Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF diagram editor cardinalities issue(only one cardinality)
icon5.gif  EMF diagram editor cardinalities issue [message #1029182] Fri, 29 March 2013 05:11 Go to next message
sams good is currently offline sams good
I'm trying to draw an ecore meta-model diagram (.ecordiag) using EMF editor.
I'm wondering why in associations and aggregations there is only one cardinality instead of two ?
thank you .
Re: EMF diagram editor cardinalities issue [message #1029347 is a reply to message #1029182] Fri, 29 March 2013 10:48 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Which particular case do you mean? If it's 1..1 we only show one, but
for 0..* I'd expect to see two. In general, if the upper and lower
bound are the same, it only shows it once.
On 29/03/2013 8:56 AM, sams good wrote:
> editor.
> thank you .
Re: EMF diagram editor cardinalities issue [message #1029381 is a reply to message #1029347] Fri, 29 March 2013 11:53 Go to previous messageGo to next message
thank you for your reply,
not really, I'm trying to apply the example of Family To Person and when I try to draw for exemple the first aggregation from left, between Family and Person (familyDaughter to daughters 0..1 to 0..*) it only shows the first one (0..1) and not (0..*), whatever the cardinality values. it doesnt allow you to add a second cardinality, in this case the 0..* one.
http://wiki.eclipse.org/images/2/26/FamiliesMetamodel.jpg
am I missing something ??
thank you.
Re: EMF diagram editor cardinalities issue [message #1029392 is a reply to message #1029381] Fri, 29 March 2013 12:10 Go to previous messageGo to next message
This is definitely for an Ecore model, not UML? What does the
properties view for the reference show? You should always be able to
edit both the upper and lower bound via the properties...
> http://wiki.eclipse.org/ATL/Tutorials_-_Create_a_simple_ATL_transformation
> thank you.
Re: EMF diagram editor cardinalities issue [message #1029397 is a reply to message #1029392] Fri, 29 March 2013 12:24 Go to previous messageGo to next message
yes its an ecore diagram (*.ecore_diagram).
here is a snapshot in attachments
index.php/fa/14192/0/
but what's confusing me is why in ecore diagrams there is only one cardinality by association??
  • Attachment: Capture.JPG
    (Size: 61.65KB, Downloaded 64 times)
Re: EMF diagram editor cardinalities issue [message #1029632 is a reply to message #1029397] Fri, 29 March 2013 20:08 Go to previous messageGo to next message
Because they're not associations, they're references and references are
only in one direction. You'd have to create two references related via
EReference.eOpposite to form a bidirectional reference, each with its
own multiplicity.
Re: EMF diagram editor cardinalities issue [message #1029826 is a reply to message #1029632] Sat, 30 March 2013 03:32 Go to previous message
thank you so much for the answer, its all clear to me now Smile
Previous Topic:EMFStore Branching support
Next Topic:[Texo] Resolve proxies
Current Time: Tue May 28 12:29:39 EDT 2013
Powered by FUDForum. Page generated in 0.04163 seconds
