Home » Eclipse Projects » Buckminster » Buckminster headless product has a version conflict with Eclipse 3.8.2 and 4.2.2(org.eclipse.equinox.ds 1.4.1 vs 1.4.0)
Buckminster headless product has a version conflict with Eclipse 3.8.2 and 4.2.2 [message #1033612] Thu, 04 April 2013 08:37 Go to next message
Tobias Bertelsen is currently offline Tobias Bertelsen
Hi there.
Problem
I'm having a small problem with in the Buckminster headless product. Essentially I'm trying to include Buckminster product feature when installing an Eclipse 3.8.2.
There is however a conflict between the included plugins:
  • Eclipse 3.8.2 includes org.eclipse.equinox.ds 1.4.1.v20120926-201320
  • Buckminster headless product include org.eclipse.equinox.ds 1.4.0.v20120522-1841
Possible solution:
My best guess is, that this could be solved, if you would rebuild the headless Buckminster p2-repository, so it contains the latest version of the Eclipse bundles.
Is this possible? Or do I need to figure out an other workarround?
Error log from the P2-director
Installation failed.
Cannot complete the install because of a conflicting dependency.
Software being installed: Buckminster Product 1.5.0.v20121128-1216 (org.eclipse.buckminster.product.feature.group 1.5.0.v20121128-1216)
Software being installed: Equinox Target Components 3.8.0.v20121212-203907-7M7fA78g4_y-edvtH0ZcEC5NOFTB (org.eclipse.equinox.sdk.feature.group 3.8.0.v20121212-203907-7M7fA78g4_y-edvtH0ZcEC5NOFTB)
Only one of the following can be installed at once:
Declarative Services 1.4.1.v20120926-201320 (org.eclipse.equinox.ds 1.4.1.v20120926-201320)
Declarative Services 1.4.0.v20120522-1841 (org.eclipse.equinox.ds 1.4.0.v20120522-1841)
Cannot satisfy dependency:
From: Buckminster Product 1.5.0.v20121128-1216 (org.eclipse.buckminster.product.feature.group 1.5.0.v20121128-1216)
To: org.eclipse.equinox.ds [1.4.0.v20120522-1841]
From: Equinox Core Function 1.1.0.v20121002-131448-7K7XFKwF7RZHQ_I5Xk8T5irEK (org.eclipse.equinox.core.feature.feature.group 1.1.0.v20121002-131448-7K7XFKwF7RZHQ_I5Xk8T5irEK)
To: org.eclipse.equinox.ds [1.4.1.v20120926-201320]
From: Equinox Target Components 3.8.0.v20121212-203907-7M7fA78g4_y-edvtH0ZcEC5NOFTB (org.eclipse.equinox.sdk.feature.group 3.8.0.v20121212-203907-7M7fA78g4_y-edvtH0ZcEC5NOFTB)
To: org.eclipse.equinox.core.feature.feature.group [1.1.0.v20121002-131448-7K7XFKwF7RZHQ_I5Xk8T5irEK]
Application failed, log file location:
Thanks Smile
Tobias Bertelsen
Re: Buckminster headless product has a version conflict with Eclipse 3.8.2 and 4.2.2 [message #1033654 is a reply to message #1033612] Thu, 04 April 2013 09:33 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas Hallgren
On 2013-04-04 14:37, Tobias Bertelsen wrote:
> Hi there.
> Problem
In that case you're doing something wrong. You should not attempt to
install the Buckminster product into another product. Install the
features that you need instead.
- thomas
Re: Buckminster headless product has a version conflict with Eclipse 3.8.2 and 4.2.2 [message #1033666 is a reply to message #1033612] Thu, 04 April 2013 09:48 Go to previous messageGo to next message
Peter Nehrer is currently offline Peter Nehrer
I'm running into the same problem when trying to include Buckminster
Headless in my target platform (via p2) with Eclipse SDK.
Thomas, are there any plans to change how Headless is packaged? Maybe it
could pull in Platform dependencies instead of including them.
On 4/4/13 8:37 AM, Tobias Bertelsen wrote:
> Hi there.
> Problem
> Possible solution:
> Only one of the following can be installed at once: Declarative Services
> Thanks :)
> Tobias Bertelsen
Re: Buckminster headless product has a version conflict with Eclipse 3.8.2 and 4.2.2 [message #1033697 is a reply to message #1033654] Thu, 04 April 2013 10:33 Go to previous messageGo to next message
Thomas Hallgren wrote on Thu, 04 April 2013 15:33
Let's say I needed the org.eclipse.buckminster.installer bundle. This has no dependencies, but it is included in two features, org.eclipse.buckminster.core.feature and org.eclipse.buckminster.product. The core feature contains a lot of UI plugins, so if I don't want those I'm left with the product feature.
A workarround to get org.eclipse.buckminster.cmdline and org.eclipse.buckminster.runtime is to just install org.eclipse.buckminster.core.headless.feature. This will drag them in as dependencies. You can't get the installer this way, as nothing depends on it.
Yet another way to solve this is to change the structure of the product feature. Let's say you divided the product into two features: Buckminster-essentials and Eclipse-essentials (see below). In this case users like me, could choose only to import the Buckminster essentials.
This will yield an inclusion tree like this:
-org.eclipse.buckminster.product
  -org.eclipse.buckminster.essentials.feature
  -org.eclipse.buckminster.eclipseessentials.feature
     org.eclipse.core.runtime
     org.eclipse.equinox.simpleconfigurator
    -org.eclipse.equinox.p2.director.feature
Re: Buckminster headless product has a version conflict with Eclipse 3.8.2 and 4.2.2 [message #1033715 is a reply to message #1033697] Thu, 04 April 2013 10:57 Go to previous messageGo to next message
>> On 2013-04-04 14:37, In that case you're doing something wrong. You
>> should not attempt to install the Buckminster product into another
>> product. Install the features that you need instead.
The product contains headless features that indeed does conflict with
the IDE product. This is intentional. The features are named headless to
emphasize the fact that they are not intended to be installed into the IDE.
Why do you want to avoid the Buckminster UI feature when you're
installing into Eclipse?
> on it.
The installer is just a thin layer on top of the director. It was
created before the director existed and then kept around for backward
compatibility. The director provides all the functionality so you don't
really need the installer.
The former doesn't sound like a product feature to me. A product defines
a root (with binaries etc.). Installing a product into another product
is bound to produce conflicts.
- thomas
Re: Buckminster headless product has a version conflict with Eclipse 3.8.2 and 4.2.2 [message #1033719 is a reply to message #1033666] Thu, 04 April 2013 11:04 Go to previous messageGo to next message
Why not just include the core headless core feature then? If you have
the SDK in there, then surely you don't need the Buckminster product.
But we already do that! Not for the product mind you, but well for the
features.
Again, a product is not meant to be installed into other types of
constellations. Please use the features instead. That's why we have
them. If you feel that some type of feature is missing, then we can
discuss that. The headless product will however not change in this respect.
- thomas
Re: Buckminster headless product has a version conflict with Eclipse 3.8.2 and 4.2.2 [message #1033735 is a reply to message #1033719] Thu, 04 April 2013 11:24 Go to previous message
I see, thank you for the pointers -- I have to take another look at this.
Essentially what I tried to do at some point was to create a top-level
product (custom) that includes all Buckminster features that I wanted in
that root IU. For that I had to pull everything into my target platform
(and I had other things in it) and that's where I ran into trouble.
I wish there was a way to mirror-in existing features from an external
p2 repository instead of pulling them into the target platform (and
losing all kinds of metadata in the process). Maybe b3 does that?
Haven't looked.
I ended up just requiring all those features so they do get installed in
the end, but that's not exactly the same thing.
Anyway I see your point, I'll take another look. Thanks.
> features.
> - thomas
Previous Topic:ANN: Buckminster for Kepler
Next Topic:Build is slow with buckminster 4.2
Current Time: Tue May 28 23:26:50 EDT 2013
Powered by FUDForum. Page generated in 0.01854 seconds
