Home » Eclipse Projects » Equinox » jboss eqquinox ejb call failed
| jboss eqquinox ejb call failed [message #102279] |
Sat, 01 December 2007 17:21  |
Valer Roman Messages: 36 Registered: July 2009 |
Member |
I have deployed RAP application as a war on Jboss
I want to call EJBs through the local interface which are deployed in
an ear on JBoss.
When trying to get an instance of the EJB I have an ClassCastError
Here is the code I use :
InitialContext ctx = new InitialContext();
Object obj = ctx.lookup("TestLocal");
TestLocalHome home = (TestLocalHome) obj;
and the error :
java.lang.ClassCastException: $Proxy85 cannot be cast to
test.interfaces.TestLocalHome
in the file launch.ini of the war I have :
osgi.parentClassloader=app
osgi.contextClassLoaderParent=ccl
Could someonepoint me what is wrong with my classloaders or what the
problem is ?
Thanks for your help
Val
| Re: jboss eqquinox ejb call failed [message #102373 is a reply to message #102356] |
Mon, 03 December 2007 05:23   |
Member |
I have added my ejb interfaces in the feature.xml as an fragment plugin
At that moment I got this error when starting jboss :
12:21:49,296 INFO [TomcatDeployer] deploy, ctxPath=/wat,
warUrl=.../deploy/at.wat.war/
12:21:51,218 ERROR [STDERR] java.lang.LinkageError:
org/eclipse/osgi/framework/internal/protocol/jar/Handler
12:21:51,218 ERROR [STDERR] at java.lang.Class.forName0(Native Method)
12:21:51,218 ERROR [STDERR] at java.lang.Class.forName(Class.java:169)
org.eclipse.osgi.framework.util.SecureAction.forName(SecureA ction.java:335)
org.eclipse.osgi.framework.internal.protocol.StreamHandlerFa ctory.getBuiltIn(StreamHandlerFactory.java:70)
org.eclipse.osgi.framework.internal.protocol.StreamHandlerFa ctory.createInternalURLStreamHandler(StreamHandlerFactory.ja va:113)
org.eclipse.osgi.framework.internal.protocol.StreamHandlerFa ctory.createURLStreamHandler(StreamHandlerFactory.java:100)
java.net.URL.getURLStreamHandler(URL.java:1106)
12:21:51,218 ERROR [STDERR] at java.net.URL.<init>(URL.java:393)
sun.misc.URLClassPath$JarLoader.<init>(URLClassPath.java:553)
sun.misc.URLClassPath$3.run(URLClassPath.java:331)
java.security.AccessController.doPrivileged(Native Method)
sun.misc.URLClassPath.getLoader(URLClassPath.java:320)
sun.misc.URLClassPath.getLoader(URLClassPath.java:297)
sun.misc.URLClassPath.getResource(URLClassPath.java:167)
java.net.URLClassLoader$1.run(URLClassLoader.java:192)
java.net.URLClassLoader.findClass(URLClassLoader.java:188)
org.eclipse.equinox.servletbridge.FrameworkLauncher$ChildFir stURLClassLoader.loadClass(FrameworkLauncher.java:742)
java.lang.ClassLoader.loadClass(ClassLoader.java:251)
java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
It seems very strange :)
Val wrote:
> Hi
> I was trying to do what u explained in that previous post :)
> I ended up by making not working even what it worked :)
> Any how, I would need some help if possible on the following points :
> 1) How to access the BridgeServlet from my RAP application.
> BridgetServlet class in in the servletbridge.jar in META-INF/lib
> folder's war. The problem is when exporting my plugin not at runtime
> cause it does not see this class. I guess I should export servletbridge
> as an plugin (or framgment plugin) but I do not know exactly how should
> I do it
> 2) how to I create that fragment plugin which contains my ejb interfaces
> The idea is that maybe I need some guiding steps :) to put in practice
> all this.
> I did mention that my EJB's are in an different ear that has nothing
> to do with osgi, is just a usual enterprise application exposing some
> ejb's which I can not change
> All I want is to access those EJB's from my RAP application.
> Cheers,
> Val
> Simon Kaegi wrote:
>> Hi Val,
>> My guess is that you have the wrong context class loader set when you're
>> creating the InitialContext and that you're not exposing (and importing)
>> your EJB's interfaces. I answered a similar question in the "Equinox for an
>> enterprise environment" from Nov. 29. If you need some help here please ask
>> away as it can be a bit tricky to setup correctly.
>> -Simon
>> "Val" <valer.roman@softgress.com> wrote in message
>> news:fismp3$6pp$1@build.eclipse.org...
>>> Hi
>>> an ear on JBoss.
>>> and the error :
>>> problem is ?
>>> Val
| Re: jboss eqquinox ejb call failed [message #102402 is a reply to message #102373] |
Mon, 03 December 2007 09:12   |
Member |
Now I'm tryong to call remote the ejb to avoid all that class loading thing
Hashtable props = new Hashtable();
props.put(Context.INITIAL_CONTEXT_FACTORY,
"org.jnp.interfaces.NamingContextFactory");
props.put(Context.URL_PKG_PREFIXES,
"org.jboss.naming:org.jnp.interfaces");
props.put(Context.PROVIDER_URL, "jnp://localhost:1099");
Context ctx = null;
try {
ctx = new InitialContext(props);
} catch (NamingException e1) {
// TODO Auto-generated catch block
e1.printStackTrace();
Object obj = null;
try {
obj = ctx.lookup("Affiliate");
} catch (NamingException e) {
e.printStackTrace();
TestHome home = (TestHome) PortableRemoteObject.narrow(obj,
TestHome.class);
but still I have this error when narrowing the object to Test
16:03:31,781 ERROR [[equinoxbridgeservlet]] Servlet.service() for
servlet equinoxbridgeservlet threw exception
com.sun.corba.se.impl.javax.rmi.PortableRemoteObject.narrow( PortableRemoteObject.java:229)
at javax.rmi.PortableRemoteObject.narrow(PortableRemoteObject.j ava:137)
I think it should not matter from where is called the ejb interface if
it's remote. My ejb interfaces are shipped together with the plugin as
an usual jar
Val
> Val wrote:
>> Hi
>> I do it
>> all this.
>> Cheers,
>> Val
>> Simon Kaegi wrote:
>>> Hi Val,
>>> -Simon
>>>> Hi
>>>> an ear on JBoss.
>>>> and the error :
>>>> problem is ?
>>>> Val
| Re: jboss eqquinox ejb call failed [message #102441 is a reply to message #102402] |
Mon, 03 December 2007 14:52   |
Simon Kaegi Messages: 381 Registered: July 2009 |
Even though you're using a remote interface you still need to narrow to an
interface that your EJB infrastructure knows about.
Try adding the packages for your EJB intrefaces to extendedFrameworkExports
in web.xml.
In your bundle that's going to use these EJBs import this package as well as
Then I'd try something like the following: (note: purely illustrative as I'm
writing this without an ide)
ClassLoader webappClassLoader = BridgeServlet.class.getClassLoader();
ClassLoader currentCCL = Thread.currentThread().getContextClassLoader();
Thread.currentThread().setContextClassLoader(webappClassLoad er);
try {
} finally {
Thread.currentThread().setContextClassLoader(currentCCL );
I would leave both osgi.parentClassloader and osgi.contextClassLoaderParent
to their default value. "app" seems to be the best choice.
-Simon
news:fj12sa$39c$1@build.eclipse.org...
> thing
> Context ctx = null;
> try {
> Object obj = null;
> try {
> TestHome.class);
> at
> an usual jar
> Val
>> Val wrote:
>>> Hi
>>> I do it
>>> interfaces
>>> all this.
>>> Cheers,
>>> Val
>>> Simon Kaegi wrote:
>>>> Hi Val,
>>>> you're
>>>> importing)
>>>> for an
>>>> ask
>>>> -Simon
>>>>> Hi
>>>>> an ear on JBoss.
>>>>> and the error :
>>>>> problem is ?
>>>>> Val
| Re: jboss eqquinox ejb call failed [message #102454 is a reply to message #102441] |
Mon, 03 December 2007 15:42   |
Member |
The one point I do not get now is where to use that
extendedFrameworkExports cause my EJBs are in an ear which is not
running as an osgi application, and I see no reason to set it on the
bundle which only uses the EJB's
> in web.xml.
> try {
> } finally {
> -Simon
>> thing
>> Context ctx = null;
>> try {
>> Object obj = null;
>> try {
>> TestHome.class);
>> at
>> an usual jar
>> Thanks,
>> Val
>>> Val wrote:
>>>> Hi
>>>> I do it
>>>> interfaces
>>>> all this.
>>>> Cheers,
>>>> Val
>>>> Simon Kaegi wrote:
>>>>> Hi Val,
>>>>> you're
>>>>> importing)
>>>>> for an
>>>>> ask
>>>>> -Simon
>>>>>> Hi
>>>>>> an ear on JBoss.
>>>>>> and the error :
>>>>>> problem is ?
>>>>>> Val
| Re: jboss eqquinox ejb call failed [message #102468 is a reply to message #102454] |
Mon, 03 December 2007 16:16   |
The OSGi environment is normally isolated from the EAR/WAR class loaders so
without adding extendedFrameworkExports the OSGi environment has no way of
seeing your EJB classes. For the bundle that's using the EJBs it still is
required to import the EJB interfaces because that's what you need in order
to share the same class definition. In other words your bundle does not
implicitly have visibility of the EJB as you control what classes/resources
from the app server you want to make visible
-Simon
news:fj1po7$sde$1@build.eclipse.org...
>> an
>> in web.xml.
>> as
>> I'm
>> try {
>> } finally {
>> -Simon
>>> thing
>>> Context ctx = null;
>>> try {
>>> Object obj = null;
>>> try {
>>> TestHome.class);
>>> at
>>> an usual jar
>>> Thanks,
>>> Val
>>>> Val wrote:
>>>>> Hi
>>>>> servletbridge
>>>>> should
>>>>> I do it
>>>>> interfaces
>>>>> practice
>>>>> all this.
>>>>> Cheers,
>>>>> Val
>>>>> Simon Kaegi wrote:
>>>>>> Hi Val,
>>>>>> you're
>>>>>> importing)
>>>>>> for an
>>>>>> please
>>>>>> ask
>>>>>> -Simon
>>>>>>> Hi
>>>>>>> in
>>>>>>> an ear on JBoss.
>>>>>>> and the error :
>>>>>>> problem is ?
>>>>>>> Val
| Re: jboss eqquinox ejb call failed [message #102481 is a reply to message #102468] |
Mon, 03 December 2007 18:05   |
Member |
ok i see what extendedFrameworkExports does it exports my ejb interface
classes from the jboss calssloaders to the osgi.
unfortunately I still can not make my thing work I have the same error
as at beginning : $Proxy85 cannot be cast to ...TestHome
Maybe is just my mistake here that I can not get it work, but still if u
thing u need some information from me that could make me advance please
ask me
Val
> -Simon
>>> an
>>> in web.xml.
>>> as
>>> I'm
>>> try {
>>> } finally {
>>> -Simon
>>>> thing
>>>> Context ctx = null;
>>>> try {
>>>> Object obj = null;
>>>> try {
>>>> TestHome.class);
>>>> at
>>>> an usual jar
>>>> Thanks,
>>>> Val
>>>>> Val wrote:
>>>>>> Hi
>>>>>> servletbridge
>>>>>> should
>>>>>> I do it
>>>>>> interfaces
>>>>>> practice
>>>>>> all this.
>>>>>> Cheers,
>>>>>> Val
>>>>>> Simon Kaegi wrote:
>>>>>>> Hi Val,
>>>>>>> you're
>>>>>>> importing)
>>>>>>> for an
>>>>>>> please
>>>>>>> ask
>>>>>>> -Simon
>>>>>>>> Hi
>>>>>>>> in
>>>>>>>> an ear on JBoss.
>>>>>>>> and the error :
>>>>>>>> problem is ?
>>>>>>>> Val
| Re: jboss eqquinox ejb call failed [message #102494 is a reply to message #102481] |
Tue, 04 December 2007 11:25  |
Member |
I have managed to get it work somehow without using the
extendedFrameworkExports parameter.
I have added some jboss libraries to support EJB remote interface
calling on the client-side (RAP application)
Actually I was rather lucky to find it, I was testing that the call to
ejb on another j2ee server is working and that forced me to add some
missing libraries for the remote calling. When switching back to
localhost I saw that is working also. So this is how I had luck fixing it
Thanks for everything
> ask me
> Val
>> -Simon
>>>> an
>>>> in web.xml.
>>>> as
>>>> I'm
>>>> try {
>>>> } finally {
>>>> -Simon
>>>>> thing
>>>>> Context ctx = null;
>>>>> try {
>>>>> Object obj = null;
>>>>> try {
>>>>> TestHome.class);
>>>>> at
>>>>> an usual jar
>>>>> Thanks,
>>>>> Val
>>>>>> Val wrote:
>>>>>>> Hi
>>>>>>> servletbridge
>>>>>>> should
>>>>>>> I do it
>>>>>>> interfaces
>>>>>>> practice
>>>>>>> all this.
>>>>>>> Cheers,
>>>>>>> Val
>>>>>>> Simon Kaegi wrote:
>>>>>>>> Hi Val,
>>>>>>>> you're
>>>>>>>> importing)
>>>>>>>> for an
>>>>>>>> please
>>>>>>>> ask
>>>>>>>> -Simon
>>>>>>>>> Hi
>>>>>>>>> in
>>>>>>>>> an ear on JBoss.
>>>>>>>>> and the error :
>>>>>>>>> problem is ?
>>>>>>>>> Val
Current Time: Sat May 25 23:37:23 EDT 2013
Powered by FUDForum. Page generated in 0.02041 seconds
