Home » Modeling » MoDisco » EMF from java? (reverse engineer)
EMF from java? (reverse engineer) [message #1022856] Fri, 22 March 2013 12:49 Go to next message
Anton Hughes is currently offline Anton Hughes
Apologizes if this is a stupid question, but is it possible to reverse engineer java to EMF?
Re: EMF from java? (reverse engineer) [message #1023538 is a reply to message #1022856] Sun, 24 March 2013 09:53 Go to previous message
Hugo Bruneliere is currently offline Hugo Bruneliere
Don't worry, there are no stupid questions Smile
Actually, the support currently provided by MoDisco allows you to automatically obtain EMF models out of you Java code.
These models reflect/represent exactly the content of your Java code, and they conform to a metamodel (defined in EMF Ecore) of the Java language.
I encourage you to take a look to this Java model discovery support via the MoDisco reference documentation (cf. more particularly the parts describing the Java metamodel and corresponding model discoverer).
I hope this helps.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Previous Topic:Small API break to be compatible with Helios
Next Topic:how to transform .uml to .xmi in modisco
Current Time: Tue May 28 18:49:09 EDT 2013
Powered by FUDForum. Page generated in 0.01849 seconds
