Home » Modeling » UML2 » Referencing UML profiles and schemaLocation
Referencing UML profiles and schemaLocation [message #1023919] Mon, 25 March 2013 09:10 Go to next message
Filip Krikava is currently offline Filip Krikava
Member
I used the UML2 4.0.2 to create an UML profile and a UML package to which I apply the profile.
I have following layout:
myplugin/model/Test.profile.uml - the profile
myplugin/model/Test.uml - the package
In the editor all works file. Now, when I try to load it in a standlone mode I get an unresolved proxy for the UML profile.
(I do all the registration as suggested in http://www.eclipse.org/forums/index.php/mv/msg/151754/)
ERROR The feature 'relatedElement' of 'org.eclipse.uml2.uml.internal.impl.ProfileApplicationImpl@3804dd1b{model/Test.uml#_OiWn8JVDEeK01KKsnbwhjg}' contains an unresolved proxy 'org.eclipse.uml2.uml.internal.impl.ProfileImpl@268c858a{Test.profile.uml#_Xt3skJLjEeKmZcJrtpLdOQ}' (org.eclipse.uml2.uml.internal.impl.ProfileApplicationImpl@3804dd1b (isStrict: false))
ERROR The feature 'target' of 'org.eclipse.uml2.uml.internal.impl.ProfileApplicationImpl@3804dd1b{model/Test.uml#_OiWn8JVDEeK01KKsnbwhjg}' contains an unresolved proxy 'org.eclipse.uml2.uml.internal.impl.ProfileImpl@268c858a{Test.profile.uml#_Xt3skJLjEeKmZcJrtpLdOQ}' (org.eclipse.uml2.uml.internal.impl.ProfileApplicationImpl@3804dd1b (isStrict: false))
ERROR The feature 'appliedProfile' of 'org.eclipse.uml2.uml.internal.impl.ProfileApplicationImpl@3804dd1b{model/Test.uml#_OiWn8JVDEeK01KKsnbwhjg}' contains an unresolved proxy 'org.eclipse.uml2.uml.internal.impl.ProfileImpl@268c858a{Test.profile.uml#_Xt3skJLjEeKmZcJrtpLdOQ}' (org.eclipse.uml2.uml.internal.impl.ProfileApplicationImpl@3804dd1b (isStrict: false))
ERROR The feature 'references' of 'org.eclipse.emf.ecore.impl.EAnnotationImpl@47503458{model/Test.uml#_OiWn8ZVDEeK01KKsnbwhjg}' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EPackageImpl@889ec59{Test.profile.uml#_4KtQgJVCEeK01KKsnbwhjg}' (org.eclipse.emf.ecore.impl.EAnnotationImpl@47503458 (source: http://www.eclipse.org/uml2/2.0.0/UML))
The Test.uml contains following schemaLocation:
xsi:schemaLocation="http://i3s.unice.fr/Sigma/examples/uml/TestProfile Test.profile.uml#_4KtQgJVCEeK01KKsnbwhjg"
When I change it to:
xsi:schemaLocation="http://i3s.unice.fr/Sigma/examples/uml/TestProfile model/Test.profile.uml#_4KtQgJVCEeK01KKsnbwhjg"
it works and I can load it programmatically, but not in the editor. I guess I'm missing something elementary, but I can't find it.
Filip
Re: Referencing UML profiles and schemaLocation [message #1023925 is a reply to message #1023919] Mon, 25 March 2013 09:24 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. Damus
Hi, Filip,
What URI are you using to load the Test.uml model? The HREFs in this
resource look correct, because the relative path to the profile from a
"Test.uml" resource in the same "model/" folder should just be
"Test.profile.uml".
It looks odd that the URI reported for the ProfileApplication element
is "model/Test.uml". The "model/" prefix shouldn't be there. I
suspect the URI that you specified when loading the Test.uml resource.
HTH,
Christian
On 2013-03-25 13:10:07 +0000, Filip Krikava said:
> (isStrict: false))
> (isStrict: false))
> (isStrict: false))
> Thanks
> Filip
Re: Referencing UML profiles and schemaLocation [message #1024002 is a reply to message #1023925] Mon, 25 March 2013 12:10 Go to previous messageGo to next message
Member
Thanks a lot for fast response. I knew I was missing something obvious. I used URI.createFileURI("model/Test.uml") instead of just createPlatformResourceURI.
/cheers
Filip
Re: Referencing UML profiles and schemaLocation [message #1024007 is a reply to message #1024002] Mon, 25 March 2013 12:18 Go to previous message
Hi, Filip,
Indeed, using relative URIs to load models will always cause trouble.
Best to use an absolute URI of some kind.
cW
On 2013-03-25 16:10:07 +0000, Filip Krikava said:
> /cheers
> Filip
Previous Topic:digram class problem
Next Topic:Applying stereotypes programmatically
Current Time: Tue May 28 17:37:12 EDT 2013
Powered by FUDForum. Page generated in 0.01785 seconds
