Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] Generator java version issue
[Texo] Generator java version issue [message #1022622] Fri, 22 March 2013 04:52 Go to next message
techteam is currently offline techteam
Member
this week I switch from my Eclipse Juno JEE SR1 to SR2
Yesterday, after some changes inside the model and xpand files I try to
generate my model again, and I've got an error about a java version issue.
After an update to the new Texo version it works.
Today, it fail's again and I have no idea why.
This is the complete error:
eclipse.buildId=M20130204-1200
java.version=1.6.0_23
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product
Error
Fri Mar 22 09:35:17 CET 2013
Unhandled event loop exception
java.lang.IllegalStateException: java.lang.reflect.InvocationTargetException
org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:87)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
org.eclipse.ui.internal.progress.ProgressManager$3.run(ProgressManager.java:960)
org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:995)
org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:970)
org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1166)
org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:80)
... 29 more
Caused by: java.lang.IllegalStateException:
java.lang.IllegalStateException: package bar.foo;
* A representation of the model object '<em><b>Product</b></em>'.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public class Product
extends bar.foo.AbstractPojo
* A toString method which prints the values of all EAttributes of
this instance.
* @generated
public String toString() {
return "Product "
22: Syntax error, annotations are only available if source level is 1.5
or greater
org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUri(GenerateCode.java:99)
org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUris(GenerateCode.java:59)
org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:128)
org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:108)
org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction$1.execute(BaseGenerateAction.java:76)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: java.lang.IllegalStateException: package bar.foo;
* @generated
this instance.
* @generated
return "Product "
or greater
org.eclipse.emf.texo.generator.ArtifactGenerator.run(ArtifactGenerator.java:145)
org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUri(GenerateCode.java:96)
... 8 more
* @generated
this instance.
* @generated
return "Product "
or greater
org.eclipse.emf.texo.generator.ImportResolver.setSource(ImportResolver.java:494)
org.eclipse.emf.texo.generator.SourceMerger.organizeImports(SourceMerger.java:147)
org.eclipse.emf.texo.generator.SourceMerger.mergeImportAndFormat(SourceMerger.java:98)
at org.eclipse.emf.texo.generator.SourceMerger.merge(SourceMerger.java:70)
org.eclipse.emf.texo.generator.MergingOutputHandler.beforeWriteAndClose(MergingOutputHandler.java:63)
at org.eclipse.xpand2.output.Outlet.beforeWriteAndClose(Outlet.java:98)
org.eclipse.xpand2.output.FileHandleImpl.writeAndClose(FileHandleImpl.java:137)
at org.eclipse.xpand2.output.OutputImpl.closeFile(OutputImpl.java:172)
org.eclipse.emf.texo.generator.ArtifactGenerator.run(ArtifactGenerator.java:98)
... 9 more
Re: [Texo] Generator java version issue [message #1022639 is a reply to message #1022622] Fri, 22 March 2013 05:20 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Heiko,
Hmm can you check the project properties > Java Compiler there is a jdk compliance option with a setting for source
compatibility.
Let me know what it says (I hope something < 1.5, then it is easy to solve :-).
gr. Martin
On 03/22/2013 09:52 AM, Heiko wrote:
> Yesterday, after some changes inside the model and xpand files I try to generate my model again, and I've got an error
> Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
> Error
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:87)
> at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
> at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
> at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
> at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
> at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
> at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
> at org.eclipse.ui.internal.progress.ProgressManager$3.run(ProgressManager.java:960)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:995)
> at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:970)
> at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1166)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:80)
> ... 29 more
> Caused by: java.lang.IllegalStateException: java.lang.IllegalStateException: package bar.foo;
> * @generated
> * A toString method which prints the values of all EAttributes of this instance.
> * @generated
> @Override
> return "Product "
> 22: Syntax error, annotations are only available if source level is 1.5 or greater
> at org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUri(GenerateCode.java:99)
> at org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUris(GenerateCode.java:59)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:128)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:108)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction$1.execute(BaseGenerateAction.java:76)
> at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
> at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
> at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
> * @generated
> * @generated
> @Override
> return "Product "
> at org.eclipse.emf.texo.generator.ArtifactGenerator.run(ArtifactGenerator.java:145)
> at org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUri(GenerateCode.java:96)
> ... 8 more
> * @generated
> * @generated
> @Override
> return "Product "
> at org.eclipse.emf.texo.generator.ImportResolver.setSource(ImportResolver.java:494)
> at org.eclipse.emf.texo.generator.SourceMerger.organizeImports(SourceMerger.java:147)
> at org.eclipse.emf.texo.generator.SourceMerger.mergeImportAndFormat(SourceMerger.java:98)
> at org.eclipse.emf.texo.generator.MergingOutputHandler.beforeWriteAndClose(MergingOutputHandler.java:63)
> at org.eclipse.xpand2.output.FileHandleImpl.writeAndClose(FileHandleImpl.java:137)
> at org.eclipse.emf.texo.generator.ArtifactGenerator.run(ArtifactGenerator.java:98)
> ... 9 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Generator java version issue [message #1022648 is a reply to message #1022639] Fri, 22 March 2013 05:34 Go to previous messageGo to next message
Member
Hi Martin,
thank for your quick answer.
No it's JDK Compliance level 1.6.
These point I also checked yesterday as first option.
Do some more tests:
old Juno SR1 with the old texo version -> works
old Juno SR1 with current texo version -> works
do this also with a very very simple model.
I seems, that the are a problem with the jdt compilation unit
Greetings
Heiko
Am 22.03.2013 10:20, schrieb Martin Taal:
> Hi Heiko,
> compliance option with a setting for source compatibility.
> solve :-).
> gr. Martin
>> Error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 29 more
>> * @generated
>> of this instance.
>> * @generated
>> @Override
>> return "Product "
>> 1.5 or greater
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> * @generated
>> of this instance.
>> * @generated
>> @Override
>> return "Product "
>> 1.5 or greater
>> at
>> at
>> ... 8 more
>> * @generated
>> of this instance.
>> * @generated
>> @Override
>> return "Product "
>> 1.5 or greater
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 9 more
Re: [Texo] Generator java version issue [message #1022653 is a reply to message #1022648] Fri, 22 March 2013 05:41 Go to previous messageGo to next message
Hi Heiko,
I am on sr1 still I see now. The texo build is done against the latest juno. But still let me download sr2 and try it
also. If you have not heard back from on this thread in a few days then feel free to ping me!
gr. Martin
On 03/22/2013 10:34 AM, Heiko wrote:
> Hi Martin,
> Do some more tests:
> Greetings
> Heiko
>> Hi Heiko,
>> solve :-).
>> gr. Martin
>>> Hi,
>>> Error
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 29 more
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> ... 8 more
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 9 more
The Netherlands
Re: [Texo] Generator java version issue [message #1022669 is a reply to message #1022653] Fri, 22 March 2013 06:19 Go to previous message
Member
Hi Martin,
I've found a solution:
After switch the jdk complicance to 1.5 rebuild workspace and than back
again to 1.6, it works fine.
But why I've got the error - I don't know. :/
Greetings
Heiko
Am 22.03.2013 10:41, schrieb Martin Taal:
> Hi Heiko,
> juno. But still let me download sr2 and try it also. If you have not
> gr. Martin
>> Hi Martin,
>> Do some more tests:
>> Greetings
>> Heiko
>>> Hi Heiko,
>>> solve :-).
>>> gr. Martin
>>>> Hi,
>>>> Error
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 29 more
>>>> * @generated
>>>> of this instance.
>>>> * @generated
>>>> @Override
>>>> return "Product "
>>>> 1.5 or greater
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> * @generated
>>>> of this instance.
>>>> * @generated
>>>> @Override
>>>> return "Product "
>>>> 1.5 or greater
>>>> at
>>>> at
>>>> ... 8 more
>>>> * @generated
>>>> of this instance.
>>>> * @generated
>>>> @Override
>>>> return "Product "
>>>> 1.5 or greater
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 9 more
Re: [Texo] Generator java version issue [message #1022670 is a reply to message #1022648] Fri, 22 March 2013 06:19 Go to previous message
Make sure you do a clean all and a full rebuild.
Make sure you haven't got a 1.5 JRE in use for some projects and a
1.6/1.7 for others,. When you have problems disable all but one recent
JRE and clean and rebuild and clean again.
Ed Willink
On 22/03/2013 09:34, Heiko wrote:
> Hi Martin,
> Do some more tests:
> Greetings
> Heiko
>> Hi Heiko,
>> solve :-).
>> gr. Martin
>>> Hi,
>>> Error
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 29 more
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> ... 8 more
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 9 more
Previous Topic:[teneo] How to specify formula with oracle || concat
Next Topic:EMFStore Hello World example
Current Time: Sat May 25 19:20:17 EDT 2013
Powered by FUDForum. Page generated in 0.04446 seconds
