Home » Modeling » EMF » BasicExtendedMetaData.demandRegistry delegation
BasicExtendedMetaData.demandRegistry delegation [message #1032720] Wed, 03 April 2013 10:41 Go to next message
Ed Willink is currently offline Ed WillinkFriend
Hi Ed
While trying to debug a UML profile issue I started watching
BasicExtendedMetaData.demandPackage and was surprised to see a demand
package being created for http://www.eclipse.org/2008/Xtext. This occurs
when opening an Xtext editor loads its grammar file. The demand package
is needed because the demand package registry does not delegate to the
global registry. Is this intentional or an oversight?
Ed Willink
Re: BasicExtendedMetaData.demandRegistry delegation [message #1032756 is a reply to message #1032720] Wed, 03 April 2013 11:56 Go to previous messageGo to next message
Ed,
The API is documented like this:
* Returns a package from the demand package registry, creating it
(with a document root class) if necessary.
EPackage demandPackage(String namespace);
So yes, it should demand create a new package or reuse a previously
demand created package. It should not consult any other registry.
If you look at the callers, it's generally is things like
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleMissingPackage(String)
where the resource set's registry or global registry have already been
consulted or like this in the QName support in XMLHelper:
ePackage = extendedMetaData.getPackage(namespace);
if (ePackage == null)
ePackage = extendedMetaData.demandPackage(namespace);
On 03/04/2013 12:41 PM, Ed Willink wrote:
> Hi Ed
> occurs when opening an Xtext editor loads its grammar file. The demand
> package is needed because the demand package registry does not
> delegate to the global registry. Is this intentional or an oversight?
> Regards
> Ed Willink
Re: BasicExtendedMetaData.demandRegistry delegation [message #1032805 is a reply to message #1032756] Wed, 03 April 2013 13:01 Go to previous messageGo to next message
Hi Ed
Yes, you're right, there is a preceding getPackage() guarding the
delegateRegistry usage..
The failure to use the already initialized XtextPackageImpl is because
BasicExtendedMetaData.registry doesn't delegate.
XMLContentHandlerImpl initializes it as
ExtendedMetaData extendedMetaData = new BasicExtendedMetaData(new
EPackageRegistryImpl());
Ed Willink
On 03/04/2013 12:56, Ed Merks wrote:
> Ed,
>> Hi Ed
>> demand package is needed because the demand package registry does not
>> Regards
>> Ed Willink
Re: BasicExtendedMetaData.demandRegistry delegation [message #1032818 is a reply to message #1032805] Wed, 03 April 2013 13:19 Go to previous message
Ed,
Comments below.
On 03/04/2013 3:01 PM, Ed Willink wrote:
> Hi Ed
Yes, the content handlers just want to do simple XML processing to
determine things like the namespace of the root element in the
document. They don't want to do any "real" processing of the document
and don't want to create any real instances of any models.
> Regards
> Ed Willink
>> Ed,
>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleMissingPackage(String) where
>>> Hi Ed
>>> demand package being created for http://www.eclipse.org/2008/Xtext.
>>> This occurs when opening an Xtext editor loads its grammar file. The
>>> not delegate to the global registry. Is this intentional or an
>>> oversight?
>>> Regards
>>> Ed Willink
Previous Topic:Flow Diagram
Next Topic:How to set duplicates at EList
Current Time: Sat Jul 22 09:03:40 GMT 2017
Powered by FUDForum. Page generated in 0.04641 seconds
