Home » Modeling » UML2 » Writing XML file from UML Model misses some data(Provided Interfaces of UML Port Element are not written to XML file)
Writing XML file from UML Model misses some data [message #1028796] Thu, 28 March 2013 14:51 Go to next message
Bjoern Steinemann is currently offline Bjoern Steinemann
Hi all,
I have created a small UML model using the org.eclipse.uml2.uml API and could get managed most of what I wanted to do. My goal is to get an XML (XMI) representation of that model which in turn I want to read into another graphical UML tool. But unfortunately the uml:Port element is not fully exported to the XML (.uml) file.
Here is the relevant part of my Java code.
Component myComponent = ExtUMLModelUtil.createComponent(myPackage, "AComponentName");
Interface if1 = ExtUMLModelUtil.createInterface(myPackage, "InterfaceName");
Interface if2 = ExtUMLModelUtil.createInterface(masterPackage, "AnotherName");
org.eclipse.uml2.uml.Class myPortClass = ExtUMLModelUtil.createClassFromName(myPackage, "APortName");
Realization portReal1 = ExtUMLModelUtil.createRealization(myPackage, if1, myPortClass);
Realization portReal2 = ExtUMLModelUtil.createRealization(myPackage, if2, myPortClass);
Port myPort = myComponent.createOwnedPort("myConnector", myPortClass);
Here is the code from the util class ExtUMLModelUtil:
public static Realization createRealization(Package package_, Interface theIf, Class implementingClass){
Realization ifReal = UMLFactory.eINSTANCE.createRealization();
ifReal.getClients().add(implementingClass);
ifReal.getSuppliers().add(theIf);
ifReal.setName(theIf.getName()+"_real");
package_.getPackagedElements().add(ifReal);
out("Realization '" + ifReal.getQualifiedName() + "' created.");
return ifReal;
public static Class createClassFromName(Package package_, String name){
Class theClass = UMLFactory.eINSTANCE.createClass();
theClass.setName(name);
package_.getPackagedElements().add(theClass);
out("Class '" + theClass.getQualifiedName() + "' created.");
return theClass;
After creating the Port element, I can programmatically access its provided interfaces:
if (elem instanceof Port){
output.append(String.format("Element is a Port of Type %s\n", ((Port)elem).getType() ));
EList<Interface> interfaces = ((Port) elem).getProvideds();
if (interfaces == null || interfaces.iterator().hasNext()==false)
output.append("No interface yet provided by this Port.\n");
else{
Iterator<Interface> iter = interfaces.iterator();
while(iter.hasNext())
output.append(String.format("--Port is connected with Interface %s\n", ((Interface)iter.next()).getName()));
But when I save the model to XML I only get the uml:Port inside the uml:Component element but without the provided interfacec. Here is the excerpt from the created XMI document:
<packagedElement xmi:type="uml:Package" xmi:id="_bBvQIZcMEeKkBLD318CJ8A" name="Components">
<packagedElement xmi:type="uml:Component" xmi:id="_bBvQIpcMEeKkBLD318CJ8A" name="AComponentName">
<ownedAttribute xmi:type="uml:Port" xmi:id="_bBvQI5cMEeKkBLD318CJ8A" name="myConnector" type="_bBvQKJcMEeKkBLD318CJ8A"/>
</packagedElement>
I was expecting to find the two interfaces nested in <provided> tags.
When running the code in the Eclipse debugger the method getProvideds() of class org.eclipse.uml2.uml.internal.impl.PortImpl is not being called by XMLHelperImpl or XMLSaveImpl which do the XMI export. org.eclipse.uml2.uml.internal.impl.PortImpl.getName() and org.eclipse.uml2.uml.internal.impl.PortImpl.getType() in turn do get called as expected.
Did I miss something in my code or is this a bug?
Many thanks in advance
Björn
Re: Writing XML file from UML Model misses some data [message #1028850 is a reply to message #1028796] Thu, 28 March 2013 16:49 Go to previous messageGo to next message
Kenn Hussey is currently offline Kenn Hussey
Port::provided is a derived property (calculated from other information)
and so its values are not redundantly serialized, per the XMI specification.
Kenn
On 13-03-28 3:38 PM, Bjoern Steinemann wrote:
> Hi all,
> "AComponentName");
> "InterfaceName");
> "AnotherName");
> if1, myPortClass);
> if2, myPortClass);
> return ifReal;
> name){
> return theClass;
> Port.\n");
> else{
> </packagedElement>
> called as expected.
> Björn
Re: Writing XML file from UML Model misses some data [message #1028873 is a reply to message #1028850] Thu, 28 March 2013 17:40 Go to previous messageGo to next message
Hi Kenn,
many thanks for that fast answer. I think, I understand the misconception now that led me the wrong path. I knew that Port::provided is a derived list of interfaces but since the Enterprise Architect produces nested <provided> XMI elements underneath the uml:Portelement I expected this to be nevertheless redundantly saved in XMI files. But I guess it is the EA here that is violating the XMI standard. Is this right?
Björn
Re: Writing XML file from UML Model misses some data [message #1029260 is a reply to message #1028873] Fri, 29 March 2013 07:47 Go to previous message
You might want to study the very detailed
http://wiki.eclipse.org/MDT/UML2/UML2_4.0_Migration_Guide that outlines
the MDT/UML2 changes to support UML 2.4.1 before deciding whether EA is
wrong or just a different interpretation of a different standard.
Further minor clarifications of ambiguous/redundant serialization are
likely in UML 2.5.
Ed Willink
On 28/03/2013 21:40, Bjoern Steinemann wrote:
> Hi Kenn,
> Björn
Previous Topic:Applying stereotypes programmatically
Next Topic:UMLModeler class and shared elements
Current Time: Tue May 28 17:35:54 EDT 2013
Powered by FUDForum. Page generated in 0.01673 seconds
