQ4Cf0qLucRbjsjggF0jMiav72xatFLhMUxaiccfM+fOJ2KprzdcfK2 IDg6AYgx2gVo
O1lcBb9lyjgi0HV4dMNlKAAFZkCBDIA+fXa0eNn4w09/+ofvassXvtjyF786 K/6NqwsD+jfZ
86svphhE7TgVz26/+9MtX3yWeWL3KN4is9+/e+Po6Wf/okX4o/o13CsyIgD0 DCxBdFkTBSoG
0ETMfSfOHOo/RaW77+S+w8f3dA9kALR1zw2LnicnJ7wATZrc93cLBUD/w20/ pZf/5//08Pdf
Pi4KbXsi0GEpHCUA9L0sJp3BwTxOrH1IMDoEoKMoNYHs/deJ6m6+srMnDlqz WLIn95ozPWsz
IBm6JgsSnUABKAAF6luBDIA+duKT4mXdvddcc+8abfnrm1pufpJ2Gj/y3vzk CdpPf7QRt+ka
iHbS9nNP7B6TBqUb1NHvfXdd3IVo0HCvyIgA0PW9muF9ugIVA2gi5m17ejZ9 2C3Kxp0H3995
KAOg+R3rXHq+cuVKGkDTWO6+9SdUxKAImme/NHD3Pw3c/dKABdD+O2Co+K5I ZbaSOtxUCk6W
FME17WULdm6xSlyOczCSFI7r6PYXkSVhMUWUi6dwiGTr6/7kP0QJyjIT2rwq 0YvUIqGZozOZ
WckbPAItE0t0Don3ekpEoPExAgWgABQIUSADoHv7hoqXd75/9dXff1tZipfW Tt3OszdEGP3n
j7sGaRXTLE3f3r7z05zYr75zU28RT/xDA0CHrBnY1KMClQFoGnmp94FW93v2 0jM1mAHQXGiC
5u+92K/+9USgjbP2KBdCXcz3KWJTG6C9F/OpJlQSs9wjW+AArbtLMqclrepL BiXgsqwJz0WE
VjqHfpl04Hqu6dy6VZ++WLBF5HMz8hbp0eZFhPTac9+9elzf8BkKQAEoUGMF MgC6+9Cp4uXN
2VddNXultPzl9S0t1z9KtdRG0sKbs6//9vq4tfXfvurT337TYxC34+yP7EWb uqmrWr7wqOGb
afPoF1qoKeGY4V7x4QCga7z80F3NFKgYQJfkMcGxeFpKGj2XBNAi8Ez/eiLQ 079/XEBuQ2Vu
gTd9V0XadHXuOY0IdEkrHMZQAAo0rQIVAGgdiCEy5pibvJGQsXh9lSBpQltV kZOutd+0FCT9
6J+xdoSBhniB75/+9qMA6KZd1Bi4R4EZA+hsei4JoNWwPDnQ06fSugJofeOO 6Q8cd+HAJwYU
gAJQoHQFMgB6/4FTzVYQgS59BaFGfSgwYwBNQeiiZZoS5igwXAWcrfHoEIGe 5mpEdSgABZpE
gQyA7tp9PKQYiYfJi5CKObQBQDfJsm/CYc4MQNdGaPrYIcrEv5VSoDazhl6g ABSAAnWtQAZA
79je12xFAPTgqTP9fcfKLrfdNrfj5c7CxCRt1PXagPONpECOAPrVjqcbSVmM BQpAASgABZpQ
AR9A7//tL8xdt3nr+5sONFt5c80aGvvZMx+VTc9UEQDdhMdR/oecI4DOv1jw EApAASgABaBA
tgIuQB862P13P37+hrseW77mvaYC6PXvb7r+jp9/Y8ELw8MjAGgcOA2mQI4A GhHoBltbGA4U
gAJQoAkVcAH6SE/f8YH+Hz756tV/9SDlMzRPodjzNxe+ODLy0bmR8wDoJjwW GnvIOQLoEKGL
XncoDFRTL+9YP/etZ6nQBu3c1fkPnU9dQ4U26OXqTV13P7aBCm2E9A4bKAAF oAAUgAKlRqCP
9h8/eWJw6OzHn3xy7ty5C+fP17pcGrtUy5IMcPTChdHR0YsXzo+eOD4IgMaB 02AKzDxAl/oE
lp6eA6L09nb39x8eGOi1ngrOAfq+lc+cPP1rKve9+QzNHKHzldFDVGiDXhI6 Hzt7jgptlDOv
e9uuvbZtbzk1y6pT4+7K8hGVoAAUgAJNroAbgZ4OO6IucqCb/IDK7fBnGKDT nvWd8QzwbHqm
J7NwgP7B8qePnnyu/8RzP1j+FM3B209cfeV815VzXbRBL7/36PrewU96B4e/ 9+g67wwRsqrb
CWlUViBbJtHyVmXzQRxeZne5XXtwDApAASjQgAoAoCsO/biIsAGPk/of0swD 9KTzN3ZpPBug
02LP4rmGHKC/v+SJ7qPPUqENmqxVv7hq8uNNV4bfX/XYVfTyOz9dfeD4EJXv /HSNO5UR52qw
XdzakryaLkAnXZUKxKXa1//qxAigABSAAnWnAAAaAF13ixYOl6HAzAP05fFx KgTNopw7f/HU
2eEMgM6m57Gxixygv/vyY7t6fkXley8/Ruqs+Nm/mjizavLMKtqgl99c8M7O vlMf9g1+c/7b
jnZEzGZcWPKrjh9f29pKKRxtRNbxX+viuA32fpTeEdeKbeT7uiMLiHXFxNLa k9hbPZQx66gC
BaAAFIACVVIAAA2ArtLSQrO5UmDmAfri2GXrqUv9J88KgBb35eD/Ehx7855F 7Jno+fLlSxyg
v9P+8/f3P7V5/9O0QU0tW/gvJ052TJ7soA16+fUfv/n+oWNUvv7jlfaseMK9 hNQx2vIItOJi
yduJjTKLaddh5wS1zQi3MItqRFtRzNvYI/pN3ibLxa3+hnO1wuAMFIACUKCp FABAA6CbasE3
7WBnHqAJeynqPHzuwvDI+aHh8yfPfHxk4HRGBNq9apDTc6EwzgH6W7/+6Zrd T1L51q8foTle
8tC/mDj6NJUlD/0uvfzaj95Ys69v7b7er/1oeZkArQhY0y0/HWhdnJF3wd+y tomcU/dEYJ3G
5E27jjFwKAAFoEBOFABAA6BzshThRlUVmHmAJmLuO3HmUP8pKt19J/cdPr6n eyADoK17blj0
PDk5wQH6G88sWLl9EZVvPLuQdHzlwU9N9D4y0fvTVx74FL386pylq3YfXrX7 0FfnvO6onJbC
YUagXYC2rgesPEALT4HRVT0u0DgUgAJQoEwF0gB614c7N23csPG9dU1Vdmzf Nn2exkWEZa5F
VKumAjMP0ETM2/b0bPqwW5SNOw++v/NQBkAPDp4YGjo9PDw0MjLs0vOVK1c4 QD/bufLrv5xP
hTZIRrr988s/+ucvt/2OuA/062sOfOWHS6jQhity1kWEVi4HVZagrPMuZIOB AO0mbKSncLTK
W+fhosJqHhloGwpAAShQlgJegCZ63tO18+TJAXqqSPOUM2dO0qhp7NNkaAB0 WSsRlaqrwAwD
NA2u1PtAZ9MzNcgBepri8RvO8XRjEf4VFxHK+0CbidH67nShAM2vPsy+iFB0 HjtQw5tQT1NJ
VIcCUAAKNIkCXoCm2HOz0bM4T6BR09gB0E2y+JtqmDMP0CXJTXCcEXsWTVUQ oEvyDcZQAApA
ASgABbwATWkbzRN4tkZKYwdA47hoPAVyBNDibhvZfwTHaZkbqiIAupiKeB8K QAEoAAWqpQAA
GgBdrbWFdvOkQI4AOkQWguOQEtIUbKAAFIACUAAKVFwBADQAuuKLCg3mUIE6 A+gcKgiXoAAU
gAJQAAooBeoeoPe//vzzv6Cyen9lrndECgeOjoZUIEcAHZLC4Z2DsisWndHN Cz+rSlFjGEAB
KAAFoAAUqCRAH1+/hFh29Ycqprt/9S+eX7L+eNm38hANRuX1/f5GPlz9/PNb jlcGnYXbAGgc
FA2pQI4AOm/6vnHnNdwl62XevIU/UAAKQAEokAcFKgzQS15fvSQhWsLfJc8v mQ5AE9FGjaQj
eETYaWxdJlUDoPOwLOFDxRXIEUCXHUguu2KGmhR4Hj/9HJWLfU8M7V54bMOc 7uV38YA0bVd8
MtAgFIACUAAK1LsClQbo9fu3PL9kSy+Fcin8vHpLgr9WLDnG4i0Unxb4q991 wskKoHUVlbBB
4WcRn47j3MXD1UFIDYCu9yUN/70K5AigqzpDIZce8tt3RHw8ul2XwtkpKnzP 6HYwdFWnDI1D
ASgABepRgYoD9PER4trX9wvwlfgbka7IUT6+5fkoxyOG3SRrObYXGRpuvJkD tKpCec8iLK3t
nS7KzRsBQNfjMobPRRXIEUCXHUgOqUhw3NNzQJTe3u7+/sMDA73WU8FtgB55 d0qUy6e+Mm8b
FdqQe+L9ZQJ0Hh4gWAEf4ofM8KfLFF1rrkEF3EjpNXraDJ4zU8aUoAoUgALT VaAKAB3FnuVV
fQZGJ4is8FpBswoku+nOZgRaplO7Ozl5Ty+vAwA93SWF+rlUIEcAXVV9FECn 0TM9FZwD9Hvz
PzN19g1RCJ3nPrOVSsTQY0ejcnYF7Y9svFCYPCnQ/7hAQY3TZ0fxmESGsCVA 47R7jzqnrvWj
GstC6UA3+FMew6mY5Eg1Xtzqf0s95dE7nMx32VMrk7Zde3sPf9RltFqibn29 JPvSW9b1wntX
i1etHJ8/VT0u0TgUaEAFqgHQcYA5yc3Qceh0gM7OcraDzSzwnIbX00iMBkA3 4CrHkKamcgTQ
IYFk75SFVBQAnUHPo6MXOECvfXDW1In2qIweJm6e175zfvsO2tjwSAsV2kll zQOz/ACdDXmB
1Fh0dUbtsIeJRy/pL+zp3tP1gcHpdJoKrBtoZismId/aLRnRJxSNSoCzt2b2 u8S9CXRLcVz7
ou2TUx6bCG8NoC/Lho3JPLWIXvGH0id6ZZ2AFF2cMIACTaxAVQBapU9kpHBo aNbZF57HHwZG
oKO8ETNLBCkcTbyqMXRXgRwBdFWnh+A4m57Hxi5ygD7yzpypc/uoiOSNp5bu eXrpXtqYOLOU
isDoI51zggFahRVbWttYBFpCsAxZa3oTOwTk6aigCX0xVi6OGyOrCKpEy0aV uMnYso0wLP6L
dikk9cQedRMWEerBcrYyw8NGL1EFZ+CiFR2GJ3bjo2XDdcevOM+KfLsDZJ2U MkfJiD3IrqiV
qedfsqKya5/ZguRbj40TLS/PhtWKF0t8ppAsBHe8/rOPqh6jaBwKNIgCNQFo fpkgi0xzzuaX
A3r2J0nVVqq0nbmRfc87XETYIIsWwyhDgRwBdEgg2TtCUTH7X4Jjb94zZW5Q 7Jno+fLlSxyg
BTdTeanz0IIXt3Z0dtMGvSwMdkwMdnS9dvN4/8NrF7REZWGL4ZX1K3iEoyaM aHaMEzlUnoEI
NBqBQqKcdOqS0BMb8DZjZjUiqbFLkpgE+yp7udvXi9rH0csFUw7QVi/egVsA nQyfKyH15IFW
RfXRRsAARROO57Jlf0jbj5jJ5Ga/y5YAnxdjJFktJKckro0+A0kSdsq2USdg 0kUtgyMIws9l
fJiiChQQClQSoMsN+noCzzPXFFI4cGg0pAI5Auiq6ktw7F41yOm5UBjnAH3H w6vj0rl+x3FV
bmnbOHlxH5WuVbcVPlq+8tGrCkceoGIDtJUeYNGJBdDaWECLACYWCjUyqtlP +UmzuoKB0Qnq
Kry2ybVoLxLUXAo1BmRGoKP4N/25nqidaQbqzIGfgRjc7GtW1OIOpW3zSaoi QCvy9GKumj5T
VH3WlFlLmpVnw3/KEFNvneqxqy7NM76qHphoHAo0ngKVBWh5UznjosAoKpwr RM52BgDdeIsc
IyIFcgTQ04xAZ08nwbF1zw2LnicnJzhAXz+7UxQKPN/z2Lol63uWbui5/u7O wsDjVLo6Pj9+
6L4Vc1tWzm2hfysK0KKxhIr9qMcgVYCpAO6SADpO/9CR6tScYE8Ut4oAzQPR LpqHD1Cp6L0a
sChAewzSfwrQ08/jtq59agusWmYtOcHl2bBF6o7O3IPwM74boMB0FKgsQNcR KKe5CoCeznJC
3dwqkCOArqpGBMeDgyeGhk4PDw+NjAy79HzlyhUO0MqZ625f9rnbl7W/fbD9 rYO0UehbUOib
v/TeFip+hz3sZQb00iLQAlv2trXK6wCFnU5XsLtLxSBfhoP16z2LXsfvpPQS xyg9aM0JKyMC
7aZwsNRbnUmSnA7IqGjSn2Zp6wzBm8JhpydEjaaefVhRapbeYl9EyKZOcave xyeWo39yDmS1
5mmBn/+k15KDS7pz29ETkm6TrB/HUUsphJ+r+kmExptAgTSAPnPmZAPQcKlD oFEDoJtg1Tfj
EHME0NWOQGfTM02+F6Bp/6xbX1m0ZM+i17po49XZLVSyVkoMnewvhh+2076I UJsK3NI5rwyb
EiMOsxlxRN0di0wLp+0gbtRdkqft9pKGoAmw8Y4sKrUvZzSSBuRtH7hWydDU +PmtIcROvafo
AOVQPTeq5n3K6ym1leqcp9DwvAt9HabVgzXt6rREXbeZ4LHZQrwyzFMUxwe9 epRhWTZJJc8Z
kZ47H1434wcjxgwFylfAC9A7tm/b07Xz5MmBUgG0ru2JnmnUNPb+vmPTKbfd Nrfj5c7CxCRt
lD8xqAkFKqpAjgC6ouOyGyM4zog9C+sMgH7ohZ3zXthBAF1hJ1NjpBXup8zm 0n/Lr4MwJRIR
ypx1VIMCUGBaCngBmvBx14c7N23cQOHYpirTp2eSDgA9rRWJytVRIEcAXe0I dFrmhhI2DaDJ
gNC58vSs4sHVmdrpt+pJf9aNxiHXsh6fMn3HireQBNaLW8ICCkABKFBRBdIA ejoh2CavC4Cu
6ApFY5VRIEcAXZkBpbRCcBxSquoDGocCUAAKQIGGVwAAXXHcB0A3/FFTjwPM EUBXNQJdj3MD
n6EAFIACUKDuFABAA6DrbtHC4TIUAEBnibZ54WdVKUNcVIECUAAKQIFmUwAA DYButjXfnOPN
EUDnbQLeuPMa7pL1Mm/ewh8oAAWgABTIgwIAaAB0HtYhfKi2AjkC6FylcFDg efz0c1Qu9j0x
tHvhsQ1zupffxQPStF3tuUH7UAAKQAEoUHcKAKAB0HW3aOFwGQrkCKDL8D68 SsgVhPwuHBEf
j27XpXB2igrfM7odDB2uPyyhABSAAk2iAAAaAN0kS73Jh5kjgK5qBJrguKfn gCi9vd39/YcH
Bnqth3vbAD3y7pQol099Zd42KrQh98T7KwbQOb8bdCUPkUrc/K56cuHmd5Wc a7QFBZpUAdwH
mt/oGveBbtLDoAmGnSOArqraCqDT6Jke7s0B+r35n5k6+4YohM5zn9lKJWLo saNRObuC9kc2
7p/5SLqgGyUHEmGgGbkUbllUdP1gxArc9Vk+fsV6jmBRHyyDwNEps0B70Yv/ 8Svuk/9cpxe3
eh7xJ1q0nj6YOWC2fpyHM6Y+E9F+/GVk6OvXehihpy9dzz+aUicL9lCg+RTw AjQ9RaVpn0RI
Y59mTBq3sWu+w6gORpwjgK5BBDqDnkdHL3CAXvvgrKkT7VEZPUzcPK995/z2 HbSx4ZEWKrST
ypoHZvkBWqFHILoFmoUvpwo1aIWLF7cGnQ6ku8ngdDoeBtYNNLPd9TxjUT1Q Ju35ixJEfchZ
tK7dv1ZZyuW2kN2mqOaxiejZnEGnr5i6pznL4csUllCgMRXwAjQ9g7DZnuMt HkJOo6axA6Ab
c60396hyBNBVnQiC42x6Hhu7yAH6yDtzps7toyKSN55auufppXtpY+LMUioC o490zikC0IJi
OMnpbR3abW1ru1awl0ghWEwvW1vpOX8Ry0g2i6BG1I3/bTOjmjqSGLWT9Uo0 ElcvykkpBGrF
j60Gzc4NfXhw1wwPW8Nh0dMWLY6KrEd1pT6RXJFwbMxyD/ODbIVVqudCaums M2z2QMYMKPe/
lVnX4HH3sY+iRbeFkDY9NmkR8njY0vtMm6oeoGgcCjSOAl6ApqwGAZRNWGjs AOjGWd8YSaJA
jgB6mhFoUT3tX4Jjb94zZW5Q7Jno+fLlSxygBTdTeanz0IIXt3Z0dtMGvSwM dkwMdnS9dvN4
/8NrF7REZWGLsZw0pRGVxeDmAWgzlKnIWFBc9GZcUaXkCvTUZgntqf16R9KC BEsHpGL3irJz
wqSuoQ5RyjEYDWaxnUGYHKCVP5KwfeIIibUCjJutuC8PvSpujjYyPedwb6Ms f+1ibjL5RQE6
csDWU+9K42ejljDK8icZh2ujT9g8J0+Kn2W2iXFGgU9LKAAFSlIAAG2dJACg S1o/MK4XBXIE
0FWVjODYvWqQ03OhMM4B+o6HV8elc/2O46rc0rZx8uI+Kl2rbit8tHzlo1cV jjxAxQZoK4XD
BWgLtiRzJ3RlRmdl6JQDtJ0iItiIwZmJpwYUpcRQFfZrHPVaWmMRIXLuD+vM AvVUgM6QS8dG
TYA2elRnHUnfBjcbkfs4Wi1OURzPUxNvqgjQCoad0K8iei8K82Roc97lMsis ZZ6hsLxv8/wn
7DyrqoctGocC9agAABoAXY/rFj6XqkCOAHqaEejskRMcW/fcsOh5cnKCA/T1 sztFocDzPY+t
W7K+Z+mGnuvv7iwMPE6lq+Pz44fuWzG3ZeXcFvo3FaAFH4UAdJy4IYmlZIAW /TOMdltQLqYA
tE89HpX1xVmzMdRpsYoArWL2HLgtEYqivwLojAh0hnpFI9B+A9obB5WNOHpK PFzHiZ1zrWQF
sOsOLRs+Ku5KWuy9hIVS6ocO7KFAYysAgAZAN/YKx+iEAjkC6KpOCcHx4OCJ oaHTw8NDIyPD
Lj1fuXKFA7Ry5rrbl33u9mXtbx9sf+sgbRT6FhT65i+9t4WK32EXTljALyE9 MwaYVNEpDBkx
VB+Ot4pEYJUsopvXeQvS21K4KA5L6wBnfMmZLxFCw5/THdeIo5oX8eVOR5zE B6keG4I0tfbo
jGee0JLpudlCRlaIPsmxArQuoCdQKxTUo3LG10pZ2nIGWQJPIp0iX1XP3WN2 IE+nrH61/Koh
fuJhIbjpZFWPTTQOBRpMgYoB9PH1S57/xfOyvL6/GvnT1MWS9cepZbVRhV6Q wtFgKxzDyR1A
VzsCnU3PJIcXoGn/rFtfWbRkz6LXumjj1dktVLJWT0ydyZ+kT7UvuvjNvqCN XycXQZ5hw0la
IJoL0PqGZckldUk42rykME7JLgWgJfZZo9EDtPKtE4ZX9haHqlvE8RY8wzEu CRQXYYompTJc
YRZxNWwSHNS1jME4nms3vOSoEohZWJcBNPdIXu6p3y1Sl5F1gsEsDUblwsf7 eOaGdWs8h4U9
t7HTQjpXXsbyyoR9KaRCenxWQgEoUJIClQRoQbdU9r/+vNquIONWk5tVHBoA XdL6gXG9KNBE
EeiM2LOYrQyAfuiFnfNe2EEAXS/zmk8/6yCs6ctbyaeY8AoKQIF8KlAVgB75 cPXzr++PeXfL
agpLxwFpHaJOXi55ffUSGbRevT8mb23z/JbjMtKctNC7JTFesvp1HYqWMe/Y fuSj41uel1Hw
cgkeAJ3PhQqvpqlAjgC62hHotMwNpWAaQIsgNOh5mktNB6iDbgJSid5KbSP+ AQCR11Jlgz0U
gAJcgWoAdESxxK8xDUsyjpBabkfvrv4wZmVJvVHEOoLsGLtFxFoEm40WWOaG DEV77WUL+1eX
mUYCgMYB0pAK5Aigq6ovwXFIqaoPaBwKQAEoAAUaXoFKArTKgXYzlXn2RYTF Mj4tUz4idH5+
y36eRR3Hra2cDSsH2si6FnHuCNNlwLvc1BEAdMOv+eYcYI4AuqoR6OacXYwa CkABKAAFaqxA
JQHaypqwoFm9mwHQGS3wawdVfNqfpzEtjAZA13gForvaKACAztJ588LPqlKb +UAvUAAKQAEo
UNcK1AigvSkc9kWHOs1DXtLnRqBVOnVU12O/ektvXJcSppP8kBJD0QDoul7P cD5NgRwBdN4m
6Y07r+EuWS/z5i38gQJQAApAgTwoUCuA9l1E6N72jmdliBxoM8a8P7ok8Re+ iwh/Ed/3Q8Se
YxtJ0iU/jRwAnYdlCR8qrkCOADpXKRwUeB4//RyVi31PDO1eeGzDnO7ld/GA NG1XfDLQIBSA
AlAACtS7AhUD6BIDvVW9l7P1bJSSXgKg631Jw3+vAjkC6KrOUMgVhPwuHBEf j27XpXB2igrf
M7odDF3VKUPjUAAKQIF6VKCCAJ08RUU9TuUXWeRak5s6l4TOwhgAXY/LGD4X VSBHAF3VCDTB
cU/PAVF6e7v7+w8PDPRaD/e2AXrk3SlRLp/6yrxtVGhD7on3VwygS3y4SdFJ hUGsQPzckGne
Mq96U4Nb5mGZQoEGVaCCAF0GreawCgC6QVd6sw8rRwBd1alQAJ1Gz/Rwbw7Q 783/zNTZN0Qh
dJ77zFYqEUOPHY3K2RW0P7Jx/4wnEYbxWyClBZoJdKzU7YzVc/TEg/CMlpMX bMiV6raExZAy
WPnQFuu5iSW0m0B4yJCUDyUp739oi/PkQo/Pi9mzv/nbIXWZvWfi3BbsPeYC F6covn6TfaZ+
3HO+tkJULnXyYA8FZkaBNIA+c+ZkDum22i7RqAHQM7MQ0WuVFcgRQNcgAp1B z6OjFzhAr31w
1tSJ9qiMHiZunte+c377DtrY8EgLFdpJZc0Ds/wArWAgEKcCzcKXQoUatEK4 i1tNgpa9cAyM
TWr85x8s82o6agTWDTSzlfE8mZH8FhKmPbVR8qsPOIvWtfvX0yXlclvIblNU 89hEbGwvBcdz
Va/GKwbdQYHqKuAF6B3bt+3p2nny5EC1gTVX7RM906hp7P19x6ZTbrttbsfL nYWJSdqo7uSh
dSgQrECOADrY53IMCY6z6Xls7CIH6CPvzJk6t4+KSN54aumep5fupY2JM0up CIw+0jmnCEAL
QuB0pbd1+K21LQkYi5/1F9PL1lZKP4gYRFJHBCOibvxvGxnGfxq2xOuIq3SI 0H0lGomrF0Vd
PxXyEcQUl4VBhiuuDtEeOVLpkLtHsiQbrjEEc7BqPjjVm+FhSzoWPW3REyE6 lWorDyW0OnFb
5gPZCiu9L9bZN2uqE7aKmJgZUJ56zpDMqWtg8Lg7ZaKC23umP7JNj01ahNz8 BQMAXc5HGerk
XwEvQBM+7vpw56aNGygc21Rl+vRM0gGg87/sm9DDHAH0NCPQonravwTH3rxn ytyg2DPR8+XL
lzhAC26m8lLnoQUvbu3o7KYNelkY7JgY7Oh67ebx/ofXLmiJysIWY90wvJLP hfYAtBleVKwm
oDZ6M0FTtZGgcwTQCn4FJrLGZEiRQ64CZd1LcXbOCoEm2KPwR54KuEBuOeYF aPXobBGzVGMn
D2QUUwczZXtcAR+E2vs4QFvSWXHeTA+5a3LGeehVcXO0kemzGbI3J4MzZTpf FgVo31mNbi6N
n41awijLn2Qcro0+ObRP1AzPtRkSOJrwu6eBh5wG0NMJwTZ5XQB0Ax8v9Tu0 HAF0VUUkOHav
GuT0XCiMc4C+4+HVcelcv+O4Kre0bZy8uI9K16rbCh8tX/noVYUjD1CxAdpK 4fBiGUcGydxO
+JCTHwdoO0VEgAgDWBMZZbBaRbR9tKKwX7+ZGgFVcXUTmR0vkuCuLyyqaF73 F/NYFH2PI7jR
n7NHELTlmM9PY58lo2jb44CZO+4aqPMBJZYM+bOKabXcNcDd0AuoigCtYNgJ Dyui96KwmmWT
u/XZUWYtdhKlZbcPdX5KUdWPATQOBWqhAAC64rgPgK7FwkUfJSqQI4CeZgQ6 e+AEx9Y9Nyx6
npyc4AB9/exOUSjwfM9j65as71m6oef6uzsLA49T6er4/Pih+1bMbVk5t4X+ TQVowSwhAB2j
o07IMMKZJu2loZi8kEsnDMhEAguXU7HY1S8VayICI3c9OSDeoGlC1kV0qBOA 5oFoF81LBWhb
MPY6Y6aKRqD9BrQ3DiobSyIlHi5bSPWHVXNt+KhMV1IdQwy6xE9umOdYAQA0 ADrHyxOuVUyB
HAF0xcbka4jgeHDwxNDQ6eHhoZGRYZeer1y5wgFatXHd7cs+d/uy9rcPtr91 kDYKfQsKffOX
3ttCxe8wRwRBGSwIl9CXGZdLqkgoycYyH4a2yqBt8p4RHTRzBEoAaPs+cMYl ZyriLajMG0/d
22Y4pk8RkiwVr1YKpaQcEX8b19VZQ7BinMITjoWunioC7aZwJGrJmWJ9yX6s PTrjmZ+6ZPps
tmCRo2JPPSx3gNYaSHwuWjeaK8rSViH+ZDmqley24GlTqMeWlbcWSxj3/TYS z5F8wzuDVf04
QONQoJoKAKAB0NVcX2g7LwrkCKCrHYHOpmeaEC9A0/5Zt76yaMmeRa910car s1uoZM1eRAPq
jxGCuMbPc5EZv3YtAi/DhoeiBTa5AK1vIqYSiuUu8yLCOCW7FICWpGSPRvAp p2Zl4dKgfMu6
sk6O0dXKp573grwkzUPSskqmSKYmIWjdoO+nAHOE4oJPeTWmmCnuTzI4EVE3 ZjPJVvHNr/mb
gGZ3h0Ol66p5lvrCaJV7JC8t1e8Wqes5X2D5PSrvnl2eKuaaXcEZOelwd4qN uqxVnV4ZS4mN
pOgFrXn5vIQfUCBAAQA0ADpgmcCk7hXIEUBXVUuC44zYs+g6A6AfemHnvBd2 EEBX1cmma9yl
+RL5PkOxOghrIvW36VY8BtwUCgCgAdBNsdCbfpA5AuhqR6DTMjfUGkgDaDIg dAY9V/5gqSZA
V+ZJhJUfc9Ji/GODSqaoXj9oGQpAgRor4AJ075H+7v0HD+zds3/PzJSundtq WdQwacgH9+2j
sZMC06FqXERY4zWM7kIUyBFAh7hbtg3BcUgpu31UhAJQAApAAShACrgATQTZ d/jAvY+/fPVf
PdjyJ7Obp/z2F+be9pPn+3u7ew73AKBxdDSYAjkC6KpGoBts2jAcKAAFoAAU yKcCLkBTFJbo
uXXOb9Z/eCSfPlfJq319gzTqHzy+GBHoKimMZmdQAQB0lvibF35WlRmcJHQN BaAAFIAC9aKA
F6Ap9rxuZ0+9DKGCfq7beZjGfvTocUSgK6gqmsqDAjkC6DzIwX14485rMl7m zVv4AwWgABSA
AnlQwAVoSgWmtA3ybbL5/mjUNPYTJwYB0HlYnPChggrkCKBzlcJBgefx089R udj3xNDuhcc2
zOlefhcPSNN2BacBTUEBKAAFoEBjKOCNQDc5QJ88eRoA3RjLG6NQCuQIoKs6 KyFXEPK7cER8
PLpdl8LZKSp8z+h2MHRVpwyNQwEoAAXqUQEANI+ziwj0KQB0PS5l+JypQI4A uqoRaILjnp4D
ovT2dvf3Hx4Y6LUe7m0D9Mi7U6JcPvWVeduo0IbcE++vGEBX7ubHWO2lKxA/ z2OaT/Ko3gzi
bnelzyhqQIGZVSADoC9NTIaWrvt//w/u/zDcPieWjtsA6Jldjei9egrkCKCr N0hqWQF0Gj3T
w705QL83/zNTZ98QhdB57jNbqUQMPXY0KmdX0P7Ixv0znqUXBmaB+BVoRi6F W2aILgbCyLK+
WS5FE/m8Ff7AwjIWYqDgyizQXnjif96K+4BA1+/F7LHd/N2QusyeLWnnaYxq fdhtmseBWEhu
v2pP8ijJoL7KmCFUgQK1UyADoC+OTcqy8/7fT57M+fv37dH7ucHv379DvczY oKYsS9Z4S8sf
/HBn0mlIa5aN23h2I449ALp2Kw891VaBHAF0DSLQGfQ8OnqBA/TaB2dNnWiP yuhh4uZ57Tvn
t++gjQ2PtFChnVTWPDDLD9Dq+RiBnBRoFr4yKtJg1Ih68riAcvqr20d/+DVh cDod0QLrBprZ
E+15qKJ6lnraAxcliPrmq2hdu//FrQkmS7ncFrLbFNV8NvyZ8PJsweyLjQ8P bgz/BIDljCqQ
AdAXRifj8vKXWv7gH7Yn23/xcrJf7InL9giLt6mXGRuuJd9D2y23vBDSTkVs HGcA0DO6GNF5
FRXIEUBXcZRxBDqbnsfGLnKAPvLOnKlz+6iI5I2nlu55eule2pg4s5SKwOgj nXOKALTAA45N
elvH3lrbiE1jMBUx3sWCXKPoROtiCUIRVYi68b9tZBj/CdrQYbuonaxXopG4 erGshdgy8iVx
TflpRwkNiEuQyPSC9avdVuoZtq5cEuXZkN09hgrx0IyRWt4kPXMmU/36FGbR 0xY9X0kv8aTI
KVPPF7RV4vOiTky0keWzoZID3ow7M6Dc/1ZmXe9U6lUuWnRbCGnTa+MAdEZf 0eFRbNFW9UME
jUOBMAUyAPqTkYm4dNzccsuv5bbYM/HJlrm/Jz/k/uDeLfHL35v7gbtfVpem Nz/fdW9S7fd+
0KWbEnWtvqwuzKZaqIrqVPSr9sTb995MncZuu+3oPS1RO2xoAOiwVQOr+lMg RwA9zQi0qJ72
L8GxN++ZMjco9kz0fPnyJQ7QgpupvNR5aMGLWzs6u2mDXhYGOyYGO7peu3m8 /+G1C1qisrDF
mHbGTZKlPABtcIomY8EH0ZsxtaqcCcF5CqAV/Kr9CVjIWKGB6QlzuNWzl6ts JKYWVdeKaCZI
o9FGbjm0FMsiXbFCiUyMyH8vQKunXkeaiNMKnk1ADYs3ktMJcd7CzxJ8NGns 4wBtu+qbL6Ge
VlX6w12TAvPQq7DS2qb7zFWy0ZG/TsfKogDtQ1JnKtkq4UvCGFuWP8k4vDb6 NNKOleu+Sv1B
p/4+heFxgymQAdCnz46K8qsvxgT8xReSPS98seUvfiXe3fjDT3/6h++Kf886 +89uv/vTLV98
Vraj7ZOW7T3P/kVL1A7ZZzZldOq4Qe+Ss7JTtx3ak7wr3dbuAaAbbHljOEqB HAF0VWeF4Ni9
apDTc6EwzgH6jodXx6Vz/Y7jqtzStnHy4j4qXatuK3y0fOWjVxWOPEDFBmjr G99LhJwXJHOb
pKsxy4g9S4zm9CZTS1lwzmTBJNEuiWj7ftZX2K/fTBoRjKND4BLxk1Z1gDqi V5l1a5xFOP3a
YKd70Ehq4al2K+YxFRiPzJw9AnetXkoC6IwZ5PPCAZpX0SdCpkp8XtQZkRqp 5bO7bPQ6qyJA
K6h2EqgV0bu9p/ujTz2yfbZOqthLYy0hAl3Vj0k0XhkFMgD62IlPjPJ0FNRt uenXx9bdew37
pG5puflJ2nPNvWvS9vN2hKW1R7Wm3nKbOvHrm6gjUVF1x+2FA+pfZel1lbfD nAFAV2ZVoZX8
KZAjgJ5mBDpbW4Jj654bFj1PTk5wgL5+dqcoFHi+57F1S9b3LN3Qc/3dnYWB x6l0dXx+/NB9
K+a2rJzbQv+mArSAkRCAjplQRyONOGVRgBb9Mwy1QI37549K+sQzKFwnGEQE r6K/ujXaisPA
lueq4SwcNP0vIledALRXpbIBOiMCnTGhRSPQfgNzKuUMpsTD3Zi02Sar5vwo kXrYWDCd2IUv
3fx9zsKjplIgA6B7+4ac8uwNLX/++Dvfv/rq77/N3xV70va7lt49VJ0aF2+5 TfXFXfN3uQ13
wN2f5oDTCwC6qRZ/Uw02RwBdVd0JjgcHTwwNnR4eHhoZGXbp+cqVKxyglTPX 3b7sc7cva3/7
YPtbB2mj0Leg0Dd/6b0tVPwO8695QQI6CKeyM9guFcVUt1tw8Vfs4f+qsGW8 v1Ve2pfUNMJ+
Zt5oOIW4lo4DFiW2Umqv9EQnVEiVMgDa8l+fSSRyeSVVEV+JW7pHOXrLf1Ny Dxa6suupceYr
EVUqwPpye9cqqWY0dzopHL6EBXcqFI1qz9wBWpqzDBoj10UMky0TesWmkuUU JSve7d3jj9Os
x0ZdnsiVUadnNmH736jq5wYahwJlKJAB0N2HTkXlzdlX/dkv9fZVs1ce+uX1 LS3XPxq/q2y8
+w+t//ZVjmXLFx5VFUX7Ud24qUe/0CLfdbrgTYkq9G/S1Mpvf7pF7FH/yi7c dmjPp7/9ZtSd
rMWcAUCXsYRQpS4UyBFAVzsCnU3PNFtegKb9s259ZdGSPYte66KNV2e3UMma 2ggF1J/8xVnt
07e1YGbsorSIAg0bHtBNA2h9dzBNGCIcbV5SGL+ePkCz6+n4XTosCGOXzDn9 2j7YibC2XK6k
PpFZjyxezqZKa6J3JsFO3aDvFwPJgvoqxiwP+TlEXIOrJH3IvIgwSpJmp1U2 3mr2F/6wzB8T
go1VaCCyEtxf1+Vp/oOtSs83evfcok6fODDwdn3WqpoyJws4cdaXeVQXn7Fw sukUKA7QMbkm
fxI9I+pV+zizWvsFHyeWgrkf/bPo9VXfXm/Ct2TxCGoF4GY2FeGyIOD476o/ +4JGZ07kpgOi
VozprBYAuulWfTMOOEcAXVX5CY4zYs+i6wyAfuiFnfNe2EEAXVUn0bhfARf6 w08DimnqDUwX
q1Tb91MyGmrrBHqDAlAgVIEMgN5/4FROyxtRpHl5Fdwj1fAkwtClA7u6UiBH AF3tCHRa5oaa
rzSAJgNCZ9DzjC3sagK0vAdgbi9Oi3+TqNubb8/YkkHHUGAGFcgA6K7dx0Ux LsOLX6i3ZmZj
yXf/t//tu0sT9yroAwB6Bpciuq6qAjkC6KqOk+A4pFTVBzQOBaAAFIACDa9A BkDv2N7XbEUA
9OCpM/19x8out902t+PlzsLEJG00/PrBAOtFgRwBdFUj0PUyH/ATCkABKAAF 6loBH0Dv/+0v
zF23eev7mw40W3lzzRoa+9kzH5VNz1QRAF3XR0SjOg+AzprZzQs/q0qjrgCM CwpAASgABSqo
gAvQhw52/92Pn7/hrseWr3mvqQB6/fubrr/j599Y8MLw8AgAuoJrDE3lQYEc AXQe5OA+vHHn
NRkv8+Yt/IECUAAKQIE8KOAC9JGevuMD/T988tWr/+pBymdonkKx528ufHFk 5KNzI+cB0HlY
nPChggrkCKBzlcJBgefx089Rudj3xNDuhcc2zOlefhcPSNN2BacBTUEBKAAF oEBjKOAC9NH+
4ydPDA6d/fiTT86dO3fh/Plal0tjl2pZkgGOXrgwOjp68cL50RPHBwHQjbG8 MQqlQI4Auqqz
EnIFIb8LR8THo9t1KZydosL3jG4HQ1d1ytA4FIACUKAeFXABejrsiLrIga7H o6AZfM4RQFc1
Ak1w3NNzQJTe3u7+/sMDA73Ww71tgB55d0qUy6e+Mm8bFdqQe+L9FQPoyt3V eOaXbPLYi9ze
F64UieLnpUxzJNWbXNzhrpS5hC0UqJkCAOiKQz8uIqzZ6kVH4QrkCKDDnS7D UgF0Gj3Tw705
QL83/zNTZ98QhdB57jNbqUQMPXY0KmdX0P7Ixv0zHpIXRl+BjBVoRi6FW2ZI 6X3aXxHp6/OZ
HylyyWes8IcUlrHyAudCmQXaC0/8ejsPGvS4vVg9dd18M6Quq8EWifMERnXm YbdpHiLiFMXX
r/8ZhNxz/QxL3C27jLWJKlVSAAANgK7S0kKzuVIgRwBdgwh0Bj2Pjl7gAL32 wVlTJ9qjMnqY
uHle+8757TtoY8MjLVRoJ5U1D8zyA7R68EUgDAWahS+cijTIGwkE4zp4rJ9P RL9cbMzT0TOw
bqCZ7b5HcfJboGvabEh+9T2epWhdu//FrQkmS7ncFrLbFNU8NhEb28F/x3NV L/zYgCUUqLoC
AGgAdNUXGTrIgQI5AuiqqkFwnE3PY2MXOUAfeWfO1Ll9VETyxlNL9zy9dC9t TJxZSkVg9JHO
OUUAWny/czbS2zp41trWdq2gGfGj/GJ62dpKyQMRQUhmiFBC1I3/bSPD+E+j kngdtaMDfO4r
0UhcvVhqgoF0CamYbZutsXCg8JP7aPfLhi+GJo1trDPecZWM9kit5JDcPZIl mWCGMyl983MG
1a9PfBY9bdFTKTqV86U8lKPTXcqnDDIfyFZYpQqo5111wtYhY8oMKPe/lVnX 4HGXXEWLbgsh
bXps0iLk5q8rAOiqfmqi8TIVAEADoMtcOqhWVwrkCKCnGYEW1dP+JTj25j1T 5gbFnomeL1++
xAFacDOVlzoPLXhxa0dnN23Qy8Jgx8RgR9drN4/3P7x2QUtUFrYYM87gSP6s 7AFoA0Y0aQmo
jd6MGUrwtNhI0FmAqYRftV/vSFqQqOagCa+evVKZ24lHxVrTVXT8UA7V6Ncc fjS8hOYtsGOG
UazTC9DqSdeiT6WePCGhlrOd8We8GI5wgLbEt+K8mR5y16T2PPSquDnayPSZ w73NkPx1Ol8W
BWg+Kck60c2l8bNRSxhl+ZOMw7VhJ2PWqZ7huTbD487r6nunwZ0FQAOgG3yJ Y3ixAjkC6KrO
CMGxe9Ugp+dCYZwD9B0Pr45L5/odx1W5pW3j5MV9VLpW3Vb4aPnKR68qHHmA ig3QVgqHF6r4
F75kbgciObdxgLZTRARGsIiyCXwytqsi2j7WUNiv3+RnAnZMNInmurxrUGAs jIBgz1lEIptx
ymGFxs2hFVEy5rEofh9HcKM/Z4/rjPDQ0SQVoDMm12pKNGH5rM+RkmmxFEur lSag7XwVAVrB
sBMeVkTvRWGeDG2uUrloM2tZZ1up6A+EruonKBovQYE0gN714c5NGzdsfG9d U5Ud27dNn6dx
EWEJ6w+mtVIgRwA9zQh0tmIEx9Y9Nyx6npyc4AB9/exOUSjwfM9j65as71m6 oef6uzsLA49T
6er4/Pih+1bMbVk5t4X+TQVoQRwhAB2Dn07IyICqVBJlrGmRN/fPzx8+8VzL onu8/YYAdBH4
SYbWGAAdCZIM2FWsVIDOiEBnzHUqhqb8FCAXCFWLg8rGfKXEw2UXqT8vsGqu DR+V6avf8/Bl
XatPVvTTxAp4AZroeU/XzpMnB+ipIs1Tzpw5SaOmsU+ToQHQTXw85XfoOQLo qopEcDw4eGJo
6PTw8NDIyLBLz1euXOEArZy57vZln7t9WfvbB9vfOkgbhb4Fhb75S+9toeJ3 mH+VC0ZgIbSE
ncyoWlJFIkU2VPkgslWGXJP3dPM6E0AjUGCozsMkxVrTVbSl9MVozRw+S1ew Jd3bZgxNn2Qk
eS5etdUApaDZzqRcbcexMO3EIOrImcrkpwA518xDVwrN0qoZzZ3mtYDuvCfx fWs+FXtqzyy9
3Ug5ywmyL0B0xtdKWdoqxK8HoGP+Vgsef4QD7DcT10bLbzlvzrjkfXeAVf00 QeNQIFMBL0BT
7LnZ6FmcJ9CoaewAaBw0jadAjgC62hHobHqmqfUCNO2fdesri5bsWfRaF228 OruFStY6iL7L
1R/7fhfX+HkuEeNXnkWoZ9jwULRABw9IeTJBxa4E8Fi2gAeLU0bjteSjs5zx YJl93V6SWcGv
kIsxympWe2QPTRlKlVy1ffp7L8jTziSXAZokmiCcbjAlEYX1KC4Zlddzirn2 DU2NSs+18iHz
IkLps54aLzmq5lk4mdEq9ygRP/WWc/a9PByeZglCOnOfXeBKc+n4o9P81Uz7 bdSFscLO5zm/
UrXxPp8xorpUwAvQlLbRPIFna6Q0dgB0XS5lOJ2pQI4AuqozRXCcEXsWXWcA 9EMv7Jz3wg4C
6Ko6icZLVsCl/PAzhGKd1UFYk4fJiw0H70MBKFAbBQDQAOjarDT0MrMK5Aig qx2BTsvcUBOQ
BtBkQOgMep7ZlervvZoALSOexW73N2OyxD9XqGSKGXMDHUMBKGAqAIAGQOOY aAYFcgTQVZWb
4DikVNUHNA4FoAAUgAINr0AjAPTx9UuWrD9eoesdkcLR8Gu+OQeYI4CuagS6 OWcXo4YCUAAK
QIEaKxAK0ASpz//ieV2e33J8ejfoMBtcvT+9tQw+Fm8BoGu8aNBdHSoAgM6a tM0LP6tKHU4u
XIYCUAAKQIFaK1ACQFcuyhtlTXDqjWE6laGL8nFRg1KC04hA13oJor+aKJAj gK7JeEvo5I07
r+HW1ssSGoIpFIACUAAKNI0C5QN0jK1bVlNY+vX9fFvAsYxVv74/YWVpqVjW ol71UtcVQe7e
LUtk5HvJlt7jW55PouDxu2YEWr87DdYHQDfN2m+ugeYIoHOVwkGB5/HTz1G5 2PfE0O6FxzbM
6V5+Fw9I03ZzrRSMFgpAASgABQIUKAGgeQqHSJxQYWMjhPzh6mR/RLSrPxQ8 bQeY7bAx1SLa
Fv/G6RwcqV0g3v+6bFmlcES9yLr7VyeNlBJ7FlcTAqADVg1M6k+BHAF0VcUL uYKQ34Uj4uPR
7boUzk5R4XtGt4OhqzplaBwKQAEoUI8KlADQFsVaORjqXTs3Q8an7Yv8vABt Z1rrALaszg04
Oke9R+AehcNLh2Z+Iw4AdD0uY/hcVIEcAXRVI9AExz09B0Tp7e3u7z88MNBr PdzbBuiRd6dE
uXzqK/O2UaENuSfeXzGArtyti4vOdzMZxI/dmOZN6Ko3NbgJXTOtRYy1qRTI C0BnXA5oZHck
Fy9ye4PFp4vRAOimWv/NM9gcAXRVRVcAnUbP9HBvDtDvzf/M1Nk3RCF0nvvM VioRQ48djcrZ
FbQ/snH/jCfhhfFbIKUFmpFL4ZYZohd5yB9/YrXzNLqqzqXVeMpg5WNQ+HME y/AqUEllFmgv
PPE/BsV9Jp/r92L2NG3+bkhdZs+mOLmhtNuCvcdc4OIUxddvss9+vqN+rR8z iRtal7E2USW3
ClQeoONIsEjY0Ckcbg6GQ71xFV1XR4VVbgarErVsRaCPr1+9pTeuRWnTSYY0 TwjxbjvhagB0
btcqHJuOAjkC6BpEoDPoeXT0AgfotQ/OmjrRHpXRw8TN89p3zm/fQRsbHmmh QjuprHlglh+g
FSIE4lSgWfg8V6RB3ohAPb5HhXcr0lf40LxnLJ7HiTA4nY6HgXUDzWznPc86 JL9F0DztOYiS
X31PUCla1+5/cWsSoJdyuS1ktymqeWwiNraD/47nqt50ph91oUDuFCgBoK3b 2O1nd192rwh0
LiL0pHB4b4pnJWnEgLs/ulTxF3QRodiItle/rm9gJ3sXsWdpKbOoAdC5W3Fw aGYUyBFAV1UA
guNseh4bu8gB+sg7c6bO7aMikjeeWrrn6aV7aWPizFIqAqOPdM4pAtCCECzu lOijw2+tbW3X
ip3iZ/3F9LK1ldIPIgaR1BHBiGgn/reNDOM/DVviddSODhG6r0QjcfViyQ0G FMYjsTCR+RM5
7/szXHF1iPbIkUqH3D2SJdlwjSGYg1U+8OCu6tcnHYuetuiJEJ1KtZWHcuZ0 l/JBgMwHshVW
el+ss79r96cCxpQZUO5/K7OuweMuuYoW3RZC2vTYpEXIzQEDoKv6mYfGZ0yB UICeXmKx9bS/
PL9EBHrG1iI6rqYCOQLoaUagRfW0fwmOvXnPlLlBsWei58uXL3GAFtxM5aXO Qwte3NrR2U0b
9LIw2DEx2NH12s3j/Q+vXdASlYUtxgQxvJI/THsA2gwvKlYTUBu9GVOYSpPl AeC4fQm/ar/e
oXEthloHbnj17IXF3JYe2dyWUHVaBgcbZRTr9AK0ehi1iFmqscvTCRqODmbK 9qwh+GjS2McB
2pLOivNmeshdk8rx0Kvi5mgj02cO9zZD8tfpfFkUoPm8J7Osm0vjZ6OWMMry JxmHa6NPDu0T
NcNzbYYnklfzQx5t11qBcIBmT1GRgd48c3DZvgGga70E0V9NFMgRQFd1vATH 7lWDnJ4LhXEO
0Hc8vDounet3HFfllraNkxf3UeladVvho+UrH72qcOQBKjZAWykcXizjyCCZ OwkJc+DjWKY4
204RESDCIsomMjK+daLIiesK+7Vf/EzAoEMe5k1tMDYyHSuiQ8xjUfQ9juDK 6uYeQdAWPpYE
0BlTI05dsudOn+EkolrKeOfI8tntRS+gKgK0gmEnPKyI3ovCal2Z3K3PjjJr sZOoaJSp6A+E
rurnHxqvqQLhAF02ktZXRQB0TdcfOquVAjkC6LIj0CFaERxb99yw6HlycoID 9PWzO0WhwPM9
j61bsr5n6Yae6+/uLAw8TqWr4/Pjh+5bMbdl5dwW+jcVoAWzhAB0DIo6ISMD y1Lxi9Gqi+DK
RT/B+CR0Lb3kWrzBxLHGAGgeiM4+1RGiutDPdciIQGcIWzQC7TegvXFQ2YDV lHi4bMH5BSNZ
Kayaa8NHZbqS6hgAOuRjDDb1oUAaQJ85c7K+wLci3tKoAdD1sXDhZYkK5Aig S/S8NHOC48HB
E0NDp4eHh0ZGhl16vnLlCgdo1fp1ty/73O3L2t8+2P7WQdoo9C0o9M1fem8L Fb8HFh6JPFp+
y4okMVlHjJMqEkqyscyHoa0yaJu8Z0QHzWTn4rybDKsIQCdZCpmcZzimTxGS LBWvVgqlpBxJ
R+q6Opfj3XxujoXe0wm5k82Ngl3FvUnGuYiIS1PWu2Zp1YzmTvNaQHfWkjYt clTsqT0zfZSu
8Eg5y+ixL0B0xtdKWdoqxK8HICfd7d3jjykUvfLWYgnjvt9G4mryDXeApR3c sIYC+VLAC9A7
tm/b07Xz5MmBilBpvTRC9EyjprH39x2bTrnttrkdL3cWJiZpI1+TDW+aWIEc AXS1I9DZ9Exr
wAvQtH/Wra8sWrJn0WtdtPHq7BYqWQsmogH1xwhBXOPnuciMX7sWwaJhU0IK R3INYeyciPqa
FxHGr6cJ0HpoCYYZ45V9JvrYSa7KVo7R1cqnnveCPH7Zoh6snpiEoHWDvp8C JAvqKzKzPExG
rEalZ0oJnnkRofRZT4GXHFXzLKWHnSFwheSlpfrdInXdlG8nfd1pwXOLOoe7 U2zUZa1iWnye
G9fCNvHnMIbeUAp4AZrwcdeHOzdt3EDh2KYq06dnkg4A3VBHSKMMJkcAXVVJ CY4zYs+i6wyA
fuiFnfNe2EEAXVUnm67xIkHuaelRB2FNHiaf1lhRGQpAgRwpkAbQ0wnBNnld AHSO1jdcSRTI
EUBXOwKdlrmhFkMaQJMBoTPoufJHTTUBWkY8i92sr/KDCmwx/rFBJVMEVoIZ FIAC+VcAAF1x
3AdA53/ZN6GHOQLoqqpPcBxSquoDGocCUAAKQIGGVwAADYBu+EWOAZICOQLo qkagMdlQAApA
ASgABWqgAAAaAF2DZYYuZlwBAPSMTwEcgAJQAApAgcZRAAANgG6c1YyRpCuQ I4DGNEEBKAAF
oAAUqHcFANAA6Hpfw/A/RIEcATRSOEImDDZQAApAASiQZwUA0ADoPK9P+FYp BXIE0CFDCrkQ
kN9M4+Ud6+e+9SwV2qD2d3X+Q+dT11ChDXq5elPX3Y9toEIbIb3DBgpAASgA BaBAtgIAaAA0
jpFmUGDmAfrxRb9xS5r0BMc9PQdE6e3t7u8/PDDQaz2jmwP0fSufOXn611Tu e/MZapPQ+cro
ISq0QS8JnY+dPUeFNpphsjFGKAAFoAAUqLYCAGgAdLXXGNrPgwIzDNCEzl4V 0vYrgE6jZ3pG
NwfoHyx/+ujJ5/pPPPeD5U9RR28/cfWV811XznXRBr383qPrewc/6R0c/t6j 62w3vI/Em8EZ
C3+CoHKyjCozOEB0DQWgABRoCAUA0ADohljIGEQRBWYeoCedv7FL49kAnUHP o6MXOEB/f8kT
3UefpUIbpMSqX1w1+fGmK8Pvr3rsKnr5nZ+uPnB8iMp3frrGA9DqMRd1+sQ4 ADQOfygABaBA
zRUAQAOga77o0OEMKDDzAH15fJwKQbMo585fPHV2OAOgs+l5bOwiB+jvvvzY rp5fUfney4+R
uit+9q8mzqyaPLOKNujlNxe8s7Pv1Id9g9+c/3YWQE8RQbcujnm0jZ4fR9tk rUPUycPueNCa
4Nu0Z2/GYB6929p6LbUmmhYb2ft5m4m94Yn5bDsHoH0+iBGlt8YbSbbtdrw+ aCN5IuLsmIHl
ji6hABSAAtVWAAANgK72GkP7eVBg5gH64thlSXDJf/0nzwqAFvfl4P8SHHvz nilzg2LPRM+X
L1/iAP2d9p+/v/+pzfufpg1qatnCfzlxsmPyZAdt0Muv//jN9w8do/L1H6/M AOiI/AQQS3Ym
2+hBzAKco93Rlt4Tw7Flz5qPaTyuFpOleqSziHNn7LfalHFxp1/VVUYEWvsg RxG5EbnjG4WK
xLsNinbcWuKUQ3ii1ZB7Frfm9vnaeTgk4QMUgAL1rQAAGgBd3ysY3ocpMPMA TdhLUefhcxeG
R84PDZ8/eebjIwOnMyLQ7lWDnJ4LhXEO0N/69U/X7H6Syrd+/QgJsuShfzFx 9GkqSx76XXr5
tR+9sWZf39p9vV/70XIPQCuuFwTpi8VqgnbftXDTF582mlWgaXXH92f34vao 2FexLB9USGve
UaeNxcBlflpExByhuT4BCVudsIICUAAK1J0CAGgAdN0tWjhchgIzD9BEzH0n zhzqP0Wlu+/k
vsPH93QPZAC0dc8Ni54nJyc4QH/jmQUrty+i8o1nF5I6rzz4qYneRyZ6f/rK A5+il1+ds3TV
7sOrdh/66pzXPQDt0qc3FitC0DxP2kJhgZUi3swRMwOUOa9nA7TbrxqJh+BT fFDdFR0Fj5EH
1jKUBUaXcZCiChSAAvWkAAAaAF1P6xW+lqvAzAM0EfO2PT2bPuwWZePOg+/v PJQB0IODJ4aG
Tg8PD42MDLv0fOXKFQ7Qz3au/Pov51OhDZKIbv/88o/++cttvyPuA/36mgNf +eESKrRRGkD7
UziK4WnCzzJVoyIAneReaDTPAGjmoOGD5nVG0E7qhU5lsdrx+MBSQYQ/e9ta jROIchcs6kEB
KAAF8q0AABoAne8VCu8qo8AMAzQNotT7QGfTMzXIAbp8kdx839SUjCSjV0RX xV9yEaEIOtOf
ejO6dJC/q5otL4WDNy365QCtHUpSlYV3lg8aoJmjSWsqX0PWcsfi9cFK89AC GD6WP0GoCQWg
ABTIpQIAaAB0LhcmnKqwAjMP0CUNiOA4I/YsmqoMQJfklmXMrqCbTjMl161s v+W1Vl6tkoeK
ClAACkCBnCoAgAZA53Rpwq2KKpAjgBZ328j+IzhOy9xQFWcKoFkAuqZ3mahs v+W1Vl6tYrON
96EAFIAC9acAABoAXX+rFh6XrkCOADrEeYLjkBLSFGygABSAAlAAClRcAQA0 ALriiwoN5lCB
OgPoHCoIl6AAFIACUAAKKAUA0ABoHA7NoECOADokhcM7JWVXLDrBmxd+VpWi xjCAAlAACkAB
KACABkDjKGgGBXIE0HmT+407r+EuWS/z5i38gQJQAApAgTwoAIAGQOdhHcKH aiuQI4AuO5Bc
dsUMcSnwPH76OSoX+54Y2r3w2IY53cvv4gFp2q723KB9KAAFoAAUqDsFANAA 6LpbtHC4DAVy
BNBleB9eJeTSQ377joiPR7frUjg7RYXvGd0Ohg7XH5ZQAApAgSZRAAANgG6S pd7kw8wRQJcd
SA6pSHDc03NAlN7e7v7+wwMDvdZTwW2AHnl3SpTLp74ybxsV2pB74v0A6Jk5 eNxn3NTGj5nq
t+zRBTkcP/BmmvddDOqorGFE90fkDwcqqxFUyr8C1VtCMzF2ADQAeibWHfqs tQI5AuiqDl0B
dBo901PBOUC/N/8zU2ffEIXQee4zW6lEDD12NCpnV9D+yMb940/gmzaZ+DXJ /rKp368iQ7p0
bCppgBWcjpL6nc5qtjsyx5A86bJ4DwEOR00TPeseykLpgI4ib62HbhYfQGzB ni7Paqg7j3sd
ns67jltM/mRRuu3be+w5M54EynxO6oW3bPoX0m+60EWPDmFg+asPzfht+0j1 7kz5oFR13ee8
qrfiIba2xZ6Yj1YNXEG1NwNAA6Brv+rQY+0VyBFAhwSSvQKFVBQAnUHPo6MX OECvfXDW1In2
qIweJm6e175zfvsO2tjwSAsV2kllzQOz/ADNvxWqxNAZKyWQZmq/1or2yD2X ZOerU9IA7Tan
EWwtqd+igy1jBkt1oLg9g9PixpkcFhImLrMLz1JQz7v0LRO2zwffmXV9Y1zc mgCkbM5tIbtN
Uc1jE6GhcQLg2ExrLP5TDz5E6+hwJzEyaG29Nnkjekl/bXtFI9a7GTu9/Gy3 nDRrnWsJQi9z
8UznOCy/LgAaAF3+6kHN+lEgRwBdVdEIjrPpeWzsIgfoI+/MmTq3j4pI3nhq 6Z6nl+6ljYkz
S6kIjD7SOacIQOtvAv5FH3+vLaavora2KLYS/YlvUTvUJb+fhIF8M7LU3yX6 CYD6e9j5pvE1
a3fN+46+sHzfrHY7pscyEKWN5NessyOQwxKWcD1hsiThL0de+Q3vfO+q1iy3 DBBjXcv5Mb/C
dd1YdcOfeCrTJs5QTLdpLoN0wayZtdwwGleOSfbg49ATwAmLK+OszDgOnKxV igVagUPPjDiL
me3Q4ORR0lmZHnZiz4v3cBV7N3LbClFn1vUuA62X6MxtIaRNj83iVotYM1su fyx67uxoMVdP
d27PdfxZFR1RkQmbfSUHH4Zvp8cB20x5EtnKj8foU0h57Jnoqn5jTKtxADQA eloLCJXrRIEc
AXRIINmrqqiY/S/BsTfvmTI3KPZM9Hz58iUO0IKbqbzUeWjBi1s7Ortpg14W BjsmBju6Xrt5
vP/htQtaorKwxfDK/qBPvpfU95PYiNFBfre7kSJtE383iS8VsaHp1vi2t7/l vUqlds1CYcJ/
F1t5g3IsTi3+Ha/a0aMslh5gfZ2Lr2UvQCdfq/ob1pJXeeufDi/NsOmQP7gn Dhua6FHLCeBf
8+JNtceaOL8+zjJIYwVjv+NGvEr0mZhYY2IqU6bAaI8DtL0yzZUWOCNqCpTY vItocr1K+g4K
G4P5a/s9M+fDlTK7Lpsht2HZmNtCVpvJwe2tZWUkeG3Sshwk0Man3ta2fJ2c oiWSumLEn0LJ
nzre2DkHH7L9yZA0Z3x8uTvZ4tEOOGbWWo1eXqvp2TpX1zGHnH7NAqAB0Dld mnCrogrkCKAr
Oi67MYJj96pBTs+FwjgH6DseXh2XzvU7jqtyS9vGyYv7qHStuq3w0fKVj15V OPIAlSCATr6a
5Zekl1D59xmnWIs87G8yc7DZX5NeOPYikfvFneaewlzj+1gE1iNI8qaxKFsd vrLaF8Mq6pv8
utdQb3C6rUZs5vFThNciGpFxQdfGlV2wgdFFTBMqZOdOnJXHmbYMvBkRXmPJ FqYbhmNZU2CI
n3HG4sYY+exYjgkd3dn0LmPVjqVk2mBtWHQ51+w6IwLtiek6y0AfW4oTSwFo TY+ZtaSZD8SN
dSh/3hCLKP6dQC12Uwdvv4mk+tBj2Rn6dMs313oNWZPIWd04Wn1yZdSVPrFT VjG+jNOHqn5h
TK9xADQAenorCLXrQ4EcAfQ0I9DZehMcW/fcsOh5cnKCA/T1sztFocDzPY+t W7K+Z+mGnuvv
7iwMPE6lq+Pz44fuWzG3ZeXcFvo3C6AZB8Rfccn3nJcLrd8r3e8bznA2GiZe WPujbyaewuiL
LvMYkhcTZSDTbCe7liFKKsP5pdNf/+EALWjIwSlXDesUQntApjHxuxyZDYsl AbRFxrUAaOG9
ZwoMxz1wk4jv1bCoJu6P72UDtD2r7HXaUeCefcmJLlrXXAa6lpo5t4XUNtkh kllL0mumb56R
ltcvO+bspWudDZrXfarzIhXZZmeDOnxt7/Q4aZwUiB/XYk/oxFP/hmLFz7Mn OmfftgBoAHTO
liTcqYoCOQLoqowvaZTgeHDwxNDQ6eHhoZGRYZeer1y5wgFaOXPd7cs+d/uy 9rcPtr91kDYK
fQsKffOX3ttCxe+w/Z1k/h6qrln3AjQDVCMR2U8eHDPTvhQNAJUs7YE29kWv AJr98GtlRSdM
7tRiP8pLh/a2tcpLgwK+ALlJxHsqkCnjUq7/hgTx17IduvVPh2rdBvhWislJ hx0b2ZTeL3u3
3M746cCnj51PTB6lTKx5HZXjRnoKR+oUuKdAonc77Gc6xF6lzghrJFktbFwh SpotWNOqoEz7
4hFN98wlLVqXqrFlINw2+ndb8LTpzKO3lmw3cd7fTrRIHSeSsyIjaUedNuhP HXO2Ms7f5GJw
5tpfxTTz1nV3yjn11U2mW1di0ijCVpc2VPXLYvqNA6AB0NNfRWgh/wrkCKCr HYHOpmeaKi9A
0/5Zt76yaMmeRa910cars1uoZM1rjHFmWqEyT4EC9uUhf5wVP60qc2uDv1SX diW5kMZP5/H3
qIg9Rr/5Ws1yWlJG8W/D4qp3o5bbDlV3ajk/3GsLb1aCDbDMKHZAfnXa/vsF 5uiXNJw2HXw/
50X+i79l45HdyVUwo3SeG7eltWmSq1At82SAJyrwH76FNPwiwowpSAhae+Wk gjihxSSB31xR
zozYqy4BPr0OJRa6DsemejI9aMxWHh97sp30rQU02lCu+eo64GusIH0tAnM7 ctdp04O8fhuZ
jiHZ0LFxx2IcMwH9epe6Rm01c+4qMi4ZlN2KebEPtXghqcwlaequrli+InWj EfH7c8hLQHi2
Se6/VwHQAOjcL1I4WAEFcgTQFRhNehMExxmxZ1EvA6AfemHnvBd2EEBPy0ke 8JtWQ9WsrIJg
JXVSXq2SuihqPFPy+ri9qLM5MfDCaU58szAsX17VozczvlBn3IFazRoAGgBd q7WGfmZSgRwB
dLUj0GmZG0r+NIAmA0Ln6dKzvjxpJuc7rW8WSi52rwzWRHm1qjT+GWP4+saC OD5ZwpxXafZS
mo3Dkez+wLXtvcF6m/GFOuMO1GpCAdAA6FqtNfQzkwrkCKCrKgPBcUipqg9o HApAASgABRpe
AQA0ALrhFzkGSArkCKCrGoHGZEMBKAAFoAAUqIECAGgAdA2WGbqYcQUA0FlT sHnhZ1WZ8amC
A1AACkABKJB/BQDQAOj8r1J4OH0FcgTQ0x9MZVt4485reIPWy8r2hdagABSA AlCgMRQAQAOg
G2MlYxTZCuQIoHOVwkGB5/HTz1G52PfE0O6FxzbM6V5+Fw9I0zbWFhSAAlAA CkABSwEANAAa
B0UzKJAjgK6q3CFXEPK7cER8PLpdl8LZKSp8z+h2MHRVpwyNQwEoAAXqUQEA NAC6HtctfC5V
gRwBdFUj0ATHPT0HROnt7e7vPzww0Gs93NsG6JF3p0S5fOor87ZRoQ25J94P gC51tU3X3v8Q
h+m2OmP16+6uXkEOV+K+eEEdlTVvuC9eWbKhUkkKAKAB0CUtGBjXqQI5Auiq KqgAOo2e6eHe
HKDfm/+ZqbNviELoPPeZrVQihh47GpWzK2h/ZOP+mQ8uq8oNdrPxonrwUbEZ sh7u5nvqnrcv
L0DzBwQWv2Vwetf8qYriaXve1io4vzWbKbuj6emfuQzkk1l0D2UdAYHKlDb1 id/+B+64j/Tj
45zOu45eTH7+3Hj9CMmoht2jPWfGM0aZyPaTC9M8X6yeWZ85nyFuhDUgno/J xY+GxB7Y7X18
q3VUiq68OzO8yLa3Flvg2sscNAAaAF2xb0s0lGMFcgTQNYhAZ9Dz6OgFDtBr H5w1daI9KqOH
iZvnte+c376DNjY80kKFdlJZ88AsP0Abj4au+UMqKvEFUKMVW6qr2RHokloz ja2o6eJW84nW
XA5ecZrB1pIcns6UZJwMFD/lYB0Xd5jxUXHj9CEF1g00s/uRkG8BsoBQz3t8 nw++1RN8fHV9
Y4yWlyLBaALcFrLbFF54bCJSNM5YvO1IFg+Y+hA3Mham57Biz5NSWjKQlnTM nh+vhyNk87ZZ
qg+GfZmrKOuABEADoKfzgY269aJAjgC6qpIRHGfT89jYRQ7QR96ZM3VuHxWR vPHU0j1PL91L
GxNnllIRGH2kc04RgBZfyNG3Af9ujb84Fkf72+j7jsWd7MhUVLe1lR4UF30r yjfld4j88tOh
Ff0943wf+Jq1uxbfS/KPGrcwMe7Obkfihhk40kZObMn9wrZc1XWT0Vh7hL2q JX6Oj5UUCou/
ADBQ8yIm0PcVGgidyszq34CphENcG0YKeiGweRdhu9hB30owpiCZJHtdpStT nv58JVhaW/FF
NTpnqfMoYmsbC/brKZbjVfPpLD82LrJNVdJZ6p75Zk+x9Mw7f8Yl31YQzJar JYh3GehPDdGZ
23umP7JNj40TVU5vxxim72MkcjLEDf7BYQULUg4hNcXS3DkpkfW81dN2qg+v IB+MQ8I9CoI+
QQDQxypOyRkN3nbb3I6XOwsTk7RRVVRA41AgXIEcAfQ0I9Cietq/BMfevGfK 3KDYM9Hz5cuX
OEALbqbyUuehBS9u7ejspg16WRjsmBjs6Hrt5vH+h9cuaInKwpbMeEbyJaS+ jMRG/BEuv3jd
sJa2iT/LBSmKDU2Qxpez/aXsXQKpXbPIlQWpXryUY3Fqud+4zEcdd1O+Od/i ZhRQty+b4b6p
ljnChn/z8a69QqZ8+zuwLbTw0gybX/mDu0lasgvfMNVZgHgz8tC3EvyCO+sq aCyOG/GyM2bE
Rh+yMOKdRj98XuylbipuzYVY4fzHfRfTlVuM0eNIruOw9yizMbgoIvMfldK8 MYkzWeS6aZe9
9QJQMjrLiU9x3GbyaeH6rDlYnncZdc3uteYpHyMWQKe6wcaZdfJgfB5FQ6Az QhGG9yzO2NW0
ozLjJz33g7RYI57fmtIOlvAv1akpRKArztYA6FIWIGxrpECOALqqIyY4dq8a 5PRcKIxzgL7j
4dVx6Vy/47gqt7RtnLy4j0rXqtsKHy1f+ehVhSMPUAkC6OQbSH6PudAgvku8 YWCLEV3G5R64
XwBpzapvLy/BuMwQ0o6OBKmcx+Tb3J1grwhSBzOJQnwRaoBjbWYCtHLZRuu0 rv1wz1y35VVf
9nzkMRskxCLjglw99aOCG+xXw5R9xlAgo+yMNgwpVNeOaAZfOhNQnv4yBdWT 3JwK0NZasjQs
uvwEM1nLj7OXe0TwBSPGnTXj2QBtdm0DXLG61jLQk6Bwz4vCFlIn1TQRZtaS Zum+pR817JCh
X8iKupFo62QzRz+ZpJ3QFjn6kmOq6G9W1udeqA/iTCPldwMAdF9NQ8uBqA2A riogofHyFMgR
QJcdgQ4ZOcGxdc8Ni54nJyc4QF8/u1MUCjzf89i6Jet7lm7ouf7uzsLA41S6 Oj4/fui+FXNb
Vs5toX+zAJp9HMdfC8lXmhcaVNzRAoLpAHT0fZh8EXk5Q/yGnIE4mtXMdrJr GaKY31heSLUE
sTjSAugYKXWwMRsTvevD+Jp0I1f+tA6bw7xnILo76iMOTqe5F4J9IuCYAdBu 2M975uNFmTIB
WozQM6dVBGh3GU8HoO1gMHudzU+ed4vWNZcBPy+i35SkkhbMpbbJVqprw0cl HE33LR2g2eES
4oY8s/GcThkXDJoHYfbRJ9/1HZWpbeoTC7MnbyPmArbmFAANgA5BCthAgamp HAF0VaeD4Hhw
8MTQ0Onh4aGRkWGXnq9cucIBWjlz3e3LPnf7sva3D7a/dZA2Cn0LCn3zl97b QsXvsP3dwAJW
cWxHkowXoBmgslQNX9wxskz5zkj/PpAQ4sEm9jWjcVn/xGo4I+JxkQNOLfYb uhRnb1trlHrC
YYfJlqJVMrAI0fwpBCyfRUcW075DiwO078qktO9Rv8/aVd5bhE4Uh5MKODYa FHzDVN/yPEpt
c09am6bkacqUq3/qnLrnVNbMyx5Nh9grd4nKN5mryfJjV/yFKGm2kJEVYk6G NZ88yKkzsMzU
I/tSRHMZ6ONHNa1AVSnh7pHHEPs48dbSHy+xpb8dY1KyDpsQNzLqxx949lWA 7oeBnlB5OsFm
wKnubbM0H6wPJXV2KuYj7cAv5fsJKRyBceVwM0SgS1mAsK2RAjkC6GpHoLPp mfT2AjTtn3Xr
K4uW7Fn0WhdtvDq7hUrW5MQf8N47MhmfzR6K1Xdnkr9+2rSUNMD3Jz0ZFxGa V9SIUGF0dZ34
UdXXtXFnqPhLWI1D/RRrt0MqqF3q2j0+fAnZ6df2Wd9Vum7YRYQiN5z9Uizc Sfvd2Jg152vS
mLckSd1V10gk4F3ZA0++jPkv/paNZx6dXAWVvWCFsX1rwDrP4SjgV6Y8/dms O1InBM2n0rve
mBRcbL1EnWPIs/ySBajXgLWEvF37zzxV83ztJdvJm3q8BrJl1hVMZp9HW58R TgtaZHVkm5yZ
sKa+9jRBbHGsy7M2TzvGEo5aN+fC/HBzHbPc4B8B/qwe89PID6n8yOCt2Eel OqpY1lLR29o5
jWifk0BEShJUud/CAOhwMg60BECXuxhRr4oK5AigqzjKGI4zYs+i6wyAfuiF nfNe2EEAPS0n
M35OnFa7Fa3MfrYtod3yapXQQTOZViIGNlN6ZcQCZ8olu9+6OAzzIlZt/ajn lc+VAkAHYnG4
GQC6tociegtSIEcAXe0IdFrmhtIpDaDJgNB5uvRs3BQqaG5qacTiSL5sxhRX yqtVy3HVZV/1
jRFxvK+ERVTbKYp/tEiis7XtGr0FKODG+gMq5c4EAB1OxoGWAOjcrXI41FQ5 0MTHRQuWBBSA
AlAACkCB6SgAgA7E4nAzAPR0FiTqVkmBZolAV0k+NAsFoAAUgAJQgCsAgA4n 40BLADQOsRwq
AIDO4aTAJSgABaAAFKhXBQDQgVgcbgaArteDoaH9zhFAN7TOGBwUgAJQAAo0 hQIA6HAyDrQE
QDfFkVNvg8wRQFf1IsJ6mxf4CwWgABSAAnWpAAA6EIvDzQDQdXkkNLrTOQLo EKmLXgUoDFRT
L+9YP/etZ6nQBu3c1fkPnU9dQ4U26OXqTV13P7aBCm2E9A4bKAAFoAAUgALZ CgCgw8k40BIA
jYMuhwrMPEA/vug3bklTiuC4p+eAKL293f39hwcGeq1ndHOAvm/lMydP/5rK fW8+Q20SOl8Z
PUSFNuglofOxs+eo0EYO58Z2qb7vblYHAsNFKAAFoMD0FQBAB2JxuBkAevrL Ei1UXIEZBmhC
Z++Q0vYrgE6jZ3pGNwfoHyx/+ujJ5/pPPPeD5U9RR28/cfWV811XznXRBr38 3qPrewc/6R0c
/t6j6zxusAdYqTvHep83F9eN33HvMGs8BWt6t8etGUDXrKOKL2c0CAWgABSY aQUA0OFkHGgJ
gJ7pRY3+PQrMPEBPOn9jl8azATqDnkdHL3CA/v6SJ7qPPkuFNmj0q35x1eTH m64Mv7/qsavo
5Xd+uvrA8SEq3/npGkcb/ryyxa3qEcsakc1HMkTQyR4qrZqzHiY8nUdM1Ixr a9YRDkkoAAWg
QMMpAIAOxOJwMwB0wx0ljTCgmQfoy+PjVAiaRTl3/uKps8MZAJ1Nz2NjFzlA f/flx3b1/IrK
915+jKZrxc/+1cSZVZNnVtEGvfzmgnd29p36sG/wm/Pf9gG09Tg15xHADDTF puchwRaMqpc6
Mh0jufEE5OS52K6NwHe9P+H6iN1bxF+0S9K8eCmt5WB8bbbR09lUXdY6ntjW CIc4xgAFoEBt
FQBAh5NxoCUAurZLGL0FKTDzAH1x7LLEt+S//pNnBUCL+3LwfwmOvXnPlLlB sWei58uXL3GA
/k77z9/f/9Tm/U/TBjW1bOG/nDjZMXmygzbo5dd//Ob7h45R+fqPV7pqyYfK Kor2xGUT0o2J
NWJbl6DtWqKKqihgV1aVXck3HRtpGfklLCV1R/8lrCveVHtUlFw65mtTBcWV 84hABx07MIIC
UAAKeBQAQAdicbgZABpHWg4VmHmAJuylqPPwuQvDI+eHhs+fPPPxkYHTGRFo 96pBTs+FwjgH
6G/9+qdrdj9J5Vu/foTUX/LQv5g4+jSVJQ/9Lr382o/eWLOvb+2+3q/9aHnq 3AiOJmLNAGj9
VlaUOu4iRlgzMVoSbAK3i1tVTJqfWcS16B07JyTZLwcQO7BYQrn2WdU1TlbM ujw6juBzDg9W
uAQFoEA9KACADifjQEsAdD0s/KbzceYBmoi578SZQ/2nqHT3ndx3+Pie7oEM gLbuuWHR8+Tk
BAfobzyzYOX2RVS+8exCmttXHvzURO8jE70/feWBT9HLr85Zumr34VW7D311 zuuZM6/CxiZX
JsRp8bBh5E3h8Id4aW8cnFZ5GhbFVgSgvW2KwQOgm+7wx4ChABSovAIA6EAs DjcDQFd+maLF
aSsw8wBNxLxtT8+mD7tF2bjz4Ps7D2UA9ODgiaGh08PDQyMjwy49X7lyhQP0 s50rv/7L+VRo
g7Si2z+//KN//nLb74j7QL++5sBXfriECm3YSgqaNcmS50rEsWSROWHkL9tZ HAYrq+wLnYbB
+436pGTmOM9ZtG9kYWekcCgsFhFwF4WdutbQbICe3v1Cpr0s0QAUgAJQoF4V AECHk3GgJQC6
Xg+GhvZ7hgGatC31PtDZ9EwNcoCextzxsLIO2/K9+rI8I6xrZnEY0Wlm523e RHF2OV+M6hyL
/Vf9yWsIPbFkT12zTR6BFvDuuynfNPREVSgABaBAUygAgA7E4nAzAHRTHDn1 NsiZB+iSFCM4
zog9i6YqBNAl+TWjxrjmb0blR+dQAApAAa4AADqcjAMtAdA4xHKoQP0BdFrm hhIXAJ3DdQaX
oAAUgAJNogAAOhCLw80A0E1y7NTXMOsPoImPi5b6mgN4CwWgABSAAg2jAAA6 nIwDLQHQDXN0
NNJA6gygG0l6jAUKQAEoAAUaTwEAdCAWh5sBoBvvMGmAETUCQIsnrVTjb/PC z6pSjfbRJhSA
AlAACjSYAgDocDIOtARAN9gx0hjDaQSArtJMvHHnNbxl62WVOkWzUAAKQAEo UNcKAKADsTjc
DABd10dEozrfCABdjQg0BZ7HTz9H5WLfE0O7Fx7bMKd7+V08IE3bjbomMC4o AAWgABQoWwEA
dDgZB1oCoMtejahYPQUaAaBD1Cl63aEwUE1FfDy6XZfC2SkqfM/odjB0iPKw gQJQAAo0lQIA
6EAsDjcDQDfVEVQvg20EgA6JQBMc9/QcEKW3t7u///DAQK/1VHAboEfenRLl 8qmvzNtGhTbk
nng/ALpeVjn8hAJQAArUTAEAdDgZB1oCoGu2etFRuAKNANAho1UAnUbP9FRw DtDvzf/M1Nk3
RCF0nvvMVioRQ48djcrZFbQ/snH/jEcPxk/ENvbEjy80baJH/i1uu9Z4nCFr N/Q5KUmjae2E
yCRsXIeL1g11Mm7c8tBWw3h+eVbP4Z1mtSKeupg8xNG1TN736ZpZl42LP57d 7MtuwSeGrxfL
K09fyfMk9RMlnXa8tSIFFqsHyrPFUGRhpUxjvDtgTWYOXD3UXg1BP+be90xP 08w93Pa6h+C1
5Cb7Ex7b3RVxUhzI2cup6KEEg/pXAAAdiMXhZgDo+j8sGnAEjQDQ4RHoDHoe Hb3AAXrtg7Om
TrRHZfQwcfO89p3z23fQxoZHWqjQTiprHpjlB2iFC4LwOOeJ53x7IXK6AJ2w bwCsFFnIrsMV
XPkljT2730oANE2IAHbrMeqy54igUoG+aN2kpny6u2uf3YKo5rFxvVrcavUV s5/hubcdu5Y6
e5KriElsPqI+e2a0bdRAa2vq2aG/GaVX4l7ihh6m3BPNml7we9taJfcaFTPO TuP+o+68Pjrd
cXeTMSpdkzcrsSwreMChqdorAIAOJ+NASwB07ZcxeiyqQCMAdNFBkgHBcTY9 j41d5AB95J05
U+f2URHJG08t3fP00r20MXFmKRWB0Uc65xQBaPHdanyhxrtKgEgd84o4Qb9K obqkZTu2aOCh
/MpPjT+mONwWhWqtCHr8UsTpBMeY/iZ8ooJynrc9MWlfO463rClOP+ykxeew dXrB6MfHPSwS
6051kbqsgmjatc9sQU6ZxybTKzkMxybbW3Pw+hXbH86FbLGpkZdwWuc5lXEg NVpztPaKQn3K
4cYnU3
| Re: [AGR] Hang problem in AGR 4.4 [message #104120 is a reply to message #103987] |
Tue, 10 July 2007 13:43   |
Barbara Rosi-Schwartz Messages: 448 Registered: July 2009 |
Liz,
I notice I did not answer one of your questions, the one regarding the
AC. Since I still have Eclipse 3.2 installed on my machine, I also have
the previous version of the AC installed. However the only instance of
Eclipse that I currently have running is 3.3, so the old AC should not
get in the way.
I am only using the Integrated Agent Controller and it is my
understanding that I do not need to run an independent AC. Is this
correct? Also, it is my understanding that the Integrated AC is managed
automatically by Eclipse, i.e. it is started and stopped as needed. Is
this accurate?
Thanks again,
B.
Liz Dancy wrote:
> Hi Barbara,
> resolved.
> Sincerely,
> Liz Dancy
> "Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
>> Hi Paul.
>> Thanks and regards,
>> B.
>>> Hi Barbara,
>>> Unfortunately, TPTP has not declared support for Java 6. That said,
>>> capture the symptom in a defect. Can you try the same scenario with Java
>>> 5?
>>> Paul
| Re: [AGR] Hang problem in AGR 4.4 [message #104204 is a reply to message #104120] |
Tue, 10 July 2007 16:18   |
Liz Dancy Messages: 77 Registered: July 2009 |
Member |
Hi Barbara,
Thanks for your replies. You are correct that you do not need to use the
standalone AC for this use case, the IAC will suffice and should be started
automatically. Could you confirm that the AC is in fact running by going to
Window >Preferences > Profiling and Logging > Hosts> Select 'localhost' and
click on 'Test Connection'. It should report a success.
You can also confirm the JRE version it is using under Window > Preferences>
Agent Controller > Integrated Agent Controller.
One last thing...could you send me the workspace you are using? I am going
to try and walk through your setup process and see if I can launch with your
workspace. This should narrow down our root causes.
In the mean time it may be worth installing the standalone AC and trying
your tests with this instead. You will need to stop the IAC first in this
case.
Sincerely,
Liz Dancy
news:f70ggv$mdb$1@build.eclipse.org...
> Liz,
> I notice I did not answer one of your questions, the one regarding the AC.
> Since I still have Eclipse 3.2 installed on my machine, I also have the
> previous version of the AC installed. However the only instance of Eclipse
> that I currently have running is 3.3, so the old AC should not get in the
> way.
> I am only using the Integrated Agent Controller and it is my understanding
> that I do not need to run an independent AC. Is this correct? Also, it is
> my understanding that the Integrated AC is managed automatically by
> Eclipse, i.e. it is started and stopped as needed. Is this accurate?
> Thanks again,
> B.
> Liz Dancy wrote:
>> Hi Barbara,
>> not able to reproduce it on my machines however other users are also
>> reporting it. Could you try executing a JUnit test and if that is
>> successful, a Junit plugin test with TPTP?
>> you choose the All-in-one package or the runtimes and/or the update
>> manager? Do you have previous versions of the AC installed on your
>> machine? What specific JRE are you using?
>> resolved.
>> Sincerely,
>> Liz Dancy
>> message news:f6tsou$hrn$1@build.eclipse.org...
>>> Hi Paul.
>>> idea?
>>> Thanks and regards,
>>> B.
>>>> Hi Barbara,
>>>> said, we would still like to confirm if this is a JRE-specific issue so
>>>> we can capture the symptom in a defect. Can you try the same scenario
>>>> with Java 5?
>>>> Paul
| Re: [AGR] Hang problem in AGR 4.4 [message #104594 is a reply to message #104578] |
Thu, 12 July 2007 12:34   |
Hi Liz.
Apologies for being really dumb, but how do I remove the old agent
controller? In version 3.2.2 the AC was already an integrated one and
therefore I did not have to download it and install it separately. I do
not have a standalone AC running on the machine. Are you perhaps saying
that I should disable the 3.2.2 Integrated AC? As I said in one of my
previous messages, although I have both 3.2.2 and 3.3 on my machine, I
am not running them simultaneously.
B.
Liz Dancy wrote:
> Hi Barbara,
> I am still working on getting your workspace going but have tried an update
> manager install with all available options and the
> eclipse-jee-europa-win32.zip as you described with no success (at
> reproducing the problem).
> Could you try removing the old agent controller (RAC)? My hunch is that this
> might be causing it. If this is the case I will open a defect as this is a
> supported use case.
> Sincerely,
> Liz Dancy
> news:f729vr$7gm$1@build.eclipse.org...
>> Hello Liz.
>> There is a problem with sending you the workspace. Zipped up it comes to
>> 21M and the NTTP server complains that it has a limit of 10M. Do you have
>> a public FTP site I can transfer it to?
>> Yes, I can confirm that the AC is running and that the JRE version it is
>> using is 1.5.0_11, as I specified earlier.
>> Tomorrow I will try the standalone AC approach and I'll see how I fare.
>> Thanks.
>> Cheerio,
>> B.
>> Liz Dancy wrote:
>>> Hi Barbara,
>>> started automatically. Could you confirm that the AC is in fact running
>>> by going to Window >Preferences > Profiling and Logging > Hosts> Select
>>> 'localhost' and click on 'Test Connection'. It should report a success.
>>> Preferences> Agent Controller > Integrated Agent Controller.
>>> going to try and walk through your setup process and see if I can launch
>>> with your workspace. This should narrow down our root causes.
>>> case.
>>> Sincerely,
>>> Liz Dancy
| Re: [AGR] Hang problem in AGR 4.4 [message #104673 is a reply to message #104594] |
Fri, 13 July 2007 10:03   |
Member |
Hi Barbara,
Your question is a good one...I had assumed you had a standalone AC
installed. I don't
think we need to worry about the IAC as long as you are not running that
version of
Eclipse at the same time.
I do have another suggestion though, so we can pinpoint what is going on
with the
InactiveProcessException, could you install a standalone 4.4 AC and set its
logging
level to debug by opening the serviceconfig.xml file located in the config
folder of
your agent controller directory, and changing 'INFORMATION' in this
fragment:
Logging directory="%TPTP_AC_HOME%\config" format="CBE" level="INFORMATION"
to 'DEBUG'.
Next, run your test in standard mode using the standalone AC and then attach
the
servicelog.log file generated during the run in a reply. I think this will
be a good
lead. Thanks for your continued patience.
Sincerely,
Liz Dancy
news:f75l6b$tom$1@build.eclipse.org...
> Hi Liz.
> previous messages, although I have both 3.2.2 and 3.3 on my machine, I am
> B.
> Liz Dancy wrote:
>> Hi Barbara,
>> update manager install with all available options and the
>> this might be causing it. If this is the case I will open a defect as
>> this is a supported use case.
>> Sincerely,
>> Liz Dancy
>> message news:f729vr$7gm$1@build.eclipse.org...
>>> Hello Liz.
>>> have a public FTP site I can transfer it to?
>>> Thanks.
>>> Cheerio,
>>> B.
>>> Liz Dancy wrote:
>>>> Hi Barbara,
>>>> the standalone AC for this use case, the IAC will suffice and should be
>>>> launch with your workspace. This should narrow down our root causes.
>>>> trying your tests with this instead. You will need to stop the IAC
>>>> first in this case.
>>>> Sincerely,
>>>> Liz Dancy
| Re: [AGR] Hang problem in AGR 4.4 [message #104688 is a reply to message #103987] |
Fri, 13 July 2007 10:48   |
Hi Liz.
Further news from the front... :-)
We have decided to go back to step one and tried a totally new and
minimalistic Eclipse install and this time we have managed to play back
a simple AGR test (yeah!...).
We have done the following:
1) downloaded and installed Eclipse Classic
2) ran the update manager and selected the Europa Discovery Site
3) selected TPTP and then clicked on the "Required" button to add the
TPTP dependencies
4) downloaded and added AGR 4.4 on top of the installation.
As I said, this results in a success in playing back AGR tests.
Our plan is now to add the other features and plugins that we need for
our development purposes one by one, at each addition testing whether or
not AGR is still working. This process will be a little slow and
painstaking, but hopefully we will be able to isolate the "offending"
feature.
Of course we will let you know the results when we get there.
Thanks and regards,
B.
Liz Dancy wrote:
> Hi Barbara,
> I am very committed to getting to the bottom of this issue for you. I am not
> able to reproduce it on my machines however other users are also reporting
> it. Could you try executing a JUnit test and if that is successful, a Junit
> Furthermore, could you walk me through the setup process you used? Did you
> choose the All-in-one package or the runtimes and/or the update manager? Do
> you have previous versions of the AC installed on your machine? What
> Thanks for your help and I will continue working with you until this is
> resolved.
> Sincerely,
> Liz Dancy
>> Hi Paul.
>> Thanks for your reply. Tried with Java 5 and no joy. Exactly the same
>> symptoms and results as described in my previous message. Any other idea?
>> Thanks and regards,
>> B.
>> Paul Slauenwhite wrote:
>>> Hi Barbara,
>>> we would still like to confirm if this is a JRE-specific issue so we can
>>> 5?
>>> Paul
| Re: [AGR] Hang problem in AGR 4.4 [message #104719 is a reply to message #104688] |
Fri, 13 July 2007 11:45   |
Member |
Hi Barbara,
That is great news. I am certainly happy to know you have had some
preliminary success. I will be very interested to know your results.
Thanks again for your great detective work and let me know if there is
anything I can do in parallel to help.
Sincerely,
Liz Dancy
news:f783ct$9tv$1@build.eclipse.org...
> Hi Liz.
> minimalistic Eclipse install and this time we have managed to play back a
> 3) selected TPTP and then clicked on the "Required" button to add the TPTP
> dependencies
> Our plan is now to add the other features and plugins that we need for our
> development purposes one by one, at each addition testing whether or not
> AGR is still working. This process will be a little slow and painstaking,
> but hopefully we will be able to isolate the "offending" feature.
> Thanks and regards,
> B.
> Liz Dancy wrote:
>> Hi Barbara,
>> resolved.
>> Sincerely,
>> Liz Dancy
>>> Hi Paul.
>>> idea?
>>> Thanks and regards,
>>> B.
>>>> Hi Barbara,
>>>> with Java 5?
>>>> Paul
| Re: [AGR] Hang problem in AGR 4.4 [message #104728 is a reply to message #104699] |
Fri, 13 July 2007 12:38   |
--------------030509090303000404060105
Liz,
Here comes the (zipped up) log from the independent AC server. I cannot
make heads or tails of it :-( ... but I am sure you will!
Cheerio,
B.
Barbara Rosi-Schwartz wrote:
> Liz,
> I will try your suggestion and let you have the results (in parallel
> with the other feature isolation strategy that I have just outlined in
> the other thread).
> Thanks and kind regards,
> B.
> Liz Dancy wrote:
>> Hi Barbara,
>> installed. I don't
>> that version of
>> on with the
>> set its logging
>> config folder of
>> fragment:
>> level="INFORMATION" />
>> to 'DEBUG'.
>> attach the
>> will be a good
>> Sincerely,
>> Liz Dancy
Content-Type: application/x-zip-compressed;
name="AClog.ZIP"
Content-Disposition: inline;
filename="AClog.ZIP"
UEsDBBQAAABiAGuM7TahjIOZ+rgAAPWeGQAOAAAAc2VydmljZWxvZy5sb2f/ AzwKCtBlIoWO
PHCY8HTiu+UbF+8sJ8tXHKFbtS3vjY3dBFOzJqxC+b3knHekWGxiuyQ5uHqK OP8/cPlCMs4o
YDCC+cBdTmYB08C6wjsKRQhwpEVEqD48l+ekNYf4+v6CntTdTzT4aNigfe0H TV7rkCgxZUnU
3T13r2GORvPg6eDF4TDYvZjLI0vSNP16u8QQyt5gDNFokknRmbXF9TqgltoD xhW/HuXdy699
V+y8IqfWHbRzIXJEGVbl0ieA7eaN65DHoRjQ14hYD9CtLkc3UJeB3NCR7kJL 6vZT4HJQF+IE
gceRumR6MtVBqH5+mvZCKJHUoLuxeo9stCyV2pUXdo66sgX27jdNuIGIIe8f Q8+J5qT8CC6v
8eiGId4Hr12r/OtUZLHPSw6fpx+FsQQpppMZnJrHRlLfDbhDIB08PiNqo4O2 TfFzU1wIEQfK
4kJ/PODFO+9pzFWQruXaaEC9vB/X7HWPdUOJ56azRNEa+E84legfw194uN// fBKGxDvLzyAE
NvVs3UpqG3sH+msoJ/VUZhBmalrfzmSYlE2xGioIUrJBcnLDlzvaUqi8gQjO hWGvGt0hKxvy
LvilhK6hRAbnwjHVyoizBWWxxp3S8rxfe1+tOcStQO2CyEf0iJah5KB5Teh6 GKee5v4hbnmn
RD96+TvbTP4/xrVxaguCN/6EpwAAAAAA2zzE+V7sSKK5wUu8GCAqeRlhDwRA xKZNcldsPrz2
EDEAAAIVAVqS1Ii3ALIpfu8hUSk+T5i25k0qb4yKyZqVYL35wP25XAcPGhby er9qr8Ou2dqC
lpgm6gXoGEP4QU1uaus1dD1KrwFt/w5g2c4B6Bs89AFX44mSyJfJFsQC3Igl 5KuheB97F6xL
rFZjdoLPXllyFE8vN+tfdbZyfBMi19AXeJxRUhEzYCMoFxBZNKVAac2VVk4F 2Oa5aKS1BWTW
119xF8WHHAAcr9ot9LlXvwNuJLjcH7uzoWigzRhNFiCoBN3wXrcSxWIo1o8Y FBh1+jXl32Td
BrjkKEDliO0Z4mSPHURp0fcZrdJME6HwhBD75Oon1AlZ6zN6W+723ZOAYWRq YEeYplQi/55f
CdI876gxaVg5ECQvV0DovNInL8ZbLB3T7P4TNCikrY0iaelJaU8Q4DRp6NBW OROAKcidqkHZ
/DefHFOkh+LL1QQTfYfxmoBJqKRh+uUZuAJ7vt6cBu/xrACPe06VUCrP13yB HvRwegeyOT4n
pgt37pgxb3cGvQkmQibH0LvYMS4lCj9RiknwpJZWyFxjel9Fn7n2CqWOq+KW NxtQaffdWRot
BFXze0DLyFsfF6BqVJvTQBWXaNm+zqA0o0iddRfqo0id4ao/zCF6RQXrNkcx PJJe3TAkjyCO
/8sK4QmIeFKhJ6vsQxjEmehMgoIeBSfhASjnuAWXXEA8S7bsgouYYRf3LKKs 12hvl0FhQ3rv
S4ps90PGa/gB87IjUJ48SjSBO2Mj8npCUKkqjZo0es2z3MgnL81CFf/yXO82 G9t3vudTMmN7
1n8HBXAw/qE4B4be1UmcG+FGPexMmcaMpODeUM2HFFkbgE5ab82HLN5TLC76 jGfCV+aioDkh
t/rFJfNG4a6V/gZ+TRvkxBU9Xy/k/Wwc9S2WzprYNQc0R8/OJ9ah1wQsJGWN 0VoJ/3xX4jtg
cNO8jtGx1Et4xW2W+r1ARDID/HdQouG6cmBDjyAts6cgvAspqO6xU6atHWx4 TUxotjLrDPTl
oIvPSEsF/WzaSYUmfsQ92zTdLSPbSzYWFWuANXQfyk5mwO3IAdaNKw7CV/g/ K8XwObauXsOQ
U3Fnddi3rDlg8xXq9nQg/7EXVY2WSdYoqepWkuN/m5PPXKuEsKH0AZ4G2OPl bmgDqr3lzvRA
PMGy3Q/8+kXahpL3KPNVQXp2O4dmCPxw8fVV6Uw6RQEMZXXKxQPap7318YaW JjbG7OR08H+m
E2s0TfWLUjV4R7fPkVmrdctdDeq+P1P1raz8XNRV384h9KLkaOSIyiPNr0q4 84ekkdmHmPaG
t++WqbtCNIbtg2tv5z932ErJ8Kn9VXxIzfUsbJqmEJpbL/kL0WonvEWieFHn IPuIuQV7Po0R
lzaMluIFJyOz5XXWLQGbgCEhNMwbYKFK8G+7AiiYQGMwI+PipH2az2pxlDNx o1E6QoAHkxZ8
Eq5VKGQUKws140bJbh0XVLUh8cORtSRl9GSrS9QJDasb/kPWeF44/BAfCU5f a3/NlKnADmHx
FbF5P+F7lor02Y6wJaWUxF5ZbkCqvgVh+nHK7+osu6fAoz1hFRdoVFoxZZnK +n5KqbMR8am7
8/pq6CCk/FWyYRjlxkBUJj7zB0NB9o4UDqkO7zYdRJtqAzlOFmYJhyDBE8fn 2BFDq+5PxE7l
850zum0Cdmfs7CxIajblSHyKh3SxtO6oyILJuJx69ZBUlnNsfRsltNPNnAmD WrXKQ2iEMBU4
ak+9t2HfXklcwhGxs3PbqCoyF9SDFHWI+HsJzIBVYW3OtmvbV7CSwBXytOVf hXvKMODYl+PW
yS9eBYmSB9nHWpCPt3k+3Xa5gMeBzaxE0rvuazdMJBoHd1FzBCg3cXcqHZXm UmMWjf634QPG
ImC76dc9+7I/Oh/fOmcwvrYSR7Z5WAOv/9w2TzzDv3/WeF2hSPJHhDoZvgN3 iZ2v+0kkDR4L
ZDEWx+PCgcUMFqgPs5b5UhGWGNBC+pPkMDuneC5L/cp2gPNS4Rdk7hzjPLax c2dZQXWm+Vrk
YyoNas+hz7N7UTzApV4T98spY+KIh9NhZtMo2+haiA1Hd9q4tMt95ebVxcVq F6i39SeQPV23
iXiEHTdk9N/1WdkWU5mtr3vuzGGhE6aNocLV7ZPEswJr/uOsh/ravZmNTeuc iR8IKp6uOzBv
GIQwv7aVe0HiTUNK1TP+wV+g/JnVm8s/av2KYqWINpHVE+kP4V8r2qeIehkA WPDu14/gIW50
xUQNQWqFo+QUL2OawXyugv93q9uIwcfm52Woaf1FbLP/gAK9qNP8iENx54ev SdhUEMWBir+w
ch/wO3IwMYKwZnDS3W9XFvSL9tqv/lNz6v6n/etUhvaJ79rHXIMi++b3yopo bgOABmXGKU8n
kKnOAMvoDe2s6BrFRxRGQ+TJ01soyYKkzVT3wTHXo7E7tryJmyZvpx92rigL HMMGlWKSdPot
3+02uvZwTzeXHrEz4JdIweQdnMoweGm+HuOrNG5tH31hCzqUdRhhOOcamDHi WdZdg50Q6l5l
n6Sy8LqWp0snXKaH7q6kHyn3C86iB+ZXJdVYuLxCLSi+50Cj7zFtncdrJ/C+ qHCzpHmVIlxJ
2eDomw18kkG2CsjWn10/8l8ELSOofQrHWReRIMDVwcgeLgnAguaDLvywlgkh 7qQJT5HwBQVd
DI1Awi95Jw1RWlQDjtAZZNccnhbGmWVwfFXfqjhHG+qVaH1OAoJ0474mjUuS KOyno2LlKQx1
AOR8BJfDPDjAm2xwoMylHi5UqnmUJybqqzvC3fIUqo9K3b4nlv7NvKtxP3By 16/j5zXDEb8e
N3n7ICQEFjKLHCL6sey1pSvxGSrU4+MfHSCASGF3nQJ1ZfbpxrmUXz+s0dRL /imie+bE6J7+
CZIKM5DcpNkM4zAEp/e4r9ycpuKOxiYGQkk4imxzAoA9ryHecCtF4uwCQTjC tTJz5W7Jsh7P
ERY8y/zILyZUclyUBV/Q2e0FrR/vLPCHvD+81QFyqzUq03RroBXix7oU+Ytd VMwWstHgftb6
CHFt5uzX5Bn8nZIolGgAE4fPT094eDBX3funmPbtSmga6j8hN6D4aEF0xxKa HzRZ+RhyhZZx
O5i4F2Ye61DG70ssqL9eQ8POGeHolwTyWZ6inWHKdwAlwQxbl83Kqq+7QvMh bpDs5YhbAXD9
j0z1PlChSnY73m5RNUwdZFmfA8pogp/+pi+hEJK2wcq5wVcJooWcEAg942k2 SBAKh/iUFE+i
zFKc+uevcDk7Dt89Umvhi/WRu8lBBVsZJOfcW5yK6ytixo8aIZAA9UFXxFSa SKLr/5WGMp/y
4xBmftYT7YwGJL9EKLVE/gU6u6Fk4VNSQRoUjZrlcFifOsdWS5Ta0xq+vFau 2EvkUv/+8/vs
TiS/0hvQYi1Q/YOnsqwsxPe48JpVENTh7tfU+vfdRCNg4eeeidlDbUBkxkyG kkQyyNRQBMT8
Eazu3vjyI+8BEpDn0TBiXQHqcutyVDUpU6N2Ffln1rsgv68yazdS9EP79UFe +WIG+gwt3mj0
JVeQBlsy4uJ06qFk7gRF/aX53Gf2sZTtiNySjs0gwdKi497nQOuQ6kaHsLi8 WmeSFLT4PKmM
XUUbG7ncffoOPxiW+EMzlQkbnbvl+vy/cK680dCGWsan1WGpYGBf8SR3MFr4 mdP9VXH902OK
eKtUGe2tqnv9oaTYzQX/n+7h3EEOFzc9SkyiGrOgebSN8rBiKd5aQP6yoKL0 rleArRQGCRzX
fwZG41vB26OFgWX8h3nzkWLdTBGF7OJ6glc5jwwpmXr0U7PkfDbEsDNANBpn oRu/2MOF+/mR
mTTcquP7SWk2qpWm9aRPsnyNSODaeYWgujPBP4wigsj8E/2QO9lYZ9+xy3Uz jOoH4FCSCwJ9
IoPAP6foQ8BOZzWYL3rK/LKuQXYiwAJ4oPMYKzOi94IzEepRuJYNXxFViz4s 73FsJefDEni3
MDXiFFJUkcBMSs+U2Hf91PINabS+WfcBf32mv8nbOH0uu/cnOa9K52VbGBEH BQqgcifR8XGk
1+QXVoSPTjMwIKtvMqmL1l+8UN1r/9/0CeiLKnxktPPt1NzvAbhHhbrKApih CcbPcnvPTdXV
8PkpPD2YymSt/Y8tNmDo1xvJayCWkP8MroKn7YW+Zh2o8XalSgelZPYgOefC t8ppwlNA0KLk
T/MGFCazIWyR/WSeQFqrJDZr6Q89sNjTcUVmLJgYAxb/IgnbPd3mejZkmf2S gfLRAq/mojVV
CBcGzpSUuq02wTJFtA9gRX32IvWnFZiT9Z5mRm/A/JgtavUShXNfGaEiC//+ w3BfE8x+UZEW
CxRoDWgFMSzcRwGm7z97IBz7Q6wHNibrh2MlY57ejhj2vFm1etgZhJsymkr8 QpJlpSs+sHCs
bBBEO+mg7ITxfQDKgVpk5rdsNNAZre2dFAegUymBxxkzNPQfmzft/fT1TfVd cI9T8Rz2IWfc
TADUJNzFXuyot4sWihPSFiOU6qDwKGUsOtfkUgCK8GN2UtFiq926JrkifiiK KicEaMXQELcQ
zgwUsRBjexD6dhdDi42VLoQwbKhCD3vwrHy3ZeqdJJiVrQFtuZUqNTx6LhwI kQR4NGY2f3SK
+5I9PnUxaZskg3D48yh7RHJK8o6A/ur4qycv4UZbH79eElIAQKsvvHjFegiH CPykAsAyoE8w
TgMsg2ttIbZZNOu4lzu1sGoH/YMluzsg+nSU0UW7zAjRDGijrx3AdX+zqZk7 ZgNmWX3KZgvL
0VkxOPx8GPASD0zU/9GkZPNwZ4KAQ5GlS/g521ahqFzN1BwH/fcSGHmXDfcI HY/bt6lg032t
luhpLBII8H8T+lWgAzH/P/MXi37S3EwkP/yinbvU6zl8+8RyYCHWD0fqFJWx TPihFujRxsx0
LVBomhpzICrUIjhcFf9st+9tdcg3sBgFqTX2P9/2MTGYrlIhrDUyzcCyudV4 cLWe17ZbvNI0
TIsMXcu3KO6yPU5JGMEn0hqwVO74lsr/QfP5J2xLYghtv5ZLkHbGTice+vTu ORRPgfu442cM
38o2gP3S8G073/qZuWyKAxR2EDoA5FroGLMBpOAOneJ0PjRcFxjb89PPBsHP iTJe7qdRRbX/
1icNn0n7JLU4RsuZOtDpE+oWJZrB8+bXJHm6ytlAo2miPk8oUSomPl7EDbL6 zWQvXYIwLaJ9
1Vp9U3GOMjN6NcYObKe4ZWG5xPmJd44qEeVoqcV5hxIqMWhKXiR4LuGGxYzf nYfLN5fAWV9i
4df/ohmSGquOgnjfILRkowrgP0puWARTEoZnOjQ1eaxcZlf4sVkVKso6Jn3c 2cqTyswEDNNj
1iqhwCtBDRj+FcgMFDLHcfgW8Y9rc9Eu3dyraMKO1nsF+pqMbR3dFTJqQHgV EG/jfbzaaDzC
XmXAI8/G1DBKLUs7TpOEM4O+efDETVfp5LBWwXd2yYQC8+00lRTn0kfQvp6F RXLZ0apq2Peh
HFueMf1T0dqxry8O6mgq+SoOG7AFFLvpxoiF2viqUzRixbIW6nJmODXdXJ8T /P6in1RqB/oQ
eLpfukLEdmZKnyo/97gXU1JWsiH8khIacpfftw0R7uj5D8WUbvbBi/CGV/eu tu//5/twiNRv
JWNR6ZWMUZ3xxBVXPHMYKjtqrvv5f56Q1eKpph3w3zIgRgQ8x/ZkzrJ1lr0b cXp4fAl0trap
Dz4Wn3uNcAiIfUdXXOQjnhnrkzuRJTvvEhWxpM0//1Rjhv6swG6M5nWXkmvh p7b33bqj48Lu
Cizyx7L2nLAcgqhTpDQ2WHA+HYVNd7K60EveEJc16gTktevkcBrK0vQE4cMi /RoYz8SzUkYi
1t6QcV9FRgNZZqlcU2y5pXpRP33fTsGYDdFXCGvP1BOarQzv/88dkNJSDV8b /QftXpL76I6u
YxDbWAUjqOmaEpNzZJOn9lkkvqbdplpeEON8B2MLMLwudSbe7Z8j031An5+q HlVImbnT3L1K
6S7K8B9DhgVnpKMMzeJKtkVdnur3PkeXDRo+jVwh4zovu3Fnd0muh5MrdWw9 hYFvKjVcf5rq
w+peleNl1EzKvyzwLJGBRr5kZyf9Uh7XgoztsZmgkc2B/gkOlURnf6ZcGlZ3 nri8EkS69F6c
5GacCyyP2Z5ysx2hAHUANtG2wbqtI7pdYEnhbQsnAK+kmmewOybLHXqje0eC mAZFieMxQEPp
oH+x8YwxiUL2cfWG84ZekJN27dRFrhwzwwprTdw8f20FxEEoTL2y5pT//f1G fiEhnd/u8OLo
fWsKIgaVwqiPfOFnTgtpDpkT2l1RDKVMKJmiovY8VEygvXxwRDuDMxMwDxIX krVM5aY81s9k
tpS91CvypFmkk16uenflbF7gMHI+d+hJWQuA1zDR83bn8gQGhfwqAIVbZ/A3 gLXgWZ5V/gC7
idW2tBdUziJm7/7CGclJOL4Z2PAJZTvIXZ+kul9ahymJQ5WP89RsHWYjqJBg Rd7XKcjC3Wx0
lUVfggHucmNRC6CkGQdC8p5/9WQ4APpXJYga40GiqHhWYky5pvNEpsUrYXOg AvaSqBz0ZXNX
AaVPO6XXeyI6jkW1Y+k4bxfHYSgtf9Ck+12BeQBSwZ10sfG/LRMo4YKZR38m J7TuRTIrsDRn
7XAeafKC261TIw1kIRwH1UvJTSPcXF0Kq1CLkUWc7f02sUus6q0R+8W0OMNB jyUw0cqkkc5m
+8dBkHydgjkrlGdXPIrBWY0SyTVOOyQUKVNkodjlQPLmDRsrU72HDZXaGw29 F08rnF42zwqj
m9apgKpVAj4Si56dsf3gCLRygObtgkjaR48EyQL2ssnvjLCCS6MOir6EmHF8 WuMEcSOeFZD7
liutL3HMB3nWrw4ji05wZsH7Gexa9Q8YK2Ib05O2s0UMvoi7LGmQZ229S3Rd 1hlq0r+UTAcM
rU1AxWnzgKCZ3T2mE43yqLpzCW9Q9ovNTkZEw7k/IZL5+TAb08+ggCe8jJ8R mgeg24m3/DnY
Q2uZHSFGe/OTHmc58HRdA9KXapMueEbFXVTBUxB/rlplUeCWq3CEh+mPZ66D SXKqCOZfIWp7
6NCCgv6MbbzSNTHn4cSyz6hyu5PObvYAyt9HYyRGqfiXVlro0Mduh4XhRChE Qn3lLNNLW8Cn
d/qFd3AjuUH+zVPefXzVa9LdZJ6noM9xxMjhqMmz/0TBG0UjPoVkqZ1JVsnI 8cPP6XUNHf1u
TDRz05bboUNetO/99mVIYJc101pBLCKqZ/4gAX4diHrEdLpoEnbMb36BbCyw Sg9Ul1EmxnL1
0GEdamawo2TkkkhmmxM4PeKQod1JZDqM6KL8sbnFVzaY/JQs/Axcxez79TOk H+V7ngXCk7ge
iU+Q+024wSfWQ+AqayotJAu3GtgENl0tjK9zGXCYhgh08lbqdoSX8x6HYan1 irYoUf0btvm2
+nhpN2vjsJfsojQjJ/AxkMa8LIBxIlI6YwqJfiQc5qG/l8qTQH1FVB+d+uqs vSNxXwFqh+gD
dm7qciQTis5ndYxTubPIxQ42I1BbETnm7D+G9TgpQBNMEatuihkmuMKYOJ0H L2mpISMpxKUE
5iBGo55TnG86FyCOCPVuU8yzUuuEtTrREsDXyc7wxC3oVljUg/7dJV0Gvc/x YWXYLEM98CII
93UbasXuFspE1JWCYHLzy+gqRcgnYNP5zto471u8l1vyVsDaZFtqzdJU//8w eteq0Hi3esJc
eR0RqPAuaFh3c32o5Q8zknwHSvCCdUEZM7WxePBkk2aeYSTl4ApUlN37dize 88ws5Q2uWGnO
wFjY3tY1TRCpjvkmKIZYD2uHq5iEoTSOqoqIf9cwMRH2lLF+GgFsqHaYY5QD c+c9wMrta8GK
J7eGbdHevNx+kMlfo/CaGmswgoICli3wUkrB9pBMy6aELv0WX5fdCEFg8Tlv 4TbWc/acbTMn
6OVjCvelIEVud6+Fj//x5R1xJvN3MyEMLCS5f+aeBPhLcnaoK4ep3s4UJ5xX /yDqRasHnSed
4Ks37JucZVJ/uqlsq/umuAg2uPSnFoqZtzeqBFeD1sgpVGa7JeDoCqMIeP8w biVH5Qh12PKb
Dyrh8QFr2iNLd8ZWXN99Crom2h2+FyAGem/uDs8roCiHV+wzrC7u0xiuqpIw foqi6b0sSPiT
Qd1dJJHEQDNA0bEcqC2YW7p0K8dhAiplqJ0mH64b7Q4WW6VQSS/MiM6zoa01 TvsCaEZL0lLg
c9RTNDnZ9A4D0HEwSkeOevl7Md7jKKy1VW3/OzgWl0/97fyGEkkkAszwmBYN eOawvtZN9TpG
xb8wdnWpLZt5k9X90HDA8s7kMk/CmUZcd4I9vhtC5/CURJa/SdS59SjKw9Gs BSKkTXrvX7QX
LdETbQWqeEROxUJwYPSMJoh3gHGoVEQ3HQP5yf1H77/PeCDQ+8Sd+7M3YTRO qSP8sgIhMOn4
nGokLymH1RHwPRznXEw1HEobYi9/yP1eiV3CL/SuoGylnNx6BfzHGMT+vm7a M2rxBpeVHrCr
9bFua6huDa19lEwouqX+DlThioFKg0vi/JnLH30HbsgbdU3hi/jy+iy0R3m/ vk4+ePEWCDk1
ITkyLan0HL5EJ8+3NLsGYq5kplXshfsrPNCQxerXIIrqDNyyZBPXU5vu1QqO rIbDogIEWGDQ
nfC1rz4yQVMJqMMLz4r3lnYZ6yiz5KTWcJQSGKoN2qBQ7jd+SuOpRsDelp6n gjM9UfxTPmxZ
FAEBIOlMRsXzinQpvdYkg8d5B2k605Ou7s1gLf/Bha5mNhzR0PPtsslldFdS RMk7c5rH4lDu
TfsMPK9QUSzfBc2aXpQO+VzD25kijK81plRMRqbBFQek1g2SNJp9qz1q2BRS +graaoa5KOO0
EKNOLcC7TuuL5VrmyApI98mKoF829hETryv4Fp4zSHxRVXwdO2c5bRRk6Cvk y4kILas+rEYI
dh6UkOHKIqQNGaqdKVKUdmvNW08IFi8GdsPEM1JI5L7MyaAxSmmAnINt+4N+ nH8cr26wy2ir
LBQJlBxCYG2ZGrZowuYGvuGHaqlQ1dEZhIXRACQUpBHESK9WpZAsZa5FXtpU s6YcN1UNktOM
5AeB0xAKex9mroFIylvGlJY8J3uUSFvmWw9KHBdyqAL+TqnRO0AQ724Tbl+y 7T2ddV20iCce
ZUAU/H99S/53l66INJE1+IwdE7Bpc3bZDFPuntspst/RKFbx6ZKw21ikA2Gr i2ibOQ9cWjV1
lAC/9ckf8nJUAjKpj2rgGcZvzZBdke02hhYcTYUwi2aCUSwfmRIPKYA2jAfA 5lKCM9NYE/HS
U5AXGXoUGpyzKi8IYl3/OHkJaHT6cm5MutJsiQYP4ym9QaGzO/SKK/bklFFn Rw3HvqILmQOh
TwfM/iRwgwN62aNNHUCYEL4GVLgmoyIRiIwaQ0UjCx5Xh7W8wLJusLJ/bhhv UAoEJTqMvLN6
u/GrOqFVm3NBogUZkbzw4PZtJDBE+qpnL+eKiGapwYFnoXiHRuQsdCy9b5+W f6YJxGaTKQTt
jtZzuyRJ6rEUSciil/T0BXme8dSQ6wVA8xY2ZzcWQ0/I0Nv1+4NOiiIt+bPu NZXvp7JzBJ8j
szhlNfx0FR1ffGXWpn9bAOGOgk5cOhuCQXBv9PJq14RN7w58iLKKr+p1l/0X M7h02BqhaM5O
ftB8N2Fn7j8+tVd11VzsQG0Aj0l5V5gJcsj9IJG13za33umDrtiXT4ooHie0 jxAOWyw+odQh
Jj13DSGmcH5AOObV+1k4DBEiRt8LKmCLyxb9o/d7+IrY0FxWQuX9Zjj3WWfc OlfK47mDjHFs
GUSQbjMFF4jF4+hnw//wif/vXLZ8JZr1Lq7Dn6SaQn1OVRjNyq2yZY8nR7Ls G3Dp//i690ht
6IQaXeTGBQuaTrfEhnk1n7bcFQ6qePjLYXQX4RCDikMltHHUV/pSjEc0b9Eh eZ45wUlGGm53
j5OxFuG27q2uom/XWlpK4dptF9VR/x6QWVZRzcZW1kxDCpTOMlkHGz9XOu+8 jE3YIFFpKAtG
oFM+4bdPVZmkq+0oq0X6dQscApKGMOq5ByL9rrzf0FcKWawFsrWgYB6wTDQZ 2Y9Phw3dOGpS
a1U9i+7hJhWM8ltTmXTz1NLmI+BSvBHPeuKfxF0aMlGwX15sMSeNixZCs0lk k5wFptRC2YV8
JWb0y5dZEIujUWHFCAOVuoSYH+Dx+EGRSB8XudjvhY3bVcNLoohqm+3IHfGL qveRI8P2dKKV
7m5HZVpl8aLGENGQup6IF7Wh1/zEdGsHmhpKw+cxI+VtKMa1z9Uf8bupkpbK nzHTRqI1Elln
WIwLN4E3fhl0oZaFHdt+UsqZojtWdVSH74izMCygAwy1JUeZe28plqZBm2mU QhE7yYmGU+0g
yNbGwD7dlVOjvPZmTtVjmx9P0TvqwZjG/9ovgMWC2q/ErGUDFl+lKzx1xHLs UjAAbdR3yQFY
e9KwAmvql2XES+719emPyRzhqBla8HCUBb1DA7ANxDMnlJh6uY42Lwkx80AI j/5GbrebdhqY
jCkCcYxYsLP5O9dRAufTzafuuPIAvyBUdtUkgJu7KT8doJhFGyIjWNV3y35K jBruf9NXfKqQ
73BahSg2G7oqXZov05Csah5mfTQZJGzjY0wQqr3ZfyVwJ5RgA3YH/oHBvf0P ITeOtouDbw9B
ZL1IcStdcMIvqc6Umb7myvm4//0XA32aCKruXlwmJubYopcXKaDS4auGV2B7 Q3VHVvp7W9Wq
o74nLVephz1iMBxw0cJ9/xBwIAQ99yy1VSiHUzqj6rt1fF3y6vAm/3xgNdlz hCL46h2nweMd
ekXyOYSvlGeRqRk1/b2Pn3A/X00e0gtUBlu8sMNyjOqOMMCbyoOkvzzBM2mK 8dVvzPtKNcM0
JZ6sUYn3qYaOCcYUQ7dFwS6cli6JFEvQPKbI3CKsIME/wklFuItWbz2nnm/p eXLgHA3c+1oz
9AIXR9fBO7SOPqgPbUYfWc9bmQu9/nZrdh6hRSdHla0HsQQFzedxwjk8709d AdepQPCDvWQB
Aj1DuPE9oXiVhzAHnXrSlyMY26ORyqXrMueID8++ozINYiIJXezWiwfaj6Xo dtv27auRR7Bv
b3wPtbQNM7hFchiYGcJCUEXd7OTw5K2rHkucqx9HEhYUOsMhwP2unnQHdeTV 26F3Kg8yAzhV
8rvcgw53rQY8Xj5eMZRIm3HHEBQgkpRu3LznRCBIxWUr6Mv6EUwc1qalN/ax xyApXf5RRHfD
rAInYTkjY955I86ehxIRPUDnnvN2UkrCf/hd1s4/MhYXl0kdTxfTNEqcRDeU 7RTFTgPTjGPb
YGxW8xMlF+qksobgvZvjeCJG8FKCIHf3zywDzo5UdwqPp3x+tIju+4XIHCiC 608IB1Lb8T+S
K3b6dFi5Eg0cb7WSCth+Y+8scuw8+Nxf/1X48JdbEyK5T0srogIQC6PPIWKY SCZwGFSVInW1
pRWXPDuY6rO6e0DLo6jV5fIOPpWOcRCyXDe+btadQcZTg69iz41Dt0mb1+J6 Q0zeWZzdQkFv
k01I/kDdaceHloin/2wiPnIIoqLGSgMS4Y3iV7XPQvmZpRiV+5RjwpI7wf/d Tc6VmNPaKZCl
9n6E4GGR/UkQuXciHUkk8NsxutN3L4LknR26JoL+L6rBmuaJSGpvynVDi5Av ngOrleIZ0dlS
IvvPdX6wecsoYycmKRcTL6A3LtqkH3dSYmTs+TFnTssV7ovBY9innrVmfSBX 3HVYAajfZrGH
Qkh6XLewRJwuIoNrDsRtQ/9vVNu/LstYPq7oM6Gu5QWtB9pZFW4juODE44hy PP4LV9IGLcSc
c2F3cI/EC92lburFCZpE8t/wKElE2Ed+6PuuG4KPSXkEFxlCNEMZotbWQuAy P9Pi+aqe/9X3
D6r2HrFUU/VeXD872SVK9UbNyqjvKewUIO8TzEPLrlDXJRO4d+euF43MpEV8 s03If7mYx0cf
HyQxrfm/jlMjXtskU8zSvft7w1jBc6nT5mOUfQvk+Zi15IopWasdMe39DOtw xtIfUGJ0Bza/
jZwBLIdfwcJgL+Kj3QDZBwCUSf9fcWkP8Rc5IVAXjxuDKfG1CGQMHfkQBRpT /y1GBR+l9THE
+WjjLxg/Z1kNhwwrroGi6S8K8Ppmlv+L5oA72AymvjCG0X8dLpkn+osOitTU n/x+/TCnbog5
joow5nMenNwhOZVbeQxe1oEdvjc89sxnfqaBjNWDdj8fz69makPKH3/FeSBE 7UWMyyBju4QV
8WpVAUt3L0GDSG5hiSB/RCDbvGW5oSNw7ym2tEDzpkZtieXc4HfitPmDU575 FglpDH7wRagw
tWbSkl+jgzfVidnrY7dBCzeiEOUViqPyuOqgOsbz2aFc/XVi0l1oG3umLfhg VPcs/X8KWMcg
E6eP9P7AEGEpgEvyu94ZAqjafx28bY5kzsOcIS3o3Hrc66MZzKfXGUYpYqvs dgPbOPr/2mmg
LdcCxAbm164NcrWz0zjuMDDTWuWk5EfLZFaxXfbMvN1eXkapKCVGlStiNTHp 4ODpP65bx5Ik
WaccxCl4AnuWhGzpb8najLZjWLOX0a0m5wyN/6uc2nvWtfSczwqiHVrZmR2T FHeFR9kuLzf/
100ycd11iv2HHFDjx84ryOsxHf6whBpyrRZykoj4ApFfh9Rj4WvFsREyqYzj tj0Z8REZjaXn
G/ZSAPASlO7sUOua3ZlIcEQ0nJCWNgctQqPRrW0LQgKmLbQNyoFJf/UXqUcH Gzju6LU+TuDc
1Yat/P0M66EOAC6Eg7q2UL5SSWNYwaOmQauL8yfQXzq5j6Vp98ntzk2rAEIX sYm+nFHZJRgD
uG9TjNrho11Vem9UC9uwe0jX1RIVN2nAzNG6b1E+QOGTqmIxCe/chSo3209S crplTLYphgAe
CIk4b7Ho1+XXiZ2V1nz0hBRM7ujS0OXOM1txhO4GNTfE7dwVN/pdhOCDcKDe JEmF00xsp/z6
a5f5aE38NgOShOLzD87Gz//4QpId10tbUWputEs/AN8ZXi59imhEqmg0kVD7 GYFO2bVnOZi7
u3ilV0DZAl/T/rUeokOrCO/IXYS9yzKToOBbvbj48xTS0jRxI+70TtJRQpI2 ggms+pKJHx/0
mfrVLCq4f669EbvNyYyxRAvc4XhVBIeoucKYyP2bcJjMhXHaMeLujFzPKWgE vdL+H9AM22pn
oE9LBRC/pPpYpLQIvQ14o6Zf2+VgkDnaUA5gUeEsV0hT0rBWXeyUEDxeqfmY +IQC+nWTvWcz
jlY2/DRlR0R86ujgSDdMwS8ZhZzcWrKOdqaRNokZv/38Rg5hC71JZ/K/L/3j di1fJwpSCvtz
P7sNKj7sZn7GwqsROseUvYTuwJpy71T8oWc6pYQqpBI1VVZ1LZrNa91hl1u2 +KySXXlMJhsY
NF4z6C4KF8ddHHHdqv9eR3ApQMZtIpLo86vJYIp4TtWY+pCaJcfnZ287vC/O lGKUBecPXSOm
Toau/uVVs+CCMMs0Fz0R1BMcDnuuVnqTp7dbd7bmcnWzx0wu29z5b84XbuzU gdFnoDU/vWaC
sHCa7vSyvR+y/+nnbvz5D6V1aMGsPfXlMbv1V/+O39cTCbHS3908k81jWN6g N6g+C4mUZNge
yK7OIDHyJlxeNHrIllNrarNKM0bFW03uBH7mGuFdWanceTLVh6jGRsofT0pd XmubzUi6RMU6
cMAN1uzOE2jVI9+g5nYcxkNh/f+oWhgmNz3YLnpVL78V3WG6QJcHpfmtoz72 cPOo9+ImdtH+
6NBTP5kMXX5eeloO/TGyIoo1UUS/SErB9SQRtjKRWi+jq9OyE8feN+IVw6z5 NBoHCHVXNJnT
FMD2BisWq0af7o/arC8Pe2fYNZszAvP08qSuucXd9qjnQ9KBaUbRnl8/A/IN z6hCbkQjGeEr
UsfPUrzl/ZORa2bpir6bFSWyjzbq8brZJx5Yw7MZ/LF16aB4lKUHSk7hMhj9 ILbCevAKRToj
Bd/lW83h1v2W7VAyi8lpjobQepvKQWJ7E+FVC1W6DnVHBfJN9n+RLpdd//vT v++e4t3oEdMt
fAUZ//jsIQamRs+lKnGFWMGzhWPFOwLs7OX8nai4XYihloziOP5xZBzbaPIc ZYm9gx72uNjM
WDTsSK8BsC8gk/ypIuvEEe21KLiqsQ5YjkocXT6kdAosy67oivN4i0jz4MLD 5FtsT9U2aQWh
7zlT5uqpW6C26marRPQ+c+MI0YGU4c8cDdwyraXOG6be3dsAXqwLC0kyVvUx ZE5eVgybE79I
jsMsOapLWLUrFx0VzpkcoQ2xrzzz/48hXZNYf2E1NRnHGMZtnLL8IsdYyO+9 GTmNX/0MfcCo
yfBphS8AsxKh8ZawmBz9voLK2nAn7DX9RRef6EF/kRnS68fjxkT+Z/XmWFnr BkZeFHl8mzmV
9ijRErhWKDr+q9ViP+X4ceOUpaju4l0nM7geCkMT74u0iUfJHhoQspJD5BNP AeqnIxZJqr0O
AGDrgQH+eb/t8/XA8IMhAGoTf1Z/vnyVZ7Lhtq3YZjA9Wo+JWTCiutcrnFOQ 5iLR3ZPwn6wF
N8XJKMkH3Tv/Gb/N7O++ZiznCtHLBNvJPy3l5eCLozh7vHPKJ/Q+5/hdf9f2 OrVPuZ4LF7pa
i1xyh59/6Sg602xy1H0gHvN4AtBJDtMF5PXq5u9vidzp+xbDgbtuxjLa9smH mubHoZvhbINh
3b+eUDKUHgZByXHnq6u5Wjv+IHzaQdwg4X6JQnhdsYpEv9tj3y8gkECzJUmt 41tsCr2O7sU/
AcXtdBZNWStyXXkuUe8SHURRA041Vg6mW1OwvDCtrY36JYHeqLtyvDU/xzIw jGmihAAM5iL4
CANiqw40/8hNqZR4u3EoKpDbc7wU2Da4vlRnErC9MCBPzWF+/sOeNhvVcxjv zAPSkgbhUQU6
MWp4NNWLwtevDQ78iBqA6Z4RYuPus7mn28lBoxvnJbkNBPVe14XtetKAnRFw tHpJAH6E2kcw
9NKujRUr25D/jgf2pDRajjuOBXrl69ETw14jeNTfOZf4/vIhvCu5LOhUMmFz k3/kIfIZzdLO
AxJ67kiOudVX+2t6I9ugp7/Ntb/cTla31rjx2J9eXzJFNQerwQXMcDgdAMj6 yzOIG0LHpTU6
azy9hE/l6ctf5cBiWPXkYJefy3c2hbtwFA3Fogechv37RuRdQLE1t0L+JZiC n2nobb3bdS/g
p3xA3DTTJHTQTRveBnGxRcnu+5ib+EdSxi7Q80CuRupAJ8ko0lAnV/20hjss ArJEMzJIBIO/
EYhw9jgu91c4Fy2Tm1Q4EmaitnUcNYyA9Qi0L1CCprP/NtemxUyAYX2+HO3e eTDQD+q+3Ak7
lwrQbM52bi2k2ovrlJcE0DUotQU6AUWhr9DzLwRD9e6WRWNuehdocncvp/LJ i573YoN/5T4u
gR/bWllAT2rMzgJUKSeqQElu1qzXK2URaxPEOFOadjH5FJkc3UcTL/vXg85T r2uYmWkCSFz0
28v17nDGno4PJTR3fGvz+LEGiYqAHlu8Mg9mlbuokfEDkDhtiZUzx0vebCSK E22NG2RO19f1
c49EtU+em1Yh2KgfHbhg73zXQbbMHIksOGpDsj/JJqxJYPO2KusEDe4GtP/1 IRmwrHJOWJTs
ZWAwGf1UFo7C+s+btciiGXD9cbTRjSOZ6HQzNf3eDljM11/zmP8sM1YxZtD5 cWYQl1wegBmP
MYCee9qBdgr9ZuDkz6Gw/O6WL9hGaq8g/VxhCjG7EoEmHT5K9wEPEfCDxO+C KAx8w6hwSSIP
+JPDwjh5h6g/dhOXY44/Nmw9BR6U/bYEh4GIi8Z2oC2OKkEwPLwguADZzNW/ k+wiyZygrfrz
BpNJaMI4nPvWzyMLNFhV21oPQf5FUCL3Zez1ZysbPQO9v8lMapVrKTja0vqG NNEU1+KLia1L
uUKCh5GgdXPGrmDmJkNbdwIQwJMHU0Fw+oD7aMeFe+gPIy97W+MPFIdNysev CQyQ99PkAX1O
FZXMt1yFM8Wh3ztgaQyjqS0jp7JCi5ne1jhKkDBAqOhrA1FXFZ68xm++S+HC +hz4PoWZGM/j
1ZsqyZDF7FEzQ2f36C24AuVFo/BOlvm2nUGsz5lnXOnt+iaFwv9baeL2YBXj BIp/VohNSEAY
/yjttyNc/XAt/lJxERQ7c5Rv3tmt5Q+b/g9pk+ec1CPofIfB8J7pSMiiaUGV aFDFVX9QPAG9
Ejo8CcjVlo5QwpEaKb1uhdFmpXeyg3n5eJRLt0Gnc3/HXnaFUpoa5cPKeNGB QEF7vjjqX39S
y77izkDepEREyh4DzT1Etw/17J/u9YyypDq6NdHqG+dzW4+ecZObfk1mhQpe ylm1ELBVE9Or
M/yT9xrI9hmLopaTLOFd0lXBxqqq5wx23EM/QMGgBb4WWbmyKoNydrCHqGeW SXoS3/IWu0Uy
GvZvJXiy5MpdsJ28feHM3dZvumUxICjaokgGNH1vUxFvh89d6aRdQ0Esw35N 8eS6nvyAiLj7
/tJX2UB6UuxbcLrXWajw3WtYJnPephi0xNfZlcnSy1bHRHyf9vv1q3UsZwAF Tm54bnYou6pY
orlh6XUDpmzJ2a7fQH6QBNz4oYhJlXRbmnH9J0/axOe/0UZozkfNzhul92ln 3FVgX7kT012a
W2vrYHupecynR1LgU1ALZO3LXfHyE1tNsIYVTSWzYhOJMvjZ3P5XKv9f+7Pf WoIl4q5Sydeg
T59bMdI74p5NhSWY119/nbemOt57ZYb71mKqUv6pr7heSAsJwQZ0SgAcgOqB PXdScT8JnCvq
2mZpk1avg38mP+/dp+HtMaJHviCNoZCZ0kuZjoNHICd+GipMQCxCnuNX7J55 Kx4CQJwjqmwC
J7mkgi/XXlKtBJVRcAVz0bkRrmnIc27veZ5oil+7SGGwLM5j2EWdFvtF0oc/ bY9D/+XtYfi8
rWrnSYjVpC1mS/W49T/5dIT/efJYMH2RvMhiBTZn/rEHQwJgMiLgEe1vJiGt RCyHK3XBLweM
GnH/IQm5DHFo7C5gMYvL4hMt8LSnrz3lSKaxX86y3kUmvnjLEliQq1gZM4ys 8zOQITI1+3C9
4ktKbR74nUW1SGm1wDg2CF1vLYn3yZrN1FKntzbPEIhloSxsABdlyyaiRNjY Kf5lbrqO/s7v
fM9Qxs5T0UQdb8IpArgctdc2rNikXFfwLOGiP6+0KtONzqAvJW00gPmJc/PY QBL5yaVOy6eT
5qfZARi46gulSY7hSrCbAKFn5b0LhvabuGvjFyRC4W+g/lzq++EsfQvtjP8w mdCJhFyqGI+f
/jLet+xpO2YBHKoRLELm8wpYkWBzNkjS7yfq9UUO6deUrLWADQF3H30v/had prwgpYWQNKCB
pvDtzUwGex17N3m0tU5gvv9OVTT2YIwpAJbC2xnkcFufYDag3Tio4h0VazCK CEbyLwy1REe5
jsqCeoA488tct4i6JDcqe2z+uy2VC9tlNXkDhhR21m/kRn4oWiu1ucYp5cwR Xso2r1R9nv4X
34i5BKoRB/6kEYryFKrL9PfOSpQ65LhSPWeGKnD5Ht8GKXLcma34qk4/pxF7 2jgc+E888McK
NTWeJqxj3/VB88mF6CsVpMCBCihmeF6MuGlT2b6BSOk5S4OsxNunu+O71gzx cXhbdZvtgjSd
hDPAP6IFpcwT+pfyRqdugmAMs68yQENdhZOx3IU7385kRSfPJ8/EOBSyDKzg JSWxDAz7y1nD
gl0wosEEa7LMe8bAzFF2Oo/LFN8Opsmv9bc7LA+GD/BKiR5t9mNydRFyvQH/ P7tpq6wbiwGE
FR/9KYrkURfJz3uXWsOJ4BKruCCxqONJr0odyhvs++XoxCqUGqgk/CsTRkxu Ff3p2W9uZigg
ePGR83pNvNtwhHuEN/1Bu/3qRx9o0AZXQMSFUszEMxyKuK9A4Y+jq98eLqFA p7Mmqbbu6bE5
T3KT9Do4HTZx/7ugjN+pOy+OwDZgxPv4Go2OKFZHx3ow3Eepk5Eumy8spDF1 qyPmCYBcIbLN
zkU3Oj3y/1K+4OJApPtTFhvaXFQYOugFl2s3kL337+EZVljrVC2UdWPSDuJy gnas+PNMZzEk
huRwXhKC5oznyZzyvjLTjuVn60KKmSdxZK9DV68U/T85lk2JgC+NlCB50MSF gDgXRx4im369
R52cQUh9ZZN558BK4KQ/efN1/AWi0PTa3HnbotpmvPWrNIHlFOproA76aelS MvD9I3c4t9hc
+Cb2wTCVVRL0B/aUcnCMeeDJeFRRz0EY8BOjsZcQ2eQRQc2Hnx1WqNY3JzIu NgiJKzemaq+1
Nog+9EzXUvVt2ZBRDLrhJv0nt7ue5q2DDWoxukN7Ohi1iiDSctBI+Hvz9Koe D8uZ5HPp/CaG
ibeCaiOiMYikwC1z3fQ/IxUnbkBGB9eLuR8Fg0TKODX1NN+cUlEpwLSdJMpJ 0MbGOq2IBFxh
1dKXlYuxTOoNb+Ab6nFAEKBmHHR0xxOddzKZ9oe8FYH0fum6nVL0q5KgVjx+ NzjS3YMI5i1Y
dhQaBBfQ9VWmlUH9fwazmNc0IpMWv2iOn99rTP0cXCFxWFV9TtOG1b2BAe3L TPZ9PgrFZsqY
ek9fbVo63IrHLxTbQNgSBYvV3UYKj++JHb9xSU+RY6LHUazPkGqOQd5qRM7v G8SLXhtZu99P
P8fvP4rFHFOfzqaz9HtqO3zVXsB4flmegyHAYslweqvqqqb2Z+1CbmCf03bk QKfqmZPooOeW
zEzAVxqoJWaEn0iItOxH065V2FvVd0tsCjtFcQeAMWqNHqphaB8JimAA2QRx QfW78Ndnh/+k
Dso19GIJmJ0oI+krehyRqMKoaS2B1ZEBm6gCM7T6N8LLU2xx3fdZkre4P2DY vVsN+HmhJJqY
414K9OaI4fP43qFLPClzm3imqMbGKTWyCbiJStr2fgE930QmCMspogI+kG2U Euu+RpTNKLbb
+XQ4sY82bdRJKnqcZzZ/2zkX0o/8AhGMoMz/uDn8Ws/Z7/qfxTSb0Nx4Ou9E 9eIUh/dOzy7v
cJe2XNNIubNn5mrYdNvT8fXhX3expe2IdKWbMYO4W4CPs8J93A/B2ImCtLk8 J3w+Y8OKCU9N
igZ7zoKOg4MHRY1GM/nMNgFmA881jabGzGpGaVfqnTnXYzqE9PYztZ+3bC03 T5jcdHvBhJVf
dUjEboQm3ZU4hv64oGwFGXTLcqDNwLow05vtzO2fj7xG0ulRpnh9UhJeT+07 k/p6wCVNYeJV
ikXMjfhvMdGaTROhbr2cgWZtzxTwI1VwIeMK2S6jX4HlYZfH+rX6Uut5gHvj U7A8e4SctipC
+jTOxtSXLTCwYY+TMLrtdFL4FiBbRl3LlrFSWtTNyTGWgZKwN6/zCMHZIizr MOuQo779munB
pJ4sbzrvXzIan0xip+qpCAekyXAtiE/tqZZzQGAmNyiLLPRc8EXuFsZNEFII Fe0d8U/8zmaL
miliA/8RKsPVcctF5LtScKIKvxdbiA717dCtomUdldvk1PGQunGxD3EfB0N+ pf+M2MsAWKJ8
7D0ijGrLuWWDMzTrBCctILE897gOmIe1lM22Mx8vistbeG7eppQJb8aoyPWe CFRh2zihGzNl
og/57zJmN5lnimC2OVWd7GK11TYpgCZPoCc9Gv5921QPDHfNU7YHzaIAgquT 2+89ztUyY+NR
q/8T2xmXE474pTnDidsmPi/kPTUI+V06cEHHZj8LMq+1fcbRPC8wlxUjfRYw GxeHNo9lsXSk
TsmedR/6UA8ETzLi9ew40fD+AiWGRqsODVQ5g06tflRQ32NONckpzAYvxdxv u5NAAKDjPD98
xFK6w48+dLMV8nsgPRMBAgJszznpthJ0WD2edEI65zie0cbFlHylH8iE9gKE CS9gsaqvBsWq
gS+RissLP/Gh2Fnk3OLjiO1vSzO3W3yFsVhQ//0kJa0lp/K+jaTPr0MJTRTy ZmizezafkTaf
6184sUW7LJcN2lEHzlqid0aXwDnjMOpAg5T+cuTZcz+6j8SMlT1F5ldX5VlM JWiJKSHhox8Z
8Ynm8dt9Z7beiCAK1TtFv1McL3CGz8bIrPE4QGqzVdZEejTXcnC2aVq6dtyU qoPvHNMvD2os
v7id02uVhgYTPYo3jChuHO6vZhP/7gM534F3w5sDKewSMldFhP4nCXNqTGxy r785bEHL52MY
EsvsPWle4JRoAzKrF3g1AsLg1HEthurAtMNKTNXPlluVlLLx53CKddovW4lS oSPH2sMkL9nc
ZJ27qcyWKxnNCI4hQevvPwh1Mnargbct84+Rz/M8xuLbs7tcztCVzDw4y3iY bh8qbvYNeSAx
PbYMSXBWqPkvfTv6BUJrzaJb7mdBH3TMAlS65XIvX6qCvKHGtgdf3PnnCgV3 WAMOG+1C1FIW
SgU96w8QFk5W8/r1x28CdFn/kuBL/L8WAqSiHvl30szNK7ln+Y4M64ZIf0Ty 4bh5gff4CTZf
jOHisy3GOb3RxketAGEy4oEN5cn7JLdXb/JTIKOKE9Ailn1D6tTd8aBbJzrh 8ld6RZ/7USfZ
2wCqtBeDpeYOC+hF/edc/GoUje6A0OVb+7Cu4FEtA89KI+NR2Y6ZxznS5khr RtH0wDfo42QB
J6OOnGeJkm8e1YJIzQ9KhRqFaqR7lPSPmsdn2ZE7+d7jKOhJpa4rG54xgc1w mzpGutMxKXG+
C2C9kaWTVlm8YnfeesLhZeP55NZYZCHryZ/u2N5TbfOVCkIa1oXVjqpSM9uP QdzNIZv2Wtxu
2y9BnjY/7ahNqCKC+THh2HngFuTM5rPFNWIOlQAVOv5sDTxFgqGG/inhD0sc niakXwC2PQ5p
0uqFFIzKi+5uVwYzJQecMfH8Tz5yD8zOVGJJcUFikExnA3ljSaTbgiRjdTXp s8tb9M0DS8wB
7/3vmWm7InjRKkyMA7LP4nyw4Qb+tTfjiK/XS+gro3smmQfRXWEVahFTXWeT 8bd0D7HhUKqP
uO6S7WJ2MP6I3TQeZcHdeQNJAPTelVatih8HwFjk6/GxXXYFrraytT/gMc3i S7OL2noO8UkG
kAJtKks6UKcnLyOh4VyeUqxHxYE4RWVyhezgLKcAz2I3OnT6jHctP3kpa6z9 6IyRlBV//S/L
7W1/fyeoUGdf7/neo/+GmNmCuqxj40IOB6cWbbruf1J/cokACnA15QI9YEz9 1/Mt6Vv7tRpE
JJ1RXPvN5Hxy4B/hOStk0+9SA+dkrH7hs05MEUU/szWd3hZ7eDKzFaORjs7B gXe8inLylhRV
KVYnLFxEntzlyhN625HvashIyw+X9PyWDfr2YHI6doz8M1m6xQqynuEJAEeA aLDyfKJ1DGy+
UmzU1mzR8keRg53n3CAmB89VBfhdX0U5seEMfMfH5T3euvUyTBL9r1j3XB28 AnQIJrquuDF7
kZwOpya4TinPfrbvJZnc3ZoEESKjwr+z9CYImIynJ8Jv6S8YtlMfzFqAhYM2 LcyJAU4jGtRK
EjhQisiDl5ZD7XuJMK5XfPYpRaZ8tq9qKov/vvRNt58kY/BPgp6x79bgU1dX oBtbM5iqo1VL
ortxuenqqCRc71hVZiDRKzSR1/5htQxBRLSIQDhh+Lxk/K13lr0SJVguFs7t shaX0r6iCQpL
LlKhKV0LVzz4A9qcl8KKhbAqCnxWXomgsCbPKbxE5oGihkJV6PiBrKq0z/Qj XC4ft7aD1CIT
JcLMdCL3nrxIxp4mjpXKAhelFq4hz+CLeHRpZk+YpecMtvIe8ldnjiQZOfsC CmLvR9VGMwqn
sSIcNJ+dJL5o4o+tncJP0wHDKkku+lCgqfHu8Unn0ERvAihs14Kw8K0PiJCu tw2iQaLEkXqY
Q9dO2qAVf2PLOiIjOH4V8VMskgD2ypDmfmMbTsJD+yK8p/JbVqtNyXbJRhpX ltHbuXnytX2o
B0AV9H1AfLd/djanDJHEujITe0SexEm2uhfyAb2sFmAGaLUIGVWrO906ILSZ vAlmo5F4WKy1
eQ70VISAGwZcN1MY3OhWpi9icxpYKzGViiI7teAV7hFCSuS38pV1qvU1EJZF nrp9mHK15YUS
r9ocy1YtdjT3Sl1t6e2B8UfBQ6GycSL99wNLojogpy9S1oAN8pY1QByD1BxC S3jMmpm8uBlU
CVy2Vt23UKdSEjfXbcsxdvgjN0iQNcW3MR7ShHSulUwlxKaLUFkKr/Nk9wrZ VLeqtqkg6TmB
n9PsGipz8ab5WFWuTNSJ8ual2/1B8bPrSbh1rCCIjzP+DU7UKINp6ONnoP8n wR6vpE43/MZS
nJscnxdZMiPOa8JGdZCrIoRUwkdoWpW7f2XOozYawyGJhC9KI8ty2zbzXxTM reBckTVWr9wv
jg+H9+DF7fsiYfHbdRRrhAZmVlN6wnwJ/yl+ySke2ObAz5My8LOSB48QKxCh 1mQshySs+qf4
xMa/bUVELi/Vfqx2KMmPllhg4iCJbyodVaPDwGIZEfWILmQ/U6zaVZpo8oiU b6LvjooBxqqm
iG5X8A1pDzKDXGpkLwpLP7hKbQSPxgymo5+x5YYwurZ4+DGZEVStqFuA9pbe CVx6/22siZux
m5hmIfx3+FAER6jGtMgbsTYxtf1d85ydKScoTN0Rp3SdF9dGAGL9Ynx9OSNK MWYR3iTx+/wV
uMTOeZmBUobxl1gCQMSAyTpqss/3kcbXUioimjVDtBZivQEhITqD1gptqH5C 8DvwgP0vGGf6
G+SDR58IhOFkeXaSRxpJ1+PiEjjVmRjYjj0MeakyvAUYgR2He6WL2ocWZlwK CBFQ417FTI73
NoJAvb7fx6JWJj8PGt17JlXj4kZhRfZK82Gf9JL8Rav8cxMsC/hHnXhTDJk2 W8fw/8+hqVyy
hshv0NIlzj83DddnflZMhgIzIEn/xbbsqdP3VkK1FXrY7JvFtwMUBkFiv1Fa BBalddoJKtAC
7sVGFcOKJjOu4q/2nYBj0eXFAleRWBD28Ah9UUT2Q17S7P2x72EAB+1C34AA 53LQty9ny/Nu
8CjC2u9PvRtCIom5+2hGYV5PsT4PXvielcpHA7kfNqD755sY/qtzFLVONJrO h1tSZ4Yvq1oQ
WpI8odesjWTUF4lD5zWilIlfKD7u54GovBqstf+LoLp7kRRubG2J98xna41C Wrd9bcvqJ3wK
9EUw6yype6UBiLeT5YjRsTEgLDgTpbHdaJ68CydMhjjy9r4Hmm7uEmzWFDe2 3IerPJJWinCF
QIgLU2bH+kGmbq2v+YSVZNFdzjdj6OznjQOU28qaktlJ2z+7h0ts2UatuiKW 03h3dD2JQlvT
Qhxvx47UEroR10vCSZ7UGTIVRDpyHPhYKBrQOg6SZowZBdmtKsxsGch1hHXZ YebStemwsjAb
UwkDYAf8EuoGR9I6UKPaJGKbhmYcBoIAjf+3qT67V9qMDmWPQT9z4eWpKH6h O9U4vbNjmkVR
eIDfKtcvqyxUXUAlXfWFAcrUMNwjYvL2vmCLL7IdGYvNWpO/l/Dg4L3Vcqtb YSv91idPAeCA
ZriMel/FgxZNWWSna3+NVSeWp9mO8ky7fPp3fkiGL+enXOEet2hlol7kmqTm R/qVMTlgw+Y1
oiIVRk6Xusa9rBGEq2c21ZmVVC4z5wpEYHaa41bJrnUoz6TMCfFHCOyX8Cn8 +IZ2V/oE4ByG
gbfKlkiFY1XlgfKiohZoztE4Z6zkKJC5LlDBVS1RBmZX84l/xodGVTQ8CEE2 eG7Ie98QbKUy
wem7wdm/VwoLGSZBiSXz+Wn6ZTFkt0gp5L4HHn2a+uLAv+QvgZk78ESpo6UJ qFKhoizFlOVV
VLzEoQNQ47axMdk67KNUV5ed7pfiY8zuKk5z17B6Dvlf2Y05N2wvF8W5Qn+F 8e8awyTIt5z6
MdINHnAkoWxcgnFTZxehzXnYQ6bP0QUCGhqwhoBLga46Mj6Vj3947SHn8uFF /+DYOja7Uqo2
U9+mVxqMHh2irt+dU/WpKXp+laL1tagO0Tm7P3XqPm6jEsBvVBf7ibkdTgSh uSx1IVwgNNuB
FGSwFFxB0YNB2U+vidUnS1N/SXfgoWvzC1fDOR9i+VjgMWhIhQu7he7jdGuH L2KCWk4EvqoU
1DNliFle12+rCjJeMGFVVqUgryv3u5GvBXgfLlk33Qf0ViiZAoVrKQ5DWXH9 hvK3O7ul7j0y
TcU+E20xoeO/ao4dSVaqVP+VBVG6kDrMvXctyLSoBjPwE35u8ntfxUfeG2cr Ky42UyOowZ5D
cuZdQk+2P082BBaYf7LECRxwKb+Pdu2dyVu1M6hau7sWNGRRQHpiHTveDc2i 2KX+oTbVc7yq
uniWaR8dbEOk/un5/nD+9U86G0ILhCzWlZ2Nwsih+ez/o47rAq3RjiM2LeVh 0so0IDP1gFxT
0jyfYL4jE0zfOCvzBdhvu5IbrbgBlb2afFF4u38pmpZNh/X3Plf+0RAAOihx wpZVRyW+7hlF
Oz1m1plDVXu1rvCh4fuz952PoJ5vINDmB8Wvyz2O1wac9ontMOE6I4iwM7KM mLx65nMrPZgF
M6KmY4S/5uyZdTwpQ+TyTLCglfYotexGZss8F+GoSsMtNEn+KMxOkOXeJpuq H0fMZqdzbl4m
taywlHRoDyZFklxaQU6ysHNWyJ5RRjEyb/hw630Qj2sIX3oOPnf5R+S9nVys AcyHvDLAXEcM
VZqH4YOcPt8kps1NfdySyAtHbw/SfVjpt7tBLJMr4JThrSpRg+5qrH7e4Mo4 fBpFkFDdI8ZK
qLpQrtzq2cZjyhORrMD5+rKjj7M963sDhE75Pookc9+1rRNxF3s+7WUKa8lW XgslS629GhY+
2ii2MN1lyOnXZRzkPnE1DOMcszk5YhcTmGciDvzmM9bmzpJ/0wr3IoniVHNJ hb+CEGH5qyHE
+gwcy9/cQ7aPYJ/peuwJ45kU0IgeufLfurGV0N6gHtOcQPAD89B9z4AbNSC2 X/x4kmpAHPfX
9LT3fitBV3nYQ80GMHhbpgfWV3dU+wYEjcSI54ETifar1Vy17axqHEnIMuXh y0NPiY7Lm4qv
e1hSuRQWWH0ykt/RCiNeqDIius0VFTBIPoiWfzPz7mwXwChnuYLw1XLkAvG5 C/+tbc5zdfxa
+9Tw69EbifERAPGiFUNYVbV8Zxu93lpfwKDJ5Usi8UFpvtqE8f/evZoDMehU QXbOuajSzSs4
flVu+xMGMmillDNjx1FVVG2WxCQVlb4S/GkeZSXCBKyTSq1FM2glHGbz1c4h m/zq1dTzs5SG
ZTWge4eaF9iHBuMWcvrJ+d2eQDt9Lw6EpdV4NZB0t1YKw7QfgGJZ3hipy7+u cvDfFe1526SB
+Tv7pXT66P5ntE4pDH69J4OharGEVMQdxwyXIzM9cFDI/lFCQY9S+vXgMv2P FI2DsZvtj6Hu
8tHoN9Sad6yKgy7CPwrBxFExsVbKlNsTKc10uyMHbV0ps2vYQhVpcI3ki0/i BJPIZgNBPI0d
48UJTxm9cZ8TcLVVe4tMRbEl/O+s5Xp9jFDw5MalXxhU4EglJ4MvfUGpCV9R X6mIO5xreoOx
K0F3xMZrhXe9vAsKmPKWD5iQ3aNPxucWDlWkVUBz2WXCDn6U9wj77SXkPbOz St0PTJotEYd3
KDSGvYzBYZc3RbvOFxddceF/Abbzf3QTm1B2s5TjrKjciUnKstR4Dz5drlW0 e87NcHu+5rXd
ULiW5+lq/INlAQNkFjdBJsM2zHOSpn2ISJX6MOnf4+oblss7d+MQ+ptNvd4B T3c5A/QUvsjw
NHfifnRJ5omZ1ShnCvMU/gR1dO4oH2atz6HW8SRwGifaqBlub27pAMulX17P OVYlj617SulU
oL1R7T39/MwlRyDf9DHKuPy49qRx5i2qdwhmY/x58ExEOjx4UXxD9uGMBMRK 5Hg0s/H/xuK1
0Hb9HdeTBl3xM9XyWkwEhxwscukXwR0aFOpRdivx549DUzZW+7haGeDQs/ru lmaduD7WEJDg
qWNNEHlqe//UaIN1RBFZ52Xqs2/My5o0gGVKsoUaYq86nn4tP+8I1E9k3sei cYc4qpDclhuZ
aEQspZi4wW2tCu9LfKaq5cTAXTWd6yhsb5Ut15M/sGnQ/lAHfg281Fiz96DU Z4y65XUyTbeG
dEGlogYAq7ComK4Fmv7qf1ys3thwAPyemmLiu/+aG3dws1zkJoqAxVqr23kv mYxHVzihGGHT
xl5CeB1NoFhWYiC0KtFAvs1BXwbVWlTH8GipZsDR21iZFKGcKrkm9+vyhxfl b0ngw8vhdSX5
SaGxn5DJbEVF5CHbNPR7nlH6lTy21Qx0deIKg5+zxlbA/3pMYPQUkhDjY+I1 58o4QIhsNj6A
Cnoo5xZLBZMNKWRErAof08FTzGNqwOZwlk9OnU/tEVCqpf9/j0sRS9G5CQig AWOOxEgRJdN9
jXHKIWBFzDeSGbUbzdkENc2TW0cBpsu8XFRHqK4Tk4Dhbis1tn3TG+oMTBUU 3l/ie8V81rRf
hK0h3IdlbwLFNA/v57bI3CqdWJZI6VhY9rRXI/28W6faBwwPJgdqh0fH9pD5 CPTJar2Oy22W
106reGoarw0qkrFn4EFX+xfV+rkrwnSPntbDvsYE982luGUR0vMRh2j8A3Y2 tmLfeuuvUigT
5SNI/QKAcWtbEGlfkeG/Myby26aa3Ua/tn+mDw68BJthZCtROaBivOiNictm 0BPGcvhh0++y
xZ+FLZKIMiT7iySpGND8hQsnK4l1hY/6zhU7604BcSu12b2cIwzwVoD6hJ+h 1/OuvgCW+WUS
LUCDt44YkkC9gG4o69c8ajm+qyPjVX3sQVLn/+9cfleKQY7O780Wj28yBT0t Jl65KnsiCw8Z
M0XBl0MKBCmXqcGkpZJ+cyt3YxD3r6zYR83MMMHkTXATHftkU0q9Tn/oFpyg 04qXDVEWSCj8
Ar+uDk6Q0q07UinmVNqutX7wWxIDGm+Oa1Vys8ieKAlpvoYsx3f2+4LPBZbj YCpb4sPFLvlT
qPZ17rIEYh45ZRFu7iUxdOzpOolF9kXW7psOhWHFSj4eemj1gt0mF8lUHFDT IEN6uk9oF5/X
9XzP1PAWBzVFmkaFjf13/1LmBfvuRmcHUQFhmUMXv0zGSwDX5K5CXn9+4zd+ zs5k5E+ui0j/
Gg0txP6XB94bS64LYMKShTjz0PuTVyu4B4q82DFijlRt8Nuunz22aaRF00LY hcj2Svc1lYoZ
m/a5mav6GcA2iDrTw8ICvGDKUOiqKUlvNPttt52wAvWUzaiNPvU7gfPE5SbM ioUh3xIKYZ1E
4ONLWh+l1tz+JZo3k/3BGunlJFrqv1KLPbe/AJlHvKtP6fri0KeDGdlxbNqc m67IPOORdZzY
+JaJA6623RC958hpFSEh3N9pcKNC0oWhb73yyp11hT7jhsmffHLI95HFLl1X EjlKFpyzysUR
mBc56e6jgv+YEASoAuEYN+3J3JA+M6u85NteQlMH4fr8uvyzb7Yzq5geK3Hn KedCL4k0HBez
iwHu556+E91KNQurXJYUfyELKO/NiZQI/EHqox2p90xfoDILc/tceSV3UnBr jtFwqYKCwpzx
mUF33VVu7AYHvW66GIcLeeVKR0Unty9vYB/tP/vwI3o26t/RHGMY328NE0DO gjPppC8g+8gJ
lgli+gANr0GyrsaS/4d2SEym/EdSEPkdrmetfwuhyzjmuKb/IiLK8hrXsrNh FnHtKTZu/g1W
Tz19CrVeO895LvZsqyjS0uUY2vsAnyiKv11haarD4cZEBxxOFwGQv6qGN8k9 Q1jSCCV3f8yz
NxOVOsuVFJD4FTzEr7ku2JJ7eZ0hKaa8oiyG1c0ZQAVgksdFfh2pDerB4LY7 hOlvXC5PaJ1w
3NYpf8nlY/lyMWClMLuZc+Fg3NvgC4HUMMke9I2RDKk65ZI+k6V4r9A6TTmM Dz49Cc2LrHlN
D5cJfeKOplK4uTTzlB03sggxihgLqK9bF+KKG4TC09TISwlCxOLmg1pKcrIk wNOapKcuHAt6
DXsuUlTdGRx+tjyqf6xB10kse68NglVYVgjDmRwKK10sMUQ2MfTXQm16YKDz OEuW66KcgaVJ
NVRwnMO08wL1onj7BOesPnkaiLp2WQ5op462gF77pDDC6utvWetlO63TTZKI Afiq96P8qUzS
Nb49dkaV4XUhcHlzXv78BSqa7jr1dJnLqafDM4Q6NDlGXQZNgUx50fc8CTlW wqg4BH2qQFAG
zZqPsRKlqt/hk0a5QSC+N4Wa5JtThrQ8v9P+BCGh9xuCrjz3k1xEz0BhWsFE +eO24DPEJjBO
V1+ke4One8IidE4qaIV6vEy3pfBgxxbSTOUQXw84uRy+SqpNDfPNyXl1Qyum s4VT40+XR+7/
9kVxvw1soDupy9WnLOqbDn/vsCSJf5oFd7qR+ej3hqWtSbyJtP76+HjQHDXl jIFV3i6pvNHp
j6dcbwAl1bEpBHzYhACX8i8hqEMJEtpXN6dvelCMuYYGp2RyybOJ3jhHVZIJ 4Hce2WqV5ANx
ttBW536YpBGEUKqHEJjYiIYcGmGnr7OlGSN+WBxHXaPLQ2BhvOD++ZozGsOQ TRfyo+903tiN
rFGfMHLKpPua7q7qpd6Cz4jcXzkjJoLv8WZVVPpn6lxbDD6b1BW7PM9vDCdL HEEqSMVAjvdA
yZ5rbt8Q/3cLchp3FB9m/1R9lbMN/kW1D7syQWuroMdd2BITff4bOUEnqHBW feU3Ko+WlrpN
N9aRcxkLiKrBbtmnny49of5garH8r3tO8xoRZsK8N+JM5hEGr0jQ13Hb20ij hFfLT6ISzEhM
1/UX/PCWEiO0liWgXB0Grv1/qmPdW8F7rM2xJG+29d/R/m2MVzzqm5YDqmyb sG7HPKg/CmG8
xKjfSVhCs860LXrLR8BsRwFvpVOZ5RtRtkO983zP2eLEOL6bU8V26G1YI5vP bTfIDF5xcO8r
FZ+4qnOO9NQTLSt4aP3X5r6h3e5y2BdFoV9J2QZOLdXU7EEgoKE+uWMLsP5o Il+0PsO3MZWP
RZ0zfDTBgvbm0Ga56J7wm+JYL7lxLNoFyyucXeWBQJFawrj8jmp9MayE1OVh 9QwJ9LLgO0SC
ITBzw5Z0fBMuCz+/zUWg0GWpY/+2MVrjamUZ/gDZp+jFY3sk6s/Cs11zLXEj BiRssPwyvNcs
vsIo4qzBhHBoafmxk82os0nzyruf/4GOyOBC+CAKlOvxKQ5lk4s49GGKFG/P Ea4WbyEai4dS
CJvpsL07TCVkWgUC4yPyZv2EPLJ9gwUxUrnGfqIcYH0tAOw7d+W0XW6qWDdE p7yM4hxjt/kT
nBa+kQZ8kyjKXjjQd6wt5CH6iX0gknaJBMRGBT6aiuvJR0jexoi+4goxOZ7u /qKHeK+ZjctV
m+mnHmX2EzdN6OfbGBDsg4D8z6pDJarQJ3ZVj8Ub4Vy8UNl94HFwjhiQK5S5 5ocrS/fnhelv
9gwgwyGvCPBiw+Jpo4hnceSyK7hsKuhhHE+iMymwajiQeh5jNTrqiNt/vi1G KhVSvbg/asdr
mLeSnaYdAMIlAoSdfskSS0fQh2Tfw41lHaHL4eTlCoc4XlzZV634YQusV414 UZ++akfwNQbo
oT4E/wmqGS9R7tFhn6+zyS3E/0xB+ISicjeXTONXbrWeDxBUYqXCIyJDetia cQipLxxeP9t2
18YMdVnplBs1NaopbfV8oRphU46A9SNQOGkCDhI4AcW3/upzXzF9WXGBXrvZ j8kVmCri9aw/
y43a70rH1vsjlkp2sKBQkZ9CVIQG6PPt76MqU6U0kHz67n3tFj3ncHuDmIqy Zufd5Un9pRMB
IdaqKWH/c8J+Yh/awUm/HKfoodtp5fg7HfLR98ePJOzZSkcY/cCz01f5DG15 G1ubddiEGEgJ
FGp7UazwWRM4QyFtAj6lFSiqFbNnVTYrQCb3E5otYYkrILaLDUhFCLXOCixV AQFtACDK4NpY
qidWeXsRHtqtBzL6uJHcjkHiXbMLzN125wcenyO14Id/5KjMHyAoa+DVBmob fe//xkJGN4H7
jBVn2ZznG+PkQPptYuhvXvEm0OwfMzXi5sMMrZYPNIID9oSBmV99TdAI3c0j FdlvMJTJTFpy
HnkaAOmqG0hA1w9QnQhEVqxrjlzK9kDNKzOY800VLZL/+sgaplTs3gGUE+Iz OrEDDIzPn6Ix
nzsCOFj38Ahe/607YQEwNMYr76YSH/oUGpOoNK9pxQmx/CARBHOWsV0/PyOz fU6TEfvxdgNu
3TJ1VeIUFwzZ/YPTScw4nAxGucQAYhIE4FoGYAuFdLegA1WqwXGgzbeCnYqh 144DHIc0n63w
x1PA/1FcULm5fdVn/DRsRVF6I8KW4peEoMyDZLeL+zFxC0w4gNkyrGSWI+iH mbbh7K93h4gU
fKvCiouwVQUO8Iy//uhvNvqtn5P5l9iCa4ChTurW7aKYXwiOm3Mi2zvj8Kkr tiRTPfn76Lgn
mOFhDIm8FQ1FOk71GcrCp1yz1YIxY8dFfQDrV/1rxD61PkvbOg1WE7ZS2kxy i158PjJaW+dP
7y9oP9eg/qdqTlcv66cKJVzEehQmvcLVA99D+U6SJhXtyfGZ6TzH/rRrI0Fk hA/clmZ0M1JV
WLiUngfAzwHsp/jQi9DEHYJB1AJP0mSbMtM7+4UOPjFHCJ0NlkCCcDz41cjp rqrXaxoBqAAu
fcfy/Suf4lLhWsAb7fJgQ4hnPeFqyfmPYYkPTucrIJcMlSt7RiGsC9nSWQsL TCD7XgJJwy4y
n3J7cJpProQ5FX9MlsxrcIrJ3EGX/VnbddSzmCAngvF2q/q3KpHmCC/Ox/LZ Mz9s7qnFkuvr
7hqBtqaoHtLuiDe9s57LNfRHFevMTh6l8aMOPa6j+lfUShJSRcc2FCQOxA1j QGRBNvmioX3H
YhiLjSRovekavigeKaXirp/N6zXi2NhKivHoGLfxCGic9+od7/fMjYvZh1E3 a15/3siCIko/
aTnBkHX5Fsj9rycGQi4Ow1ywrGBdHQ943NAesG8s57XxeZBCdE2CFn27tGsV xtzLtja8VSaY
XA0iO9GVg28qLlehDPae2ySBskhVlq6e2wbMNSvZksfOLt1Ah4FsED2DKW/D xB1Jzgi67LGt
4y9hzMko0+vX64mEQIEPQp0FmpS2omQBd5XE9mRbJ+LWhSANftWpDK91fJds O1IEUl2UMxnS
o9slB49a3K3y+zcw6626cCxl4A88bIQDMAFU9ph3gxDv3WGu5nFXmbioGrar FKv6vIWBla5O
pC+kgALijd5QTzp50iC7xkTTOFLQ0FkAnMO5IgVPGFw8eFYL5Kr6TEnQA2Sn Glq0NOXqs3oj
lyHzsQE7YJ4KYO5bEU0iTWSmzWmIKPDGDTrkD+bpAeL4zGaGt41j1gvv43NX Fx8riiqWI6qU
1GjgnBrlAxk78YN+x4basx4h5VzJlF6CKswC8c2b+WydqUspLie5YMyjyJyj VF1VkKYWLrhU
bQW/pDjmRVfeZ0eHiW+HMcrwXC/6MiBOXJe8+PCxaYeeLWtjpie71Wu5UmE+ RPA2Q1GmyaJQ
hexBzIJNhA46rHW3R3J4kWzuMCxKh8jcJ5qEhB/pv8nOmPnPg5tZ/+46J4h6 ug2VA/0OTkZb
q5j1NooBQ8HyGwFsjo0uSeagpaeDDzKEeRX7es73rpgViMqZF/y8LQcA6R2o nuJjqGRBtxI3
EeaxzqwqqPMEvETrOBxiPmxrbv1KbU03tO/8wjPgyDc9knP/uoM2qOiqVgr8 o9komUzU80fo
Vjd5phMv0WPbQW/Ial5eXK+ys318K61FLGCrqUUPJBPKc2VVOJwFAPGOYqns oiEwwp30G81r
zcZig6lVzXFylusLVAVd+6vG5q1r5oJW203/UZ2wfF58Mtt+wuuHcHPNCM4J sdfIxK2Sxh1s
f3TkMVbfgxsiPupX0Mr8eEcZ9W83CBgE2ri1Lfhjy+JkBF4OfOO42FLJP7ye F+5UB2n/Ye1h
sFV2GhuIuuaF3UH7JamGybLxYPLuHJVIs78tSsxhQFEoJ9M7TH3KtbTodrBW wHXbwHQh2LK4
idmqIWhfaLI18c3iK2opRb7TSBZ2V+GHespjuY3Z2BBy29gG5RQ42DwINBa0 +OOwd514OMjY
OmL8+qyYlkbr3l/+umM+uKHRla7mpqXu0Ti6sAx7xxsuhucJUHy8wQ68OfGX RQpfXv4125Fo
3wb3hQHAgn2jHJF9K8toQ/zVLQwNxAYhKedoYF5Ase6/cSKNTYhXMdhctK51 lwDKYK93uBfI
kDRhI37iqFOU3taVMrhLbSgnzDBLjnLL0pcRBwyo/3dyk67jfyrq21gn+YSH ohGQUC0jdu+D
+5BepfkV7PpdmrJBUX07DwKJXdgiP3x913/yB1FeO/TwHZ4CSBowwKS5cBYB OFxkAJrrQpd2
GTBIEobqn8OQi8xhQ7YF0IlTYPR78zKftO9yaUPioZJtHf4kLS33HKuU62yw OVyaGAKHp7I9
m500AhY9/4QuEpRlrEcKGeOS5nX7PIxcg+66ZAK8dj2nkQFtelt2CYq8OSQF mTjipR0HG0T2
h1Mdr0uJdG5R32Kd2u3dq3wlTwaTsFzC9dHcf4ADJUDnUsauFM4FJrTy+XXa HtCLSYAS0fEr
SnOdLSVadhfp9C8Je2dQgeTOnN+l61LIK1oDRcigJPhituiOQ8ngcPs9z0x9 6aJb9O2ceyw5
gdFQKaMuE9rM6MvW4ArlxF4MYtOFbjVnlhbzT1Se9LPvW0EtLtKLEu120+mk XQVacpkb8Ct3
aHPYusvQqzBsF4a7OSgjOCjEqws7/gXUR1FcKsYNR0k4ZMmeAmDHzOEFWCyB MZjMS/dVZQxj
J5DT/SyNecjKfuf+h0tStWK5o07RqpUSsX6rRjNPfMamVcO549Shztac67vf p+DmhbTVPTPl
P8w/CLPXDJsn2HD6xXS1GY50wierWA8aKdE0Zf59CF1FWiK6oPLtX5sgqzwq DdHmpPIpcURl
lrgjuQ9f7bPNgFjSgD273+d3wtyxpGPDdpwvy+pIadKSeHRE8xFyf9+/sufx jerkIbYTMcZa
8u66bYavMJPV/GWfWBd/wrGy2pagh4elXwAnWG3Oc4YX9ehAtqlAt70Vm4hM wJ0/YrGYRF4N
+9nf7dDQroOPXNb9VcBsKZDvOF2U8bKFNOJU1zBMSV3Pl+agw+cUvnAA5ksQ 2l4Eask3nFec
fNJQcUJnHGY4TXQtHaXkSajli/cuWz2KDR8jjS6KvrjQInJ8+bF885lTahP2 WJAAE3Qb6eXt
lTXKbw3tBWP9jOn5+L+7HHm5iGAoo79fSqi3U/gMiCICGkDKbmL5CxFUuG3P XzzYc5Zuku+6
wgTbOefrAYrlDWd8JapNC0DYveQ87a3Ga9mTz/fC8EcND6WEIy8VN6VYRwsl 2iUJWN0k1U5v
gQPUTjONfcOH9x+hrmaOtuiYM5zWmwxJ0vs43jNOyYuixKoGI+XFjOnAdLPu ynZI0eoCbcj3
z+BYrlX6NCYoOYQlPfBBzK+PnzES/VwHUm9KLalbvLg+uHdUAu3d0E5zNlSe 3WZtZjnapEHq
bw1bEJrFAtDk1hbZOUVsn+sM/ncMwMn9NZEwncqhyDDIVVwgJEzHTiYhLtWR tx2MCJmn86uC
sPjUjiSySwK+/NBpfEI5KtVQ+3EAhyS1jrIP2VYMa8LEW4OxqGl9UjQ9b6Hz UVZXT1mjy9hM
5FHJwhNJbyW+0FxHGETd3+JDFPOm0SyaJ+T79VTF4Pveg3JGPCRskL9qNpPc IdhgW0dYL8k8
grv/X/MujH76pS1zD0xYz5nxtTAJk+q7Rij3nsm21jn6BPZfCnJvDPc84O6w mffHKJnDtHSw
rQ7nyjHIDNU8g7xX+ib53JFujywvZzU7dAw//GuBW5nANd63TCCF2fzH4gTy cAbO0wfH5bVQ
JCypGLzxJ62IjxkjzdJ0Bfu4Tstq9egDQzYu8bdSYxIzcGnPwgFmhGYkN8V9 YpVW6CyIsOTt
za2DDnzUoAOLXkI1mD/mYPyiuwzzENIpYid6gGlb/uCozhQtpRr4y8SCSrqH v16GQ2xKuPGq
xSI0Tp3zeDON/7bqUri/Lj0v5K+dyab00Lzu2/NXoI8qihQECUXsOAjbw5R9 nLbUr3hyoq1L
4PMQidmpZNj+ZsPvnJ5PO5IrK/TiBD01lbpmOJM7NY8vVXvOT47t0fJ/1ehF c5D7/fPyFnrz
TJCyAVwiv320fbiraC8SRnuOfxarIc2WQBDUIkgqd+2qDc5XWyDWWDN5knNN SUIqkzMaOIGR
JlcuTRXUhPD9qzNb9j8Bz34SWgmaSkMuNo++PLPXz4hJySB2qN/oRLbEkE/w 2XjSzvwGLZz8
2mwVu87TSiCNjugDvADVDGyhgUFC4ohC98oneQkVZ2xn5Gp/D13rBWo4WPJU 03mtO4SEH7yp
bEu/t8fcrLNoS4YZe51MVqhY8MFpIIyEgKR3cZHsnLMMGW5GLBbHZx276q2a eZmqwXj+Ns8c
OlSQlpY7GjQuMjNPvdNDaAXxrod0sxLUnyVSg8IoGx2ox5iYD4p0s1rN7WDP iGBrnI14wBV3
N60NJRM9V4BENOKXdPTottp9ewJ7R4DMeuTH4cAyh7WVmzhLPmz4Bm0pT54W UtDGIRiBOab/
QEjCHcvpvE/JdfeTQU/fqpx6GiLTxz6EXnLZ5+5prQDqOV3uw9wluGkuMsTp Soq2qoy6jDVh
6leigY5bin9TT7jWAHlnYwOk5jVt/0getxJBgHUoeH6lMSel5lMFohmvVBfA gPRBNbpyKxjn
V6Sz/HT4ItflWxyI3VhMoD9udggJxB4SH/Caq42DkhjqPFTyrOyq+G3LIppE gHNiEK/Ew7Tm
6v2Uu8h3yqJmKJefer3IPp6gYaMFdOIDNwunSRtM5xrSmeHYqeoPm+l4Uop8 /lBww8asM25d
C7YrcsTby2UW5qfcKfNHRUr5X39zkxT0O5UMcsqWP/lMP0CjVmde+PomOYId bU0H07yeFR4h
B1MHerQ52ZEMpPsV1r05ufHhIQF5W4jgCkPdB+U8Hf3Hl9cBxtzgTW/i2+r0 ezaxfMqSqIFz
KqwH4w/+9zaqWlcfajYDG3qcSK9Vv4Adp6+J+838WTAsRBx8DqPuaoP0cGhp XyMF2AdO5KC/
wdcKLKDXD11Dz1PSMW0r8q1VH9h19tnKtSbJDQIPZWXFykwBwWXpB4ncmn4h Wi5h1G0QqUUL
klqauiDp4whca/H+txktf00Ed6UE3BUxLzDNMheRqE1x3LTlUqx55T8vuBYH aMAwfZsIMsjO
fc0HhloFcy0M3ITaXI2dQYlhlt396jJw88ags6pBGMT9wgE/feQdJn1fOUcN vJob6z0YPoMp
DyzqcXjiC2A17DPE2BgJPsBeIynrfy8Lcjhm4tA1r+8oUgGTI/mNOt0VwHod Yl7pjzU+Joc6
h02NKyG2Nonu+4FOfVZ9oHrvGXRZItEMFi5ytwXO4aleBwkO+gL4XBu3hSrC yBBP0SzeVmv9
jI7HFVOYKbbKzpcdTZVuCUU4VR1ILMFM2+fosrouw2kTss3zfHAfoFW/IfUt lr9QL/NnUdvU
1YY41jN+qB8EfX2Atsm7h4w9Atl6+J2aWFnbdZzm0YKb52M9A9GaT/vtJCAL eUsbyO74veVV
VTFXA6XPt2C49qOhMrRBdZEyBm2lM+MU6GOwtTNYPc6BnHzIVZkInBOV/l7u HyKq12nqB+DQ
RzDcuf/e98zi00aceYsCS7tXoHdD7JjqMQPZmurgh5Z7/V/7cWI+h1Pejoau Efupihf48BPF
PfghSdfF0cFMhSkqAW7ekf8mTbXJ3dGQieDdsdwZaZ829SsMNlBIgyvTNvNW DRRUk27aEnqk
bV8g8+CTRm1IFPwkzM9bPM9e6ucbYAVRvIJx4kLfie4CtfdApIVDIIdTpQ78 Jp6RnNPUB1g0
FJYuwuZ27XyVZ88JNSu9SjithzU9BFJ6Bc/WVlD6ggip0ZsAQQNrVW+dutG2 UCh9/vTZw9it
PR/PbJFI/ELDp5XwUcnHlWFFzRXolgzJ4OFpssq1Dv8dnl5KbtZpxtELZqBS ictSL/OMXw3Y
SyK/4pUAuYTXRYGV1BwPlyciiNz/Z5auqmnY8tYt+ZuSeaNIPkupDD9exSG9 5IitTsIa9mpJ
d6/aqQ/E+GSSoIeFvFd7hjJCfrWy85YlAn8L2QPFpCL1HX0ET2wzgji51915 5fiM8it8D4Sl
rtWHE0rFGqXy9JcEPHY7sMJDfoIjYlsSqw/V/3vkX2Azud9vZXummV6Yxm96 yAqsfT6+B4gr
2hTxj7biaZ76spqTQvzNEeZnzUfA2gWTeCFITTNYPIEh66nAKRXDG10BvWdB hKZI6F1qPeOr
TrUhvM2THzBi9YSqjbmta/vzgLrdLlnlDRV2hyZNxAOTxQ46NS3odrrTp4bK E9ZJinl59s9g
ybPwgBAl4mFOxtemAYDSgqO1ZbExYi5gK1SG2trWwldTbRq9WpufbXly25R2 0h/4g6TSchAE
gM5ggaxUtZvh/m/yEdVGn4mvQj/SpiniW4Q0Bp6ePI4yf1RykKmKWD5vOyAT zXkQ+aoI4+Ve
5iOPgcogHHqWJDArrV3zRVwoWrpXjN4ghSJMfYUQs03NkBXmsEGUJYd7axiF QWQUozx2AKXj
hovCblj40OxHGop22/1Va+7GDgwG43RC7+ZfEYLXf69GlqlET2fE0ZrSK9Pg /dbm61Vk+xGx
aAjRfsh1aHhnHNDS8nTP+TEaaIg9Q5ALOZ/Qn3WunzjGn8RJe30uTALQTuQy Oby+7wSDyZGO
ZisnF+RqClzOMP54Q5yCZXGU5asW/fjHIPTnG03JwuayHNUbSdXWk/UryqXt l2TNm/wjImqv
/DCsVDm8ssiaznez0J22Nioc9xOHqVBR+CzOYsQy1DV+TFODRz6AQCTABpyI 3xeAlz3P3I3U
BCnSxRduM1wf5uUE8x/h/14GzSNekgGJNi5tjCO2BxSx2+owXnkAprJTUsbl t7C+/NOFoFCP
WLQSrkWq+wS5di0B6cYbs732CGM+gTpVgcvNEKCKA6FWvdZLlrJcxAn97UWe 5uZPdbk8VtOw
RDZZMZ9MeE12cwL8sHHAXSDf6Hz4CJG57HS+tGFDkLgnek93L+e1b+RaZLOn FOh9ZJHUwRan
sOnfWBz9207Ge+Mu/582W60i3dJSfAI4z8O15U5b/VpRwe+VZDnEiovq38aN wJkFYaUXJt5b
AphaGpltPmEkaApgNZOh7hZw0z567fJ28Bhtlie11/YU7pkndh7SFpqR+SmC z7RrVcG+7oI7
aLHg5/EEqfX4nAyjS3iN+IRPyW7G22ANR51jWn+9hPB6Xja4mZE5XORcduJG nR4Qvn6jGns/
Da7eCo7YfJVe38OeqcBTMCnFBOF+ZLTulppBLMAGWVTo78MqYRuChBnLv2/Y 5G+4cEG10T+r
OGq8flyUtaMv38kCtPTFGrUJ//gf1uC2wmQVnic9EEEBd9oBmcrwGo0C87Fd uz+JY5MKmLNI
wTRnE8Mtb822e+FKK15PReACbH+QKPKFC2HUiED453B0GFGmevTPtuLdMnh4 zSD3qM7leJHv
iYc6Yz8p3eVYPjCEAYS3IQzmvQNtVDhsvZeOI6cwlImqx8Vfu8ofS0pGQdvZ 2L/j43uRSoUz
OGWpo3HPYId4lngddPugjhGmHfYz2+ZJS3gZ6UlFxRl5Ui3fK67clISUJf1e vfedPl/Ynw8M
OdjgZNBdTcORfGo/2Nu3JfqzURGNfywQcKbSRRUdKlrfcihpqfOZyj33NM28 68YqsPqfqsfo
yEWD9Yrxv7sY8iD/AqaAUjac6HHmRkSZALbzkIcjtefvbiNUXmCEcWmV63g4 SuSPvFpxBKFv
QlSgfPeXTA0GlRg8DC7XQGwzy8eUAMf2Fe3LdiOEVwr4aTm0bOygyz/J7NA6 vFSfLRZwj7XR
PQ323IhyObtF9JGaXEarpwE/1KHUefKPjZNrJLm35g/BG3XpHvWTMNsmti2/ rTYk9hbFZB6z
nLeUbAFHdOSHmOYNw/EXtCGH9L5ptLUjqXQge8iBP8BiprdUDXvowkt6FCqG FaG+covD60le
FDYpP8+HhBbvgGdqpX7bu0iG8KY1sQ7dKrjOdPR+U/3Y2vcAkN3lHD+8w2mB OXZwg66NZCu3
XcyyrOwj6XeDkQkBHhafHO7hWu9GOTc8BVb6jx7LBLytWoTULhJzIWxYzpUg AhA4N1yW6DhA
NPjILa1n4OealghDpcgdUV2hmpnuh6jR+LtsFlzAcBQOZf8+lTYQBf6/OaAq PiP8I4jjk305
NdxqTRQP4K6OaA/XSIwR+p4ggJ9hKpSpf3dw3U11FuRNF8IeU7ZrdR4PK2LY b+GeixH4MA8y
7pxj19z/+Fxb99hwHcNM4uYlUktI7A7PDhnjfRG0nCbZfW52QT25ZogPEKB8 lC35Tp6PZaKD
7lgc6EuOk9b8+i8e994LsXyIkD8gp17i/9nHb3fP69A31dMFA3i1KgpeCxCL daG3sj+SZNnO
iixZb875GQMWz8KPsyrLnC5Ltf9MNZZNJD673OJqgyPEqmwMzSm1eYKaInMW 0lYF4563frFt
he/O8+0IpT0wQYFmhS+zbQ+oIOr9F1icbWCP5M6IVFZ0Lu4ah6lMBXImj4kt j+o3p6mCTyoz
x0Orl8uYQFncyvOhTmEqrntgJP3NhNeSt6Bo/vqSen2SyFORs7ZVyWQgBb/o XnLvneeO/fFz
t31PQKqLIIk0MvXmUO2ts3n7nDEq2vt89DZIYVPM16JdmAOIuIMKcaFFP7iM MESmCyjLWYtz
IapmJCH3xqLQ/wUmo4o6fRsyacH2vzSophszQmKNjIbSYHbIskurkp4i3+2d rMgqcQTCO4LO
FNVsH6j0y0HGRVeWXVPGEnfHn7LWOo7ahmyDZ4jbUkz1DHV0k68tDj969fRu FpwzRlZuTb8N
GuPzhOlUHIqwGETrBH/2BF6UY8sGsvkC1faa0YqhjYTyyEre4G8yw/fNOD+i mEY5o8kBtWkW
bjDUp3wWfs8awMej4Yv8GUO1Q23Owi+5RfV/Rqw2qO6r6ym77GQcCEJPnKar QOtoe5we6886
U3uoql/cuzwfha7AWVrelzXx8FmHrrChypOZ2yoRlJUFYF94cZxSFRX7KD4x c+BKieV3lM3j
5FHeiptE9ZPMjC2Y+4v7QekE7FBZwgcmNtkEH4zCvRboTa0I/Fa1pvc1BIum UEb7Bs81HRwM
d1Ym1hibcN1WyD9IrTJwmGycZnfhF0UPKS7HsW26ogPs3RcabLZye3iVV+S6 m87CMM9wOng5
kUdYt185eq5j9IPFrQbwdfGfOCqm5uCEeIDbroeh0bQBjH3sae13j3YCqlDu NN5nZyPxUMjw
9Cqa/pKlvzWUo4XPaGzhfs1kVLUYWVqBPi32EgbTcQrhJvU38ce05v2RHssK yBQt/5sIw8VK
Be/qHiKwceTCdDwEJGNDIOGHiUiU2GSSnrYlWm9gcFrkJ03ZaxqQWdW6Is+p wX/8avK5Voqb
LzH2d/TNA7//DpR5aZCpQrWXj9lf0w4IH15t8MKAeDtzfvXBgWgVuIG8FC// ofpUh4KGUwy5
FNcMcPc+Y6GZBiAR12INhWx6JqdrxhQZMkXiP7nthKe9YdU1ME11WyHl3GkB fxtfNAxH9yTl
EWhYHgrREWAO3faFxwt7s+2OQFhIhOMJUM3NR8jasp9hIsRX3yqjGzqnyQxM TKR33tfSOkOo
N4DWmTKypPdZPXAeuhsz6fxrygKjs8fNtmZH+4NEbz1210eprClyvBpTwMyu 27LfB8+uU24W
JNT5FA8b1zf7IlWPIPhyP7qZ9ykiTRyUc04eol9/mtur4oyC3dScqCEw6Npg gnnt4yydA++Y
JRd+pwDcpFtEkydB/AhMe29qtdR8akJJikGrvmJdmM4WM7gkgMG657ZsrTEZ UFwVJwswdWwr
JER1CrZPTPHEEAqmZNe9eaCSTLH3ZaSP2Oei9DiMdtrRSDM6nw6nXnTKiCt0 iSM78/IEA5Gk
LVDkYOelhBhCUVJT0nnUiibGEMGWkg/IxQ3hSfIpSaYlXDJ+pj2suVQfzfYg d/5W1NOoypoe
3ZJPGIrEJEd8X2NmZZS1uxDe9s2HngHm6XI8ddNwkf83FI66ivU+r9lyL335 5mm6KFsy5fb/
r5NcclNL6kEvPy5I3KDFphAr0vGAi1j8STVDcq7qcL4hVgwJ7zCxDsm7YcnR iD65qdo4luS2
gPNKzLxOaIWAwFfuG0DThhUwy20o+rdKAzyqHpBGe5HoDGtVaefS5z/paYCV xofPFrIewyZj
bX9aXy3G37BfMF/cWdnKStZId8cXE4ALm5xdukkB6rQmuHCB2Bc7F7dEgfvl M92NRRIY458I
ZAFG5fIrYRVwgRKeX+e8+BY6Q1RUvBoPqL5XqNNUhOf+bfLW3NjdwjVqevuq BEgTIWccuh6o
yiuMhDwBeMvJUW9vctWGtGec14NXQf8fOgfUHJgNGce3wHAmf7cttAVGwQy3 eIS0ZK9m4xtG
iFGjfeqL3uRPUwzYLEk3YGuv+Oon5OimZNel3ld0xzbTlRwvQVjQMk1QokV3 NOcFvf+RcByQ
+V1RdQOt1pthzlmQa4bzUaj6WZePaA4AnW0QUNAp8ARjpliTcLwnj7NQf/J+ pZUeWgZmG2eR
Xz/wjLxIi6qxbAC97qew3ELtY5h/1DR5s4ryJ2ylwFgAsuXBdwvxUhkfTjiz rfyUCAdj6wXs
J7gItUJfeGO780WWlU8Kh7Mk90MZw8t8B/z3EX7eI8moVrlD9PI5q+c4NHEm vaWRtmJ7XCNs
CjWcySt6cWfTnt/kbuw9OpMPdx8ZKf0RrGdmv1ueqJAo+0L1Ikjplg7U/iMP qVZnKeQs8Ilx
CgVT0fUQkEu8N64jcpy/sfzNq3APEcGh0gpErmJI89en1YpayEzguNmkuiC9 JbeHZQkwVRX7
a1x3a3YiPwUizOOO9wZb6zvlOyEQXkJlfBAJbVSGTHjxMdJeRNlwVqkiFCP/ LV55R0G3lW8o
wxHOt5aeki6yXXjZyKX0SdDHjkh8Z9+GGU5kssEfMK5KcbwPNzdpcsjlBQOf rJSC8/27cIWJ
RWq+md3G7g2gq6XBaKfepYjuZhbzt4RxYy54X2FsZfCtm/yLPPKJrfNsqzoX AC9a0drmUA+C
GlHOrcyBoBfg05sKhVIhqv6IS8J1w6QEp1u3afXTV9dotyGxI2V5focKpopw t2twGYDtCyob
pD7QlYCXC/OOVgvVyz/uJyLReFR/TShSInMZQG8cYR5xRoHcmZBJuQWWAqSz G5iwt8Q1pvU4
DNDJ+S1lcZORkyA+zPk2eUcrWFFYU5xvo76raiB3iUpvgyj1W6RCuorFot4e vVFmao7Rt4yu
q2tCORy37iWiuqeDonygcw+4Lr0VrlfkOz0P+VefcYz8BACDYzbCqEofxenA qrJfj6KT0UzL
/uQxgLDoLiAHuFuy4qXQhY0IhcZ80hTcog85dtHZci0efjtr7aGB6BdwN3Qc MrZ5PGqsgERP
1JFXBklSuR9bhQLPNYisPfiteTOOX+ryJo1rCRX12d3VulH+MRHK4GfcwXoW LvkHlf2RYd2d
QjZ6iBSClCfUPMB14vC0ZlB7z4obKsNjaJhLvQ8uI1jggFHrLI2A5OUgXLa8 rMmiiyb1OMur
ItHvc6Skoof0zE4ZFOUs6yiI1DCHEoLUuL0gMh0opavS8hSinoImT3oTzwiw M17lCmx95Drw
c2XE+PEcPakm6T43hIEShZuoOqG6feeIiR0CMZo02bRPKwszCOkVdBTBbmnc wo8g+BoTBi/y
gqpCOdM3vws2Z2sB9JC5bE4YAWVnWMiv1Z4+b3/oAnXucU3nP7h/KziwfLMB 3wMYnPx1j/MB
Cf3yFVG7rog9gTm6+F6aU2yzd536kiivRkZKC5e74XgOl5GBo9ptWOTQDxJe QpUcPt2CJlZI
66t4j9R9XZU3j37FRFkmJ+Cm+fk/Vyq8J5FDR3EQcu6+MVBHge2qrtmT4Cze R0UpPgtCYSII
ZwLDSjHzyejfTGbYuE38o3PoO2VmWGuYFCgS6TO8HIlOuNLqB+31KKucINEd 7uiNKV8eYPAt
p/8k5L90gb19hsPQNxBi7KrG3Oh+dlKxAyMcILPtBc7vOxqPgTag9uk2ObP/ uu6JHwOUSDma
XqBnSUTjelEIY8ukf4R5utLYz+kb1DDRHQNm9HZ1+qQVJcdOEO+iUoFxrqF3 +wq2PJcA5UHD
hy0sTdZrWML5CSuVQZNWiLyhybsw+kXLU8U49W947xHeGPsTJSAZWyygntwE 57idXSt4fz4D
9feaqV4aCXO7bHLOiEeHPz740BSo/gaH6JzuwoLp/vGBrG8Ek6HhqiP+lbna cWksfmCKar5j
9adJF0PQ4sQe5Z/mclzK/dHl2XA8WZl8M8GNiIvjYf+eyeSlP0D7LWhGCRZp lKDhGpEod4GJ
e8WyaDSL3LdjgWld+AEOJ3woKUV+zjrat9Qhg8LQS0GWpVWYMjeFSqDYa0w7 KKVd9zi7Ykwr
hLjoJI0aGUe4arugSZkej7TL5UNSRjn4ZG8llEKK+X/KW3yJ6YW29Lrqwtum v4iC+5/zKWQA
LqAfuS+QhW7Q2fQCVIwLgwwU75ORhyhVXmeUKcLGdMn8mBTw0lhyccVREmzp w0lItvs74tW7
Vtnge4ES/VzwFOQpOg+SdLzBs0dD443qQTnXt1k+bhIuxOnfVJxT/WANyCTx MvJs+ufWEkul
buFF41xZGIn69Wt1NMVJOy/08tCoZMgrPEV02SjHwRRRsayh4QaFoyL5Kj04 cTXNJ+pAEaxQ
H/dr/U7beXRVeUPRKSXlLrTXN+vV7HmcVj+waWBjlyzOjTyPjDtL6TERsqQ1 N9O3JnvKeVA3
WWHhaK39b/LW9+tLO/cZHD6j20bCwgL/GFu2lfgdAOBMVawG6b01iFt/YQFG DlSP4s/KnJ88
vTKSkUaDMGMIu4B1BPFu2EWH4knIaAmVnBXHE8TYn7QcQKprlthjLrk+AJqV e+JkDn0evVa+
NK80756AtCHik92DRyD1XdaYoIJho1aE15mH/Pc6jTFdiR2TYrHNI0VHt2dc LIB+xypdn4oW
lkeWM3VlEOoXBAhbEWGz1+H/XfLlPV0XR0RKc3ERqqvsyIEz8HrldHNhrSUV 23ezd6ifVKDz
hjuxVAh+XA3bCBBZRUhtQdFwuAnZP9FylxBJl3rJFrVQBPmp0dWit0s0xkmE JN4HkgnYCAdZ
6UtQdsZirBq6qsOh8dw5AW4+9qLZY4JIXspI9wzQBms8FXTdtR8/npG+ruAv M/6MqoKIJVXC
vM6B//0Rl1JXym8wv+RDhlpEWMjzrwEcIQu/DJ7wv1/KJELu94bF2uMqJEKf IhA889MpQoTs
Pqj+H7DKnypTdZ51E/7R+ZWJ1PD4EFD5lH7z+IyAmEubFHp8xPWoXoVMNX6d kLFYYoNsrJ6X
prOm8RPLxdWk6xTKYLzwM9RjqAOxKr8A0pAZndd4gz0VTHhgxJxXza+bZ13r fmro7N2LKGlb
NBlSqdcChKUj2PkX+UUXgdAmJoSSAyRzc9RFV42YvjCc5STiFjlQGesQ7iAO TLoLnsfXsbvA
bx6ua4nfNQe5UdhmGrifMmE993ozhTo6HjTFZ+LZkqaQ/dZO574xjKJ9U45U 5yeTwgPXmVrs
lDE7c7v2imqpT2Y3yGj12nrR39C6rxVhgqN7jbWpXiKqWuBktiS+eY0HO26H tb4OIR69TxcB
11Jq/PHFiU1ILMX+23YlAHmdrecsPjRAXDZDE2W8Ivxn8Nj10ldopDE4zu15 yMZ6zIl6NPkv
ayCJCkfv3tXKb6XzeWOy/+TN7XSohw7/Ia2XahJZhw+wAvsYZ/dXAUouoXIS 9y/7lAyc8V15
p9vUMhdXKYEYrUiDKg8AV0T7ch2U8+uax7Y/1jL9n83LTwqMPqUz34mSqvUe 4zosiWlxQigV
Vvvbhep0bcSSvruwfL5AiSeywBcmFP1XljIoSVV2mKgTW8VCmobieLBcWPr5 EQ8yLtKMrH2X
wfEbdA+gov8U5RwaPXmRhNBrTOXzGSpmJ8jw/RlwFU2N8DkAwskPMS6NWX2W s6UleRFOZlAV
s5fwp89oD9XEWWiXzeipG5JEo5R06JCSB+/oXT6hHqynaiqPdNXLxLi6fbU/ p7jCecO0bQ1k
+xWRtDrEQ37D+LBRDy7/nxxUJt8VOSOZcuhq8/h2DZ6xsHexhpE4DValwl30 vkz/TPKGwgx8
1KpFS9riWM60oeCCNgZVEnfiUROgQJ3LkvlhfP5UBjsIAqzmM2n/Pw3rSree Ln2xd8dN/UYM
AgUKqg+wNjupMMe4Z2Q0J+P4TKc3b578NG+zMcq2txgIY3xJho2307lNTJqh FEL4AdrnIc4U
ToyPgwpz047CU7nEYw0mZHFhg4t8dff1AWIc4ei/TI0lPX6/VNOGtj4c54kw yeOUeGsHA8N1
CgxT/11PYjsNOUkUHDP/tI3Ix7N0mtW/MclJRtkNaEYT8alnanSaNq/KnK+/ vAwaeCW0ATD3
bzfTmJ+807BIIbMcR3eJWZxWY8iUL0YCEptBfMjbF4YAMr+1Btxga5HAGW0Q V8nWNlZ4ky1i
C8FGETCS2i+ekn1TUQ6+vr6LnuGPF0u1rA1PBhbGth4soWx/wH/9ffQgAhQz cys/Ok0N6GdN
mFmQEznDabz/fjMLK6qtm6M9eZ+RsCeY0wYS4MmWhSBk48xYHzQ/9k954KBg bOfRcNI1GdSa
ZwMkLBs80LNWPAJlO8H72ZRA2yfgftJd1tXB/YNcuNpZgZBvpuoNWC2Q8PL0 Jsx/Bx/lML2z
vy2YauO7sItEJwOZhJiQ7ycC3ajrQZq1yAscspk+LTCDNBc9a8jp+s4SLDyW RzNNwA0RqVmS
HdVayU9UIXhpNaeAoQIieN8mlkRvYokoEUiAmyeFBjM0jnCOXrakBpfqlhxi nDR481O7wtjK
ZsBFZal/uXsbmOAXcxZokDfGQjJ6JGKQkLoDn4/9wjYCAc0maoXJQ7VkJo7S Ysui9dBehJQL
hb0xZnUusGcbzwxLmAH8PPGNBP0weHP6pT83CsAMItOj/kI1k1sqbjEIXR0s jSpf2mKDJJuH
5HVrSLt7fpYexzYrq37j2ZXmUreTuYn6fQHpGRh/XPV0YOgYRbcMmybVFwsr qTFB9Z3UDUXm
Y8jifuh5tueS+yLP/PzPPYqjIpPVTri5BZpBXNDPcoWmg4XVDNNUXTO81aSl fuonLnH2sS89
HqVqYVnA2/v3T/ugRTSdIlgr1dUJ+0y1/tj4RhpbxdduKz6BX/r2fWWPNVg3 co2KK6ZVtbOZ
aFI1y/180nAWPYznD0U1AhbcqdnZukiNYdlg0H3yBkavdclwwV4HG13XMCFz uG0rDBI97hEN
TOsDMALCOCJ6BMOBp5A2c/snVN4Fyu+j0B1G2zLUmlHbcKJJoCTN0y2CsTJx FMUGvnzP83Rr
wFCaREV7jwFFc5hB9Tx1vhxIU/FdtS/Rg5uGsQrF0Z4F9iY/LN3CBJslgdrZ QNLsmZ6BZysF
IAlWhE3iWV5qTod2YNiphSqPgMuf2sxewLaHjlk0aBwBDZjbSlR1f9ih3FtS ft+KNGfF4SbY
yZ0N/7d3uiCzSfWm9p2OcjOmhCESk0OwEL9CdhZnUZiGVGy0eFw5xafpEFOi czEuyc7hTbKt
JYRXW228lK+4qlhemyrgLer+GZGPIPpWd+zFyTdQ4NkTHH5OQWsqxHBhwK37 o6I/OQyVd20i
rUIuMbd4hM/GUdRiTfMU/L8/73VRkzC5c2fGIRCL/yX21J3Qfil6+TGRmjvv t56yf6Y3KuC4
l5Syk7savkOreuLXK6bmZrYg7kOB+c1u9r2CConTZkwcvQRh6aE+3C/nMUD/ u1IVluj4TH86
MZLmrssdY3RBSP3bHxiapvi5TeHwzUi4bP0GL0Eot8jdYcqo04EXj0N2TUTk RBbKFqxBQbb1
feXhrLpfQf6VDSCWvpr+EOHVUf0uL5UkFBVLnDJwhtKgPRjBx2BTJrHS6iTt anN8ZpvrSEOj
rAN+96KganCdYgA5O3698TkFmg+CRv3uFgSBjouuORq1/LW73IqD9ASp2DAg A4tWYj1wv1NP
bCqDWKLZ+yGMxuVuj8UUtXb42/e9dXqJHL2dsT8/DBJyXFbjrwCHAP8dMDbv UOcgz6oVJ7F3
/k9HaCIgS33cpYgewKxwdiWMT1tKRBNds5zZi3/sTX5zWuZRlTAffSFbiyGL FX6pcdbIggNn
+vZ3EfGSi3cVePPWFRdYJYmUvOtt2HU5h/mBueOL0vddTgXyjNQAp5Ao1/Jj 4bTBWX8r0aup
P+O9AesNb9oohCMKcC+rErvRZzdmJ+6qZUwx6W5Wc61QKWSM6lpXeXg8+fvH 6Ps65l1TvIO7
Vm5+aaxcJL3Utk9CLR/EWeK1Wia0lYTWZbQV88J0junv5WzXVvtnE1UXQDaQ lj+SWSi9lyII
x8mmfjIN+5WXt+sP/i1bDg2P8JNcL8PGofhtn8LGtpxnaBfMuasxBHqlr4VY MN2P4nI6ycK+
p80g2cUz4ouJfGCdrtvC6oVArrc7HyYtFA6oLHL9BVZFAm9cpaY5x1tyqbUZ NFSro19un2q0
Ju7X28Oi0z6AteuhsbzsHkvqg2sSQQkToZWDh/Cr8rG5j4kyrMYtnNinyHWL ueTb73eR1dpK
llRqll0K/wEOJMRN+rRFhAqvvfH9tPIBJtzS0MGH0YgkgyUnY7GgwerndjiQ MTcfFEtxuvDI
kD0orsMkBSqUAG8ygz4d7Ig27G3djloWVjgLEqqNJFQMzM6ZH5/Z+5JqKkbY 1kGYtGu9GP9S
pbnJnsDW0UponNn24PFk0kKLTDRzOKaT+/WMTBc+GvVHPCtp5rxzgKWxfe/k 9beHdDObxmJr
V3UXWk+VJlU+wAuSqviUBSMasPG6Bk7PT1kdTLZhax6YTX5yo6+72LEBOCeq wPczgsrZmLxl
4ziQPlJC5VweVedeJzPkgIkghPFoieJ+xnPH7kyD/x73lCFR50Wgs3A7CxMc 3UqXopepPc5n
zOhYKihhg2qr7Iqp8qM+dPn5D6JsXEISf6cfyP6yEdUhGPOifCtKj6lWnmRr ulQ6ig0l9jHw
/ED+KuPSPeUQy0tGxteW+9MmBL+PlvkRrYwROHiGu3sZV8xc/6d4ELf6xgyd 56h2aLiZnvZn
/X0GNriYPPHs9+RPbSwYyO/vGFl86UXzqhOafGr+xqjhG8obDejREpUB4ukU g4muFPCXChhG
5t9Zt06ntYi3WljqSIoVTrTvR7k9KwXgQ6Eh44N3G3813hnzYAfiXrDcI0os PmgYKcEiB5DP
eKfNv/uPv1AeTeotv7FBzBg3/LKKiv9p2j98RpdlOcff+RPdIgBbpmQuCGGZ rzJCkwW0oHzf
W+IEEPCkMWOMst3AZRTFk+2LiSneX60V/alRly8x7LuEHmI7Ix6VSEVHwSYV RNXHdlPacoJ4
0tVCBlnKeiUq96003vPVXfUOAr1RwS/cu3oSYfxYqDY9fqlvmhyJp9wgbILF 9rXTBR/KGr//
ru3f8kvx3tEMDcAtO/CIsFHaVOhsjK7R3yU+BA7QVxNumrCi2OiQHnr6Kr1W dJX+haOY+lKI
gI+/WyY1ttHsvUODJVfIubGCNOHUFSYKMS/iCyQfP/34AC6Pt2rt3/htlPye f6tqTO8zixB7
l8gXmfC9KRL0O0BiS4ZRz7NTtATZi16F11O4rxVo+rzJnzTbm55KtYZI0x7S TNM5xgvAKPJ+
GSLkPVlS8hn2cEjRB7EpZ1u3qyWd8tUqhygC3Unxnb98XL7mE+/tNdRfQtoV x9L/eahMetJK
g9SoTDJBvmt4cOUf0cyx7LcTT02FvfoWIEUI3J8WUKDoNSUC+M0aHya2X+LQ K1kOGYfmrg7+
OMucnwNFP6XVKqgWfUSKguYwCwwafd9G9W39Xout1/oPSPFMzf1NlpoeEVZf uOr8LL8hsDJO
OzEZA1TyxhFooDnWorTxFev3jWjEjgYDTwcorqSkNWmLyiC5I2fk6hVAbuBn X4eTcdSWYGKW
oP2UB+5Rva/zQ6cNQMC9Qmh95QTbta5FNn8Gz8I720yaPe9vrpJH39Q4bR0p hh/CcDqH89zr
5ldfVz+yYW5Q1MgOksER+JglrrwfrU+0RxujdAnFiXaqGy8xZMxVPQFZoNXD UV08TwdjBI+V
x7IY0X4+ObrT25RKjmlRLmzA4XEAvOuYLPWsQ8OhMmzu6UhFoswsEjHYzhfb JmfkNg4Zt5hh
CJ7IjXU9HJlNHCR5QoehgLeYZeFiLzabkE9NCKLujmPb4H1ydoTrJYC22dav ToTeqfm5N7GL
xBoz6yJBRK1VuzqtPJfH9DI2pXyZd59ru7FcTgC0XhCOGr/KGE/f3ITrMILO 8tq07AmOVvWH
K0PBssUUZ0xI+tcCa5Rp1Bd/kJW2ubPikZF9ynZ7v8scQ5iZSOvCM2whRkm5 pyhOPbkBa51U
LY65bINeaJJ9z1IIlk5/A9USsiL9HfzFClHe8G5124kwe5Si9iHiNQhErM+p BWNnWZq1v/EA
J/X7kBiTvIE0UWfr43iNwR8PMIFdOR7AYGIblq5ZJTZ9EblQglPewDXrYYKT ymPwo4sYyAfP
jXhBwhsEXGeByZivrq9q39lpInhXUO6Pbrzp+6ZZXMY7ravXmL08kzXSRp7t h7kqpDZd77uX
AkTYyHpF8uerjGf3ydQ9VP7BtM3dQtWDdQ/SzVvFMX4EnHJodNFQ+jHMYWz7 i334LE8nb6dH
cKh1wA5+VJvLF4exUqYjBiX5EiB5lCrBNTYMJQNWvrks6GF29icWJofAMlNm gDZ8dONG/5rb
eXaSL/t2PbjHdWGsb/DSzzOhOa2FK1ZFBQhjMA9wQYaWz1a8DxfqgXCv0oIA wljACwxc71KI
YAsoccY+bXbt6TZiO5dcVbaqSIL8kej//++Nw0uvoaabr99h156sdJs7/l+Z tj83IlfdwYyB
6bh2dXNv3l62vXKgjL32SPG2/rAJsUKwf31u5Uom0a5cqruvt3qWSuGR8BuK nX5Y7kebAhqV
vhSjICIkpzuE0RFKzMjO4ckwwdKF5Jr20pgFgDH55L0FudJR2MFO9Emk0dHh 1IQtCBM0Gf3n
X1T3hL8YWGpoAXhRJjKnSodB8l4T3AgDNjque+E1qJRn8KyQ51V1QFBvgbxY DPm/axQ4lnnq
JerrRfc8yoqXu+bSh8/S8JDGrMMT5/GLLXgmiUpBIz9UYgOc3fVIN3KmUiZd z9zIroVWFvHn
JxPPJfLB5cVuOE/GpGJilGtcIX9lOMv59SXWrG8iRZI9A8dRsjGFpRrRR8xb 6qwl56zMKjIS
HICUZTd3rD3WP5il/iSdtYb87daGtmy5UhtY9H8zB/PAZd6mcuzMt32bgzX+ 52Luz+Jnk7yr
z7c9lvDht2ipn8RUK4IQJB4PArlX4t4T5/By7iSVQS75/UFjN5zXhEYP4W4O alrfWexfQvuq
BNOrxlrtmZ9osrlDHN01FRU546PHy0YwZqFEVRBDGhoqW7U0hvss28EvdnVQ lMs1rdDiWxEn
HCzLwljrf0mCL0eMuM+XoOAkXPLuev54kUj95aDVRqXniQJyGmwtuuBYV9WC FhoK1Yal5H1c
IhwNLBJkKVKAoOFQbZ0PjroFgeWzUlFhSblk4oK4mvj59Hq8/Bkf0Hi+EOYl nnXr2heI9Ei8
1wIiwUl3wx78KWHrTPa77+Dl3rony5zM/TJXdV0Cpnqatae93mKXxMCbjZk0 S/JolGVe7viv
OKDPkxyVPmmzvnzuFMSYst8dLc6lPq2S27Kt99ZegFgfw27T2x/ZZN3wD5Rm n9WmBhS/GD5n
y2nW2y2krP8foyOXwtFajBHJSF7TF/80oJQFongL6ESoLat7W5wvhZXDFvHC 0x2RSJLH2mpq
IMwjnSCJj3siyUF9f3mwUHsjlb9rtiPIm1x6DvDjX2RwqEsikwmWwq6EUMfg sxZhyda+QSE+
SUNkAiQSWl/63N4CwnV7rkFRADZd6rL3hPS6YTTnsdgYtS1klvJSbBg5JPf7 VzdOayFkolY9
6reC1WWu4ZSOyBPuWKuKYwaXqr7JmAIUZB9hHIFy+uXzsIjUpt3XYXy0FJ5o n9z7E3ZXA7xX
GpzpqG/OQVL3BOShsn6ItfhLlD/nVvz7DXIGVjQ336oAcYAuCYUusKDtDNXW LR5pQrqJ6OCR
ZYPbepWy2RwFSetAa7UBoYzgJ5syRmEpamOjM+sssl74b6wSbY2wGvmBy+GM Qyf3Xpy0Bre9
0ne8Shpe+2I4TShPbv8KjCvYqx3ZfBnGULSqV/tlwRdvJbutnyysBDk7vyfH 3Gry723LNqKG
Wmg+8C9XS1zXA25l0FUTn9zjRO/VOodq9k2gaOaIylDOIBCR1uT9/Z3+GXNG WMvsUZsWp+dS
e8skTlx/hchfqmyGF+ELbPLfQUb3yi/LWem6laLoaF6Itht/zftfLuMZLrIF vrCCgkED08bK
BulLJ/VwDzWpibt3h44tPPDWAbmM7b7r/GGOT1sWoSTUxRnKusT0Mv1PB59I ikDNUrHTm11B
ceEqhpTmNKmj1AD2LMEfpWOrFIBHx6wfUdvnIuhg2VjGHMxt7E8OZaXU9NvE qOeljv4+ASM6
3k13QrwR0eOxbGzQOBd0CDXvWpGzQ1IYPdfAQI1wTuGvKAVKRlZFB10JMgHZ rcYpd1d/d0hw
qjYeZUF35c37cw18nBYb8J4o0Af6VGe6fSem6V2zjHwNyJ+lvpEY/cm5ZMHO BNuTIOGsVuf2
lVJEUqQIJkR455JnlwXafpRUJAo/wlbYvwY5ECBoMTIBhkT1b3bU3iVT1P0g PYaCbAGEq2BP
+NcwnIrP80SEXc/8WO5MBjDHAq1dpCLZC3oN1z7ZMZy+FxYbY1BOQSaAu+Ow zUJWVgMmgkM1
34sC1yAgdn0aVoCBvgnPS37FfVcJVhnfd/B+wqlco8l/L2/qOJncqgHEKduN 84td9UeE/4t+
aaLlc+zegJdfQtVMAYKxmaeI2BvpeE1NRJjWzE/25VQM61uimUo3z4DJSTg4 Zel30hMoV5hd
FCb4DRzDrWdAP3LiGWMKFc2GuQgotMsSCobEUPpBG/aLd4od+hKXx3ll3+C7 OYYkRpanSJqI
TxsUVcVHoVwjT2tPQSFLOrqeKxWSQgZBCxGj+gCqV6Tah9QpobuJHGFA5/T8 N2OLSFdBw+n+
NUZqZkihkGlCXnk92mRNlET1HZiBNfXUN8LJJ+MbqWiofi/I1xZ/1TDEbmc8 WT6q14f+zWS1
Sst0PLEN38I5id4OepW2jQPpHeKNTCKVrA/5ltsYu2QIOA1G1CdjCPunJpW/ KGgYNWxOLIZZ
+cQ8PMchOD6hr1H1CoMhsB691ReWHLpls2GkMzinaoPUuj80+YYuRLo5jxe7 KSfGO+scTriD
ouxC3rf4fnWdVDGyuShMFRenRaxz3fACvlBgWD6+1JFbeA1rPu5WkzjT7dWe yi8E5cMVa6Hi
nBD4wteiseGnuNuvSX595tcai50c2QGwpKQRE/Z31BhyMOeEnOP8jOlKlIjx y9EFysYbYjRk
8J4zzh0ksTxNQMfaW6Le2itvpChCnBL4+MWrW435z9Y9m3SZzsfpqBsHuvkN 5Vy2Ue5Qonf9
RxGXfQN8Bt48vhwcKjzzwV1dgYxHQyq0USPR3UMKdZxB6gxzlHn8YeBikSq1 wf5bZWk4aa7b
2CVY9l7ycXy1G2QrgRJlxH5a04BiJhTT/9uTXfjPoP0dsTYQv61mBAwXl3n7 /hc/iaFAjOOW
T133BSrdeayEHAd3APAnbA7DvKLLNn2nzYdr0QeKJqKz1nEa6s2BNpJL+AgC whWZvhd4nWJs
rAcZGreQdgVQpgTihpT9a1fG2vbXstntIdIYI/OngOOQ4Ipg8UD/+G1PrZJ/ t7sO6VNCAtKQ
QZ620BdWBTwGMnEpBVtBhNspi12ZmZ97BjMxto6opyFfyDbuCHGD8HbZrThr c/pOOl1ZTh22
YZ7SntsHPi/29yuMpuwzx9n/geHHEKj81CUKjLc7okJz21LS2m1ENJC82vpP EF6orHklhO3L
KMAjV4BGKgN/haWvKaMQSeMXQIc36pCTkPPV0H1P0VTFbS67GlvK6mAmYxEP 3IpMIIKZ8V8P
80CU8HH2MvRzvWvzWQZq3AQd7/iN3pCj+uCWJFobDcP+681tfheWlj0TLFFW G2gv2TMpGrH4
LFQ1eW20Ew7d0k4O8UBAsymoDgRila2QCQQltjSb2Mt01K+xd+il5czoPEXQ DvMnelU7Ai8w
KFLdnB0E1NzxhZ9rsAr8/VVRyERvfX2Pd1CKSiJ8uZXjAdZQxGkfxplTBwjG xLZ9gxV7pR39
SAz5DtKUN+mg7ktTlDBqMwSuhTltRXbMMUSzltbw1cSuGaksTIetwDSlTM9p 41pYWbsnvL0i
PWz6Ize+2m49lO4Yd0Skk7NmFXd/cupVdSTxEq3QepXd7HUI5sOW7FSw0lF/ a5Ft+sxqiApY
5JfqfJBtcvlUTBfEQrqdsbKWC6i5Tg5+gbkedt81zAJ6GN3Q10iC5DwQcJ9Y TYwjAb2kVeev
Ax+2TJc6hPYGz0b0YqMpmOrhnvwBwUgK3/pBkJSWIkaUErX8+dvWtX6le8fB US9HuCuvEy36
WLEl56mwpk33My2YqzCh6FIICCkZPrkpragGkCGEnUOD0inmftMCVvTf7Srf /tUYwI9QGr3A
Uf4EkptCb90lZCYf7mn5gomb5fa/l2uX6cz203aHB39ngiwulwxJywyaPVMT ZiDX2DWnHq5F
X+es7l2ejgxBPPe7ikP1I7O4m641LEU+WsSGwiCpV69KsWynPA/NI/fFh4A8 brJEFMWcW2do
pEAVEmX3hRT2b8rm/Ow3r0mywsTvlOlyfWYsTEwyMzGODGiVqlw9cE+szsH0 AIdxyZgooGxR
1VLTsSk3RcKpEReGQxDDF+LRX8bByjUgzcULwyB1XhcQwxc8vDoTvhbtCSR0 3urD7yYtxyYs
GGAz9PtSLT4WyiMqMOZhYdggEWORkWi70dvbhlFSjDJ80gPcd6oFaKE3sjFl jfmVetiIdQQ4
vEMROe8wso5tFUZt7R93E7md8O0gQTra6nwhYwg5SikW4lhuutWjPi8Q/gom 1fQDUVZNT8OF
8nNRkUtPkFLOdwKQLTwywRqSJf2FVVjPPdjsTC0r/WmutbZAVrd+nOpmF14Y y7By1Il0HnWn
X1RbWiuZKczIA4NMQvOFEqtVdlE8de57Ams2tg7TF/2hRhMAKW9pdodpamIx r9J8SpwbCOwl
heQmHYXhPzPTZWAlQq6aCOUdJmFPnCjBLfihDfrWkCrjcEIeilh1jP96nxjP KVuysAK+1vEi
kWI1B2yxF43gltLWmxOpg2Q4bei9idDI61yiRbb4JzGo4L35nbXVbM1I9umi qq6v4kh2/sbI
xL9In3z7wn7lcpGC9916IJkfkM/4kNrICEXFOvrVdyXdPQAhiFKMdIlEn+B+ fi3Tf9QLzwuv
BZz8xaB6Wzi8f3xzVrPQzlj8gOochdCkMHOO5MeFEv8+g79NwbDaN6Ol5O5A u1Y35efYhZlg
Ai9Gohp3k9ewXr8regzxnWnMlBdzoz1bfRpdUgj+0ZrZZtSOME8odUZBfniu gOfhR4hr3bu/
I/LG4+Fji11p7aIdaIY1YzL1OrVGLcfwEFxB9TI+wvoxD9Gz4YH2P7ixDE04 TTB0+oKJwZoz
CFHNSXM4Mfa/LZ48ff6E1KYQKqbP34HKjfwLIfm4iTvONDilYymwg3ZEiTQU 7JyrVe+TFpsb
VK6CsP4dOzukuoXZhyt0NXFo9J2FETL4fpF+BghvCYnRlfpCykWEZXRPCJJO 81W3q0/sD32Z
9vB/bCg8uWewTK5gW3YcfOPXzhYQ+oMg5Qsa+7n0EjCEq8n4SZbmymRZvJPK qBP5nhBMTk7j
rIJX8UI3Wy068MnoXQTuip/VFW8fVCgvGsOobheAszogXmufsSRwn6hQz1iq QoXe5oLc5Av1
ji5jWPZGcl89yuiPUIPzJi5g/+jdPockLngxgdyXbpcXkJ6Krptz7V0JEIaZ U50QsBUSvOEJ
iveTR2lY+9SeWTYEY+DmvcAhBJnqHHNY3clCADdKvSqRYHVPJqL3gqVgqG5T e0ucORLqoboO
iqKBGpAN3Fe+HYBW1cibmuiKn8p6YvS5KasTCdbKMBf6GiiWyYJBBBYTwy+B 7q57DONuEbsY
FYwEYBKmM0JSQWK50+aFtQiNrzYoZk2HVQqSbmcw+Im+Zzfmf/0CsSeKWgA7 Z7esRXwz/oKw
/ADEGnZDV84z4atgOcflBtY0TYX8r+Ep1zTVl9H9mmB9LtgD0Y53p4Y5oSwQ c16J3LNgp2jI
0LBs7Tk+gXroxPqRaA7iQqt8fSqy6KHxei+S1vbjPekOtfr17Zqzc3VqzTHH 4OMo0JRh3PC7
5xv9YRUkSvtGHBZxcHX/ZRtpJyXTPwTQl+dqP3+Nr3SvSYErvis1ZZO6S+be kRJ9bW9axWlT
OVqAe32UuBAqtABvyL77cvyzCxWa3DER9nr6875XC6IieNGgZJEtyJ70TmTA t4dTv3984HNo
tO8fPxzQVvoIQ1hBXbHcMopK8apmcBkD8cvxXsuYBnM/
| Re: [AGR] Hang problem in AGR 4.4 [message #104771 is a reply to message #104719] |
Fri, 13 July 2007 14:39   |
Barbara Rosi-Schwartz Messages: 448 Registered: July 2009 |
Hello Liz.
By cutting a few corners, we have been able to complete the "detective
work", as you call it.
We have now reinstalled practically everything as in the old "bad"
installation and AGR is now working OK. We have then explored the
differences in the plugins in the two installations and we have noticed
that, apart from a few meaningless source and documentation plugins, the
only major difference between the two is that the new and good
installation contains the eclipse SDK 3.3, whereas the old one did not.
This has us baffled no end:
1) How could we be possibly be able to run Eclipse without the SDK 3.3
plugin?
2) Would the absence of the SDK 3.3 plugin account for AGR not playing
back properly?
We (my husband and partner in crime Joel and myself) would dearly love
to understand what the issues are here. The urgency is no longer there,
as we now have an operational system, but we would greatly appreciate it
if you could let us have your thoughts or investigate further if and
when you have a little time to spare. To this end I am attaching the
list of the installed plugins in the two cases, so that you can peruse
them in greater detail. The one with the "old" bit in the name is the
one for which AGR did not work and the other one is the successful
installation.
If you would like, we could also send you a copy of the bad installation
by post (having cut it on a CD). Just let us know and we will do it. We
could send it by airmail if about a week was ok by you or by courier if
it was more urgent for you.
Looking forward to a few words of wisdom, as at the moment we are
incredibly confused.
Cheerio,
B.
Liz Dancy wrote:
> Hi Barbara,
> That is great news. I am certainly happy to know you have had some
> preliminary success. I will be very interested to know your results.
> Thanks again for your great detective work and let me know if there is
> anything I can do in parallel to help.
> Sincerely,
> Liz Dancy
| Re: [AGR] Hang problem in AGR 4.4 [message #117228 is a reply to message #104728] |
Tue, 06 November 2007 06:35   |
Paul Slauenwhite Messages: 970 Registered: July 2009 |
Hi Barbara.
I cannot uncompress this file on Windows XP. Any ideas?
Paul
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:f789pk$uli$1@build.eclipse.org...
> Liz,
> Here comes the (zipped up) log from the independent AC server. I cannot
> make heads or tails of it :-( ... but I am sure you will!
> Cheerio,
> B.
> Barbara Rosi-Schwartz wrote:
>> Liz,
>> I will try your suggestion and let you have the results (in parallel
>> with the other feature isolation strategy that I have just outlined in
>> the other thread).
>> Thanks and kind regards,
>> B.
>> Liz Dancy wrote:
>>> Hi Barbara,
>>> Your question is a good one...I had assumed you had a standalone AC
>>> installed. I don't
>>> think we need to worry about the IAC as long as you are not running
>>> that version of
>>> Eclipse at the same time.
>>> I do have another suggestion though, so we can pinpoint what is going
>>> on with the
>>> InactiveProcessException, could you install a standalone 4.4 AC and
>>> set its logging
>>> level to debug by opening the serviceconfig.xml file located in the
>>> config folder of
>>> your agent controller directory, and changing 'INFORMATION' in this
>>> fragment:
>>> Logging directory="%TPTP_AC_HOME%\config" format="CBE"
>>> level="INFORMATION" />
>>> to 'DEBUG'.
>>> Next, run your test in standard mode using the standalone AC and then
>>> attach the
>>> servicelog.log file generated during the run in a reply. I think this
>>> will be a good
>>> lead. Thanks for your continued patience.
>>> Sincerely,
>>> Liz Dancy
| Re: [AGR] Hang problem in AGR 4.4 [message #117253 is a reply to message #105163] |
Tue, 06 November 2007 07:09  |
Hi Barbara,
Liz has received your CD and passed it along to me. After unpacking the
archive on the CD, I cannot run the Eclipse executable:
!SESSION 2007-11-06
08:08:25.531 -----------------------------------------------
eclipse.buildId=I20070625-1500
java.fullversion=J2RE 1.5.0 IBM J9 2.3 Windows XP x86-32
j9vmwi3223ifx-20070323 (JIT enabled)
J9VM - 20070322_12058_lHdSMR
JIT - 20070109_1805ifx3_r8
GC - WASIFIX_2007
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2007-11-06 08:08:26.046
!MESSAGE Startup error
!STACK 1
java.lang.NumberFormatException: For input string: ""
java.lang.NumberFormatException.forInputString(NumberFormatE xception.java:63)
at java.lang.Integer.parseInt(Integer.java:502)
at java.lang.Integer.parseInt(Integer.java:531)
org.eclipse.osgi.storagemanager.StorageManager.updateTable(S torageManager.java:512)
org.eclipse.osgi.storagemanager.StorageManager.open(StorageM anager.java:702)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.initFileMa nager(BaseStorage.java:162)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.initialize (BaseStorage.java:139)
org.eclipse.osgi.baseadaptor.BaseAdaptor.initializeStorage(B aseAdaptor.java:124)
org.eclipse.osgi.framework.internal.core.Framework.initializ e(Framework.java:174)
org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:147)
org.eclipse.osgi.framework.internal.core.OSGi.createFramewor k(OSGi.java:90)
at org.eclipse.osgi.framework.internal.core.OSGi.<init>(OSGi.java:31)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:283)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:172)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:64)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:615)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
What are the required parameters?
Paul
news:f7gm2i$q8p$2@build.eclipse.org...
> Hi Liz.
> Will do, thanks.
> So long,
> B.
> Liz Dancy wrote:
>> Hi Barbara,
>> Thanks for the additional information. You can send your configuration on
>> a CD. Regular mail is fine. I will continue investigating in the mean
>> time and update this thread with any new findings.
>> Sincerely,
>> Liz Dancy
>> message news:f78h6i$ha3$1@build.eclipse.org...
>>> Sorry, I forgot to attach the plugin lists. Here they are.
>>> B.
Current Time: Sun May 19 20:02:12 EDT 2013
Powered by FUDForum. Page generated in 0.06124 seconds
