| Using Lemo Eclipse [message #469420] |
Wed, 24 January 2007 15:24  |
Originally posted by: jcastro.gesfor.cl
I instaled the lemo IDE cobdt-prof-rm-1.3.4-win32, and update from
update.lemosoft.com.
com.lemosoft.cobdt.feature.prof.mf_1.3.1 feature-install success
com.lemosoft.cobdt.feature.base_1.3.1 feature-enable success
com.lemosoft.cobdt.feature.compiler_1.3.1 feature-enable success
com.lemosoft.cobdt.feature.mf_1.3.1 feature-enable success
com.lemosoft.cobdt.feature.prof.mf_1.3.1 feature-enable success
com.lemosoft.cobdt.feature.prof.fujitsu_1.3.1 feature-install success
com.lemosoft.cobdt.feature.fujitsu_1.3.1 feature-enable success
com.lemosoft.cobdt.feature.prof.fujitsu_1.3.1 feature-enable success
com.lemosoft.cobdt.feature.prof.ibm_1.3.1 feature-install success
com.lemosoft.cobdt.feature.ibm_1.3.1 feature-enable success
com.lemosoft.cobdt.feature.prof.ibm_1.3.1 feature-enable success
I don't have cobol compilers in my pc.
I created one rm-cobol project, so I trie build assembly for my .cas file,
and ERROR "EXCEPTION OCURRED TO COMMAND LINE. PLEASE CORRECT YOUR
LAUNCHING CONFIGURATIION. PATH TO YOU COMPILER HAS TO BE INCULDED INTO
PATH ENVIROMENT VARIABLE".
in the log:
java.io.IOException: CreateProcess: rmcobolc
"C:\cobol\cobdt\workspace\prueba3\bg3cade2.cbl"
O="C:\cobol\cobdt\workspace\prueba3\bin\prueba3.cas\" R
l="C:\cobol\cobdt\workspace\prueba3\bin\prueba3.cas\" D Y=3 W=2048 error=2
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(Unknown Source)
at java.lang.ProcessImpl.start(Unknown Source)
at java.lang.ProcessBuilder.start(Unknown Source)
at java.lang.Runtime.exec(Unknown Source)
Whats happend?
FUDForum. Page generated in 0.01806 seconds
